[QGIS Commit] r8520 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Mon May 26 10:17:44 EDT 2008
Author: timlinux
Date: 2008-05-26 10:17:44 -0400 (Mon, 26 May 2008)
New Revision: 8520
trunk/qgis/src/gui/qgsdetaileditemdata.cpp
trunk/qgis/src/gui/qgsdetaileditemdata.h
trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
trunk/qgis/src/gui/qgsdetaileditemdelegate.h
trunk/qgis/src/gui/qgsdetaileditemwidget.cpp
Implemented word wrap in manually draw detailed item delegate and other related cleanups
Modified: trunk/qgis/src/gui/qgsdetaileditemdata.cpp
--- trunk/qgis/src/gui/qgsdetaileditemdata.cpp 2008-05-26 14:16:03 UTC (rev 8519)
+++ trunk/qgis/src/gui/qgsdetaileditemdata.cpp 2008-05-26 14:17:44 UTC (rev 8520)
@@ -35,6 +35,19 @@
mDetail=theDetail;
+void QgsDetailedItemData::setIcon(QPixmap theIcon)
+ mPixmap = theIcon;
+void QgsDetailedItemData::setCheckable(bool theFlag)
+ mCheckableFlag = theFlag;
+void QgsDetailedItemData::setChecked(bool theFlag)
+ mCheckedFlag = theFlag;
QString QgsDetailedItemData::title()
return mTitle;
@@ -44,3 +57,18 @@
return mDetail;
+QPixmap QgsDetailedItemData::icon()
+ return mPixmap;
+bool QgsDetailedItemData::isCheckable()
+ return mCheckableFlag;
+bool QgsDetailedItemData::isChecked()
+ return mCheckedFlag;
Modified: trunk/qgis/src/gui/qgsdetaileditemdata.h
--- trunk/qgis/src/gui/qgsdetaileditemdata.h 2008-05-26 14:16:03 UTC (rev 8519)
+++ trunk/qgis/src/gui/qgsdetaileditemdata.h 2008-05-26 14:17:44 UTC (rev 8520)
@@ -21,6 +21,7 @@
#include <QMetaType>
#include <QString>
+#include <QPixmap>
/** This class is the data only representation of a
* QgsDetailedItemWidget, designed to be used in custom views.
@@ -32,13 +33,23 @@
~QgsDetailedItemData();
void setTitle(QString theTitle);
void setDetail(QString theDetail);
+ void setIcon(QPixmap theIcon);
+ void setCheckable(bool theFlag);
+ void setChecked(bool theFlag);
QString title();
QString detail();
+ QPixmap icon();
+ bool isCheckable();
+ bool isChecked();
private:
QString mTitle;
QString mDetail;
QString mLibraryName;
- bool mCheckBoxEnabled;
+ QPixmap mPixmap;
+ bool mCheckableFlag;
+ bool mCheckedFlag;
// Make QVariant aware of this data type (see qtdocs star
Modified: trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
--- trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp 2008-05-26 14:16:03 UTC (rev 8519)
+++ trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp 2008-05-26 14:17:44 UTC (rev 8520)
@@ -32,6 +32,7 @@
mpCheckBox(new QCheckBox())
+ //mpWidget->setFixedHeight(80);
mpCheckBox->resize(16,16);
@@ -86,21 +87,24 @@
QString myDetailString = theIndex.model()->data(theIndex, Qt::UserRole).toString();
bool myCheckState = theIndex.model()->data(theIndex, Qt::CheckStateRole).toBool();
mpCheckBox->setChecked(myCheckState);
- QPixmap myPixmap(mpCheckBox->size());
- mpCheckBox->render(&myPixmap); //we will draw this onto the widget further down
+ QPixmap myCbxPixmap(mpCheckBox->size());
+ mpCheckBox->render(&myCbxPixmap); //we will draw this onto the widget further down
+ QPixmap myDecoPixmap;
// Calculate the widget height and other metrics
QFont myFont = theOption.font;
