[QGIS Commit] r9136 - in trunk/qgis: python/core src/app src/app/composer src/core src/core/raster src/core/sqlite3 src/core/symbology src/gui src/plugins/dxf2shp_converter src/plugins/dxf2shp_converter/shapelib-1.2.10 src/plugins/georeferencer src/plugins/gps_importer src/plugins/grid_maker src/plugins/interpolation src/plugins/quick_print src/plugins/spit src/providers/gpx src/providers/ogr tests/algorithms/qgsproject tools/mapserver_export
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 23 15:55:27 EDT 2008
Author: timlinux
Date: 2008-08-23 15:55:27 -0400 (Sat, 23 Aug 2008)
New Revision: 9136
   trunk/qgis/python/core/qgslogger.sip
   trunk/qgis/python/core/qgsmarkercatalogue.sip
   trunk/qgis/python/core/qgsproject.sip
   trunk/qgis/python/core/qgsrasterlayer.sip
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/main.cpp
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgsabout.cpp
   trunk/qgis/src/app/qgsmapserverexport.cpp
   trunk/qgis/src/app/qgsmapserverexport.h
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/app/qgsvectorlayerproperties.cpp
   trunk/qgis/src/core/qgslogger.h
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/core/qgsproject.cpp
   trunk/qgis/src/core/qgsproject.h
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.h
   trunk/qgis/src/core/sqlite3/sqlite3.h
   trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp
   trunk/qgis/src/core/symbology/qgsmarkercatalogue.h
   trunk/qgis/src/gui/qgsquickprint.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/shapelib-1.2.10/shapefil.h
   trunk/qgis/src/plugins/georeferencer/plugingui.cpp
   trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp
   trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.cpp
   trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.h
   trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp
   trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h
   trunk/qgis/src/plugins/grid_maker/plugingui.cpp
   trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.h
   trunk/qgis/src/plugins/interpolation/Triangulation.h
   trunk/qgis/src/plugins/interpolation/qgsinterpolationdialog.cpp
   trunk/qgis/src/plugins/quick_print/quickprintgui.cpp
   trunk/qgis/src/plugins/spit/qgsshapefile.cpp
   trunk/qgis/src/plugins/spit/qgsshapefile.h
   trunk/qgis/src/plugins/spit/qgsspit.cpp
   trunk/qgis/src/providers/gpx/gpsdata.cpp
   trunk/qgis/src/providers/gpx/gpsdata.h
   trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
   trunk/qgis/tests/algorithms/qgsproject/projecttest.h
   trunk/qgis/tools/mapserver_export/qgsmapserverexport.cpp
   trunk/qgis/tools/mapserver_export/qgsmapserverexport.h
Follow Qt naming style: fileName instead of filename, layerName instead of layerName
Modified: trunk/qgis/python/core/qgslogger.sip
--- trunk/qgis/python/core/qgslogger.sip	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/python/core/qgslogger.sip	2008-08-23 19:55:27 UTC (rev 9136)
@@ -3,7 +3,7 @@
 QGIS_DEBUG is an int describing what debug messages are written to the console. If the debug level of a message is <= QGIS_DEBUG, the message is written to the console. It the variable QGIS_DEBUG is not defined, it defaults to 1 for debug mode and to 0 for release mode
-QGIS_DEBUG_FILE may contain a filename. Only the messages from this file are printed (provided they have the right debuglevel). If QGIS_DEBUG_FILE is not set, messages from all files are printed
+QGIS_DEBUG_FILE may contain a fileName. Only the messages from this file are printed (provided they have the right debuglevel). If QGIS_DEBUG_FILE is not set, messages from all files are printed
 class QgsLogger
@@ -17,7 +17,7 @@
   /**Goes to qDebug.
   @param msg the message to be printed
   @param debuglevel
-  @param file filename where the message comes from
+  @param file fileName where the message comes from
   @param function function where the message comes from
   @param line place in file where the message comes from*/
   static void debug(const QString& msg, int debuglevel = 1, const char* file = NULL, const char* function = NULL, int line = -1);
Modified: trunk/qgis/python/core/qgsmarkercatalogue.sip
--- trunk/qgis/python/core/qgsmarkercatalogue.sip	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/python/core/qgsmarkercatalogue.sip	2008-08-23 19:55:27 UTC (rev 9136)
@@ -26,7 +26,7 @@
     QPicture pictureMarker (QString fullName, int size, QPen pen, QBrush brush, bool qtBug = true );
-    /** Returns a pixmap given a filename of a svg marker
+    /** Returns a pixmap given a fileName of a svg marker
      *  NOTE: this method needs to be public static for QgsMarkerDialog::visualizeMarkers */
     static void svgMarker (QPainter * thepPainter, QString name, int size );
Modified: trunk/qgis/python/core/qgsproject.sip
--- trunk/qgis/python/core/qgsproject.sip	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/python/core/qgsproject.sip	2008-08-23 19:55:27 UTC (rev 9136)
@@ -59,7 +59,7 @@
        Every project has an associated file that contains its XML
-    void setFilename( const QString & name );
+    void setFileName( const QString & name );
     /** returns file name */
     QString fileName() const;
Modified: trunk/qgis/python/core/qgsrasterlayer.sip
--- trunk/qgis/python/core/qgsrasterlayer.sip	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/python/core/qgsrasterlayer.sip	2008-08-23 19:55:27 UTC (rev 9136)
@@ -21,7 +21,7 @@
     static void buildSupportedRasterFileFilter(QString & fileFilters);
     static void registerGdalDrivers();
-    /** This helper checks to see whether the filename appears to be a valid
+    /** This helper checks to see whether the fileName appears to be a valid
        raster file name */
     static bool isValidRasterFileName(const QString & theFileNameQString);
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -781,7 +781,7 @@
   std::auto_ptr < QFileDialog > myQFileDialog(
       new QFileDialog(
         this,
-        tr("Choose a filename to save the map image as"),
+        tr("Choose a fileName to save the map image as"),
         file.path(),
         myFilters
@@ -797,7 +797,7 @@
   // set the 'Open' button to something that makes more sense
   myQFileDialog->setAcceptMode(QFileDialog::AcceptSave);
-  //prompt the user for a filename
+  //prompt the user for a fileName
   QString myOutputFileNameQString; // = myQFileDialog->getSaveFileName(); //delete this
   int result = myQFileDialog->exec();
@@ -876,7 +876,7 @@
   QString myLastUsedFile = myQSettings.value("/UI/lastSaveAsSvgFile","qgis.svg").toString();
   QFileInfo file(myLastUsedFile);
-  QFileDialog *myQFileDialog = new QFileDialog( this, tr("Choose a filename to save the map as"),
+  QFileDialog *myQFileDialog = new QFileDialog( this, tr("Choose a fileName to save the map as"),
                                                 file.path(), tr("SVG Format") + " (*.svg *SVG)" );
   myQFileDialog->selectFile( file.fileName() );
   myQFileDialog->setFileMode(QFileDialog::AnyFile);
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/main.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -84,7 +84,7 @@
       << "raster and vector data.\n"
       << "Usage: " << appName <<  " [options] [FILES]\n"
       << "  options:\n"
-      << "\t[--snapshot filename]\temit snapshot of loaded datasets to given file\n"
+      << "\t[--snapshot fileName]\temit snapshot of loaded datasets to given file\n"
       << "\t[--lang language]\tuse language for interface text\n"
       << "\t[--project projectfile]\tload the given QGIS project\n"
       << "\t[--extent xmin,ymin,xmax,ymax]\tset initial map extent\n"
@@ -584,7 +584,7 @@
-  // autoload any filenames that were passed in on the command line
+  // autoload any fileNames that were passed in on the command line
 #ifdef QGISDEBUG
   std::cout << "Number of files in myFileList: " << myFileList.count() << std::endl;
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgisapp.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -1975,7 +1975,7 @@
-  This method prompts the user for a list of vector filenames with a dialog.
