[QGIS Commit] r8521 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Mon May 26 10:25:56 EDT 2008
Author: timlinux
Date: 2008-05-26 10:25:56 -0400 (Mon, 26 May 2008)
New Revision: 8521
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsattributetabledisplay.h
trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
trunk/qgis/src/app/qgsgraduatedsymboldialog.h
trunk/qgis/src/app/qgspluginmanager.h
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/app/qgsuniquevaluedialog.cpp
trunk/qgis/src/app/qgsuniquevaluedialog.h
trunk/qgis/src/ui/qgsattributetablebase.ui
trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
Further work on ui cleanups and useability:
- in unique value and graduated symbol dialogs, show symbol previews in classification lists
- tidy up for raster props dialog (PeteE I finally capitulated and used a stack widget)
- use a label instead of a textbrowser in detailed item widget
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-05-26 14:25:56 UTC (rev 8521)
@@ -1018,7 +1018,7 @@
void QgisApp::createToolBars()
QSize myIconSize ( 24,24 );
- //QSize myIconSize ( 32,32 ); //large icons
+ // QSize myIconSize ( 32,32 ); //large icons
// Note: we need to set each object name to ensure that
// qmainwindow::saveState and qmainwindow::restoreState
// work properly
Modified: trunk/qgis/src/app/qgsattributetabledisplay.h
--- trunk/qgis/src/app/qgsattributetabledisplay.h 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsattributetabledisplay.h 2008-05-26 14:25:56 UTC (rev 8521)
@@ -53,7 +53,6 @@
void doSearch(const QString& searchString);
virtual void closeEvent(QCloseEvent* ev);
- void showHelp();
/** array of feature IDs that match last searched condition */
QgsFeatureIds mSearchIds;
@@ -71,7 +70,7 @@
void search();
void advancedSearch();
void searchShowResultsChanged(int item);
- void on_btnHelp_clicked();
+ void showHelp();
public slots:
void changeFeatureAttribute(int row, int column);
Modified: trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
--- trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp 2008-05-26 14:25:56 UTC (rev 8521)
@@ -155,74 +155,74 @@
QgsGraduatedSymbolRenderer* renderer = new QgsGraduatedSymbolRenderer(mVectorLayer->vectorType());
for (int item=0;item<mClassListWidget->count();++item)
+ QString classbreak=mClassListWidget->item(item)->text();
+ std::map<QString,QgsSymbol*>::iterator it=mEntries.find(classbreak);
+ if(it==mEntries.end())
- QString classbreak=mClassListWidget->item(item)->text();
- std::map<QString,QgsSymbol*>::iterator it=mEntries.find(classbreak);
- if(it==mEntries.end())
- continue;
- QString lower_bound=it->second->lowerValue();
- QString upper_bound=it->second->upperValue();
- QString label=it->second->label();
- QgsSymbol* sy = new QgsSymbol(mVectorLayer->vectorType(), lower_bound, upper_bound, label);
- sy->setColor(it->second->pen().color());
- sy->setLineStyle(it->second->pen().style());
- sy->setLineWidth(it->second->pen().widthF());
- if (mVectorLayer->vectorType() == QGis::Point)
- sy->setNamedPointSymbol(it->second->pointSymbolName());
- sy->setPointSize(it->second->pointSize());
- sy->setScaleClassificationField(it->second->scaleClassificationField());
- sy->setRotationClassificationField(it->second->rotationClassificationField());
- if (mVectorLayer->vectorType() != QGis::Line)
- sy->setFillColor(it->second->brush().color());
- sy->setCustomTexture(it->second->customTexture());//necessary?
- sy->setFillStyle(it->second->brush().style());
- //test, if lower_bound is numeric or not (making a subclass of QString would be the proper solution)
- bool lbcontainsletter = false;
- for (int j = 0; j < lower_bound.length(); j++)
- if (lower_bound.ref(j).isLetter())
- lbcontainsletter = true;
- //test, if upper_bound is numeric or not (making a subclass of QString would be the proper solution)
- bool ubcontainsletter = false;
- for (int j = 0; j < upper_bound.length(); j++)
- if (upper_bound.ref(j).isLetter())
- ubcontainsletter = true;
- if (lbcontainsletter == false && ubcontainsletter == false && lower_bound.length() > 0 && upper_bound.length() > 0) //only add the item if the value bounds do not contain letters and are not null strings
- renderer->addSymbol(sy);
- else
- delete sy;
+ continue;
+ QString lower_bound=it->second->lowerValue();
+ QString upper_bound=it->second->upperValue();
+ QString label=it->second->label();
+ QgsSymbol* sy = new QgsSymbol(mVectorLayer->vectorType(), lower_bound, upper_bound, label);
+ sy->setColor(it->second->pen().color());
+ sy->setLineStyle(it->second->pen().style());
+ sy->setLineWidth(it->second->pen().widthF());
+ if (mVectorLayer->vectorType() == QGis::Point)
+ sy->setNamedPointSymbol(it->second->pointSymbolName());
+ sy->setPointSize(it->second->pointSize());
+ sy->setScaleClassificationField(it->second->scaleClassificationField());
+ sy->setRotationClassificationField(it->second->rotationClassificationField());
+ if (mVectorLayer->vectorType() != QGis::Line)
+ sy->setFillColor(it->second->brush().color());
+ sy->setCustomTexture(it->second->customTexture());//necessary?