- QFont myBoldFont = myFont;
- myBoldFont.setBold(true);
- myBoldFont.setPointSize(myFont.pointSize() + 3);
- QFontMetrics myMetrics(myBoldFont);
+ QFont myTitleFont = myFont;
+ myTitleFont.setBold(true);
+ myTitleFont.setPointSize(myFont.pointSize() + 3);
+ QFontMetrics myTitleMetrics(myTitleFont);
+ QFontMetrics myDetailMetrics(myFont);
int myVerticalSpacer = 3; //spacing between title and description
int myHorizontalSpacer = 5; //spacing between checkbox / icon and description
- int myTextStartX = theOption.rect.x() + myPixmap.width() + myHorizontalSpacer;
- int myHeight = myMetrics.height() + myVerticalSpacer;
+ int myTextStartX = theOption.rect.x() + myHorizontalSpacer;
+ int myTextStartY= theOption.rect.y() + myVerticalSpacer;
+ int myHeight = myTitleMetrics.height() + myVerticalSpacer;
// Draw the item background with a gradient if its highlighted
@@ -110,7 +114,7 @@
QColor myColor1 = theOption.palette.highlight();
QColor myColor2 = myColor1;
myColor2 = myColor2.lighter(110); //10% lighter
QLinearGradient myGradient(QPointF(0,theOption.rect.y()),
QPointF(0,theOption.rect.y() + myHeight*2));
myGradient.setColorAt(0, myColor1);
@@ -124,19 +128,61 @@
// Draw the checkbox
- thepPainter->drawPixmap(theOption.rect.x(),
- theOption.rect.y() + mpCheckBox->height(),
- myPixmap);
+ bool myCheckableFlag = true;
+ if (theIndex.flags() == Qt::ItemIsUserCheckable)
+ myCheckableFlag = false;
+ if (myCheckableFlag)
+ thepPainter->drawPixmap(theOption.rect.x(),
+ theOption.rect.y() + mpCheckBox->height(),
+ myCbxPixmap);
+ myTextStartX = theOption.rect.x() + myCbxPixmap.width() + myHorizontalSpacer;
- // Draw the title and description
+ // Draw the decoration (pixmap)
- thepPainter->setFont(myBoldFont);
- thepPainter->drawText( myTextStartX ,theOption.rect.y() + myHeight, myString);
+ bool myIconFlag = false;
+ if (!theIndex.model()->data(theIndex, Qt::DecorationRole).isNull())
+ myDecoPixmap = theIndex.model()->data(theIndex, Qt::DecorationRole).value<QPixmap>();
+ thepPainter->drawPixmap(myTextStartX,
+ myTextStartY + (myDecoPixmap.height() / 2),
+ myDecoPixmap);
+ myTextStartX += myDecoPixmap.width() + myHorizontalSpacer;
+ // Draw the title
+ myTextStartY += myHeight/2;
+ thepPainter->setFont(myTitleFont);
+ thepPainter->drawText( myTextStartX ,
+ myTextStartY ,
+ myString);
+ // Draw the description with word wrapping if needed
thepPainter->setFont(myFont); //return to original font set by client
- thepPainter->drawText( myTextStartX,
- theOption.rect.y() + (myHeight *2) - myVerticalSpacer,
- myDetailString);
+ if (myIconFlag)
+ myTextStartY += myVerticalSpacer;
+ else
+ myTextStartY += myDetailMetrics.height() + myVerticalSpacer;
+ QStringList myList =
+ wordWrap( myDetailString, myDetailMetrics, theOption.rect.width() - myTextStartX );
+ QStringListIterator myLineWrapIterator(myList);
+ while (myLineWrapIterator.hasNext())
+ QString myLine = myLineWrapIterator.next();
+ thepPainter->drawText( myTextStartX,
+ myTextStartY,
+ myLine);
+ myTextStartY += myDetailMetrics.height() - myVerticalSpacer;
thepPainter->restore();
@@ -152,14 +198,70 @@