+  This method prompts the user for a list of vector fileNames with a dialog.
 void QgisApp::addVectorLayer()
@@ -2074,7 +2074,7 @@
-/** This helper checks to see whether the filename appears to be a valid vector file name */
+/** This helper checks to see whether the fileName appears to be a valid vector file name */
 bool QgisApp::isValidVectorFileName(QString theFileNameQString)
   return (theFileNameQString.toLower().endsWith(".shp"));
@@ -2527,7 +2527,7 @@
   QgsProject* prj = QgsProject::instance();
   prj->title( QString::null );
-  prj->setFilename( QString::null );
+  prj->setFileName( QString::null );
   prj->clearProperties(); // why carry over properties from previous projects?
   QSettings settings;
@@ -2599,7 +2599,7 @@
   bool haveLastUsedFilter = false; // by default, there is no last
   // used filter
   QString enc;
-  QString filename;
+  QString fileName;
   QSettings settings;         // where we keep last used filter in
   // persistant state
@@ -2634,14 +2634,14 @@
     return;
-  filename = openFileDialog->selectedFiles().first();
+  fileName = openFileDialog->selectedFiles().first();
   enc = openFileDialog->encoding();
   // If the file exists, delete it otherwise we'll end up loading that
   // file, which can cause problems (e.g., if the file contains
   // linestrings, but we're wanting to create points, we'll end up
   // with a linestring file).
-  QFile::remove(filename);
+  QFile::remove(fileName);
   settings.setValue("/UI/lastVectorFileFilter", openFileDialog->selectedFilter());
@@ -2668,20 +2668,20 @@
 #if 0
       if(geometrytype == QGis::WKBPoint)
-        createEmptyDataSource(filename,fileformat, enc, QGis::WKBPoint, attributes);
+        createEmptyDataSource(fileName,fileformat, enc, QGis::WKBPoint, attributes);
       else if (geometrytype == QGis::WKBLineString)
-        createEmptyDataSource(filename,fileformat, enc, QGis::WKBLineString, attributes);
+        createEmptyDataSource(fileName,fileformat, enc, QGis::WKBLineString, attributes);
       else if(geometrytype == QGis::WKBPolygon)
-        createEmptyDataSource(filename,fileformat, enc, QGis::WKBPolygon, attributes);
+        createEmptyDataSource(fileName,fileformat, enc, QGis::WKBPolygon, attributes);
 #endif
       if(geometrytype != QGis::WKBUnknown)
-        createEmptyDataSource(filename,fileformat, enc, geometrytype, attributes);
+        createEmptyDataSource(fileName,fileformat, enc, geometrytype, attributes);
       else
@@ -2696,9 +2696,9 @@
   //then add the layer to the view
-  QStringList filenames;
-  filenames.append(filename);
-  addVectorLayers(filenames, enc);
+  QStringList fileNames;
+  fileNames.append(fileName);
+  addVectorLayers(fileNames, enc);
 void QgisApp::fileOpen()
@@ -2749,7 +2749,7 @@
     delete mComposer;
     mComposer = new QgsComposer(this);
-    QgsProject::instance()->setFilename( fullPath );
+    QgsProject::instance()->setFileName( fullPath );
     try
@@ -2873,7 +2873,7 @@
       return false;
-  // if we don't have a filename, then obviously we need to get one; note
+  // if we don't have a fileName, then obviously we need to get one; note
   // that the project file name is reset to null in fileNew()
   QFileInfo fullPath;
@@ -2917,7 +2917,7 @@
-    QgsProject::instance()->setFilename( fullPath.filePath() );
+    QgsProject::instance()->setFileName( fullPath.filePath() );
   try
@@ -2964,7 +2964,7 @@
   QString lastUsedDir = settings.value("/UI/lastProjectDir", ".").toString();
   auto_ptr<QFileDialog> saveFileDialog( new QFileDialog(this,
-      tr("Choose a filename to save the QGIS project file as"),
+      tr("Choose a fileName to save the QGIS project file as"),
       lastUsedDir, QObject::tr("QGis files (*.qgs)")) );
   saveFileDialog->setFileMode(QFileDialog::AnyFile);
@@ -2973,7 +2973,7 @@
   saveFileDialog->setConfirmOverwrite( true );
   QFileInfo fullPath;
@@ -3003,7 +3003,7 @@
   try
     if ( QgsProject::instance()->write() )
@@ -3205,7 +3205,7 @@
   //create a file dialog using the the filter list generated above
   std::auto_ptr < QFileDialog > myQFileDialog( new QFileDialog(this,
       myLastUsedDir, myFilters) );
   // allow for selection of more than one file
@@ -3222,7 +3222,7 @@
   if (myQFileDialog->exec() == QDialog::Accepted)
@@ -3233,7 +3233,7 @@
   QgsDebugMsg("Selected filter: " + myFilterString);
   QgsDebugMsg("Image type to be passed to mapcanvas: " + myFilterMap[myFilterString]);
-  // Add the file type suffix to the filename if required
+  // Add the file type suffix to the fileName if required
   if (!myOutputFileNameQString.endsWith(myFilterMap[myFilterString]))
     myOutputFileNameQString += "." + myFilterMap[myFilterString];
@@ -3259,7 +3259,7 @@
   if ( theImageFileNameQString=="")
-    //no filename chosen
+    //no fileName chosen
     return;
   else
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgisapp.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -80,14 +80,14 @@
   QgsVectorLayer* addVectorLayer(QString vectorLayerPath, QString baseName, QString providerKey);
   /** \brief overloaded vesion of the privat addLayer method that takes a list of
-   * filenames instead of prompting user with a dialog.
+   * fileNames instead of prompting user with a dialog.
    @param enc encoding type for the layer
    @returns true if successfully added layer
   bool addVectorLayers(QStringList const & theLayerQStringList, const QString& enc);
   /** overloaded vesion of the private addRasterLayer()
-    Method that takes a list of filenames instead of prompting
+    Method that takes a list of fileNames instead of prompting
     user with a dialog.
     @returns true if successfully added layer(s)
@@ -178,7 +178,7 @@
 public slots:
   //! About QGis
   void about();
-  //! Add a raster layer to the map (will prompt user for filename using dlg )
+  //! Add a raster layer to the map (will prompt user for fileName using dlg )
   void addRasterLayer();
   //#ifdef HAVE_POSTGRESQL
   //! Add a databaselayer to the map
@@ -452,7 +452,7 @@
   bool addRasterLayer(QgsRasterLayer * theRasterLayer);
   //@todo We should move these next two into vector layer class
-  /** This helper checks to see whether the filename appears to be a valid vector file name */
+  /** This helper checks to see whether the fileName appears to be a valid vector file name */
   bool isValidVectorFileName (QString theFileNameQString);
   /** Overloaded version of the above function provided for convenience that takes a qstring pointer */
   bool isValidVectorFileName (QString * theFileNameQString);
Modified: trunk/qgis/src/app/qgsabout.cpp
--- trunk/qgis/src/app/qgsabout.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgsabout.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -245,10 +245,10 @@
  * Step 2: Replace all bytes of the UTF-8 above 0x7f with the hexcode in lower case.