+ sy->setFillStyle(it->second->brush().style());
+ //test, if lower_bound is numeric or not (making a subclass of QString would be the proper solution)
+ bool lbcontainsletter = false;
+ for (int j = 0; j < lower_bound.length(); j++)
+ if (lower_bound.ref(j).isLetter())
+ lbcontainsletter = true;
+ //test, if upper_bound is numeric or not (making a subclass of QString would be the proper solution)
+ bool ubcontainsletter = false;
+ for (int j = 0; j < upper_bound.length(); j++)
+ if (upper_bound.ref(j).isLetter())
+ ubcontainsletter = true;
+ if (lbcontainsletter == false && ubcontainsletter == false && lower_bound.length() > 0 && upper_bound.length() > 0) //only add the item if the value bounds do not contain letters and are not null strings
+ renderer->addSymbol(sy);
+ else
+ delete sy;
renderer->updateSymbolAttributes();
std::map<QString,int>::iterator iter=mFieldMap.find(classificationComboBox->currentText());
if(iter!=mFieldMap.end())
- renderer->setClassificationField(iter->second);
+ renderer->setClassificationField(iter->second);
mVectorLayer->setRenderer(renderer);
@@ -339,7 +339,9 @@
(*symbol_it)->setLowerValue(QString::number(lower,'f',3));
(*symbol_it)->setUpperValue(QString::number(upper,'f',3));
listBoxText=QString::number(lower,'f',3)+" - " +QString::number(upper,'f',3);
- mClassListWidget->addItem(listBoxText);
+ QListWidgetItem * mypItem = new QListWidgetItem(listBoxText);
+ updateEntryIcon(*symbol_it,mypItem);
+ mClassListWidget->addItem(mypItem);
mEntries.insert(std::make_pair(listBoxText,*symbol_it));
++symbol_it;
@@ -372,6 +374,7 @@
sydialog.set((*it).second);
sydialog.setLabel((*it).second->label());
+ updateEntryIcon((*it).second,item);
sydialog.blockSignals(false);
@@ -388,6 +391,7 @@
sydialog.apply((*it).second);
it->second->setLabel((*it).second->label());
@@ -419,7 +423,8 @@
QString newclass=dialog.lowerValue()+"-"+dialog.upperValue();
mEntries.insert(std::make_pair(newclass,symbol));
item->setText(newclass);
+ updateEntryIcon(symbol,item);
@@ -532,3 +537,24 @@
return color;
+void QgsGraduatedSymbolDialog::updateEntryIcon(QgsSymbol * thepSymbol,
+ QListWidgetItem * thepItem)
+ QGis::VectorType myType = mVectorLayer->vectorType();
+ switch (myType)
+ case QGis::Point:
+ thepItem->setIcon(QIcon(QPixmap::fromImage(thepSymbol->getPointSymbolAsImage())));
+ break;
+ case QGis::Line:
+ thepItem->setIcon(QIcon(QPixmap::fromImage(thepSymbol->getLineSymbolAsImage())));
+ break;
+ case QGis::Polygon:
+ thepItem->setIcon(QIcon(QPixmap::fromImage(thepSymbol->getPolygonSymbolAsImage())));
+ break;
+ default: //unknown
+ //do nothing
Modified: trunk/qgis/src/app/qgsgraduatedsymboldialog.h
--- trunk/qgis/src/app/qgsgraduatedsymboldialog.h 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsgraduatedsymboldialog.h 2008-05-26 14:25:56 UTC (rev 8521)
@@ -75,6 +75,11 @@
void deleteCurrentClass();
private:
+ /** Update the list widget item icon with a preview for the symbol.
+ * @param QgsSymbol * - symbol holding the style info.
+ * @param QListWidgetItem * - item to get its icon updated.
