[QGIS Commit] r8230 - in branches/rendercontext-branch: python/core src/app src/app/composer src/core src/core/raster src/gui src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Mar 16 12:04:52 EDT 2008
Author: mhugent
Date: 2008-03-16 12:04:52 -0400 (Sun, 16 Mar 2008)
New Revision: 8230
   branches/rendercontext-branch/python/core/qgsmaplayer.sip
   branches/rendercontext-branch/python/core/qgsrasterlayer.sip
   branches/rendercontext-branch/python/core/qgsvectorlayer.sip
   branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp
   branches/rendercontext-branch/src/app/qgsmaptoolselect.cpp
   branches/rendercontext-branch/src/core/qgscoordinatetransform.cpp
   branches/rendercontext-branch/src/core/qgscoordinatetransform.h
   branches/rendercontext-branch/src/core/qgsmaplayer.cpp
   branches/rendercontext-branch/src/core/qgsmaplayer.h
   branches/rendercontext-branch/src/core/qgsmaprender.cpp
   branches/rendercontext-branch/src/core/qgsmaprender.h
   branches/rendercontext-branch/src/core/qgsmaptopixel.cpp
   branches/rendercontext-branch/src/core/qgsmaptopixel.h
   branches/rendercontext-branch/src/core/qgsrendercontext.cpp
   branches/rendercontext-branch/src/core/qgsrendercontext.h
   branches/rendercontext-branch/src/core/qgsscalecalculator.cpp
   branches/rendercontext-branch/src/core/qgsscalecalculator.h
   branches/rendercontext-branch/src/core/qgsvectorlayer.cpp
   branches/rendercontext-branch/src/core/qgsvectorlayer.h
   branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp
   branches/rendercontext-branch/src/core/raster/qgsrasterlayer.h
   branches/rendercontext-branch/src/gui/qgsmapcanvas.cpp
   branches/rendercontext-branch/src/gui/qgsmapcanvas.h
   branches/rendercontext-branch/src/gui/qgsmapoverviewcanvas.cpp
   branches/rendercontext-branch/src/gui/qgsmaptoolzoom.cpp
   branches/rendercontext-branch/src/plugins/grass/qgsgrassedit.h
Started transition to render context for vector layer. Most things don't work at the moment (e.g. rasters, labels, print composer). Added a lot of consts to several methods
Modified: branches/rendercontext-branch/python/core/qgsmaplayer.sip
--- branches/rendercontext-branch/python/core/qgsmaplayer.sip	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/python/core/qgsmaplayer.sip	2008-03-16 16:04:52 UTC (rev 8230)
@@ -56,13 +56,9 @@
     const QString & name() const;
     /** Render the layer, to be overridden in child classes
-     * @param painter Painter that to be used for rendered output
-     * @param rect Extent of the layer to be drawn
-     * @param mtp Transformation class
-     * @return FALSE if an error occurred during drawing
-    virtual bool draw(QPainter* painter, QgsRect& rect, QgsMapToPixel* mtp, QgsCoordinateTransform* ct, bool);
+    virtual bool draw(QPainter* painter, const QgsRenderContext& renderContext);
     /** Draw labels
      * @TODO to be removed: used only in vector layers
Modified: branches/rendercontext-branch/python/core/qgsrasterlayer.sip
--- branches/rendercontext-branch/python/core/qgsrasterlayer.sip	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/python/core/qgsrasterlayer.sip	2008-03-16 16:04:52 UTC (rev 8230)
@@ -105,16 +105,8 @@
      QPixmap getPaletteAsPixmap();
     /** \brief This is called when the view on the rasterlayer needs to be refreshed (redrawn).
-        \param drawingToEditingCanvas  Are we drawing to an editable canvas?