  * Step 2: Replace all non [a-z][a-Z][0-9] with underscore (backward compatibility)
-QString QgsAbout::fileSystemSafe(QString filename)
+QString QgsAbout::fileSystemSafe(QString fileName)
   QString result;
-  QByteArray utf8 = filename.toUtf8();
+  QByteArray utf8 = fileName.toUtf8();
   for (int i = 0; i < utf8.size(); i++)
Modified: trunk/qgis/src/app/qgsmapserverexport.cpp
--- trunk/qgis/src/app/qgsmapserverexport.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgsmapserverexport.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -367,7 +367,7 @@
   QString s = QFileDialog::getSaveFileName(
                     this,
-                    "Choose a filename for the exported map file",
+                    "Choose a fileName for the exported map file",
                     "Mapserver files (*.map)" );
   txtMapFilePath->setText(s);
Modified: trunk/qgis/src/app/qgsmapserverexport.h
--- trunk/qgis/src/app/qgsmapserverexport.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgsmapserverexport.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -45,7 +45,7 @@
   //! get the full path name of the map file
   QString fullPathName();
   //! Set the full path to the file
-  void setFileName(QString filename);
+  void setFileName(QString fileName);
   enum ACTION {
   	SAVE,
 	SAVEAS,
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -804,7 +804,7 @@
   cboxShowDebugInfo->hide();
-  //these properties (layername and label) are provided by the qgsmaplayer superclass
+  //these properties (layerName and label) are provided by the qgsmaplayer superclass
   leLayerSource->setText(mRasterLayer->source());
   leDisplayName->setText(mRasterLayer->name());
@@ -1824,15 +1824,15 @@
 void QgsRasterLayerProperties::on_pbnExportTransparentPixelValues_clicked()
-  QString myFilename = QFileDialog::getSaveFileName(this, tr("Save file"), "/", tr("Textfile (*.txt)"));
-  if(!myFilename.isEmpty())
+  QString myFileName = QFileDialog::getSaveFileName(this, tr("Save file"), "/", tr("Textfile (*.txt)"));
+  if(!myFileName.isEmpty())
-    if(!myFilename.endsWith(".txt", Qt::CaseInsensitive))
+    if(!myFileName.endsWith(".txt", Qt::CaseInsensitive))
-      myFilename = myFilename + ".txt";
+      myFileName = myFileName + ".txt";
-    QFile myOutputFile(myFilename);
+    QFile myOutputFile(myFileName);
     if (myOutputFile.open(QFile::WriteOnly))
       QTextStream myOutputStream(&myOutputFile);
@@ -2307,8 +2307,8 @@
   int myLineCounter = 0;
   bool myImportError = false;
   QString myBadLines;
-  QString myFilename = QFileDialog::getOpenFileName(this, tr("Open file"), "/", tr("Textfile (*.txt)"));
-  QFile myInputFile(myFilename);
+  QString myFileName = QFileDialog::getOpenFileName(this, tr("Open file"), "/", tr("Textfile (*.txt)"));
+  QFile myInputFile(myFileName);
   if (myInputFile.open(QFile::ReadOnly))
     QTextStream myInputStream(&myInputFile);
@@ -2383,7 +2383,7 @@
       QMessageBox::warning(this, tr("Import Error"), tr("The following lines contained errors\n\n") + myBadLines );
-  else if(!myFilename.isEmpty())
+  else if(!myFileName.isEmpty())
     QMessageBox::warning(this, tr("Read access denied"), tr("Read access denied. Adjust the file permissions and try again.\n\n") );
@@ -2921,7 +2921,7 @@
   myFileDialog->setFileMode ( QFileDialog::AnyFile );
   myFileDialog->setAcceptMode ( QFileDialog::AcceptOpen );
   QString myFileName;
   if ( myFileDialog->exec() == QDialog::Accepted )
@@ -2936,7 +2936,7 @@
     if ( myFileDialog->selectedFilter() == tr ( "QGIS Layer Style File (*.qml)" ) )
-      //ensure the user never ommitted the extension from the filename
+      //ensure the user never ommitted the extension from the fileName
       if ( !myFileName.toUpper().endsWith ( ".QML" ) )
         myFileName += ".qml";
@@ -2987,7 +2987,7 @@
   myFileDialog->setAcceptMode ( QFileDialog::AcceptSave );
   QString myOutputFileName;
@@ -3002,7 +3002,7 @@
       if ( !myOutputFileName.toUpper().endsWith ( ".QML" ) )
         myOutputFileName += ".qml";
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -927,7 +927,7 @@
   QString myFileName;
@@ -942,7 +942,7 @@
       if ( !myFileName.endsWith( ".qml", Qt::CaseInsensitive ) )
@@ -992,7 +992,7 @@
@@ -1009,7 +1009,7 @@
       apply(); // make sure the qml to save is uptodate
       if ( !myOutputFileName.endsWith ( ".qml", Qt::CaseInsensitive ) )
Modified: trunk/qgis/src/core/qgslogger.h
--- trunk/qgis/src/core/qgslogger.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/qgslogger.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -39,7 +39,7 @@
  * If the debug level of a message is <= QGIS_DEBUG, the message is written to the
  * console. It the variable QGIS_DEBUG is not defined, it defaults to 1 for debug
  * mode and to 0 for release mode
- * QGIS_DEBUG_FILE may contain a filename. Only the messages from this file are
+ * QGIS_DEBUG_FILE may contain a fileName. Only the messages from this file are
  * printed (provided they have the right debuglevel). If QGIS_DEBUG_FILE is not
  * set, messages from all files are printed
@@ -51,7 +51,7 @@
   /**Goes to qDebug.
   @param debuglevel
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -191,7 +191,7 @@
   setMaxScale(element.attribute("maxScale").toFloat());
   // set name
-  mnl = layer_node.namedItem("layername");
+  mnl = layer_node.namedItem("layerName");
   mne = mnl.toElement();
   setLayerName( mne.text() );
@@ -255,7 +255,7 @@
   // layer name
-  QDomElement layerName = document.createElement( "layername" );
+  QDomElement layerName = document.createElement( "layerName" );
   QDomText layerNameText = document.createTextNode( name() );
   layerName.appendChild( layerNameText );
@@ -482,7 +482,7 @@
   else
     QFileInfo project( QgsProject::instance()->fileName() );
-    QgsDebugMsg( QString("project filename: %1").arg( project.absoluteFilePath() ) );
+    QgsDebugMsg( QString("project fileName: %1").arg( project.absoluteFilePath() ) );
     QString qml;
     if( loadNamedStyleFromDb( QDir( QgsApplication::qgisSettingsDirPath() ).absoluteFilePath( "qgis.qmldb" ), theURI, qml ) ||
@@ -574,7 +574,7 @@
   QFileInfo myFileInfo ( theURI );
   if ( myFileInfo.exists() || theURI.endsWith(".qml", Qt::CaseInsensitive) )
-    QFileInfo myDirInfo ( myFileInfo.path() ); //excludes filename
+    QFileInfo myDirInfo ( myFileInfo.path() ); //excludes fileName
     if ( !myDirInfo.isWritable() )
       return QObject::tr( "The directory containing your dataset needs to be writeable!" );
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/qgsproject.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -402,12 +402,12 @@
- void QgsProject::setFilename(QString const &name)
+ void QgsProject::setFileName(QString const &name)
      imp_->file.setFileName(name);
      dirty(true);
- } // void QgsProject::setFilename( QString const & name )
+ } // void QgsProject::setFileName( QString const & name )
@@ -608,7 +608,7 @@
    @note XML of form:
    <maplayer type="vector">
-      <layername>Hydrop</layername>
+      <layerName>Hydrop</layerName>
       <datasource>/data/usgs/city_shp/hydrop.shp</datasource>
       <zorder>0</zorder>
       <provider>ogr</provider>
Modified: trunk/qgis/src/core/qgsproject.h
--- trunk/qgis/src/core/qgsproject.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/qgsproject.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -92,7 +92,7 @@
-    void setFilename( QString const & name );
+    void setFileName( QString const & name );
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -254,7 +254,7 @@
-/** This helper checks to see whether the filename appears to be a valid raster file name */
+/** This helper checks to see whether the fileName appears to be a valid raster file name */
 bool QgsRasterLayer::isValidRasterFileName(QString const & theFileNameQString,
                                            QString & retErrMsg )
@@ -2959,7 +2959,7 @@
       myQPainter.drawPixmap(0,myHeight-myNoPyramidPixmap.height(),myNoPyramidPixmap);
-    // Overlay the layername
+    // Overlay the layerName
     if (drawingStyle == MULTI_BAND_SINGLE_BAND_GRAY || drawingStyle == PALETTED_SINGLE_BAND_GRAY || drawingStyle == SINGLE_BAND_GRAY)
@@ -3187,7 +3187,7 @@
   QPixmap myQPixmap2 = myLegendQPixmap.transformed(myQWMatrix);
   QPainter myQPainter2(&myQPixmap2);
@@ -4004,7 +4004,7 @@
   Raster layer project file XML of form:
   <maplayer type="raster" visible="1" showInOverviewFlag="1">
-  <layername>Wynoochee_dem</layername>
+  <layerName>Wynoochee_dem</layerName>
   <datasource>/home/mcoletti/mnt/MCOLETTIF8F9/c/Toolkit_Course/Answers/Training_Data/wynoochee_dem.img</datasource>
   <zorder>0</zorder>
   <transparencyLevelInt>255</transparencyLevelInt>
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -181,8 +181,8 @@
-       raster file name.  If the filename looks like it could be valid,
+       raster file name.  If the fileName looks like it could be valid,
        but some sort of error occurs in processing the file, the error is
        returned in retError. */
     static bool isValidRasterFileName(const QString & theFileNameQString,
Modified: trunk/qgis/src/core/sqlite3/sqlite3.h
--- trunk/qgis/src/core/sqlite3/sqlite3.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/sqlite3/sqlite3.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -701,11 +701,11 @@