+ void updateEntryIcon(QgsSymbol * thepSymbol,QListWidgetItem * thepItem);
/**Default constructor is privat to not use is*/
QgsGraduatedSymbolDialog();
Modified: trunk/qgis/src/app/qgspluginmanager.h
--- trunk/qgis/src/app/qgspluginmanager.h 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgspluginmanager.h 2008-05-26 14:25:56 UTC (rev 8521)
@@ -19,7 +19,6 @@
#ifndef QGSPLUGINMANAGER_H
#define QGSPLUGINMANAGER_H
#include <vector>
-#include <QTableView>
#include <QStandardItemModel>
#include <QSortFilterProxyModel>
#include <QStandardItem>
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-05-26 14:25:56 UTC (rev 8521)
@@ -2417,6 +2417,7 @@
if(theState)
//--- enable and disable appropriate controls
+ stackedWidget->setCurrentIndex(1);
rbtnThreeBand->setChecked(false);
cboxColorMap->setEnabled(true);
@@ -2439,9 +2440,6 @@
grpRgbBands->setEnabled(false);
- grpRgbScaling->setEnabled(false);
- grpGrayBand->setEnabled(true);
- grpGrayScaling->setEnabled(true);
if(mRasterLayer->getUserDefinedGrayMinMax())
@@ -2492,14 +2490,12 @@
if(theState)
+ stackedWidget->setCurrentIndex(0);
rbtnSingleBand->setChecked(false);
cboxColorMap->setEnabled(false);
tabBar->setTabEnabled(tabBar->indexOf(tabPageColormap), false);
grpRgbBands->setEnabled(true);
- grpRgbScaling->setEnabled(true);
- grpGrayBand->setEnabled(false);
- grpGrayScaling->setEnabled(false);
pbtnLoadMinMax->setEnabled(true);
labelContrastEnhancement->setEnabled(true);
@@ -2864,3 +2860,161 @@
myGradient.setColorAt(0.0,QColor(255, 255, 255, 150));
return myGradient;
+// Next four methods for saving and restoring qml style state
+void QgsRasterLayerProperties::on_pbnLoadDefaultStyle_clicked()
+ bool defaultLoadedFlag = false;
+ QString myMessage = mRasterLayer->loadDefaultStyle( defaultLoadedFlag );
+ //reset if the default style was loaded ok only
+ if ( defaultLoadedFlag )
+ sync();
+ QMessageBox::information( this,
+ tr("Default Style"),
+ myMessage
+void QgsRasterLayerProperties::on_pbnSaveDefaultStyle_clicked()
+ // a flag passed by reference
+ bool defaultSavedFlag = false;
+ // after calling this the above flag will be set true for success
+ // or false if the save operation failed
+ QString myMessage = mRasterLayer->saveDefaultStyle( defaultSavedFlag );
+ myMessage
+void QgsRasterLayerProperties::on_pbnLoadStyle_clicked()
+ QSettings myQSettings; // where we keep last used filter in persistant state
+ QString myLastUsedDir = myQSettings.value ( "style/lastStyleDir", "." ).toString();
+ //create a file dialog
+ std::auto_ptr < QFileDialog > myFileDialog
+ new QFileDialog (
+ this,
+ QFileDialog::tr ( "Load layer properties from style file (.qml)" ),
+ myLastUsedDir,
+ tr ( "QGIS Layer Style File (*.qml)" )
+ myFileDialog->setFileMode ( QFileDialog::AnyFile );
+ myFileDialog->setAcceptMode ( QFileDialog::AcceptOpen );
+ //prompt the user for a filename
+ QString myFileName;
+ if ( myFileDialog->exec() == QDialog::Accepted )
+ QStringList myFiles = myFileDialog->selectedFiles();
+ if ( !myFiles.isEmpty() )
+ myFileName = myFiles[0];
+ if ( !myFileName.isEmpty() )
+ if ( myFileDialog->selectedFilter() == tr ( "QGIS Layer Style File (*.qml)" ) )
+ //ensure the user never ommitted the extension from the filename
+ if ( !myFileName.toUpper().endsWith ( ".QML" ) )
+ myFileName += ".qml";
+ QString myMessage = mRasterLayer->loadNamedStyle( myFileName, defaultLoadedFlag );
+ sync();
+ myMessage
+ else
+ QMessageBox::warning ( this, tr ( "QGIS" ), tr ( "Unknown style format: " ) +
+ myFileDialog->selectedFilter() );
+ myQSettings.setValue ( "style/lastStyleDir", myFileDialog->directory().absolutePath() );
+void QgsRasterLayerProperties::on_pbnSaveStyleAs_clicked()
+ new QFileDialog (
+ this,
+ QFileDialog::tr ( "Save layer properties as style file (.qml)" ),
+ myLastUsedDir,
+ myFileDialog->setAcceptMode ( QFileDialog::AcceptSave );
+ QString myOutputFileName;
+ myOutputFileName = myFiles[0];
+ if ( !myOutputFileName.isEmpty() )
+ if ( !myOutputFileName.toUpper().endsWith ( ".QML" ) )
+ myOutputFileName += ".qml";
+ QString myMessage = mRasterLayer->saveNamedStyle( myOutputFileName, defaultLoadedFlag );
+ sync();
+ myMessage
+ else
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-05-26 14:25:56 UTC (rev 8521)
@@ -113,6 +113,14 @@
/**This slot save the current contrast enhancement algorithm as the default algorithm */
void on_pbtnMakeContrastEnhancementAlgorithmDefault_clicked();
+ /** Load the default style when appriate button is pressed. */
+ void on_pbnLoadDefaultStyle_clicked();
+ /** Save the default style when appriate button is pressed. */
+ void on_pbnSaveDefaultStyle_clicked();
