[QGIS Commit] r9127 - in trunk/qgis/src: app app/composer core/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 23 06:57:38 EDT 2008
Author: jef
Date: 2008-08-23 06:57:38 -0400 (Sat, 23 Aug 2008)
New Revision: 9127
   trunk/qgis/src/app/composer/qgscomposeritemwidget.cpp
   trunk/qgis/src/app/qgsmaptooladdfeature.cpp
   trunk/qgis/src/core/composer/qgscomposeritem.h
   trunk/qgis/src/core/composer/qgscomposeritemgroup.h
   trunk/qgis/src/core/composer/qgscomposerlabel.h
   trunk/qgis/src/core/composer/qgscomposerlegend.h
   trunk/qgis/src/core/composer/qgscomposermap.h
   trunk/qgis/src/core/composer/qgscomposerpicture.h
   trunk/qgis/src/core/composer/qgscomposerscalebar.h
   trunk/qgis/src/core/composer/qgscomposition.h
   trunk/qgis/src/core/composer/qgsdoubleboxscalebarstyle.h
   trunk/qgis/src/core/composer/qgslegendmodel.h
   trunk/qgis/src/core/composer/qgsnumericscalebarstyle.h
   trunk/qgis/src/core/composer/qgsscalebarstyle.h
   trunk/qgis/src/core/composer/qgssingleboxscalebarstyle.h
   trunk/qgis/src/core/composer/qgsticksscalebarstyle.h
add CORE_EXPORT to composer
Modified: trunk/qgis/src/app/composer/qgscomposeritemwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposeritemwidget.cpp	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/app/composer/qgscomposeritemwidget.cpp	2008-08-23 10:57:38 UTC (rev 9127)
@@ -30,7 +30,7 @@
-QgsComposerItemWidget::QgsComposerItemWidget::~QgsComposerItemWidget()
+QgsComposerItemWidget::~QgsComposerItemWidget()
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.cpp
--- trunk/qgis/src/app/qgsmaptooladdfeature.cpp	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.cpp	2008-08-23 10:57:38 UTC (rev 9127)
@@ -104,7 +104,7 @@
       try
         savePoint = toLayerCoords(vlayer, idPoint);
-        QgsDebugMsg("savePoint = " + savePoint.stringRep());
+        QgsDebugMsg("savePoint = " + savePoint.toString());
       catch(QgsCsException &cse)
Modified: trunk/qgis/src/core/composer/qgscomposeritem.h
--- trunk/qgis/src/core/composer/qgscomposeritem.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposeritem.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -29,7 +29,7 @@
 /** \ingroup MapComposer
  * A item that forms part of a map composition.
-class QgsComposerItem: public QGraphicsRectItem
+class CORE_EXPORT QgsComposerItem: public QGraphicsRectItem
 public:
Modified: trunk/qgis/src/core/composer/qgscomposeritemgroup.h
--- trunk/qgis/src/core/composer/qgscomposeritemgroup.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposeritemgroup.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -22,7 +22,7 @@
  * A container for grouping several QgsComposerItems
-class QgsComposerItemGroup: public QObject, public QgsComposerItem
+class CORE_EXPORT QgsComposerItemGroup: public QObject, public QgsComposerItem
   Q_OBJECT
  public:
Modified: trunk/qgis/src/core/composer/qgscomposerlabel.h
--- trunk/qgis/src/core/composer/qgscomposerlabel.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposerlabel.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -22,7 +22,7 @@
  * A label that can be placed onto a map composition.
-class QgsComposerLabel: public QgsComposerItem
+class CORE_EXPORT QgsComposerLabel: public QgsComposerItem
  public:
   QgsComposerLabel( QgsComposition *composition);
Modified: trunk/qgis/src/core/composer/qgscomposerlegend.h
--- trunk/qgis/src/core/composer/qgscomposerlegend.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposerlegend.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -23,10 +23,11 @@
 #include <QObject>
 class QgsSymbol;
  * A legend that can be placed onto a map composition
-class QgsComposerLegend: public QObject, public QgsComposerItem
+class CORE_EXPORT QgsComposerLegend: public QObject, public QgsComposerItem
   Q_OBJECT
Modified: trunk/qgis/src/core/composer/qgscomposermap.h
--- trunk/qgis/src/core/composer/qgscomposermap.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposermap.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -36,7 +36,7 @@
  *  \brief Object representing map window.
 // NOTE: QgsComposerMapBase must be first, otherwise does not compile
-class QgsComposerMap : /*public QWidget , private Ui::QgsComposerMapBase,*/ public QObject, public QgsComposerItem
+class CORE_EXPORT QgsComposerMap : /*public QWidget , private Ui::QgsComposerMapBase,*/ public QObject, public QgsComposerItem
   Q_OBJECT
Modified: trunk/qgis/src/core/composer/qgscomposerpicture.h
--- trunk/qgis/src/core/composer/qgscomposerpicture.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposerpicture.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -25,7 +25,7 @@
  * A composer class that displays svg files or raster format (jpg, png, ...)