-                                       currently not used, but retain to be similar to
-                                       the QgsVectorLayer interface
-    bool draw(QPainter * theQPainter,
-              QgsRect & theViewExtent,
-              QgsMapToPixel * theQgsMapToPixel,
-              QgsCoordinateTransform* ct,
-              bool drawingToEditingCanvas);
+    bool draw(QPainter* painter, const QgsRenderContext& renderContext);
     /** \brief This is an overloaded version of the above function that is called by both draw above and drawThumbnail */
     void draw(QPainter * theQPainter, QgsRasterViewPort * myRasterViewPort,
Modified: branches/rendercontext-branch/python/core/qgsvectorlayer.sip
--- branches/rendercontext-branch/python/core/qgsvectorlayer.sip	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/python/core/qgsvectorlayer.sip	2008-03-16 16:04:52 UTC (rev 8230)
@@ -273,14 +273,10 @@
   /** Draws the layer using coordinate transformation
-  bool draw(QPainter * p,
-            QgsRect & viewExtent,
-            QgsMapToPixel * cXf,
   /** Draws the layer labels using coordinate transformation */
-  void drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * cXf, QgsCoordinateTransform* ct);
+  void drawLabels(QPainter* painter, const QgsRenderContext& renderContext);
   /** \brief Draws the layer using coordinate transformation
    *  \param widthScale line width scale
@@ -294,11 +290,6 @@
             double widthScale,
             double symbolScale);
-  /** \brief Draws the layer labels using coordinate transformation
-   *  \param scale size scale, applied to all values in pixels
-  void drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * cXf, QgsCoordinateTransform* ct, double scale);
   /** returns array of added features */
   QList<QgsFeature>& addedFeatures();
Modified: branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp
--- branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/app/composer/qgscomposermap.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -183,13 +183,13 @@
         painter->save();
         painter->scale( 1./multip, 1./multip);
-        layer->draw( painter, extent, &trans, ct, FALSE);
+        //layer->draw( painter, extent, &trans, ct, FALSE);
         painter->restore();
       else
-        layer->draw( painter, extent, transform, ct, FALSE);
+        //layer->draw( painter, extent, transform, ct, FALSE);
Modified: branches/rendercontext-branch/src/app/qgsmaptoolselect.cpp
--- branches/rendercontext-branch/src/app/qgsmaptoolselect.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/app/qgsmaptoolselect.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -81,7 +81,7 @@
   mSelectRect.setRight(e->pos().x());
   mSelectRect.setBottom(e->pos().y());
-  QgsMapToPixel* transform = mCanvas->getCoordinateTransform();
+  const QgsMapToPixel* transform = mCanvas->getCoordinateTransform();
   QgsPoint ll = transform->toMapCoordinates(mSelectRect.left(), mSelectRect.bottom());
   QgsPoint ur = transform->toMapCoordinates(mSelectRect.right(), mSelectRect.top());
Modified: branches/rendercontext-branch/src/core/qgscoordinatetransform.cpp
--- branches/rendercontext-branch/src/core/qgscoordinatetransform.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgscoordinatetransform.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -208,7 +208,7 @@
-QgsPoint QgsCoordinateTransform::transform(const QgsPoint thePoint,TransformDirection direction)
+QgsPoint QgsCoordinateTransform::transform(const QgsPoint thePoint,TransformDirection direction) const
   if (mShortCircuit || !mInitialisedFlag) return thePoint;
   // transform x
@@ -233,7 +233,7 @@
-QgsPoint QgsCoordinateTransform::transform(const double theX, const double theY=0,TransformDirection direction)
+QgsPoint QgsCoordinateTransform::transform(const double theX, const double theY=0,TransformDirection direction) const
   try
@@ -247,7 +247,7 @@
-QgsRect QgsCoordinateTransform::transform(const QgsRect theRect,TransformDirection direction)
+QgsRect QgsCoordinateTransform::transform(const QgsRect theRect,TransformDirection direction) const
   if (mShortCircuit || !mInitialisedFlag) return theRect;
   // transform x
@@ -287,7 +287,7 @@
 void QgsCoordinateTransform::transformInPlace(double& x, double& y, double& z,
-    TransformDirection direction)
+    TransformDirection direction) const
     return;
@@ -309,7 +309,7 @@
 void QgsCoordinateTransform::transformInPlace(std::vector<double>& x,
     std::vector<double>& y, std::vector<double>& z,
     return;
@@ -334,7 +334,7 @@
-QgsRect QgsCoordinateTransform::transformBoundingBox(const QgsRect rect, TransformDirection direction)
+QgsRect QgsCoordinateTransform::transformBoundingBox(const QgsRect rect, TransformDirection direction) const
   // Calculate the bounding box of a QgsRect in the source SRS
   // when projected to the destination SRS (or the inverse).
@@ -409,7 +409,7 @@
   return bb_rect;
-void QgsCoordinateTransform::transformCoords( const int& numPoints, double *x, double *y, double *z,TransformDirection direction)
+void QgsCoordinateTransform::transformCoords( const int& numPoints, double *x, double *y, double *z,TransformDirection direction) const
   // Refuse to transform the points if the srs's are invalid
   if (!mSourceSRS.isValid())
Modified: branches/rendercontext-branch/src/core/qgscoordinatetransform.h
--- branches/rendercontext-branch/src/core/qgscoordinatetransform.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgscoordinatetransform.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -125,7 +125,7 @@
     * @param direction TransformDirection (defaults to FORWARD)
     * @return QgsPoint in Destination Coordinate System
-   QgsPoint transform(const QgsPoint p,TransformDirection direction=FORWARD);
+   QgsPoint transform(const QgsPoint p,TransformDirection direction=FORWARD) const;
     /*! Transform the point specified by x,y from Source Coordinate System to Destination Coordinate System
     * If the direction is FORWARD then coordinates are transformed from layer CS --> map canvas CS,
@@ -135,7 +135,7 @@
-   QgsPoint transform(const double x, const double y,TransformDirection direction=FORWARD);
+   QgsPoint transform(const double x, const double y,TransformDirection direction=FORWARD) const;
     /*! Transform a QgsRect to the dest Coordinate system
@@ -147,15 +147,15 @@
     * @return QgsRect in Destination Coordinate System
-   QgsRect transformBoundingBox(const QgsRect theRect,TransformDirection direction=FORWARD);
+   QgsRect transformBoundingBox(const QgsRect theRect,TransformDirection direction=FORWARD) const;
    // Same as for the other transform() functions, but alters the x
    // and y variables in place. The second one works with good old-fashioned
    // C style arrays.