+ /** Load a saved style when appriate button is pressed. */
+ void on_pbnLoadStyle_clicked();
+ /** Save a style when appriate button is pressed. */
+ void on_pbnSaveStyleAs_clicked();
signals:
Modified: trunk/qgis/src/app/qgsuniquevaluedialog.cpp
--- trunk/qgis/src/app/qgsuniquevaluedialog.cpp 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsuniquevaluedialog.cpp 2008-05-26 14:25:56 UTC (rev 8521)
@@ -85,6 +85,7 @@
QListWidgetItem *item = new QListWidgetItem(symbolvalue);
mClassListWidget->addItem(item);
item->setFlags(Qt::ItemIsSelectable|Qt::ItemIsEditable|Qt::ItemIsEnabled);
item->setData( Qt::UserRole, symbol->lowerValue() );
item->setToolTip(symbol->label());
@@ -253,11 +254,9 @@
for(int i=0; i<selection.size(); i++)
QListWidgetItem *item=selection[i];
- if(!item)
- continue;
+ if( !item ) continue;
- if( !mValues.contains( item->text() ) )
- continue;
+ if( !mValues.contains( item->text() ) )continue;
setSymbolColor( mValues[ item->text() ], white);
@@ -325,6 +324,7 @@
mValues.insert(newValue, sy);
sy->setLowerValue(newValue);
item->setData( Qt::UserRole, newValue );
+ updateEntryIcon(sy,item);
else
item->setText(oldValue);
@@ -423,5 +423,27 @@
item->setToolTip(sydialog.label());
item->setData( Qt::UserRole, value);
+void QgsUniqueValueDialog::updateEntryIcon(QgsSymbol * thepSymbol,
+ switch (myType)
+ case QGis::Point:
+ break;
+ case QGis::Line:
+ break;
+ break;
+ QgsDebugMsg("Vector layer type unknown");
+ //do nothing
Modified: trunk/qgis/src/app/qgsuniquevaluedialog.h
--- trunk/qgis/src/app/qgsuniquevaluedialog.h 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/app/qgsuniquevaluedialog.h 2008-05-26 14:25:56 UTC (rev 8521)
@@ -59,6 +59,11 @@
void applySymbologyChanges();
private:
QColor randomColor();
void setSymbolColor(QgsSymbol *symbol, QColor thecolor);
Modified: trunk/qgis/src/ui/qgsattributetablebase.ui
--- trunk/qgis/src/ui/qgsattributetablebase.ui 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/ui/qgsattributetablebase.ui 2008-05-26 14:25:56 UTC (rev 8521)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>686</width>
- <height>547</height>
+ <width>687</width>
+ <height>583</height>
</rect>
</property>
<property name="windowTitle" >
@@ -16,20 +16,14 @@
<iconset/>
</property>
<layout class="QGridLayout" >
- <property name="margin" >
- <number>9</number>
+ <property name="horizontalSpacing" >
+ <number>2</number>
</property>
- <property name="spacing" >
- <number>6</number>
+ <property name="verticalSpacing" >
</property>
<item row="0" column="0" >
<layout class="QHBoxLayout" >
- <number>0</number>
- </property>
- </property>
<item>
<widget class="QToolButton" name="mRemoveSelectionButton" >
<property name="toolTip" >
@@ -116,9 +110,7 @@
<item>
<widget class="QToolButton" name="mAddAttributeButton" >
<property name="sizePolicy" >
- <sizepolicy>
- <hsizetype>0</hsizetype>
- <vsizetype>0</vsizetype>
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
@@ -191,9 +183,7 @@
<item row="1" column="0" >
<widget class="QgsAttributeTable" native="1" name="tblAttributes" >
- <sizepolicy>
- <hsizetype>7</hsizetype>
- <vsizetype>7</vsizetype>
+ <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
</sizepolicy>
@@ -202,26 +192,10 @@
</item>
<item row="2" column="0" >
- </property>
- </property>
<item>
- <widget class="QPushButton" name="btnHelp" >
- <property name="text" >
- <string>&Help</string>
- </property>
- <property name="shortcut" >
- <string>Alt+C</string>
- </property>
- </widget>
- </item>
- <item>
<widget class="QLabel" name="textLabel1" >
- <string>Search for:</string>
+ <string>Search for</string>
</property>
<property name="buddy" >
<cstring>mSearchText</cstring>
@@ -244,9 +218,7 @@
<item>
<widget class="QComboBox" name="mSearchColumns" >
- <sizepolicy>
+ <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
</sizepolicy>
@@ -273,18 +245,15 @@
</property>
</widget>
</item>
- <item>
- <widget class="QPushButton" name="btnClose" >
- <string>&Close</string>
- </property>
- </property>
- </widget>
- </item>
</layout>
</item>
+ <item row="3" column="0" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Close|QDialogButtonBox::Help|QDialogButtonBox::NoButton</set>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
@@ -300,6 +269,7 @@
<tabstop>mSelectedToTopButton</tabstop>
<tabstop>mInvertSelectionButton</tabstop>
<tabstop>mCopySelectedRowsButton</tabstop>
+ <tabstop>mZoomMapToSelectedRowsButton</tabstop>
<tabstop>mAddAttributeButton</tabstop>
<tabstop>mDeleteAttributeButton</tabstop>
<tabstop>btnStartEditing</tabstop>
@@ -309,8 +279,25 @@
<tabstop>mSearchButton</tabstop>
<tabstop>mSearchShowResults</tabstop>