 ** The zName field holds the name of the VFS module.  The name must
 ** be unique across all VFS modules.
-** {F11141} SQLite will guarantee that the zFilename string passed to
+** {F11141} SQLite will guarantee that the zFileName string passed to
 ** xOpen() is a full pathname as generated by xFullPathname() and
 ** that the string will be valid and unchanged until xClose() is
 ** called.  {END} So the [sqlite3_file] can store a pointer to the
-** filename if it needs to remember the filename for some reason.
+** fileName if it needs to remember the fileName for some reason.
 ** {F11142} The flags argument to xOpen() includes all bits set in
 ** the flags argument to [sqlite3_open_v2()].  Or if [sqlite3_open()]
@@ -797,7 +797,7 @@
   int (*xAccess)(sqlite3_vfs*, const char *zName, int flags);
   int (*xGetTempname)(sqlite3_vfs*, int nOut, char *zOut);
   int (*xFullPathname)(sqlite3_vfs*, const char *zName, int nOut, char *zOut);
-  void *(*xDlOpen)(sqlite3_vfs*, const char *zFilename);
+  void *(*xDlOpen)(sqlite3_vfs*, const char *zFileName);
   void (*xDlError)(sqlite3_vfs*, int nByte, char *zErrMsg);
   void *(*xDlSym)(sqlite3_vfs*,void*, const char *zSymbol);
   void (*xDlClose)(sqlite3_vfs*, void*);
@@ -1495,8 +1495,8 @@
 ** The windows OS interface layer calls
 ** the system malloc() and free() directly when converting
-** filenames between the UTF-8 encoding used by SQLite
-** and whatever filename encoding is used by the particular windows
+** fileNames between the UTF-8 encoding used by SQLite
+** and whatever fileName encoding is used by the particular windows
 ** installation.  Memory allocation errors are detected, but
 ** they are reported back as [SQLITE_CANTOPEN] or
 ** [SQLITE_IOERR] rather than [SQLITE_NOMEM].
@@ -1783,7 +1783,7 @@
 #define SQLITE_SELECT               21   /* NULL            NULL            */
 #define SQLITE_TRANSACTION          22   /* NULL            NULL            */
 #define SQLITE_UPDATE               23   /* Table Name      Column Name     */
-#define SQLITE_ATTACH               24   /* Filename        NULL            */
+#define SQLITE_ATTACH               24   /* FileName        NULL            */
 #define SQLITE_DETACH               25   /* Database Name   NULL            */
 #define SQLITE_ALTER_TABLE          26   /* Database Name   Table Name      */
 #define SQLITE_REINDEX              27   /* Index Name      NULL            */
@@ -1908,8 +1908,8 @@
 ** CAPI3REF: Opening A New Database Connection {F12700}
 ** These routines open an SQLite database file whose name
-** is given by the filename argument.
-** The filename argument is interpreted as UTF-8
+** is given by the fileName argument.
