[QGIS Commit] r8744 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 9 06:37:11 EDT 2008
Author: timlinux
Date: 2008-07-09 06:37:11 -0400 (Wed, 09 Jul 2008)
New Revision: 8744
   trunk/qgis/src/app/qgsmaptoolidentify.cpp
Code formatting changes only
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp	2008-07-09 04:42:57 UTC (rev 8743)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp	2008-07-09 10:37:11 UTC (rev 8744)
@@ -47,7 +47,7 @@
   QPixmap myIdentifyQPixmap = QPixmap((const char **) identify_cursor);
   mCursor = QCursor(myIdentifyQPixmap, 1, 1);
 QgsMapToolIdentify::~QgsMapToolIdentify()
   if (mResults)
@@ -61,7 +61,7 @@
 void QgsMapToolIdentify::canvasMoveEvent(QMouseEvent * e)
 void QgsMapToolIdentify::canvasPressEvent(QMouseEvent * e)
@@ -69,12 +69,12 @@
 void QgsMapToolIdentify::canvasReleaseEvent(QMouseEvent * e)
   if(!mCanvas || mCanvas->isDrawing())
-      return;
+    return;
   QgsMapLayer* layer = mCanvas->currentLayer();
   // delete rubber band if there was any
   delete mRubberBand;
   mRubberBand = 0;
@@ -119,11 +119,11 @@
   else
     QMessageBox::warning(mCanvas,
-      QObject::tr("No active layer"),
-      QObject::tr("To identify features, you must choose an active layer by clicking on its name in the legend"));
+        QObject::tr("No active layer"),
+        QObject::tr("To identify features, you must choose an active layer by clicking on its name in the legend"));
@@ -131,10 +131,10 @@
   if (!layer)
     return;
   QMap<QString, QString> attributes;
   layer->identify(point, attributes);
   if(!mResults)
     QgsAttributeAction aa;
@@ -179,9 +179,9 @@
   QgsRect viewExtent = mCanvas->extent();
   double mupp = mCanvas->mupp();
   if(mupp == 0)
-      return;
+    return;
   double xMinView = viewExtent.xMin();
   double yMaxView = viewExtent.yMax();
@@ -192,26 +192,26 @@
   double i, j;
   if(xMinView < xMinLayer)
-      i = (int)(point.x() - (xMinLayer - xMinView) / mupp);
+    i = (int)(point.x() - (xMinLayer - xMinView) / mupp);
   else
-      i = point.x();
+    i = point.x();
   if(yMaxView > yMaxLayer)
-      j = (int)(point.y() - (yMaxView - yMaxLayer) / mupp);
+    j = (int)(point.y() - (yMaxView - yMaxLayer) / mupp);
   else
-      j = point.y();
+    j = point.y();
   QString text = layer->identifyAsText(QgsPoint(i, j));
   if (text.isEmpty())
     showError(layer);
@@ -229,7 +229,7 @@
   if (!layer)
     return;
   // load identify radius from settings
   QSettings settings;
   double identifyValue = settings.value("/Map/identifyRadius", QGis::DEFAULT_IDENTIFY_RADIUS).toDouble();
@@ -237,13 +237,13 @@
   // create the search rectangle
   double searchRadius = mCanvas->extent().width() * (identifyValue/100.0);
   QgsRect r;
   r.setXmin(point.x() - searchRadius);
   r.setXmax(point.x() + searchRadius);
   r.setYmin(point.y() - searchRadius);
   r.setYmax(point.y() + searchRadius);
   r = toLayerCoords(layer, r);
   int featureCount = 0;
@@ -258,104 +258,104 @@
   calc.setProjectionsEnabled(mCanvas->projectionsEnabled()); // project?
   calc.setEllipsoid(ellipsoid);
   calc.setSourceSRS(layer->srs().srsid());
   // display features falling within the search radius
   if(!mResults)
-      mResults = new QgsIdentifyResults(actions, mCanvas->window());
-      mResults->setAttribute(Qt::WA_DeleteOnClose);
-      // Be informed when the dialog box is closed so that we can stop using it.
-      connect(mResults, SIGNAL(accepted()), this, SLOT(resultsDialogGone()));
-      connect(mResults, SIGNAL(rejected()), this, SLOT(resultsDialogGone()));
-      connect(mResults, SIGNAL(selectedFeatureChanged(int)), this, SLOT(highlightFeature(int)));
-      // restore the identify window position and show it
-      mResults->restorePosition();
+    mResults = new QgsIdentifyResults(actions, mCanvas->window());
+    mResults->setAttribute(Qt::WA_DeleteOnClose);
+    // Be informed when the dialog box is closed so that we can stop using it.