-class QgsComposerPicture: public QObject, public QgsComposerItem
+class CORE_EXPORT QgsComposerPicture: public QObject, public QgsComposerItem
   Q_OBJECT
  public:
Modified: trunk/qgis/src/core/composer/qgscomposerscalebar.h
--- trunk/qgis/src/core/composer/qgscomposerscalebar.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposerscalebar.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -26,7 +26,7 @@
  * A scale bar item that can be added to a map composition.
-class QgsComposerScaleBar: public QObject, public QgsComposerItem
+class CORE_EXPORT QgsComposerScaleBar: public QObject, public QgsComposerItem
  Q_OBJECT
Modified: trunk/qgis/src/core/composer/qgscomposition.h
--- trunk/qgis/src/core/composer/qgscomposition.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgscomposition.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -30,7 +30,7 @@
  * Graphics scene for map printing. It manages the paper item which always
  * is the item in the back (z-value 0).
-class QgsComposition: public QGraphicsScene
+class CORE_EXPORT QgsComposition: public QGraphicsScene
  public:
Modified: trunk/qgis/src/core/composer/qgsdoubleboxscalebarstyle.h
--- trunk/qgis/src/core/composer/qgsdoubleboxscalebarstyle.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgsdoubleboxscalebarstyle.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -22,7 +22,7 @@
   * Double box with alternating colors
-class QgsDoubleBoxScaleBarStyle: public QgsScaleBarStyle
+class CORE_EXPORT QgsDoubleBoxScaleBarStyle: public QgsScaleBarStyle
  public:
   QgsDoubleBoxScaleBarStyle(const QgsComposerScaleBar* bar);
Modified: trunk/qgis/src/core/composer/qgslegendmodel.h
--- trunk/qgis/src/core/composer/qgslegendmodel.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgslegendmodel.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -31,7 +31,7 @@
  * A model that provides layers as root items. The classification items are
  * children of the layer items.
-class QgsLegendModel: public QStandardItemModel
+class CORE_EXPORT QgsLegendModel: public QStandardItemModel
   Q_OBJECT
Modified: trunk/qgis/src/core/composer/qgsnumericscalebarstyle.h
--- trunk/qgis/src/core/composer/qgsnumericscalebarstyle.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgsnumericscalebarstyle.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -22,7 +22,7 @@
  * A scale bar style that draws text in the form of '1:XXXXX'
-class QgsNumericScaleBarStyle: public QgsScaleBarStyle
+class CORE_EXPORT QgsNumericScaleBarStyle: public QgsScaleBarStyle
  public:
   QgsNumericScaleBarStyle(QgsComposerScaleBar* bar);
Modified: trunk/qgis/src/core/composer/qgsscalebarstyle.h
--- trunk/qgis/src/core/composer/qgsscalebarstyle.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgsscalebarstyle.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -27,7 +27,7 @@
  * Abstraction of composer scale bar style. Subclasses draw themselves, have the
 possibility to implement custom labeling and calculate corresponding box size.
-class QgsScaleBarStyle
+class CORE_EXPORT QgsScaleBarStyle
  public:
   QgsScaleBarStyle(const QgsComposerScaleBar* bar);
Modified: trunk/qgis/src/core/composer/qgssingleboxscalebarstyle.h
--- trunk/qgis/src/core/composer/qgssingleboxscalebarstyle.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgssingleboxscalebarstyle.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -23,7 +23,7 @@
  * Scalebar style that draws a single box with alternating
  * color for the segments.
-class QgsSingleBoxScaleBarStyle: public QgsScaleBarStyle
+class CORE_EXPORT QgsSingleBoxScaleBarStyle: public QgsScaleBarStyle
  public:
   QgsSingleBoxScaleBarStyle(const QgsComposerScaleBar* bar);
Modified: trunk/qgis/src/core/composer/qgsticksscalebarstyle.h
--- trunk/qgis/src/core/composer/qgsticksscalebarstyle.h	2008-08-23 10:22:31 UTC (rev 9126)
+++ trunk/qgis/src/core/composer/qgsticksscalebarstyle.h	2008-08-23 10:57:38 UTC (rev 9127)
@@ -22,7 +22,7 @@
  * A scale bar that draws segments using short ticks.
-class QgsTicksScaleBarStyle: public QgsScaleBarStyle
+class CORE_EXPORT QgsTicksScaleBarStyle: public QgsScaleBarStyle
   public:
   enum TickPosition
More information about the QGIS-commit mailing list