-   void transformInPlace(double& x, double& y, double &z, TransformDirection direction = FORWARD);
+   void transformInPlace(double& x, double& y, double &z, TransformDirection direction = FORWARD) const;
    void transformInPlace(std::vector<double>& x, std::vector<double>& y, std::vector<double>& z,
-       TransformDirection direction = FORWARD);
+       TransformDirection direction = FORWARD) const;
@@ -164,7 +164,7 @@
-   QgsRect transform(const QgsRect theRect,TransformDirection direction=FORWARD);
+   QgsRect transform(const QgsRect theRect,TransformDirection direction=FORWARD) const;
     /*! Transform an array of coordinates to a different Coordinate System
@@ -174,7 +174,7 @@
-   void transformCoords( const int &numPoint, double *x, double *y, double *z,TransformDirection direction=FORWARD);
+   void transformCoords( const int &numPoint, double *x, double *y, double *z,TransformDirection direction=FORWARD) const;
    * Flag to indicate whether the coordinate systems have been initialised
@@ -217,7 +217,7 @@
  signals:
     /** Signal when an invalid pj_transform() has occured */
-    void  invalidTransformInput();
+    void  invalidTransformInput() const;
  private:
Modified: branches/rendercontext-branch/src/core/qgsmaplayer.cpp
--- branches/rendercontext-branch/src/core/qgsmaplayer.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsmaplayer.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -32,7 +32,6 @@
 #include "qgslogger.h"
-#include "qgsmaptopixel.h"
 #include "qgsrect.h"
 #include "qgssymbol.h"
 #include "qgsmaplayer.h"
@@ -127,14 +126,12 @@
     return mLayerExtent;
-bool QgsMapLayer::draw(QPainter *, QgsRect &, QgsMapToPixel *, QgsCoordinateTransform *, bool)
+bool QgsMapLayer::draw(QPainter* painter, const QgsRenderContext& renderContext)
-    //  std::cout << "In QgsMapLayer::draw" << std::endl;
-    return false;
+  return false;
-void QgsMapLayer::drawLabels(QPainter *, QgsRect &, QgsMapToPixel *, QgsCoordinateTransform *)
+void QgsMapLayer::drawLabels(QPainter* painter, const QgsRenderContext& renderContext)
Modified: branches/rendercontext-branch/src/core/qgsmaplayer.h
--- branches/rendercontext-branch/src/core/qgsmaplayer.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsmaplayer.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -26,8 +26,7 @@
-class QgsCoordinateTransform;
-class QgsMapToPixel;
+class QgsRenderContext;
 class QgsSpatialRefSys;
 class QDomNode;
@@ -72,18 +71,12 @@
     QString const & name() const;
-    /** Render the layer, to be overridden in child classes
     /** Draw labels
-    virtual void drawLabels(QPainter* painter, QgsRect& rect, QgsMapToPixel* mtp, QgsCoordinateTransform* ct);
+    virtual void drawLabels(QPainter* painter, const QgsRenderContext& renderContext);
     /** Return the extent of the layer as a QRect */
     const QgsRect extent();
Modified: branches/rendercontext-branch/src/core/qgsmaprender.cpp
--- branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsmaprender.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -36,7 +36,6 @@
 QgsMapRender::QgsMapRender()
-  mCoordXForm = new QgsMapToPixel;
   mScaleCalculator = new QgsScaleCalculator;
   mDistArea = new QgsDistanceArea;
@@ -55,7 +54,6 @@
 QgsMapRender::~QgsMapRender()
-  delete mCoordXForm;
   delete mScaleCalculator;
   delete mDistArea;
   delete mDestSRS;
@@ -64,12 +62,13 @@
 QgsRect QgsMapRender::extent()
-  return mExtent;
+  return mRenderContext.extent();
 void QgsMapRender::updateScale()
-  mScale = mScaleCalculator->calculate(mExtent, mSize.width());
+  mScale = mScaleCalculator->calculate(mRenderContext.extent(), mSize.width());
 bool QgsMapRender::setExtent(const QgsRect& extent)
@@ -104,8 +103,8 @@
       return false;
-  mExtent = extent;
-  if (!mExtent.isEmpty())
+  mRenderContext.setExtent(extent);
+  if (!extent.isEmpty())
     adjustExtentToSize();
   return true;
@@ -131,19 +130,22 @@
   int myHeight = mSize.height();
   int myWidth = mSize.width();
+  QgsMapToPixel newCoordXForm;
+  QgsRect theExtent = mRenderContext.extent();
   if (!myWidth || !myHeight)
     mScale = 1;