<tabstop>btnAdvancedSearch</tabstop>
- <tabstop>btnClose</tabstop>
+ <tabstop>buttonBox</tabstop>
</tabstops>
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsAttributeTableBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>645</x>
+ <y>560</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>682</x>
+ <y>529</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
Modified: trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
--- trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui 2008-05-26 14:25:56 UTC (rev 8521)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>299</width>
- <height>159</height>
+ <width>295</width>
+ <height>68</height>
</rect>
</property>
@@ -14,22 +14,22 @@
</property>
<property name="leftMargin" >
- <number>3</number>
</property>
<property name="topMargin" >
</property>
<property name="rightMargin" >
</property>
<property name="bottomMargin" >
</property>
</property>
</property>
@@ -106,7 +106,26 @@
</layout>
</item>
- <widget class="QTextBrowser" name="tbDetail" />
+ <widget class="QLabel" name="lblDetail" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="MinimumExpanding" hsizetype="Preferred" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="text" >
+ <string>Detail label</string>
+ </property>
+ <property name="scaledContents" >
+ <bool>false</bool>
+ </property>
+ <property name="alignment" >
+ <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignTop</set>
+ </property>
+ <property name="wordWrap" >
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
</layout>
</widget>
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-05-26 14:17:44 UTC (rev 8520)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-05-26 14:25:56 UTC (rev 8521)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>609</width>
- <height>647</height>
+ <width>596</width>
+ <height>629</height>
</rect>
</property>
@@ -32,55 +32,23 @@
<string>Symbology</string>
</attribute>
- <item row="0" column="0" >
+ <item row="0" column="0" colspan="2" >
<widget class="QGroupBox" name="groupBox_3" >
<property name="title" >
<string>Render as</string>
</property>
- <widget class="QRadioButton" name="rbtnThreeBand" >
- <string>Three band color</string>
- </property>
- </widget>
- </item>
- <item row="1" column="0" >
<widget class="QRadioButton" name="rbtnSingleBand" >
<string>Single band gray</string>
</property>
</widget>
</item>
- </layout>
- </widget>
- </item>
- <item row="0" column="1" >
- <widget class="QGroupBox" name="groupBox_5" >
- <property name="title" >
- <string>Color map</string>
- </property>
- <layout class="QVBoxLayout" >
- <item>
- <widget class="QComboBox" name="cboxColorMap" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="minimumSize" >
- <size>
- <width>150</width>
- <height>0</height>
- </size>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QCheckBox" name="cboxInvertColorMap" >
+ <item row="0" column="1" >
+ <widget class="QRadioButton" name="rbtnThreeBand" >
- <string>Invert color map</string>
+ <string>Three band color</string>
</property>
</widget>
</item>
@@ -88,662 +56,614 @@
</widget>
</item>
<item row="1" column="0" colspan="2" >
- <widget class="Line" name="line_2" >
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
+ <widget class="QStackedWidget" name="stackedWidget" >
+ <sizepolicy vsizetype="Minimum" hsizetype="Expanding" >
+ </sizepolicy>
</property>
- </widget>
- </item>
- <item rowspan="2" row="2" column="0" >
- <widget class="QGroupBox" name="grpRgbBands" >
- <string>RGB mode band selection</string>
+ <property name="currentIndex" >
+ <number>1</number>
</property>
- <layout class="QGridLayout" >
- <item row="2" column="0" >
- <widget class="QLabel" name="lblBlue" >
- <string><b><font color='blue'>Blue</font></b></string>
- </property>
- <property name="buddy" >
- <cstring>cboBlue</cstring>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="lblGreen" >
- <string><b><font color='green'>Green</font></b></string>
- </property>
- <cstring>cboGreen</cstring>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="lblRed" >
- <string><b><font color='red'>Red</font></b></string>
- </property>
- <cstring>cboRed</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="1" >
- <widget class="QComboBox" name="cboBlue" >
- </sizepolicy>
- </property>
- <size>
- </size>
- </property>
- <property name="baseSize" >
- <size>
- <width>100</width>
- </size>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="cboRed" >
- </sizepolicy>
- </property>
- <size>
- </size>
- </property>
- <size>
- </size>
- </property>
- </widget>
- </item>
- <item row="1" column="1" >
