[QGIS Commit] r9135 - in trunk/qgis: python/core src/app src/core tests/algorithms/qgsproject
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 23 15:38:17 EDT 2008
Author: timlinux
Date: 2008-08-23 15:38:17 -0400 (Sat, 23 Aug 2008)
New Revision: 9135
   trunk/qgis/python/core/qgsproject.sip
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/core/qgsproject.cpp
   trunk/qgis/src/core/qgsproject.h
   trunk/qgis/tests/algorithms/qgsproject/projecttest.h
Use fileName() instead of setFilename() for filename accessor
Modified: trunk/qgis/python/core/qgsproject.sip
--- trunk/qgis/python/core/qgsproject.sip	2008-08-23 19:15:03 UTC (rev 9134)
+++ trunk/qgis/python/core/qgsproject.sip	2008-08-23 19:38:17 UTC (rev 9135)
@@ -62,7 +62,7 @@
     void setFilename( const QString & name );
     /** returns file name */
-    QString setFilename() const;
+    QString fileName() const;
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-08-23 19:15:03 UTC (rev 9134)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-08-23 19:38:17 UTC (rev 9135)
@@ -224,14 +224,14 @@
   if ( QgsProject::instance()->title().isEmpty() )
-    if ( QgsProject::instance()->setFilename().isEmpty() )
+    if ( QgsProject::instance()->fileName().isEmpty() )
       // no project title nor file name, so just leave caption with
       // application name and version
     else
-      QFileInfo projectFileInfo( QgsProject::instance()->setFilename() );
+      QFileInfo projectFileInfo( QgsProject::instance()->fileName() );
       caption += projectFileInfo.baseName();
@@ -2882,7 +2882,7 @@
   // the current project file name is empty
   bool isNewProject = false;
-  if ( QgsProject::instance()->setFilename().isNull() )
+  if ( QgsProject::instance()->fileName().isNull() )
     isNewProject = true;
@@ -2925,7 +2925,7 @@
     if ( QgsProject::instance()->write() )
       setTitleBarText_(*this); // update title bar
-      statusBar()->showMessage(tr("Saved project to:") + " " + QgsProject::instance()->setFilename() );
+      statusBar()->showMessage(tr("Saved project to:") + " " + QgsProject::instance()->fileName() );
       if (isNewProject)
@@ -2938,13 +2938,13 @@
       QMessageBox::critical(this,
           tr("Unable to save project"),
-          tr("Unable to save project to ") + QgsProject::instance()->setFilename() );
+          tr("Unable to save project to ") + QgsProject::instance()->fileName() );
   catch ( std::exception & e )
     QMessageBox::critical( this,
-        tr("Unable to save project ") + QgsProject::instance()->setFilename(),
+        tr("Unable to save project ") + QgsProject::instance()->fileName(),
         QString::fromLocal8Bit( e.what() ) );
   return true;
@@ -3008,7 +3008,7 @@
       // add this to the list of recently used project files
       saveRecentProjectPath(fullPath.filePath(), settings);
@@ -3016,13 +3016,13 @@
     QMessageBox::critical( 0x0,
         QString::fromLocal8Bit( e.what() ),
         QMessageBox::Ok,
         Qt::NoButton );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2008-08-23 19:15:03 UTC (rev 9134)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2008-08-23 19:38:17 UTC (rev 9135)
@@ -481,7 +481,7 @@
   else
-    QFileInfo project( QgsProject::instance()->setFilename() );
+    QFileInfo project( QgsProject::instance()->fileName() );
     QgsDebugMsg( QString("project filename: %1").arg( project.absoluteFilePath() ) );
     QString qml;
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp	2008-08-23 19:15:03 UTC (rev 9134)
+++ trunk/qgis/src/core/qgsproject.cpp	2008-08-23 19:38:17 UTC (rev 9135)
@@ -411,10 +411,10 @@
- QString QgsProject::setFilename() const
+ QString QgsProject::fileName() const
      return imp_->file.fileName();
- } // QString QgsProject::setFilename() const
+ } // QString QgsProject::fileName() const
Modified: trunk/qgis/src/core/qgsproject.h
--- trunk/qgis/src/core/qgsproject.h	2008-08-23 19:15:03 UTC (rev 9134)
+++ trunk/qgis/src/core/qgsproject.h	2008-08-23 19:38:17 UTC (rev 9135)
@@ -95,7 +95,7 @@
     void setFilename( QString const & name );
Modified: trunk/qgis/tests/algorithms/qgsproject/projecttest.h
--- trunk/qgis/tests/algorithms/qgsproject/projecttest.h	2008-08-23 19:15:03 UTC (rev 9134)
+++ trunk/qgis/tests/algorithms/qgsproject/projecttest.h	2008-08-23 19:38:17 UTC (rev 9135)
@@ -103,7 +103,7 @@
         QgsProject::instance()->dirty( false );
         QgsProject::instance()->setFilename( mFile );
-        CPPUNIT_ASSERT( mFile == QgsProject::instance()->setFilename() );
+        CPPUNIT_ASSERT( mFile == QgsProject::instance()->fileName() );
         CPPUNIT_ASSERT( QgsProject::instance()->isDirty() );
     } // testFileName
More information about the QGIS-commit mailing list