+** The fileName argument is interpreted as UTF-8
 ** for [sqlite3_open()] and [sqlite3_open_v2()] and as UTF-16
 ** in the native byte order for [sqlite3_open16()].
 ** An [sqlite3*] handle is usually returned in *ppDb, even
@@ -1952,16 +1952,16 @@
 ** The third options is behavior that is always used for [sqlite3_open()]
 ** and [sqlite3_open16()].
-** If the filename is ":memory:", then an private
+** If the fileName is ":memory:", then an private
 ** in-memory database is created for the connection.  This in-memory
 ** database will vanish when the database connection is closed.  Future
-** version of SQLite might make use of additional special filenames
+** version of SQLite might make use of additional special fileNames
 ** that begin with the ":" character.  It is recommended that
-** when a database filename really does begin with
-** ":" that you prefix the filename with a pathname like "./" to
+** when a database fileName really does begin with
+** ":" that you prefix the fileName with a pathname like "./" to
 ** avoid ambiguity.
-** If the filename is an empty string, then a private temporary
+** If the fileName is an empty string, then a private temporary
 ** on-disk database will be created.  This private database will be
 ** automatically deleted as soon as the database connection is closed.
@@ -1971,9 +1971,9 @@
 ** fourth parameter is a NULL pointer then the default [sqlite3_vfs]
 ** object is used.
-** <b>Note to windows users:</b>  The encoding used for the filename argument
+** <b>Note to windows users:</b>  The encoding used for the fileName argument
 ** of [sqlite3_open()] and [sqlite3_open_v2()] must be UTF-8, not whatever
-** codepage is currently defined.  Filenames containing international
+** codepage is currently defined.  FileNames containing international
 ** characters must be converted to UTF-8 prior to passing them into
 ** [sqlite3_open()] or [sqlite3_open_v2()].
@@ -1984,7 +1984,7 @@
 **          [database connection] associated with
 **          the database file given in their first parameter.
-** {F12702} The filename argument is interpreted as UTF-8
+** {F12702} The fileName argument is interpreted as UTF-8
@@ -2024,13 +2024,13 @@
 **          previously exist, then an attempt is made to create and
 **          initialize the database.
-** {F12717} If the filename argument to [sqlite3_open()], [sqlite3_open16()],
+** {F12717} If the fileName argument to [sqlite3_open()], [sqlite3_open16()],
 **          or [sqlite3_open_v2()] is ":memory:", then an private,
 **          ephemeral, in-memory database is created for the connection.
 **          <todo>Is SQLITE_OPEN_CREATE|SQLITE_OPEN_READWRITE required
 **          in sqlite3_open_v2()?</todo>
-** {F12719} If the filename is an empty string, then a private, ephermeral
+** {F12719} If the fileName is an empty string, then a private, ephermeral
@@ -2041,15 +2041,15 @@
 **          the default [sqlite3_vfs] object is V is a NULL pointer.
 int sqlite3_open(
-  const char *filename,   /* Database filename (UTF-8) */
+  const char *fileName,   /* Database fileName (UTF-8) */
   sqlite3 **ppDb          /* OUT: SQLite db handle */
 int sqlite3_open16(
-  const void *filename,   /* Database filename (UTF-16) */
+  const void *fileName,   /* Database fileName (UTF-16) */
 int sqlite3_open_v2(
   sqlite3 **ppDb,         /* OUT: SQLite db handle */
   int flags,              /* Flags */
   const char *zVfs        /* Name of VFS module to use */
Modified: trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp
--- trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -182,10 +182,10 @@
   return QPicture(); // empty
-void QgsMarkerCatalogue::svgMarker ( QPainter * thepPainter, QString filename, double scaleFactor)
+void QgsMarkerCatalogue::svgMarker ( QPainter * thepPainter, QString fileName, double scaleFactor)
   QSvgRenderer mySVG;
-  mySVG.load(filename);
+  mySVG.load(fileName);
   mySVG.render(thepPainter);
Modified: trunk/qgis/src/core/symbology/qgsmarkercatalogue.h
--- trunk/qgis/src/core/symbology/qgsmarkercatalogue.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/core/symbology/qgsmarkercatalogue.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -50,7 +50,7 @@
     QPicture pictureMarker (QString fullName, double size, QPen pen, QBrush brush, bool qtBug = true );
     static void svgMarker (QPainter * thepPainter, QString name, double size );
 private:
Modified: trunk/qgis/src/gui/qgsquickprint.cpp
--- trunk/qgis/src/gui/qgsquickprint.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/gui/qgsquickprint.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -122,7 +122,7 @@
     return;
   if ( !mOutputFileName.toUpper().endsWith ( ".PDF" ) )
     mOutputFileName += ".pdf";
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -119,7 +119,7 @@
   QString s = tr("Fields description:\n"
   "* Input DXF file: path to the DXF file to be converted\n"
-  "* Output Shp file: desired filename of the ShapeFile to be created\n"
+  "* Output Shp file: desired fileName of the ShapeFile to be created\n"
   "* Shp output file type: specifies the type of the output shapefile\n"
   "* Export text labels checkbox: if checked, an additional shp points layer will be created, "
   "  and the associated dbf table will contain informations about the \"TEXT\" fields found"
@@ -159,7 +159,7 @@
 void dxf2shpConverterGui::getOutputDir()
   QString s = QFileDialog::getSaveFileName(this,
-                                           tr("Choose a filename to save to"),
+                                           tr("Choose a fileName to save to"),
 					   "output.shp",
 					   "Shapefile (*.shp)");
Modified: trunk/qgis/src/plugins/dxf2shp_converter/shapelib-1.2.10/shapefil.h
--- trunk/qgis/src/plugins/dxf2shp_converter/shapelib-1.2.10/shapefil.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/dxf2shp_converter/shapelib-1.2.10/shapefil.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -354,9 +354,9 @@
       SHPDestroyTree( SHPTree * hTree );
 int	SHPAPI_CALL
-      SHPWriteTree( SHPTree *hTree, const char * pszFilename );
+      SHPWriteTree( SHPTree *hTree, const char * pszFileName );
 SHPTree SHPAPI_CALL
-      SHPReadTree( const char * pszFilename );
+      SHPReadTree( const char * pszFileName );
 int	SHPAPI_CALL
       SHPTreeAddObject( SHPTree * hTree, SHPObject * psObject );
@@ -470,7 +470,7 @@
       DBFWriteTuple(DBFHandle psDBF, int hEntity, void * pRawTuple );
 DBFHandle SHPAPI_CALL
-      DBFCloneEmpty(DBFHandle psDBF, const char * pszFilename );
+      DBFCloneEmpty(DBFHandle psDBF, const char * pszFileName );
 void	SHPAPI_CALL
       DBFClose( DBFHandle hDBF );
Modified: trunk/qgis/src/plugins/georeferencer/plugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/plugingui.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/georeferencer/plugingui.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -80,17 +80,17 @@
   QString dir = settings.value("/Plugin-GeoReferencer/rasterdirectory").toString();
   if (dir.isEmpty())
     dir = ".";
-  QString filename =
+  QString fileName =
 				 tr("Choose a raster file"),
                  dir,
 				 tr("Raster files (*.*)"));
-  if(filename.isNull())
+  if(fileName.isNull())
       return;
-  leSelectRaster->setText(filename);
+  leSelectRaster->setText(fileName);
   // do we think that this is a valid raster?
   if (!QgsRasterLayer::isValidRasterFileName(leSelectRaster->text())) {
@@ -149,7 +149,7 @@
     prj->writeEntry("SpatialRefSys", "/ProjectCRSID", mProjectCRSID);
-  mPointDialog->openImageFile(filename);
+  mPointDialog->openImageFile(fileName);
   mPointDialog->show();
Modified: trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/georeferencer/qgspointdialog.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -186,20 +186,20 @@
 void QgsPointDialog::on_pbnSelectWorldFile_clicked()
-  QString filename = QFileDialog::getSaveFileName(this,
+  QString fileName = QFileDialog::getSaveFileName(this,
               tr("Choose a name for the world file"), ".");
-  leSelectWorldFile->setText(filename);
+  leSelectWorldFile->setText(fileName);
 void QgsPointDialog::on_pbnSelectModifiedRaster_clicked()
-  if (filename.right(4) != ".tif")
-    filename += ".tif";
-  leSelectModifiedRaster->setText(filename);
-  leSelectWorldFile->setText(guessWorldFileName(filename));
+  if (fileName.right(4) != ".tif")
+    fileName += ".tif";
+  leSelectModifiedRaster->setText(fileName);
+  leSelectWorldFile->setText(guessWorldFileName(fileName));
 void QgsPointDialog::on_cmbTransformType_currentIndexChanged(const QString& value)
@@ -210,20 +210,20 @@
     // Make up a modified raster field name based on the layer file name
     if(mLayer)
-	QString filename(mLayer->source());
+	QString fileName(mLayer->source());
 	QFileInfo file(mLayer->source());
-	int pos = filename.size()-file.suffix().size()-1;
-	filename.insert(pos, tr("-modified", "Georeferencer:QgsPointDialog.cpp - used to modify a user given filename"));
-	pos = filename.size()-file.suffix().size();
-	filename.replace(pos, filename.size(), "tif");
+	int pos = fileName.size()-file.suffix().size()-1;
+	fileName.insert(pos, tr("-modified", "Georeferencer:QgsPointDialog.cpp - used to modify a user given fileName"));
+	pos = fileName.size()-file.suffix().size();
+	fileName.replace(pos, fileName.size(), "tif");
   else
-    // Reset to the default filenames
+    // Reset to the default fileNames
     leSelectModifiedRaster->setText("");
     enableModifiedRasterControls(false);
     if(mLayer)
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.cpp
--- trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -195,11 +195,11 @@
   delete mQActionPointer;
-void QgsGPSPlugin::loadGPXFile(QString filename, bool loadWaypoints, bool loadRoutes,
+void QgsGPSPlugin::loadGPXFile(QString fileName, bool loadWaypoints, bool loadRoutes,
 			       bool loadTracks) {
   //check if input file is readable
-  QFileInfo fileInfo(filename);
+  QFileInfo fileInfo(fileName);
   if (!fileInfo.isReadable()) {
     QMessageBox::warning(NULL, tr("GPX Loader"),
 			 tr("Unable to read the selected file.\n")+
@@ -213,22 +213,22 @@
   // add the requested layers
   if (loadTracks)
-    emit drawVectorLayer(filename + "?type=track",
+    emit drawVectorLayer(fileName + "?type=track",
 			 fileInfo.baseName() + ", tracks", "gpx");
   if (loadRoutes)
-    emit drawVectorLayer(filename + "?type=route",
+    emit drawVectorLayer(fileName + "?type=route",
 			 fileInfo.baseName() + ", routes", "gpx");
   if (loadWaypoints)
-    emit drawVectorLayer(filename + "?type=waypoint",
+    emit drawVectorLayer(fileName + "?type=waypoint",
 			 fileInfo.baseName() + ", waypoints", "gpx");
   emit closeGui();
-void QgsGPSPlugin::importGPSFile(QString inputFilename, QgsBabelFormat* importer,
+void QgsGPSPlugin::importGPSFile(QString inputFileName, QgsBabelFormat* importer,
 				 bool importWaypoints, bool importRoutes,
-				 bool importTracks, QString outputFilename,
+				 bool importTracks, QString outputFileName,
 				 QString layerName) {
   // what features does the user want to import?