-    mCoordXForm->setParameters(0, 0, 0, 0);
+    newCoordXForm.setParameters(0, 0, 0, 0);
     return;
   // calculate the translation and scaling parameters
   // mupp = map units per pixel
-  double muppY = static_cast<double>(mExtent.height())
+  double muppY = static_cast<double>(theExtent.height())
                / static_cast<double>(myHeight);
-  double muppX = static_cast<double>(mExtent.width())
+  double muppX = static_cast<double>(theExtent.width())
                / static_cast<double>(myWidth);
   mMupp = muppY > muppX ? muppY : muppX;
@@ -152,39 +154,39 @@
   if (muppY > muppX)
-    dymin = mExtent.yMin();
-    dymax = mExtent.yMax();
-    whitespace = ((myWidth * mMupp) - mExtent.width()) * 0.5;
-    dxmin = mExtent.xMin() - whitespace;
-    dxmax = mExtent.xMax() + whitespace;
+    dymin = theExtent.yMin();
+    dymax = theExtent.yMax();
+    whitespace = ((myWidth * mMupp) - theExtent.width()) * 0.5;
+    dxmin = theExtent.xMin() - whitespace;
+    dxmax = theExtent.xMax() + whitespace;
   else
-    dxmin = mExtent.xMin();
-    dxmax = mExtent.xMax();
-    whitespace = ((myHeight * mMupp) - mExtent.height()) * 0.5;
-    dymin = mExtent.yMin() - whitespace;
-    dymax = mExtent.yMax() + whitespace;
+    dxmin = theExtent.xMin();
+    dxmax = theExtent.xMax();
+    whitespace = ((myHeight * mMupp) - theExtent.height()) * 0.5;
+    dymin = theExtent.yMin() - whitespace;
+    dymax = theExtent.yMax() + whitespace;
 #ifdef QGISDEBUG
   QgsDebugMsg("========== Current Scale ==========");
-  QgsDebugMsg("Current extent is " + mExtent.stringRep());
+  QgsDebugMsg("Current extent is " + theExtent.stringRep());
   QgsLogger::debug("MuppX", muppX, 1, __FILE__, __FUNCTION__, __LINE__);
   QgsLogger::debug("MuppY", muppY, 1, __FILE__, __FUNCTION__, __LINE__);
   QgsLogger::debug("Pixmap width", myWidth, 1, __FILE__, __FUNCTION__, __LINE__);
   QgsLogger::debug("Pixmap height", myHeight, 1, __FILE__, __FUNCTION__, __LINE__);
-  QgsLogger::debug("Extent width", mExtent.width(), 1, __FILE__, __FUNCTION__, __LINE__);
-  QgsLogger::debug("Extent height", mExtent.height(), 1, __FILE__, __FUNCTION__, __LINE__);
+  QgsLogger::debug("Extent width", theExtent.width(), 1, __FILE__, __FUNCTION__, __LINE__);
+  QgsLogger::debug("Extent height", theExtent.height(), 1, __FILE__, __FUNCTION__, __LINE__);
   QgsLogger::debug("whitespace: ", whitespace, 1, __FILE__, __FUNCTION__, __LINE__);
 #endif
   // update extent
-  mExtent.setXmin(dxmin);
-  mExtent.setXmax(dxmax);
-  mExtent.setYmin(dymin);
-  mExtent.setYmax(dymax);
+  theExtent.setXmin(dxmin);
+  theExtent.setXmax(dxmax);
+  theExtent.setYmin(dymin);
+  theExtent.setYmax(dymax);
   // update the scale
   updateScale();
@@ -193,7 +195,9 @@
   QgsLogger::debug("Scale (assuming meters as map units) = 1", mScale, 1, __FILE__, __FUNCTION__, __LINE__);
 #endif
-  mCoordXForm->setParameters(mMupp, dxmin, dymin, myHeight);
+  newCoordXForm.setParameters(mMupp, dxmin, dymin, myHeight);
+  mRenderContext.setMapToPixel(newCoordXForm);
+  mRenderContext.setExtent(theExtent);
@@ -201,7 +205,7 @@
   QgsDebugMsg("========== Rendering ==========");
-  if (mExtent.isEmpty())
+  if (mRenderContext.extent().isEmpty())
     QgsLogger::debug("empty extent... not rendering");
     return;
@@ -258,7 +262,8 @@
       connect(ml, SIGNAL(drawingProgress(int,int)), this, SLOT(onDrawingProgress(int,int)));
-      QgsRect r1 = mExtent, r2;
+      QgsRect r1 = mRenderContext.extent();
+      QgsRect r2;
       bool split = splitLayersExtent(ml, r1, r2);
                   // Now do the call to the layer that actually does
@@ -273,14 +278,20 @@
         ct = NULL;
+      mRenderContext.setCoordTransform(ct);
+      mRenderContext.setDrawEditingInformation(!mOverview);
+      if (!ml->draw(painter, mRenderContext))
+	  emit drawError(ml);
-      if (!ml->draw(painter, r1, mCoordXForm, ct, !mOverview))
-        emit drawError(ml);
       if (split)
-        if (!ml->draw(painter, r2, mCoordXForm, ct, !mOverview))
+	//todo: set render context extent to r2
+        //if (!ml->draw(painter, r2, mCoordXForm, ct, !mOverview))
+	//emit drawError(ml);
       delete ct;