- <widget class="QComboBox" name="cboGreen" >
- </sizepolicy>
- </property>
- <size>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </widget>
- </item>
- </layout>
+ <widget class="QWidget" name="rgb" >
+ <layout class="QGridLayout" >
+ <property name="leftMargin" >
+ <number>0</number>
+ </property>
+ <property name="topMargin" >
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <item row="0" column="0" >
+ <widget class="QGroupBox" name="grpRgbBands" >
+ <property name="title" >
+ <string>RGB mode band selection and scaling</string>
+ </property>
+ <widget class="QLabel" name="lblRed" >
+ <string>Red band</string>
+ </property>
+ <property name="buddy" >
+ <cstring>cboRed</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1" colspan="3" >
+ <widget class="QComboBox" name="cboRed" >
+ </sizepolicy>
+ </property>
+ <property name="minimumSize" >
+ <size>
+ <width>150</width>
+ <height>0</height>
+ </size>
+ </property>
+ <property name="baseSize" >
+ <size>
+ <width>100</width>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QLabel" name="lblGreen" >
+ <string>Green band</string>
+ </property>
+ <cstring>cboGreen</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" colspan="3" >
+ <widget class="QComboBox" name="cboGreen" >
+ </sizepolicy>
+ </property>
+ <size>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QLabel" name="lblBlue" >
+ <string>Blue band</string>
+ </property>
+ <cstring>cboBlue</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1" colspan="3" >
+ <widget class="QComboBox" name="cboBlue" >
+ </sizepolicy>
+ </property>
+ <size>
+ </size>
+ </property>
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0" colspan="2" >
+ <widget class="QRadioButton" name="rbtnThreeBandMinMax" >
+ <string>Custom min / max values</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0" >
+ <widget class="QLabel" name="lblRedMin" >
+ <sizepolicy vsizetype="Minimum" hsizetype="MinimumExpanding" >
+ </sizepolicy>
+ </property>
+ <string>Red min</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="1" >
+ <widget class="QLineEdit" name="leRedMin" >
+ </sizepolicy>
+ </property>
+ <property name="maximumSize" >
+ <size>
+ <width>75</width>
+ <height>16777215</height>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ <property name="maxLength" >
+ <number>16</number>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="2" >
+ <widget class="QLabel" name="lblRedMax" >
+ </sizepolicy>
+ </property>
+ <string>Red max</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="3" >
+ <widget class="QLineEdit" name="leRedMax" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="0" >
+ <widget class="QLabel" name="lblGreenMin" >
+ </sizepolicy>
+ </property>
+ <string>Green min</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="1" >
+ <widget class="QLineEdit" name="leGreenMin" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="2" >
+ <widget class="QLabel" name="lblGreenMax" >
+ </sizepolicy>
+ </property>
+ <string>Green max</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="3" >
+ <widget class="QLineEdit" name="leGreenMax" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="0" >
+ <widget class="QLabel" name="lblBlueMin" >
+ </sizepolicy>
+ </property>
+ <string>Blue min</string>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="1" >
+ <widget class="QLineEdit" name="leBlueMin" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="2" >
+ <widget class="QLabel" name="lblBlueMax" >
+ </sizepolicy>
+ </property>
+ <string>Blue max</string>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="3" >
+ <widget class="QLineEdit" name="leBlueMax" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="7" column="0" colspan="2" >
+ <widget class="QRadioButton" name="rbtnThreeBandStdDev" >
+ <string>Std. deviation</string>
+ </property>
+ </widget>
+ </item>
+ <item row="7" column="3" >
+ <widget class="QDoubleSpinBox" name="sboxThreeBandStdDev" >
+ <property name="maximum" >
+ <double>10.000000000000000</double>
+ </property>
+ <property name="singleStep" >
+ <double>0.100000000000000</double>
+ </property>
+ <property name="value" >
+ <double>0.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="gray" >
+ </property>
+ </property>
+ </property>
+ </property>
+ <widget class="QGroupBox" name="groupBox_5" >
+ <string>Single band properties</string>
+ </property>
+ <widget class="QLabel" name="label" >
+ </sizepolicy>
+ </property>
+ <string>Gray band</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1" colspan="6" >
+ <widget class="QComboBox" name="cboGray" >
+ </sizepolicy>
+ </property>