+    connect(mResults, SIGNAL(accepted()), this, SLOT(resultsDialogGone()));
+    connect(mResults, SIGNAL(rejected()), this, SLOT(resultsDialogGone()));
+    connect(mResults, SIGNAL(selectedFeatureChanged(int)), this, SLOT(highlightFeature(int)));
+    // restore the identify window position and show it
+    mResults->restorePosition();
   else
-      mResults->raise();
-      mResults->clear();
-      mResults->setActions(actions);
+    mResults->raise();
+    mResults->clear();
+    mResults->setActions(actions);
   QApplication::setOverrideCursor(Qt::WaitCursor);
   int lastFeatureId = 0;
   QList<QgsFeature> featureList;
   layer->featuresInRectangle(r, featureList, true, true);
   QList<QgsFeature>::iterator f_it = featureList.begin();
   for(; f_it != featureList.end(); ++f_it)
+    featureCount++;
+    QTreeWidgetItem* featureNode = mResults->addNode("foo");
+    featureNode->setData(0, Qt::UserRole, QVariant(f_it->featureId())); // save feature id
+    lastFeatureId = f_it->featureId();
+    featureNode->setText(0, fieldIndex);
+    const QgsAttributeMap& attr = f_it->attributeMap();
+    for (QgsAttributeMap::const_iterator it = attr.begin(); it != attr.end(); ++it)
+      //QgsDebugMsg(it->fieldName() + " == " + fieldIndex);
+      if (fields[it.key()].name() == fieldIndex)
-	featureCount++;
-	QTreeWidgetItem* featureNode = mResults->addNode("foo");
-	featureNode->setData(0, Qt::UserRole, QVariant(f_it->featureId())); // save feature id
-	lastFeatureId = f_it->featureId();
-	featureNode->setText(0, fieldIndex);
-	const QgsAttributeMap& attr = f_it->attributeMap();
-	for (QgsAttributeMap::const_iterator it = attr.begin(); it != attr.end(); ++it)
-	    //QgsDebugMsg(it->fieldName() + " == " + fieldIndex);
-	    if (fields[it.key()].name() == fieldIndex)
-		featureNode->setText(1, it->toString());
-	    mResults->addAttribute(featureNode, fields[it.key()].name(), it->isNull() ? "NULL" : it->toString());
-	// Calculate derived attributes and insert:
-	// measure distance or area depending on geometry type
-	if (layer->vectorType() == QGis::Line)
-	    double dist = calc.measure(f_it->geometry());
-	    QString str = calc.textUnit(dist, 3, mCanvas->mapUnits(), false);
-	    mResults->addDerivedAttribute(featureNode, QObject::tr("Length"), str);
-	else if (layer->vectorType() == QGis::Polygon)
-	    double area = calc.measure(f_it->geometry());
-	    QString str = calc.textUnit(area, 3, mCanvas->mapUnits(), true);
-	    mResults->addDerivedAttribute(featureNode, QObject::tr("Area"), str);
-	// Add actions
-	QgsAttributeAction::aIter iter = actions.begin();
-	for (register int i = 0; iter != actions.end(); ++iter, ++i)
-	    mResults->addAction( featureNode, i, QObject::tr("action"), iter->name() );
+        featureNode->setText(1, it->toString());
-    QgsDebugMsg("Feature count on identify: " + QString::number(featureCount));
-    //also test the not commited features //todo: eliminate copy past code
-    mResults->setTitle(layer->name() + " - " + QString::number(featureCount) + QObject::tr(" features found"));
-    if (featureCount == 1)
-	mResults->showAllAttributes();
-	mResults->setTitle(layer->name() + " - " + QObject::tr(" 1 feature found") );
-	highlightFeature(lastFeatureId);
-    else if (featureCount == 0)
-	mResults->setTitle(layer->name() + " - " + QObject::tr("No features found") );
-	mResults->setMessage ( QObject::tr("No features found"), QObject::tr("No features were found in the active layer at the point you clicked") );
-    else
-	QString title = layer->name();
-	title += QString( tr("- %1 features found","Identify results window title",featureCount) ).arg(featureCount);
-	mResults->setTitle(title);
-    QApplication::restoreOverrideCursor();
-    mResults->show();
+      mResults->addAttribute(featureNode, fields[it.key()].name(), it->isNull() ? "NULL" : it->toString());
+    // Calculate derived attributes and insert:
+    // measure distance or area depending on geometry type
+    if (layer->vectorType() == QGis::Line)
+      double dist = calc.measure(f_it->geometry());
+      QString str = calc.textUnit(dist, 3, mCanvas->mapUnits(), false);
+      mResults->addDerivedAttribute(featureNode, QObject::tr("Length"), str);
+    else if (layer->vectorType() == QGis::Polygon)
+      double area = calc.measure(f_it->geometry());