@@ -315,7 +326,9 @@
         if ((ml->scaleBasedVisibility() && ml->minScale() < mScale  && ml->maxScale() > mScale)
             || (!ml->scaleBasedVisibility()))
+	  QgsRect r2;
           if (projectionsEnabled())
@@ -327,9 +340,9 @@
             ct = NULL;
-          ml->drawLabels(painter, r1, mCoordXForm, ct);
+          //ml->drawLabels(painter, r1, mCoordXForm, ct);
           if (split)
-            ml->drawLabels(painter, r2, mCoordXForm, ct);
+            //ml->drawLabels(painter, r2, mCoordXForm, ct);
           delete ct;
Modified: branches/rendercontext-branch/src/core/qgsmaprender.h
--- branches/rendercontext-branch/src/core/qgsmaprender.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsmaprender.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -21,6 +21,7 @@
 #include "qgis.h"
+#include "qgsrendercontext.h"
 class QDomDocument;
 class QDomNode;
@@ -59,7 +60,7 @@
     //! returns current extent
     QgsRect extent();
-    QgsMapToPixel* coordXForm() { return mCoordXForm; }
+    const QgsMapToPixel* coordXForm() { return &(mRenderContext.mapToPixel()); }
     double scale() const { return mScale; }
     double mupp() const { return mMupp; }
@@ -127,6 +128,9 @@
     //! write settings
     bool writeXML(QDomNode & theNode, QDomDocument & theDoc);
+    //! Accessor for render context
+    QgsRenderContext* renderContext(){return &mRenderContext;}
   signals:
     void drawingProgress(int current, int total);
@@ -175,10 +179,10 @@
     QgsScaleCalculator * mScaleCalculator;
     //! utility class for transformation between map and pixmap units
-    QgsMapToPixel* mCoordXForm;
+    //QgsMapToPixel* mCoordXForm; //in mRenderContext
     //! current extent to be drawn
-    QgsRect mExtent;
+    //QgsRect mExtent; //in mRenderContext
     //! indicates whether it's map image for overview
     bool mOverview;
@@ -199,6 +203,9 @@
     //! tool for measuring
     QgsDistanceArea* mDistArea;
+    //!Encapsulates context of rendering
+    QgsRenderContext mRenderContext;
 #endif
Modified: branches/rendercontext-branch/src/core/qgsmaptopixel.cpp
--- branches/rendercontext-branch/src/core/qgsmaptopixel.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsmaptopixel.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -36,20 +36,20 @@
-QgsPoint QgsMapToPixel::toMapPoint(int x, int y)
+QgsPoint QgsMapToPixel::toMapPoint(int x, int y) const
   double mx = x * mMapUnitsPerPixel + xMin;
   double my = -1 * ((y - yMax) * mMapUnitsPerPixel - yMin);
   return QgsPoint(mx, my);
-QgsPoint QgsMapToPixel::toMapCoordinates(QPoint p)
+QgsPoint QgsMapToPixel::toMapCoordinates(QPoint p) const
   QgsPoint mapPt = toMapPoint(p.x(), p.y());
   return QgsPoint(mapPt);
-QgsPoint QgsMapToPixel::toMapCoordinates(int x, int y)
+QgsPoint QgsMapToPixel::toMapCoordinates(int x, int y) const
   return toMapPoint(x, y);
@@ -98,13 +98,13 @@
-QgsPoint QgsMapToPixel::transform(double x, double y)
+QgsPoint QgsMapToPixel::transform(double x, double y) const
   transformInPlace(x,y);
   return QgsPoint(x,y);
-QgsPoint QgsMapToPixel::transform(const QgsPoint& p)
+QgsPoint QgsMapToPixel::transform(const QgsPoint& p) const
   double dx = p.x();
   double dy = p.y();
@@ -114,7 +114,7 @@
   return QgsPoint(dx, dy);
-void QgsMapToPixel::transform(QgsPoint* p)
+void QgsMapToPixel::transform(QgsPoint* p) const
   double x = p->x();
   double y = p->y();
@@ -126,14 +126,14 @@
   p->set(x,y);
-void QgsMapToPixel::transformInPlace(double& x, double& y)
+void QgsMapToPixel::transformInPlace(double& x, double& y) const
   x = (x - xMin) / mMapUnitsPerPixel;
   y = yMax - (y - yMin) / mMapUnitsPerPixel;
 void QgsMapToPixel::transformInPlace(std::vector<double>& x,
-					    std::vector<double>& y)
+					    std::vector<double>& y) const
   assert(x.size() == y.size());
   for (unsigned int i = 0; i < x.size(); ++i)
Modified: branches/rendercontext-branch/src/core/qgsmaptopixel.h
--- branches/rendercontext-branch/src/core/qgsmaptopixel.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsmaptopixel.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -47,15 +47,15 @@
     * @param p Point to transform