@@ -243,7 +243,7 @@
   // try to start the gpsbabel process
   QStringList babelArgs =
     importer->importCommand(mBabelPath, typeArg,
-			       inputFilename, outputFilename);
+			       inputFileName, outputFileName);
   QgsDebugMsg(QString("Import command: ") + babelArgs.join("|"));
@@ -268,7 +268,7 @@
   if (babelProcess.exitStatus() != 0) {
     QString babelError(babelProcess.readAllStandardError());
     QString errorMsg(tr("Could not import data from %1!\n\n")
-		     .arg(inputFilename));
+		     .arg(inputFileName));
     errorMsg += babelError;
     QMessageBox::warning(NULL, tr("Error importing data"), errorMsg);
     return;
@@ -276,22 +276,22 @@
   // add the layer
   if (importTracks)
-    emit drawVectorLayer(outputFilename + "?type=track",
+    emit drawVectorLayer(outputFileName + "?type=track",
 			 layerName, "gpx");
   if (importRoutes)
-    emit drawVectorLayer(outputFilename + "?type=route",
+    emit drawVectorLayer(outputFileName + "?type=route",
 			 layerName, "gpx");
   if (importWaypoints)
-    emit drawVectorLayer(outputFilename + "?type=waypoint",
+    emit drawVectorLayer(outputFileName + "?type=waypoint",
 			 layerName, "gpx");
   emit closeGui();
-void QgsGPSPlugin::convertGPSFile(QString inputFilename,
+void QgsGPSPlugin::convertGPSFile(QString inputFileName,
                                   int convertType,
-				  QString outputFilename,
+				  QString outputFileName,
@@ -311,8 +311,8 @@
   QStringList babelArgs;
-  babelArgs << mBabelPath << "-i"<<"gpx"<<"-f"<< inputFilename
-            << convertStrings <<"-o"<<"gpx"<<"-F"<< outputFilename;
+  babelArgs << mBabelPath << "-i"<<"gpx"<<"-f"<< inputFileName
+            << convertStrings <<"-o"<<"gpx"<<"-F"<< outputFileName;
   QgsDebugMsg(QString("Conversion command: ") + babelArgs.join("|"));
   QProcess babelProcess;
@@ -336,7 +336,7 @@
     QString errorMsg(tr("Could not convert data from %1!\n\n")
     QMessageBox::warning(NULL, tr("Error converting data"), errorMsg);
     return;
@@ -346,11 +346,11 @@
   switch ( convertType )
   case 0:
 			 layerName, "gpx");
     break;
   case 1:
 			 layerName, "gpx");
     break;
   default:
@@ -363,7 +363,7 @@
 void QgsGPSPlugin::downloadFromGPS(QString device, QString port,
 				   bool downloadWaypoints, bool downloadRoutes,
-				   bool downloadTracks, QString outputFilename,
+				   bool downloadTracks, QString outputFileName,
   // what does the user want to download?
@@ -384,7 +384,7 @@
     mDevices[device]->importCommand(mBabelPath, typeArg,
-				    port, outputFilename);
+				    port, outputFileName);
   if (babelArgs.isEmpty()) {
     QMessageBox::warning(NULL, tr("Not supported"),
 			 QString(tr("This device does not support downloading ") +
@@ -423,13 +423,13 @@
   // add the layer
   if (downloadWaypoints)
 			 layerName, "gpx");
   if (downloadRoutes)
 			 layerName, "gpx");
   if (downloadTracks)
 			 layerName, "gpx");
   // everything was OK, remember the device and port for next time
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.h
--- trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsplugin.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -57,19 +57,19 @@
   void help();
   //! load a GPX file
-  void loadGPXFile(QString filename, bool loadWaypoints, bool loadRoutes,
+  void loadGPXFile(QString fileName, bool loadWaypoints, bool loadRoutes,
 		   bool loadTracks);
-  void importGPSFile(QString inputFilename, QgsBabelFormat* importer,
+  void importGPSFile(QString inputFileName, QgsBabelFormat* importer,
 		     QString layerName);
-  void convertGPSFile(QString inputFilename,
+  void convertGPSFile(QString inputFileName,
                       int convertType,
                       QString layerName);
   void downloadFromGPS(QString device, QString port,
 		       QString layerName);
   void uploadToGPS(QgsVectorLayer* gpxLayer, QString device,
 		   QString port);
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp
--- trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -143,7 +143,7 @@
   QString myFileNameQString =
     QFileDialog::getSaveFileName(this, //parent dialog
-				 tr("Choose a filename to save under"),
+				 tr("Choose a fileName to save under"),
                  "." , //initial dir
 				 tr("GPS eXchange format (*.gpx)"));
   if (!myFileNameQString.isEmpty())
@@ -278,7 +278,7 @@
 void QgsGPSPluginGui::on_pbnIMPOutput_clicked() {
                  ".", //initial dir
@@ -480,7 +480,7 @@
   QString sentence1 = tr("QGIS can only load GPX files by itself, but many other formats can be converted to GPX using GPSBabel (%1).")
     .arg("<a href=\"http://www.gpsbabel.org\">http://www.gpsbabel.org</a>");
   QString sentence2 = tr("This requires that you have GPSBabel installed where QGIS can find it.");
-  QString sentence3 = tr("Select a GPS file format and the file that you want to import, the feature type that you want to use, a GPX filename that you want to save the converted file as, and a name for the new layer.");
+  QString sentence3 = tr("Select a GPS file format and the file that you want to import, the feature type that you want to use, a GPX fileName that you want to save the converted file as, and a name for the new layer.");
   QString sentence4 = tr("All file formats can not store waypoints, routes, and tracks, so some feature types may be disabled for some file formats.");
   QString text = format.arg(sentence1).arg(sentence2).arg(sentence3).arg(sentence4);
@@ -499,7 +499,7 @@
   QString sentence1 = tr("QGIS can perform conversions of GPX files, by using GPSBabel (%1) to perform the conversions.")
