[QGIS Commit] r8484 - trunk/qgis/src/core
    svn_qgis at osgeo.org
    Wed May 21 13:22:55 EDT 2008
Author: timlinux
Date: 2008-05-21 13:22:55 -0400 (Wed, 21 May 2008)
New Revision: 8484
   trunk/qgis/src/core/qgsapplication.cpp
   trunk/qgis/src/core/qgsapplication.h
Added show settings to show application var state when debugging
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp	2008-05-21 17:20:58 UTC (rev 8483)
+++ trunk/qgis/src/core/qgsapplication.cpp	2008-05-21 17:22:55 UTC (rev 8484)
@@ -51,21 +51,16 @@
 QgsApplication::QgsApplication(int & argc, char ** argv, bool GUIenabled)
 : QApplication(argc, argv, GUIenabled)
-  QgsDebugMsg("\n**********************************");
-  QgsDebugMsg("\nInitialising QgsApplication...");
 #if defined(Q_WS_MACX) || defined(Q_WS_WIN32) || defined(WIN32)
   setPrefixPath(applicationDirPath(), true);
 #else
   QDir myDir(applicationDirPath());
   myDir.cdUp();
   QString myPrefix = myDir.absolutePath();
-  QgsDebugMsg("Prefix: " +  myPrefix.toLocal8Bit());
   setPrefixPath(myPrefix, true);
 #endif
-  QgsDebugMsg("\nPlugin Path:" + mPluginPath);
-  QgsDebugMsg("\nPkgData Path:" + mPkgDataPath);
-  QgsDebugMsg("\nTheme Path:" + mThemePath);
-  QgsDebugMsg("\n**********************************\n");
+  //for debuggin
+  showSettings();
 QgsApplication::~QgsApplication()
@@ -84,7 +79,6 @@
 void QgsApplication::setPluginPath(const QString thePluginPath)
   mPluginPath = thePluginPath;
-  QgsDebugMsg("\n\n\n\n\n +++++++++++++++++++++++\n plugin path changed\n" + mPluginPath + "\n +++++++++++++++++ \n\n\n\n");
 void QgsApplication::setPkgDataPath(const QString thePkgDataPath)
@@ -248,6 +242,17 @@
   delete QgsProviderRegistry::instance();
+void QgsApplication::showSettings()
+  qDebug("\n**********************************");
+  qDebug("QgsApplication state:");
+  qDebug("Prefix       :" + mPrefixPath.toLocal8Bit());
+  qDebug("Plugin Path  :" + mPluginPath.toLocal8Bit());
+  qDebug("PkgData Path :" + mPkgDataPath.toLocal8Bit());
+  qDebug("Theme Path   :" + mThemePath.toLocal8Bit());
+  qDebug("**********************************\n");
 QString QgsApplication::reportStyleSheet()
   QString myStyle;
@@ -295,3 +300,5 @@
   return myStyle;
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h	2008-05-21 17:20:58 UTC (rev 8483)
+++ trunk/qgis/src/core/qgsapplication.h	2008-05-21 17:22:55 UTC (rev 8484)
@@ -113,6 +113,9 @@
      * the gradient fills for backgrounds.
     static QString reportStyleSheet();
+    /** Print to stdout the paths used in this application instance.
+     * useful for debugging mainly.*/
+    static void showSettings();
   private:
     static QString mPrefixPath;
     static QString mPluginPath;