     * @return QgsPoint in device coordinates
-    QgsPoint transform(const QgsPoint& p);
-    void transform(QgsPoint* p);
+    QgsPoint transform(const QgsPoint& p) const;
+    void transform(QgsPoint* p) const;
     /*! Transform the point specified by x,y from map (world)
      * coordinates to device coordinates
      * @param x x cordinate o point to transform
      * @param y y coordinate of point to transform
-    QgsPoint transform(double x, double y);
+    QgsPoint transform(double x, double y) const;
        /*! Tranform device coordinates to map (world)  coordinates
     * @param x x coordinate of point to be converted to map cooordinates
     * @param y y coordinate of point to be converted to map cooordinates
@@ -65,22 +65,22 @@
     /* Transform device coordinates to map coordinates. Modifies the
        given coordinates in place. Intended as a fast way to do the
        transform. */
-    void transformInPlace(double& x, double& y);
+    void transformInPlace(double& x, double& y) const;
        transform. */
-			  std::vector<double>& y);
+			  std::vector<double>& y) const;
-    QgsPoint toMapCoordinates(int x, int y);
+    QgsPoint toMapCoordinates(int x, int y) const;
     * @param p Point to be converted to map cooordinates
     * @return QgsPoint in map coorndiates
-    QgsPoint toMapCoordinates(QPoint p);
+    QgsPoint toMapCoordinates(QPoint p) const;
-    QgsPoint toMapPoint(int x, int y);
+    QgsPoint toMapPoint(int x, int y) const;
     /*! Set map units per pixel
     * @param mupp Map units per pixel
Modified: branches/rendercontext-branch/src/core/qgsrendercontext.cpp
--- branches/rendercontext-branch/src/core/qgsrendercontext.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -18,7 +18,7 @@
-QgsRenderContext::QgsRenderContext(): mCoordTransform(0), mDrawEditingInformation(false), mForceVectorOutput(true), mRenderingStopped(false)
+QgsRenderContext::QgsRenderContext(): mCoordTransform(0), mDrawEditingInformation(false), mForceVectorOutput(true), mRenderingStopped(false), mScaleFactor(1.0)
Modified: branches/rendercontext-branch/src/core/qgsrendercontext.h
--- branches/rendercontext-branch/src/core/qgsrendercontext.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsrendercontext.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -32,9 +32,9 @@
   //getters
   const QgsCoordinateTransform* coordTransform() const {return mCoordTransform;}
-  const QgsRect* extent() const {return &mExtent;}
+  const QgsRect& extent() const {return mExtent;}
-  const QgsMapToPixel* mapToPixel() const {return &mMapToPixel;}
+  const QgsMapToPixel& mapToPixel() const {return mMapToPixel;}
   double scaleFactor() const {return mScaleFactor;}
Modified: branches/rendercontext-branch/src/core/qgsscalecalculator.cpp
--- branches/rendercontext-branch/src/core/qgsscalecalculator.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsscalecalculator.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -50,7 +50,7 @@
   return mMapUnits;
-double QgsScaleCalculator::calculate(QgsRect &mapExtent, int canvasWidth)
+double QgsScaleCalculator::calculate(const QgsRect &mapExtent, int canvasWidth)
   double conversionFactor = 0;
   double delta = 0;
@@ -87,7 +87,7 @@
-double  QgsScaleCalculator::calculateGeographicDistance(QgsRect &mapExtent)
+double  QgsScaleCalculator::calculateGeographicDistance(const QgsRect &mapExtent)
   // need to calculate the x distance in meters
   // We'll use the middle latitude for the calculation
Modified: branches/rendercontext-branch/src/core/qgsscalecalculator.h
--- branches/rendercontext-branch/src/core/qgsscalecalculator.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsscalecalculator.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -72,7 +72,7 @@
      * @param canvasWidth Width of the map canvas in pixel (physical) units
      * @return scale of current map view
-    double calculate(QgsRect &mapExtent, int canvasWidth);
+    double calculate(const QgsRect &mapExtent, int canvasWidth);
      * Calculate the distance between two points in geographic coordinates.
@@ -80,7 +80,7 @@
      * data.
