[QGIS Commit] r8229 - branches/rendercontext-branch/src/core
svn_qgis at osgeo.org
Sun Mar 16 04:56:35 EDT 2008
Author: mhugent
Date: 2008-03-16 04:56:35 -0400 (Sun, 16 Mar 2008)
New Revision: 8229
Added:
branches/rendercontext-branch/src/core/qgsrendercontext.cpp
branches/rendercontext-branch/src/core/qgsrendercontext.h
branches/rendercontext-branch/src/core/CMakeLists.txt
Added initial implementation of QgsRenderContext. Not wired into rendering operations yet
Modified: branches/rendercontext-branch/src/core/CMakeLists.txt
--- branches/rendercontext-branch/src/core/CMakeLists.txt 2008-03-16 07:02:25 UTC (rev 8228)
+++ branches/rendercontext-branch/src/core/CMakeLists.txt 2008-03-16 08:56:35 UTC (rev 8229)
@@ -37,6 +37,7 @@
qgsproviderregistry.cpp
qgsrasterdataprovider.cpp
qgsrect.cpp
+qgsrendercontext.cpp
qgsrunprocess.cpp
qgsscalecalculator.cpp
qgssearchstring.cpp
Added: branches/rendercontext-branch/src/core/qgsrendercontext.cpp
--- branches/rendercontext-branch/src/core/qgsrendercontext.cpp (rev 0)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.cpp 2008-03-16 08:56:35 UTC (rev 8229)
@@ -0,0 +1,36 @@
+ qgsrendercontext.cpp
+ begin : March 16, 2008
+ copyright : (C) 2008 by Marco Hugentobler
+ email : marco dot hugentobler at karto dot baug dot ethz dot ch
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include "qgsrendercontext.h"
+QgsRenderContext::QgsRenderContext(): mCoordTransform(0), mDrawEditingInformation(false), mForceVectorOutput(true), mRenderingStopped(false)
+QgsRenderContext::~QgsRenderContext()
+ delete mCoordTransform;
+void QgsRenderContext::setCoordTransform(QgsCoordinateTransform* t)
+ mCoordTransform = t;
Added: branches/rendercontext-branch/src/core/qgsrendercontext.h
--- branches/rendercontext-branch/src/core/qgsrendercontext.h (rev 0)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.h 2008-03-16 08:56:35 UTC (rev 8229)
@@ -0,0 +1,84 @@
+ qgsrendercontext.h
+#ifndef QGSRENDERCONTEXT_H
+#define QGSRENDERCONTEXT_H
+#include "qgscoordinatetransform.h"
+#include "qgsmaptopixel.h"
+#include "qgsrect.h"
+/**Contains information about the context of a rendering operation*/
+class QgsRenderContext
+ public:
+ QgsRenderContext();
+ ~QgsRenderContext();
+ //getters
+ const QgsCoordinateTransform* coordTransform() const {return mCoordTransform;}
+ const QgsRect* extent() const {return &mExtent;}
+ const QgsMapToPixel* mapToPixel() const {return &mMapToPixel;}
+ double scaleFactor() const {return mScaleFactor;}
+ bool renderingStopped() const {return mRenderingStopped;}
+ bool forceVectorOutput() const {return mForceVectorOutput;}
+ bool drawEditingInformation() const {return mDrawEditingInformation;}
+ //setters
+ /**Sets coordinate transformation. QgsRenderContext takes ownership of the pointer and takes \
+ care of releasing the memory properly*/
+ void setCoordTransform(QgsCoordinateTransform* t);
+ void setMapToPixel(const QgsMapToPixel& mtp) {mMapToPixel = mtp;}
+ void setExtent(const QgsRect& extent){mExtent = extent;}
+ void setDrawEditingInformation(bool b){mDrawEditingInformation = b;}
+ void setRenderingStopped(bool stopped){mRenderingStopped = stopped;}
+ void setScaleFactor(double factor){mScaleFactor = factor;}
+ private:
+ //Copy constructor and assignement operator forbidden
+ QgsRenderContext(const QgsRenderContext& other){}
+ QgsRenderContext& operator=(const QgsRenderContext&){}
+ /**For transformation between coordinate systems. Can be 0 if on-the-fly reprojection is not used*/
+ QgsCoordinateTransform* mCoordTransform;
+ /**True if vertex markers for editing should be drawn*/
+ bool mDrawEditingInformation;
+ QgsRect mExtent;
+ /**If true then no rendered vector elements should be cached as image*/
+ bool mForceVectorOutput;
+ QgsMapToPixel mMapToPixel;
+ /**True if the rendering has been canceled*/
+ bool mRenderingStopped;
+ /**Factor to scale line widths and point marker sizes*/
+ double mScaleFactor;
+#endif