-  QString sentence3 = tr("Select a GPX input file name, the type of conversion you want to perform, a GPX filename that you want to save the converted file as, and a name for the new layer created from the result.");
+  QString sentence3 = tr("Select a GPX input file name, the type of conversion you want to perform, a GPX fileName that you want to save the converted file as, and a name for the new layer created from the result.");
   QString text = format.arg(sentence1).arg(sentence2).arg(sentence3);
@@ -528,7 +528,7 @@
 void QgsGPSPluginGui::on_pbnCONVOutput_clicked() {
                  ".", //initial dir
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h
--- trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsplugingui.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -79,19 +79,19 @@
 signals:
   void drawRasterLayer(QString);
   void drawVectorLayer(QString,QString,QString);
-  void loadGPXFile(QString filename, bool showWaypoints, bool showRoutes,
+  void loadGPXFile(QString fileName, bool showWaypoints, bool showRoutes,
 		   bool showTracks);
 		     QString layerName);
                       int convertType,
                       QString layerName);
   void downloadFromGPS(QString device, QString port, bool downloadWaypoints,
 		       bool downloadRoutes, bool downloadTracks,
-		       QString outputFilename, QString layerName);
+		       QString outputFileName, QString layerName);
   void uploadToGPS(QgsVectorLayer* gpxLayer, QString device, QString port);
 private:
Modified: trunk/qgis/src/plugins/grid_maker/plugingui.cpp
--- trunk/qgis/src/plugins/grid_maker/plugingui.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/grid_maker/plugingui.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -89,9 +89,9 @@
   // If you have a produced a raster layer using your plugin, you can ask qgis to
   // add it to the view using:
-  // emit drawRasterLayer(QString("layername"));
+  // emit drawRasterLayer(QString("layerName"));
   // or for a vector layer
-  //emit drawVectorLayer(QString("pathname"),QString("layername"),QString("provider name (either ogr or postgres"));
+  //emit drawVectorLayer(QString("pathname"),QString("layerName"),QString("provider name (either ogr or postgres"));
   emit drawVectorLayer(leOutputShapeFile->text(),QString("Graticule"),QString("ogr"));
@@ -105,7 +105,7 @@
  QgsLogger::debug(" Gps File Importer Gui::pbnSelectOutputFile_clicked()");
   QString myOutputFileNameQString = QFileDialog::getSaveFileName(
           this,
           tr("ESRI Shapefile (*.shp)"));
Modified: trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.h
--- trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -97,9 +97,9 @@
   /**Returns true, if the point with coordinates x and y is inside the convex hull and false otherwise*/
   bool pointInside(double x, double y);
   /**Reads the dual edge structure of a taff file*/
-  //bool readFromTAFF(QString filename);
+  //bool readFromTAFF(QString fileName);
   /**Saves the dual edge structure to a taff file*/
-  //bool saveToTAFF(QString filename) const;
+  //bool saveToTAFF(QString fileName) const;
   /**Swaps the edge which is closest to the point with x and y coordinates (if this is possible)*/
   virtual bool swapEdge(double x, double y);
   /**Returns a value list with the numbers of the four points, which would be affected by an edge swap. This function is e.g. needed by NormVecDecorator to know the points, for which the normals have to be recalculated. The returned ValueList has to be deleted by the code which calls the method*/
Modified: trunk/qgis/src/plugins/interpolation/Triangulation.h
--- trunk/qgis/src/plugins/interpolation/Triangulation.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/interpolation/Triangulation.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -83,9 +83,9 @@
   virtual bool pointInside(double x, double y)=0;
   /**Reads the content of a taff-file*/
-  //virtual bool readFromTAFF(QString filename)=0;
+  //virtual bool readFromTAFF(QString fileName)=0;
   /**Saves the content to a taff file*/
-  //virtual bool saveToTAFF(QString filename) const=0;
+  //virtual bool saveToTAFF(QString fileName) const=0;
   virtual bool swapEdge(double x, double y)=0;
Modified: trunk/qgis/src/plugins/interpolation/qgsinterpolationdialog.cpp
--- trunk/qgis/src/plugins/interpolation/qgsinterpolationdialog.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/interpolation/qgsinterpolationdialog.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -67,9 +67,9 @@
       return;
-  //read filename
-  QString filename = mOutputFileLineEdit->text();
-  QFileInfo theFileInfo(filename);
+  //read fileName
+  QString fileName = mOutputFileLineEdit->text();
+  QFileInfo theFileInfo(fileName);
   if(!theFileInfo.dir().exists())
       QMessageBox::information(0, "File name invalid", "Please enter a valid file name");
@@ -111,10 +111,10 @@
   //create grid file writer
-  QgsGridFileWriter theWriter(theInterpolator, filename, theVectorLayer->extent(), mNumberOfColumnsSpinBox->value(), mNumberOfRowsSpinBox->value());
+  QgsGridFileWriter theWriter(theInterpolator, fileName, theVectorLayer->extent(), mNumberOfColumnsSpinBox->value(), mNumberOfRowsSpinBox->value());
   if(theWriter.writeFile(true) == 0)
-      mIface->addRasterLayer(filename, "Interpolation");
+      mIface->addRasterLayer(fileName, "Interpolation");
       accept();
Modified: trunk/qgis/src/plugins/quick_print/quickprintgui.cpp
--- trunk/qgis/src/plugins/quick_print/quickprintgui.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/quick_print/quickprintgui.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -113,7 +113,7 @@
@@ -128,7 +128,7 @@
     if ( myFileDialog->selectedFilter() == tr ( "Portable Document Format (*.pdf)" ) )
       if ( !myOutputFileName.toUpper().endsWith ( ".PDF" ) )
         myOutputFileName += ".pdf";
Modified: trunk/qgis/src/plugins/spit/qgsshapefile.cpp
--- trunk/qgis/src/plugins/spit/qgsshapefile.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/spit/qgsshapefile.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -47,10 +47,10 @@
 QgsShapeFile::QgsShapeFile(QString name, QString encoding){
-  filename = name;
+  fileName = name;
   features = 0;
   OGRRegisterAll();
-  ogrDataSource = OGROpen(QFile::encodeName(filename).constData(),FALSE,NULL);
+  ogrDataSource = OGROpen(QFile::encodeName(fileName).constData(),FALSE,NULL);
   if (ogrDataSource != NULL){
     valid = true;
     ogrLayer = OGR_DS_GetLayer(ogrDataSource,0);
@@ -81,7 +81,7 @@
   sg->setMinimum(0);
   sg->setMaximum(0);
   QString label = tr("Scanning ");
-  label += filename;
+  label += fileName;
   sg->setLabel(new QLabel(label));
   sg->show();
   qApp->processEvents();
@@ -172,7 +172,7 @@
       QgsDebugMsg("After escaping, geom_type is : " + geom_type);
       delete[] esc_str;
-      QString file(filename);
+      QString file(fileName);
       file.replace(file.length()-3, 3, "dbf");
       // open the dbf file
       std::ifstream dbf(file.toUtf8(), std::ios::in | std::ios::binary);
@@ -236,7 +236,7 @@
 QString QgsShapeFile::getName(){
-  return filename;
+  return fileName;
 QString QgsShapeFile::getTable(){
@@ -250,7 +250,7 @@
 void QgsShapeFile::setDefaultTable(){
-  QFileInfo fi(filename);
+  QFileInfo fi(fileName);
   table_name = fi.baseName();
Modified: trunk/qgis/src/plugins/spit/qgsshapefile.h
--- trunk/qgis/src/plugins/spit/qgsshapefile.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/spit/qgsshapefile.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -41,7 +41,7 @@
   Q_OBJECT
   public:
-  QgsShapeFile(QString filename, QString encoding = QString());
+  QgsShapeFile(QString fileName, QString encoding = QString());
   ~QgsShapeFile();
   int getFeatureCount();
   QString getFeatureClass();
@@ -70,7 +70,7 @@
   bool isMulti;
   bool hasMoreDimensions;
   int features;
-  QString filename;
+  QString fileName;
   QString geom_type;
   QStringList geometries;
   QTextCodec* codec;
Modified: trunk/qgis/src/plugins/spit/qgsspit.cpp
--- trunk/qgis/src/plugins/spit/qgsspit.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/plugins/spit/qgsspit.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -225,7 +225,7 @@
           QString featureClass = file->getFeatureClass();
           fileList.push_back( file );
-          QTableWidgetItem *filenameItem       = new QTableWidgetItem( name );
+          QTableWidgetItem *fileNameItem       = new QTableWidgetItem( name );
           QTableWidgetItem *featureClassItem   = new QTableWidgetItem( featureClass );
           QTableWidgetItem *featureCountItem   = new QTableWidgetItem( QString( "%1" ).arg( file->getFeatureCount() ) );
           // Sanitize the relation name to make it pg friendly
@@ -234,12 +234,12 @@
           QTableWidgetItem *dbSchemaNameItem   = new QTableWidgetItem( cmbSchema->currentText() );