      * @param mapExtent QgsRect containing the current map extent
-    double calculateGeographicDistance(QgsRect &mapExtent);
+    double calculateGeographicDistance(const QgsRect &mapExtent);
   private:
Modified: branches/rendercontext-branch/src/core/qgsvectorlayer.cpp
--- branches/rendercontext-branch/src/core/qgsvectorlayer.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsvectorlayer.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -63,6 +63,7 @@
 #include "qgspoint.h"
 #include "qgsproviderregistry.h"
 #include "qgssinglesymbolrenderer.h"
 #include "qgsspatialrefsys.h"
 #include "qgsvectordataprovider.h"
@@ -275,9 +276,12 @@
-void QgsVectorLayer::drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * theMapToPixelTransform, QgsCoordinateTransform* ct)
+//void QgsVectorLayer::drawLabels(QPainter * p, QgsRect & viewExtent, QgsMapToPixel * theMapToPixelTransform, QgsCoordinateTransform* ct)
+void QgsVectorLayer::drawLabels(QPainter* painter, const QgsRenderContext& renderContext)
+#if 0 //todo: adapt to render context
   drawLabels(p, viewExtent, theMapToPixelTransform, ct, 1.);
+#endif //0
 // NOTE this is a temporary method added by Tim to prevent label clipping
@@ -351,8 +355,8 @@
 unsigned char* QgsVectorLayer::drawLineString(unsigned char* feature,
     QPainter* p,
-    QgsMapToPixel* mtp,
+    const QgsMapToPixel* mtp,
+    const QgsCoordinateTransform* ct,
   unsigned char *ptr = feature + 5;
@@ -458,8 +462,8 @@
 unsigned char* QgsVectorLayer::drawPolygon(unsigned char* feature,
     QPainter* p,
   typedef std::pair<std::vector<double>, std::vector<double> > ringType;
@@ -707,25 +711,22 @@
   return ptr;
-bool QgsVectorLayer::draw(QPainter * p,
-                          QgsMapToPixel * theMapToPixelTransform,
+bool QgsVectorLayer::draw(QPainter* painter, const QgsRenderContext& renderContext)
   //set update threshold before each draw to make sure the current setting is picked up
   QSettings settings;
   mUpdateThreshold = settings.readNumEntry("Map/updateThreshold", 0);
-  draw ( p, viewExtent, theMapToPixelTransform, ct, drawingToEditingCanvas, 1., 1.);
+  //draw ( p, viewExtent, theMapToPixelTransform, ct, drawingToEditingCanvas, 1., 1.);
+  draw(painter, renderContext.extent(), &(renderContext.mapToPixel()), renderContext.coordTransform(), \
+       renderContext.drawEditingInformation(), renderContext.scaleFactor(), renderContext.scaleFactor());
   return TRUE; // Assume success always
 void QgsVectorLayer::draw(QPainter * p,
+                          const QgsRect& viewExtent,
+                          const QgsMapToPixel * theMapToPixelTransform,
                           bool drawingToEditingCanvas,
                           double widthScale,
                           double symbolScale)
@@ -2935,8 +2936,8 @@
 void QgsVectorLayer::drawFeature(QPainter* p,
                                  QgsFeature& fet,
+                                 const QgsMapToPixel* theMapToPixelTransform,
                                  QImage * marker,
                                  double markerScaleFactor,
@@ -3187,8 +3188,8 @@
 // Convenience function to transform the given point
 inline void QgsVectorLayer::transformPoint(double& x,
     double& y,
-    QgsCoordinateTransform* ct)
+    const QgsCoordinateTransform* ct)
   // transform the point
   if (ct)
@@ -3204,7 +3205,7 @@
 inline void QgsVectorLayer::transformPoints(
-    QgsMapToPixel* mtp, QgsCoordinateTransform* ct)
+    const QgsMapToPixel* mtp, const QgsCoordinateTransform* ct)
   if (ct)
Modified: branches/rendercontext-branch/src/core/qgsvectorlayer.h
--- branches/rendercontext-branch/src/core/qgsvectorlayer.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/qgsvectorlayer.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -33,6 +33,7 @@
 class QImage;
 class QgsAttributeAction;
+class QgsCoordinateTransform;
 class QgsField;
 class QgsFeature;
 class QgsGeometry;
@@ -333,26 +334,22 @@
                               const QgsNewAttributesMap& added,
                               const QgsChangedAttributesMap& changed);
-  /** Draws the layer using coordinate transformation
+  /** Draws the layer
    *  \param symbolScale symbol scale
   void draw(QPainter * p,
+            const QgsMapToPixel * cXf,
             double widthScale,
@@ -439,26 +436,26 @@
   void drawFeature(QPainter* p,
                    QgsFeature& fet,
+                   const QgsMapToPixel* cXf,
                    QImage* marker,
   /** Convenience function to transform the given point */
   void transformPoint(double& x, double& y,
-                      QgsMapToPixel* mtp, QgsCoordinateTransform* ct);
+                      const QgsMapToPixel* mtp, const QgsCoordinateTransform* ct);
   void transformPoints(std::vector<double>& x, std::vector<double>& y, std::vector<double>& z,
   /** Draw the linestring as given in the WKB format. Returns a pointer
    * to the byte after the end of the line string binary data stream (WKB).