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_5" >
+ <string>Color map</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" colspan="6" >
+ <widget class="QComboBox" name="cboxColorMap" >
+ </sizepolicy>
+ </property>
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1" colspan="6" >
+ <widget class="QCheckBox" name="cboxInvertColorMap" >
+ </sizepolicy>
+ </property>
+ <string>Invert color map</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QRadioButton" name="rbtnSingleBandMinMax" >
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="3" >
+ <widget class="QLabel" name="lblGrayMin" >
+ </sizepolicy>
+ </property>
+ <string>Min</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="4" >
+ <widget class="QLineEdit" name="leGrayMin" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="5" >
+ <widget class="QLabel" name="lblGrayMax" >
+ </sizepolicy>
+ </property>
+ <string>Max</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="6" >
+ <widget class="QLineEdit" name="leGrayMax" >
+ </sizepolicy>
+ </property>
+ <size>
+ <width>75</width>
+ </size>
+ </property>
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0" colspan="3" >
+ <widget class="QRadioButton" name="rbtnSingleBandStdDev" >
+ <string>Use standard deviation</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="4" >
+ <widget class="QDoubleSpinBox" name="sboxSingleBandStdDev" >
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="0" colspan="7" >
+ <widget class="QLabel" name="lblMinMaxEstimateWarning" >
+ <sizepolicy vsizetype="Maximum" hsizetype="Expanding" >
+ </sizepolicy>
+ </property>
+ <string>Estimate note:</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
- <spacer>
- <enum>Qt::Vertical</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>20</width>
- <height>40</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="3" column="1" >
- <widget class="QGroupBox" name="grpGrayBand" >
- <string>Grayscale band selection</string>
- </property>
- <property name="horizontalSpacing" >
- </property>
- <property name="verticalSpacing" >
- </property>
- <widget class="QLabel" name="label" >
- </sizepolicy>
- </property>
- <string>Gray</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="cboGray" >
- </sizepolicy>
- </property>
- <size>
- </size>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item rowspan="2" row="4" column="0" >
- <widget class="QGroupBox" name="grpRgbScaling" >
- <string>RGB scaling</string>
- </property>
- <item row="3" column="3" >
- <widget class="QLabel" name="lblBlueMax" >
- <string><b><font color='blue'>Max</font></b></string>
- </property>
- </widget>
- </item>
- <item row="4" column="0" colspan="2" >
- <widget class="QRadioButton" name="rbtnThreeBandStdDev" >
- <string>Std. deviation</string>
- </property>
- </widget>
- </item>
- <item row="0" column="0" colspan="5" >
- <widget class="QRadioButton" name="rbtnThreeBandMinMax" >
- <string>Custom min / max values</string>
- </property>
- </widget>
- </item>
- <item row="2" column="4" >
- <widget class="QLineEdit" name="leGreenMax" >
- </sizepolicy>
- </property>
- <property name="maximumSize" >
- <size>
- <width>75</width>
- <height>16777215</height>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- <property name="maxLength" >
- <number>16</number>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="lblGreenMin" >
- </sizepolicy>
- </property>
- <string><b><font color='green'>Min</font></b></string>
- </property>
- </widget>
- </item>
- <item row="2" column="3" >
- <widget class="QLabel" name="lblGreenMax" >
- </sizepolicy>
- </property>
- <string><b><font color='green'>Max</font></b></string>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="lblRedMin" >
- </sizepolicy>
- </property>
- <string><b><font color='red'>Min</font></b></string>
- </property>
- </widget>
- </item>
- <item row="3" column="2" >
- <spacer>
- </property>
- <size>
- <width>21</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="1" column="4" >
- <widget class="QLineEdit" name="leRedMax" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <item row="1" column="3" >
- <widget class="QLabel" name="lblRedMax" >
- </sizepolicy>
- </property>
- <string><b><font color='red'>Max</font></b></string>
- </property>
- </widget>
- </item>
- <item row="2" column="2" >
- <spacer>
- </property>
- <size>
- <width>21</width>
- </size>
- </property>
- </spacer>
- </item>
- <item row="3" column="4" >
- <widget class="QLineEdit" name="leBlueMax" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLineEdit" name="leBlueMin" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <item row="3" column="0" >