           // All items are editable except for these two
-          filenameItem->setFlags(Qt::ItemIsSelectable | Qt::ItemIsEnabled);
+          fileNameItem->setFlags(Qt::ItemIsSelectable | Qt::ItemIsEnabled);
           featureCountItem->setFlags(Qt::ItemIsSelectable | Qt::ItemIsEnabled);
           int row = tblShapefiles->rowCount();
           tblShapefiles->insertRow( row );
-          tblShapefiles->setItem( row, ColFILENAME, filenameItem );
+          tblShapefiles->setItem( row, ColFILENAME, fileNameItem );
           tblShapefiles->setItem( row, ColFEATURECLASS, featureClassItem );
           tblShapefiles->setItem( row, ColFEATURECOUNT, featureCountItem );
           tblShapefiles->setItem( row, ColDBRELATIONNAME, dbRelationNameItem );
Modified: trunk/qgis/src/providers/gpx/gpsdata.cpp
--- trunk/qgis/src/providers/gpx/gpsdata.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/providers/gpx/gpsdata.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -324,16 +324,16 @@
-GPSData* GPSData::getData(const QString& filename) {
+GPSData* GPSData::getData(const QString& fileName) {
   // if the data isn't there already, try to load it
-  if (dataObjects.find(filename) == dataObjects.end()) {
-    QFile file(filename);
+  if (dataObjects.find(fileName) == dataObjects.end()) {
+    QFile file(fileName);
     if (!file.open(QIODevice::ReadOnly)) {
-      QgsLogger::warning(QObject::tr("Couldn't open the data source: ") + filename);
+      QgsLogger::warning(QObject::tr("Couldn't open the data source: ") + fileName);
       return 0;
     GPSData* data = new GPSData;
-    QgsLogger::debug("Loading file " + filename);
+    QgsLogger::debug("Loading file " + fileName);
     GPXHandler handler(*data);
     bool failed = false;
@@ -365,27 +365,27 @@
     data->setNoDataExtent();
-    dataObjects[filename] = std::pair<GPSData*, unsigned>(data, 0);
+    dataObjects[fileName] = std::pair<GPSData*, unsigned>(data, 0);
   else
-    QgsLogger::debug(filename + " is already loaded");
+    QgsLogger::debug(fileName + " is already loaded");
-  // return a pointer and increase the reference count for that filename
-  DataMap::iterator iter = dataObjects.find(filename);
+  // return a pointer and increase the reference count for that fileName
+  DataMap::iterator iter = dataObjects.find(fileName);
   ++(iter->second.second);
   return (GPSData*)(iter->second.first);
-void GPSData::releaseData(const QString& filename) {
+void GPSData::releaseData(const QString& fileName) {
-  /* decrease the reference count for the filename (if it is used), and erase
+  /* decrease the reference count for the fileName (if it is used), and erase
      it if the reference count becomes 0 */
   if (iter != dataObjects.end()) {
-    QgsLogger::debug("unrefing " + filename);
+    QgsLogger::debug("unrefing " + fileName);
     if (--(iter->second.second) == 0) {
-      QgsLogger::debug("No one's using " + filename + ", I'll erase it");
+      QgsLogger::debug("No one's using " + fileName + ", I'll erase it");
       delete iter->second.first;
       dataObjects.erase(iter);
Modified: trunk/qgis/src/providers/gpx/gpsdata.h
--- trunk/qgis/src/providers/gpx/gpsdata.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/providers/gpx/gpsdata.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -210,21 +210,21 @@
   void writeXML(QTextStream& stream);
   /** This function returns a pointer to the GPSData object associated with
-      the file @c filename. If the file does not exist or can't be parsed,
+      the file @c fileName. If the file does not exist or can't be parsed,
       NULL will be returned. If the file is already used by another layer,
       a pointer to the same GPSData object will be returned. And if the file
       is not used by any other layer, and can be parsed, a new GPSData object
       will be created and a pointer to it will be returned. If you use this
-      function you should also call releaseData() with the same @c filename
+      function you should also call releaseData() with the same @c fileName
       when you're done with the GPSData pointer, otherwise the data will stay
       in memory forever and you will get an ugly memory leak. */
-  static GPSData* getData(const QString& filename);
+  static GPSData* getData(const QString& fileName);
   /** Call this function when you're done with a GPSData pointer that you
       got earlier using getData(). Do NOT call this function if you haven't
-      called getData() earlier with the same @c filename, that can cause data
+      called getData() earlier with the same @c fileName, that can cause data
       that is still in use to be deleted. */
-  static void releaseData(const QString& filename);
+  static void releaseData(const QString& fileName);
   /** operator<< is our friend. For debugging, not for file I/O. */
@@ -242,7 +242,7 @@
   /** This is used internally to store GPS data objects (one per file). */
   typedef std::map<QString, std::pair<GPSData*, unsigned> > DataMap;
-  /** This is the static container that maps filenames to GPSData objects and
+  /** This is the static container that maps fileNames to GPSData objects and
       does reference counting, so several providers can use the same GPSData
       object. */
   static DataMap dataObjects;
Modified: trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp
--- trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/providers/gpx/qgsgpxprovider.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -64,7 +64,7 @@
   // we always use UTF-8
   mEncoding = QTextCodec::codecForName("utf8");
-  // get the filename and the type parameter from the URI
+  // get the fileName and the type parameter from the URI
   int fileNameEnd = uri.indexOf('?');
   if (fileNameEnd == -1 || uri.mid(fileNameEnd + 1, 5) != "type=") {
     QgsLogger::warning(tr("Bad URI - you need to specify the feature type."));
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -715,14 +715,14 @@
 bool QgsOgrProvider::createSpatialIndex()
-  QString filename=dataSourceUri().section('/',-1,-1);//find out the filename from the uri
-  QString layername=filename.section('.',0,0);
-  QString sql="CREATE SPATIAL INDEX ON "+layername;
+  QString fileName=dataSourceUri().section('/',-1,-1);//find out the fileName from the uri
+  QString layerName=fileName.section('.',0,0);
+  QString sql="CREATE SPATIAL INDEX ON "+layerName;
   OGR_DS_ExecuteSQL (ogrDataSource, sql.toAscii(), OGR_L_GetSpatialFilter(ogrLayer),"");
   //find out, if the .qix file is there
   QString indexname = dataSourceUri();
-  indexname.truncate(dataSourceUri().length()-filename.length());
-  indexname=indexname+layername+".qix";
+  indexname.truncate(dataSourceUri().length()-fileName.length());
+  indexname=indexname+layerName+".qix";
   QFile indexfile(indexname);
   if(indexfile.exists())
@@ -746,9 +746,9 @@
   OGR_L_SyncToDisk(ogrLayer);
-  QString sql="REPACK " + layername;
+  QString sql="REPACK " + layerName;
   OGR_DS_ExecuteSQL(ogrDataSource,sql.toLocal8Bit().data(), NULL, NULL);
   numberFeatures = OGR_L_GetFeatureCount(ogrLayer,TRUE); //new feature count
   return returnvalue;
Modified: trunk/qgis/tests/algorithms/qgsproject/projecttest.h
--- trunk/qgis/tests/algorithms/qgsproject/projecttest.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/tests/algorithms/qgsproject/projecttest.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -101,7 +101,7 @@
     void testFileName()
         QgsProject::instance()->dirty( false );
-        QgsProject::instance()->setFilename( mFile );
+        QgsProject::instance()->setFileName( mFile );
         CPPUNIT_ASSERT( mFile == QgsProject::instance()->fileName() );
         CPPUNIT_ASSERT( QgsProject::instance()->isDirty() );
Modified: trunk/qgis/tools/mapserver_export/qgsmapserverexport.cpp
--- trunk/qgis/tools/mapserver_export/qgsmapserverexport.cpp	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/tools/mapserver_export/qgsmapserverexport.cpp	2008-08-23 19:55:27 UTC (rev 9136)
@@ -196,7 +196,7 @@
     okToSave = QMessageBox::warning(0, tr("Overwrite File?"), txtMapFilePath->text() +
         tr(" exists. \nDo you want to overwrite it?",
-           "a filename is prepended to this text, and appears in a dialog box"),
+           "a fileName is prepended to this text, and appears in a dialog box"),
            QMessageBox::Ok | QMessageBox::Cancel);
   if (okToSave == QMessageBox::Ok)
Modified: trunk/qgis/tools/mapserver_export/qgsmapserverexport.h
--- trunk/qgis/tools/mapserver_export/qgsmapserverexport.h	2008-08-23 19:38:17 UTC (rev 9135)
+++ trunk/qgis/tools/mapserver_export/qgsmapserverexport.h	2008-08-23 19:55:27 UTC (rev 9136)
@@ -44,7 +44,7 @@
   enum ACTION {
   	SAVE,
 	SAVEAS,
More information about the QGIS-commit mailing list
