[QGIS Commit] r8485 - trunk/qgis/src/app
svn_qgis at osgeo.org
Wed May 21 13:25:48 EDT 2008
Author: timlinux
Date: 2008-05-21 13:25:48 -0400 (Wed, 21 May 2008)
New Revision: 8485
trunk/qgis/src/app/main.cpp
Prettified application variable name
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2008-05-21 17:22:55 UTC (rev 8484)
+++ trunk/qgis/src/app/main.cpp 2008-05-21 17:25:48 UTC (rev 8485)
@@ -379,7 +379,7 @@
std::cerr << "QGIS starting in non-interactive mode not supported.\n You are seeing this message most likely because you have no DISPLAY environment variable set." << std::endl;
exit(1); //exit for now until a version of qgis is capabable of running non interactive
- QgsApplication a(argc, argv, myUseGuiFlag );
+ QgsApplication myApp(argc, argv, myUseGuiFlag );
// Set up the QSettings environment must be done after qapp is created
QCoreApplication::setOrganizationName("QuantumGIS");
@@ -423,7 +423,7 @@
- // a.setFont(QFont("helvetica", 11));
+ // myApp.setFont(QFont("helvetica", 11));
QString i18nPath = QgsApplication::i18nPath();
@@ -467,7 +467,7 @@
QTranslator qgistor(0);
if (qgistor.load(QString("qgis_") + myTranslationCode, i18nPath))
- a.installTranslator(&qgistor);
+ myApp.installTranslator(&qgistor);
/* Translation file for Qt.
* The strings from the QMenuBar context section are used by Qt/Mac to shift
@@ -477,7 +477,7 @@
QTranslator qttor(0);
if (qttor.load(QString("qt_") + myTranslationCode, i18nPath))
- a.installTranslator(&qttor);
+ myApp.installTranslator(&qttor);
//set up splash screen
@@ -535,7 +535,7 @@
//next two lines should not be needed, testing only
//QCoreApplication::addLibraryPath( myPath + "/imageformats" );
//QCoreApplication::addLibraryPath( myPath + "/sqldrivers" );
- //foreach (myPath, a.libraryPaths())
+ //foreach (myPath, myApp.libraryPaths())
//qDebug("Path:" + myPath.toLocal8Bit());
@@ -662,11 +662,11 @@
qApp->processEvents(), grab the pixmap, save it, hide the window and exit.
//qgis->show();
- a.processEvents();
+ myApp.processEvents();
QPixmap * myQPixmap = new QPixmap(800,600);
myQPixmap->fill();
qgis->saveMapAsImage(mySnapshotFileName,myQPixmap);
qgis->hide();
return 1;
@@ -676,10 +676,10 @@
// Continue on to interactive gui...
qgis->show();
- a.connect(&a, SIGNAL(lastWindowClosed()), &a, SLOT(quit()));
+ myApp.connect(&myApp, SIGNAL(lastWindowClosed()), &myApp, SLOT(quit()));
mypSplash->finish(qgis);
delete mypSplash;
- return a.exec();
+ return myApp.exec();