- <widget class="QLabel" name="lblBlueMin" >
- </sizepolicy>
- </property>
- <string><b><font color='blue'>Min</font></b></string>
- </property>
- </widget>
- </item>
- <item row="1" column="2" >
- <spacer>
- </property>
- <size>
- <width>21</width>
- </size>
- </property>
- </spacer>
- </item>
- <widget class="QLineEdit" name="leRedMin" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <item row="4" column="2" colspan="2" >
- <spacer>
- </property>
- <size>
- <width>40</width>
- </size>
- </property>
- </spacer>
- </item>
- <item row="4" column="4" >
- <widget class="QDoubleSpinBox" name="sboxThreeBandStdDev" >
- <property name="maximum" >
- <double>10.000000000000000</double>
- </property>
- <property name="singleStep" >
- <double>0.100000000000000</double>
- </property>
- <property name="value" >
- <double>0.000000000000000</double>
- </property>
- </widget>
- </item>
- <widget class="QLineEdit" name="leGreenMin" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item row="4" column="1" >
- <widget class="QGroupBox" name="grpGrayScaling" >
- <string>Grayscale band scaling</string>
- </property>
- <item row="3" column="0" colspan="5" >
- <widget class="QLabel" name="lblMinMaxEstimateWarning" >
- <sizepolicy vsizetype="Preferred" hsizetype="Expanding" >
- </sizepolicy>
- </property>
- <string/>
- </property>
- </widget>
- </item>
- <widget class="QLineEdit" name="leGrayMin" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="sboxSingleBandStdDev" >
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLineEdit" name="leGrayMax" >
- </sizepolicy>
- </property>
- <size>
- <width>75</width>
- </size>
- </property>
- <size>
- <width>0</width>
- </size>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="lblGrayMax" >
- </sizepolicy>
- </property>
- <string>Max</string>
- </property>
- </widget>
- </item>
- <spacer>
- </property>
- <size>
- <width>21</width>
- </size>
- </property>
- </spacer>
- </item>
- <item row="2" column="0" colspan="2" >
- <widget class="QRadioButton" name="rbtnSingleBandStdDev" >
- </property>
- </widget>
- </item>
- <widget class="QRadioButton" name="rbtnSingleBandMinMax" >
- </property>
- </widget>
- </item>
- <item row="2" column="2" colspan="2" >
- <spacer>
- </property>
- <size>
- <width>40</width>
- </size>
- </property>
- </spacer>
- </item>
- <widget class="QLabel" name="lblGrayMin" >
- </sizepolicy>
- </property>
- <string>Min</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item row="5" column="1" >
- <spacer>
- </property>
- <size>
- <width>20</width>
- </size>
- </property>
- </spacer>
- </item>
- <item row="6" column="0" colspan="2" >
<widget class="Line" name="line" >
</property>
</widget>
</item>
- <item row="7" column="0" >
<widget class="QGroupBox" name="groupBox_2" >
<string>Load min / max values from band</string>
</property>
- <item rowspan="2" row="0" column="0" >
<widget class="QRadioButton" name="rbtnEstimateMinMax" >
<string>Estimate (faster)</string>
@@ -757,13 +677,20 @@
</property>
<size>
- <width>201</width>
+ <width>81</width>
<height>20</height>
</size>
</property>
</spacer>
</item>
- <item rowspan="2" row="1" column="1" >
+ <widget class="QRadioButton" name="rbtnActualMinMax" >
+ <string>Actual (slower)</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" >
<spacer>
@@ -776,24 +703,17 @@
</property>
</spacer>
</item>
- <item rowspan="2" row="1" column="2" >
+ <item row="1" column="2" >
<widget class="QPushButton" name="pbtnLoadMinMax" >
<string>Load</string>
</property>
</widget>
</item>
- <widget class="QRadioButton" name="rbtnActualMinMax" >
- <string>Actual (slower)</string>
- </property>
- </widget>
- </item>
</layout>
</widget>
</item>
- <item row="7" column="1" >
<widget class="QGroupBox" name="groupBox_8" >
<string>Contrast enhancement</string>
@@ -870,6 +790,19 @@
</layout>
</widget>
</item>
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="tabPageTransparency" >
@@ -2067,6 +2000,53 @@
</widget>
</item>
+ <layout class="QHBoxLayout" >
+ <property name="spacing" >
+ <number>3</number>
+ </property>
+ </property>
+ </property>
+ </property>
+ </property>
+ <item>
+ <widget class="QPushButton" name="pbnLoadDefaultStyle" >
+ <string>Restore Default Style</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="pbnSaveDefaultStyle" >
+ <string>Save As Default</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="pbnLoadStyle" >
+ <string>Load Style ...</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="pbnSaveStyleAs" >
+ <string>Save Style ...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
@@ -2129,7 +2109,7 @@
<hints>
<x>458</x>
- <y>562</y>
+ <y>589</y>
</hint>
<x>3</x>