   unsigned char* drawLineString(unsigned char* WKBlinestring,
                                 QPainter* p,
   /** Draw the polygon as given in the WKB format. Returns a pointer to
@@ -466,8 +463,8 @@
   unsigned char* drawPolygon(unsigned char* WKBpolygon,
                              QPainter* p,
   /** Goes through all features and finds a free id (e.g. to give it temporarily to a not-commited feature) */
Modified: branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp
--- branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/raster/qgsrasterlayer.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -1000,14 +1000,9 @@
-bool QgsRasterLayer::draw(QPainter * theQPainter,
-    QgsCoordinateTransform*,
+bool QgsRasterLayer::draw(QPainter* painter, const QgsRenderContext& renderContext)
   QgsDebugMsg("QgsRasterLayer::draw(4 arguments): entered.");
   //Dont waste time drawing if transparency is at 0 (completely transparent)
@@ -1283,6 +1278,7 @@
   delete myRasterViewPort;
   QgsDebugMsg("QgsRasterLayer::draw: exiting.");
+#endif //0
   return TRUE;
Modified: branches/rendercontext-branch/src/core/raster/qgsrasterlayer.h
--- branches/rendercontext-branch/src/core/raster/qgsrasterlayer.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/core/raster/qgsrasterlayer.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -158,6 +158,7 @@
 // Forward declarations
 class QgsColorTable;
+class QgsMapToPixel;
 class QgsRect;
 class QgsRasterBandStats;
 class QgsRasterPyramid;
@@ -275,16 +276,8 @@
Modified: branches/rendercontext-branch/src/gui/qgsmapcanvas.cpp
--- branches/rendercontext-branch/src/gui/qgsmapcanvas.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/gui/qgsmapcanvas.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -213,7 +213,7 @@
 // return the current coordinate transform based on the extents and
 // device size
-QgsMapToPixel * QgsMapCanvas::getCoordinateTransform()
+const QgsMapToPixel * QgsMapCanvas::getCoordinateTransform()
   return mMapRender->coordXForm();
Modified: branches/rendercontext-branch/src/gui/qgsmapcanvas.h
--- branches/rendercontext-branch/src/gui/qgsmapcanvas.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/gui/qgsmapcanvas.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -198,7 +198,7 @@
     QGis::units mapUnits() const;
     //! Get the current coordinate transform
-    QgsMapToPixel * getCoordinateTransform();
+    const QgsMapToPixel* getCoordinateTransform();
     //! true if canvas currently drawing
     bool isDrawing();
Modified: branches/rendercontext-branch/src/gui/qgsmapoverviewcanvas.cpp
--- branches/rendercontext-branch/src/gui/qgsmapoverviewcanvas.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/gui/qgsmapoverviewcanvas.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -99,7 +99,7 @@
     return;
-  QgsMapToPixel* cXf = mMapRender->coordXForm();
+  const QgsMapToPixel* cXf = mMapRender->coordXForm();
   QgsPoint ll(extent.xMin(), extent.yMin());
   QgsPoint ur(extent.xMax(), extent.yMax());
   if(cXf)
@@ -183,7 +183,7 @@
   if ((e->state() && Qt::LeftButton) == Qt::LeftButton)
     // set new extent
     QRect rect = mPanningWidget->geometry();
     QgsPoint center = cXf->toMapCoordinates(rect.center());
Modified: branches/rendercontext-branch/src/gui/qgsmaptoolzoom.cpp
--- branches/rendercontext-branch/src/gui/qgsmaptoolzoom.cpp	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/gui/qgsmaptoolzoom.cpp	2008-03-16 16:04:52 UTC (rev 8230)
@@ -76,7 +76,7 @@
     mZoomRect.setRight(e->pos().x());
     mZoomRect.setBottom(e->pos().y());
-    QgsMapToPixel *coordXForm = mCanvas->getCoordinateTransform();
+    const QgsMapToPixel* coordXForm = mCanvas->getCoordinateTransform();
     // set the extent to the zoomBox
     QgsPoint ll = coordXForm->toMapCoordinates(mZoomRect.left(), mZoomRect.bottom());
Modified: branches/rendercontext-branch/src/plugins/grass/qgsgrassedit.h
--- branches/rendercontext-branch/src/plugins/grass/qgsgrassedit.h	2008-03-16 08:56:35 UTC (rev 8229)
+++ branches/rendercontext-branch/src/plugins/grass/qgsgrassedit.h	2008-03-16 16:04:52 UTC (rev 8230)
@@ -330,7 +330,7 @@
     //QPixmap *mBackgroundPixmap;
     //! Transformation
-    QgsMapToPixel *mTransform;
+    const QgsMapToPixel* mTransform;
     //! Last point where user clicked (map units)
     QgsPoint mLastPoint;
More information about the QGIS-commit mailing list