+      QString str = calc.textUnit(area, 3, mCanvas->mapUnits(), true);
+      mResults->addDerivedAttribute(featureNode, QObject::tr("Area"), str);
+    // Add actions
+    QgsAttributeAction::aIter iter = actions.begin();
+    for (register int i = 0; iter != actions.end(); ++iter, ++i)
+      mResults->addAction( featureNode, i, QObject::tr("action"), iter->name() );
+  QgsDebugMsg("Feature count on identify: " + QString::number(featureCount));
+  //also test the not commited features //todo: eliminate copy past code
+  mResults->setTitle(layer->name() + " - " + QString::number(featureCount) + QObject::tr(" features found"));
+  if (featureCount == 1)
+    mResults->showAllAttributes();
+    mResults->setTitle(layer->name() + " - " + QObject::tr(" 1 feature found") );
+    highlightFeature(lastFeatureId);
+  else if (featureCount == 0)
+    mResults->setTitle(layer->name() + " - " + QObject::tr("No features found") );
+    mResults->setMessage ( QObject::tr("No features found"), QObject::tr("No features were found in the active layer at the point you clicked") );
+  else
+    QString title = layer->name();
+    title += QString( tr("- %1 features found","Identify results window title",featureCount) ).arg(featureCount);
+    mResults->setTitle(title);
+  QApplication::restoreOverrideCursor();
+  mResults->show();
 #if 0 //MH: old state of the function
@@ -363,7 +363,7 @@
   if (!layer)
     return;
   QSettings settings;
@@ -371,13 +371,13 @@
   QgsRect r;
@@ -387,7 +387,7 @@
   QgsVectorDataProvider* dataProvider = layer->getDataProvider();
   QgsAttributeList allAttributes = dataProvider->allAttributesList();
   const QgsFieldMap& fields = dataProvider->fields();
   dataProvider->select(allAttributes, r, true, true);
   // init distance/area calculator
@@ -395,7 +395,7 @@
   if ( !layer->isEditable() )
@@ -418,7 +418,7 @@
     QTreeWidgetItem *click = mResults->addNode(tr("(clicked coordinate)"));
@@ -433,11 +433,11 @@
       lastFeatureId = feat.featureId();
       const QgsAttributeMap& attr = feat.attributeMap();
@@ -500,7 +500,7 @@
     // Edit attributes
     // TODO: what to do if more features were selected? - nearest?
     QgsChangedAttributesMap& changedAttributes = layer->changedAttributes();
     if (dataProvider->getNextFeature(feat))
@@ -563,9 +563,9 @@
       QMessageBox::information(0, tr("No features found"),
-			       tr("<p>No features were found within the search radius. "
-				  "Note that it is currently not possible to use the "
-				  "identify tool on unsaved features.</p>"));
+          tr("<p>No features were found within the search radius. "
+            "Note that it is currently not possible to use the "
+            "identify tool on unsaved features.</p>"));
@@ -574,26 +574,26 @@
 void QgsMapToolIdentify::showError(QgsMapLayer * mapLayer)
-//   QMessageBox::warning(
-//     this,
-//     mapLayer->errorCaptionString(),
-//     tr("Could not draw") + " " + mapLayer->name() + " " + tr("because") + ":\n" +
-//       mapLayer->errorString()
+  //   QMessageBox::warning(
+  //     this,
+  //     mapLayer->errorCaptionString(),
+  //     tr("Could not draw") + " " + mapLayer->name() + " " + tr("because") + ":\n" +
+  //       mapLayer->errorString()
   QgsMessageViewer * mv = new QgsMessageViewer();
   mv->setWindowTitle( mapLayer->errorCaptionString() );
   mv->setMessageAsPlainText(
-    QObject::tr("Could not identify objects on") + " " + mapLayer->name() + " " + QObject::tr("because") + ":\n" +
-    mapLayer->errorString()
+      QObject::tr("Could not identify objects on") + " " + mapLayer->name() + " " + QObject::tr("because") + ":\n" +
+      mapLayer->errorString()
   mv->exec(); // deletes itself on close
 void QgsMapToolIdentify::resultsDialogGone()
   mResults = 0;
   delete mRubberBand;
   mRubberBand = 0;
@@ -610,23 +610,23 @@
   QgsVectorLayer* layer = dynamic_cast<QgsVectorLayer*>(mCanvas->currentLayer());
   if (!layer)
     return;
   delete mRubberBand;
   mRubberBand = 0;
   QgsFeature feat;
   if(layer->getFeatureAtId(featureId, feat, true, false) != 0)
-      return;
+    return;
   if(!feat.geometry())
-      return;
+    return;
   mRubberBand = new QgsRubberBand(mCanvas, feat.geometry()->vectorType() == QGis::Polygon);
   if (mRubberBand)
     mRubberBand->setToGeometry(feat.geometry(), *layer);
More information about the QGIS-commit mailing list
