[QGIS Commit] r8745 - trunk/qgis/src/gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 9 06:46:52 EDT 2008
Author: timlinux
Date: 2008-07-09 06:46:52 -0400 (Wed, 09 Jul 2008)
New Revision: 8745
   trunk/qgis/src/gui/qgsrubberband.cpp
Code formatting changes only
Modified: trunk/qgis/src/gui/qgsrubberband.cpp
--- trunk/qgis/src/gui/qgsrubberband.cpp	2008-07-09 10:37:11 UTC (rev 8744)
+++ trunk/qgis/src/gui/qgsrubberband.cpp	2008-07-09 10:46:52 UTC (rev 8745)
@@ -27,8 +27,8 @@
   \brief The QgsRubberBand class provides a transparent overlay widget
   for tracking the mouse while drawing polylines or polygons.
-QgsRubberBand::QgsRubberBand(QgsMapCanvas* mapCanvas, bool isPolygon)
-  : QgsMapCanvasItem(mapCanvas), mIsPolygon(isPolygon), mTranslationOffsetX(0.0), mTranslationOffsetY(0.0)
+  QgsRubberBand::QgsRubberBand(QgsMapCanvas* mapCanvas, bool isPolygon)
+: QgsMapCanvasItem(mapCanvas), mIsPolygon(isPolygon), mTranslationOffsetX(0.0), mTranslationOffsetY(0.0)
   reset(isPolygon);
   setColor(QColor(Qt::lightGray));
@@ -42,7 +42,7 @@
   Set the outline and fill color.
 void QgsRubberBand::setColor(const QColor & color)
   mPen.setColor(color);
@@ -53,7 +53,7 @@
   Set the outline width.
 void QgsRubberBand::setWidth(int width)
   mPen.setWidth(width);
@@ -61,7 +61,7 @@
   Remove all points from the shape being created.
 void QgsRubberBand::reset(bool isPolygon)
@@ -75,39 +75,39 @@
   Add a point to the shape being created.
 void QgsRubberBand::addPoint(const QgsPoint & p, bool do_update /* = true */, int geometryIndex)
   if(mPoints.size() < (geometryIndex + 1))
-      return;
+    return;
   //we need to set two points at the begin of the ruber band for operations that move the last point
   if(mPoints[geometryIndex].size() == 0)
-      mPoints[geometryIndex].push_back(p);
+    mPoints[geometryIndex].push_back(p);
   if (do_update)
-      updateRect();
-      update();
+    updateRect();
+    update();
 void QgsRubberBand::removeLastPoint(int geometryIndex)
-      return;
+    return;
   if(mPoints[geometryIndex].size() > 0)
-      mPoints[geometryIndex].pop_back();
+    mPoints[geometryIndex].pop_back();
   updateRect();
   update();
@@ -115,21 +115,21 @@
   Update the line between the last added point and the mouse position.
 void QgsRubberBand::movePoint(const QgsPoint & p, int geometryIndex)
-      return;
+    return;
   if(mPoints.at(geometryIndex).size() < 1)
-      return;
+    return;
   mPoints[geometryIndex][mPoints.at(geometryIndex).size() - 1] = p;
   updateRect();
   update();
@@ -137,17 +137,17 @@
 void QgsRubberBand::movePoint(int index, const QgsPoint& p, int geometryIndex)
-      return;
+    return;
   if(mPoints.at(geometryIndex).size() < index)
-      return;
+    return;
   mPoints[geometryIndex][index] = p;
   updateRect();
   update();
@@ -155,188 +155,188 @@
 void QgsRubberBand::setToGeometry(QgsGeometry* geom, QgsVectorLayer& layer)
   if(!geom)
-      return;
+    return;
   //maprender object of canvas
   QgsMapRender* mr = mMapCanvas->mapRender();
   if(!mr)
-      return;
+    return;
   reset(mIsPolygon);
   switch (geom->wkbType())
     case QGis::WKBPoint:
     case QGis::WKBPoint25D:
-	mIsPolygon = true;
-	double d = mMapCanvas->extent().width() * 0.005;
-	QgsPoint pt = mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, geom->asPoint());
-	addPoint(QgsPoint(pt.x()-d,pt.y()-d));
-	addPoint(QgsPoint(pt.x()+d,pt.y()-d));
-	addPoint(QgsPoint(pt.x()+d,pt.y()+d));
-	addPoint(QgsPoint(pt.x()-d,pt.y()+d));
+        mIsPolygon = true;
+        double d = mMapCanvas->extent().width() * 0.005;
+        QgsPoint pt = mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, geom->asPoint());
+        addPoint(QgsPoint(pt.x()-d,pt.y()-d));
+        addPoint(QgsPoint(pt.x()+d,pt.y()-d));
+        addPoint(QgsPoint(pt.x()+d,pt.y()+d));
+        addPoint(QgsPoint(pt.x()-d,pt.y()+d));
       break;
     case QGis::WKBMultiPoint:
     case QGis::WKBMultiPoint25D:
-	QgsMultiPoint mpt = geom->asMultiPoint();
-	for(int i = 0; i < mpt.size(); ++i)
-	    QgsPoint pt = mpt[i];
-	    addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()-d,pt.y()-d)));
-	    addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()+d,pt.y()-d)));
-	    addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()+d,pt.y()+d)));
-	    addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()-d,pt.y()+d)));
+        QgsMultiPoint mpt = geom->asMultiPoint();
+        for(int i = 0; i < mpt.size(); ++i)
+          QgsPoint pt = mpt[i];
+          addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()-d,pt.y()-d)));
+          addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()+d,pt.y()-d)));
+          addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()+d,pt.y()+d)));
+          addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, QgsPoint(pt.x()-d,pt.y()+d)));
       break;
     case QGis::WKBLineString:
     case QGis::WKBLineString25D:
-	mIsPolygon = false;
-	QgsPolyline line = geom->asPolyline();