else // fall back to hand calculated & hand drawn item
- return QSize(50,
- myHeight *2 + myVerticalSpacer);
+ QString myDetailString = theIndex.model()->data(theIndex, Qt::UserRole).toString();
+ QStringList myList = wordWrap( myDetailString,
+ myDetailMetrics,
+ theOption.rect.width() - (mpCheckBox->width() + myHorizontalSpacer));
+ myHeight += (myList.count() + 1) * (myDetailMetrics.height() - myVerticalSpacer);
+#ifdef Q_OS_MACX
+ //for some reason itmes are non selectable if using rect.width() on osx
+ return QSize(50, myHeight + myVerticalSpacer);
+#else
+ return QSize(theOption.rect.width(), myHeight + myVerticalSpacer);
+#endif
+QStringList QgsDetailedItemDelegate::wordWrap(QString theString,
+ QFontMetrics theMetrics,
+ int theWidth) const
+ if ( theString.isEmpty() ) return QStringList();
+ if ( 50 >= theWidth ) return QStringList() << theString;
+ QString myDebug = QString("Word wrapping: %1 into %2 pixels").arg(theString).arg(theWidth);
+ qDebug(myDebug.toLocal8Bit());
+ //iterate the string
+ QStringList myList;
+ QString myCumulativeLine="";
+ QString myStringToPreviousSpace="";
+ int myPreviousSpacePos=0;
+ for (int i=0; i < theString.count(); ++i)
+ QChar myChar = theString.at(i);
+ if (myChar == QChar(' '))
+ myStringToPreviousSpace = myCumulativeLine;
+ myPreviousSpacePos=i;
+ myCumulativeLine += myChar;
+ if (theMetrics.width(myCumulativeLine) >= theWidth)
+ //time to wrap
+ //@todo deal with long strings that have no spaces
+ //forcing a break at current pos...
+ myList << myStringToPreviousSpace.trimmed();
+ i = myPreviousSpacePos;
+ myStringToPreviousSpace = "";
+ myCumulativeLine = "";
+ }//end of i loop
+ //add whatever is left in the string to the list
+ if (!myCumulativeLine.trimmed().isEmpty())
+ myList << myCumulativeLine.trimmed();
+ //qDebug("Wrapped legend entry:");
+ //qDebug(theString);
+ //qDebug(myList.join("\n").toLocal8Bit());
+ return myList;
Modified: trunk/qgis/src/gui/qgsdetaileditemdelegate.h
--- trunk/qgis/src/gui/qgsdetaileditemdelegate.h 2008-05-26 14:16:03 UTC (rev 8519)
+++ trunk/qgis/src/gui/qgsdetaileditemdelegate.h 2008-05-26 14:17:44 UTC (rev 8520)
@@ -23,6 +23,7 @@
class QCheckBox;
class QgsDetailedItemWidget;
+class QFontMetrics;
class GUI_EXPORT QgsDetailedItemDelegate :
public QAbstractItemDelegate
@@ -37,6 +38,9 @@
QSize sizeHint( const QStyleOptionViewItem & theOption,
const QModelIndex & theIndex ) const;
private:
+ QStringList wordWrap(QString theString,
+ int theWidth) const;
QgsDetailedItemWidget * mpWidget;
QCheckBox * mpCheckBox;
Modified: trunk/qgis/src/gui/qgsdetaileditemwidget.cpp
--- trunk/qgis/src/gui/qgsdetaileditemwidget.cpp 2008-05-26 14:16:03 UTC (rev 8519)
+++ trunk/qgis/src/gui/qgsdetaileditemwidget.cpp 2008-05-26 14:17:44 UTC (rev 8520)
@@ -31,7 +31,10 @@
void QgsDetailedItemWidget::setData(QgsDetailedItemData theData)
lblTitle->setText(theData.title());
- tbDetail->setText(theData.detail());
+ lblDetail->setText(theData.detail());
+ cbx->setVisible(theData.isCheckable());
+ cbx->setChecked(theData.isChecked());
+ lblIcon->setPixmap(theData.icon());
void QgsDetailedItemWidget::setChecked(bool theFlag)