-	for (int i = 0; i < line.count(); i++)
-	    addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, line[i]));
+        mIsPolygon = false;
+        QgsPolyline line = geom->asPolyline();
+        for (int i = 0; i < line.count(); i++)
+          addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, line[i]));
       break;
     case QGis::WKBMultiLineString:
     case QGis::WKBMultiLineString25D:
-	mPoints.clear();
-	QgsMultiPolyline mline = geom->asMultiPolyline();
-	for(int i = 0; i < mline.size(); ++i)
-	    QList<QgsPoint> newList;
-	    mPoints.push_back(newList);
-	    QgsPolyline line = mline[i];
-	    for(int j = 0; j < line.size(); ++j)
-		addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, line[j]), false, i);
+        mPoints.clear();
+        QgsMultiPolyline mline = geom->asMultiPolyline();
+        for(int i = 0; i < mline.size(); ++i)
+          QList<QgsPoint> newList;
+          mPoints.push_back(newList);
+          QgsPolyline line = mline[i];
+          for(int j = 0; j < line.size(); ++j)
+            addPoint(mr->layerCoordsToOutputCoords((QgsMapLayer*)&layer, line[j]), false, i);
       break;
     case QGis::WKBPolygon:
     case QGis::WKBPolygon25D:
-	QgsPolygon poly = geom->asPolygon();
-	QgsPolyline line = poly[0];
+        QgsPolygon poly = geom->asPolygon();
+        QgsPolyline line = poly[0];
       break;
     case QGis::WKBMultiPolygon:
     case QGis::WKBMultiPolygon25D:
-	mPoints.clear();
+        mPoints.clear();
-	QgsMultiPolygon multipoly = geom->asMultiPolygon();
-	for(int i = 0; i < multipoly.size(); ++i)
-	    QgsPolygon poly = multipoly[i];
-	    for(int j = 0; j < line.count(); ++j)
+        QgsMultiPolygon multipoly = geom->asMultiPolygon();
+        for(int i = 0; i < multipoly.size(); ++i)
+          QgsPolygon poly = multipoly[i];
+          for(int j = 0; j < line.count(); ++j)
       break;
     case QGis::WKBUnknown:
     default:
       return;
   updateRect();
   update();
   Draw the shape in response to an update event.
 void QgsRubberBand::paint(QPainter* p)
   QList<QgsPoint> currentList;
   if(mPoints.size() > 0)
+    p->setPen(mPen);
+    p->setBrush(mBrush);
+    for(int i = 0; i < mPoints.size(); ++i)
-      p->setPen(mPen);
-      p->setBrush(mBrush);
+      QPolygonF pts;
+      QList<QgsPoint>::const_iterator it = mPoints.at(i).constBegin();
+      for(; it != mPoints.at(i).constEnd(); ++it)
+        //QgsDebugMsg("Drawing rubberband vertex: " + QString::number(it->x() + mTranslationOffsetX) + "//" + QString::number(it->y() + mTranslationOffsetY));
+        pts.append(toCanvasCoords(QgsPoint(it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY))-pos());
-      for(int i = 0; i < mPoints.size(); ++i)
-	  QPolygonF pts;
-	  QList<QgsPoint>::const_iterator it = mPoints.at(i).constBegin();
-	  for(; it != mPoints.at(i).constEnd(); ++it)
-	      //QgsDebugMsg("Drawing rubberband vertex: " + QString::number(it->x() + mTranslationOffsetX) + "//" + QString::number(it->y() + mTranslationOffsetY));
-	      pts.append(toCanvasCoords(QgsPoint(it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY))-pos());
-	  if (mIsPolygon)
-	      p->drawPolygon(pts);
-	  else
-	      p->drawPolyline(pts);
+      if (mIsPolygon)
+        p->drawPolygon(pts);
+      else
+        p->drawPolyline(pts);
 void QgsRubberBand::updateRect()
+    //initial point
+    QList<QgsPoint>::const_iterator it = mPoints.at(0).constBegin();
+    if(it == mPoints.at(0).constEnd())
-      //initial point
-      QList<QgsPoint>::const_iterator it = mPoints.at(0).constBegin();
-      if(it == mPoints.at(0).constEnd())
-	      return;
-      QgsRect r(it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY, \
-		it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY);
+      return;
+    QgsRect r(it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY, \
+        it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY);
-	      r.combineExtentWith(it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY);
-	      //QgsDebugMsg("Combining extent with: " + QString::number(it->x()) + "//" + QString::number(it->y()));
-	  //QgsDebugMsg("r: " + r.stringRep());
-      setRect(r);
+        r.combineExtentWith(it->x() + mTranslationOffsetX, it->y() + mTranslationOffsetY);
+        //QgsDebugMsg("Combining extent with: " + QString::number(it->x()) + "//" + QString::number(it->y()));
+      //QgsDebugMsg("r: " + r.stringRep());
+    setRect(r);
   else
-      setRect(QgsRect());
+    setRect(QgsRect());
   setVisible(mPoints.size() > 0);
@@ -352,13 +352,13 @@
   int count = 0;
   QList<QList<QgsPoint> >::const_iterator it = mPoints.constBegin();
   for(;it != mPoints.constEnd(); ++it)
+    QList<QgsPoint>::const_iterator iter = it->constBegin();
+    for(;iter != it->constEnd(); ++iter)
-      QList<QgsPoint>::const_iterator iter = it->constBegin();
-      for(;iter != it->constEnd(); ++iter)
-	  ++count;
+      ++count;
   return count;
More information about the QGIS-commit mailing list
