[QGIS Commit] r9309 - in trunk/qgis/src: app core/raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Sep 12 16:29:55 EDT 2008
Author: timlinux
Date: 2008-09-12 16:29:55 -0400 (Fri, 12 Sep 2008)
New Revision: 9309
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
   trunk/qgis/src/core/raster/qgsrasterlayer.h
Remove debug overlay from api and code base
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-09-12 19:57:38 UTC (rev 9308)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2008-09-12 20:29:55 UTC (rev 9309)
@@ -1437,7 +1437,6 @@
   mRasterLayer->setLayerName( leDisplayName->text() );
-  mRasterLayer->setShowDebugOverlayFlag( true );
   // set up the scale based layer visibility stuff....
   mRasterLayer->setScaleBasedVisibility( chkUseScaleDependentRendering->isChecked() );
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-09-12 19:57:38 UTC (rev 9308)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2008-09-12 20:29:55 UTC (rev 9309)
@@ -310,7 +310,6 @@
     TRSTRING_NOT_SET( tr( "Not Set" ) ),
     mRasterXDim( std::numeric_limits<int>::max() ),
     mRasterYDim( std::numeric_limits<int>::max() ),
-    mDebugOverlayFlag( false ),
     mInvertPixelsFlag( false ),
     mStandardDeviations( 0 ),
     mDataProvider( 0 )
@@ -1325,12 +1324,6 @@
-  //see if debug info is wanted
-  if ( mDebugOverlayFlag )
-    showDebugOverlay( theQPainter, theRasterViewPort );
 }                               //end of draw method
@@ -2035,38 +2028,7 @@
   //return;
-  Print some debug info to the qpainter
-void QgsRasterLayer::showDebugOverlay( QPainter * theQPainter, QgsRasterViewPort * theRasterViewPort )
-  QFont myQFont( "arial", 10, QFont::Bold );
-  theQPainter->setFont( myQFont );
-  theQPainter->setPen( Qt::black );
-  QBrush myQBrush( qRgba( 128, 128, 164, 50 ), Qt::Dense6Pattern ); //semi transparent
-  theQPainter->setBrush( myQBrush );  // set the yellow brush
-  theQPainter->drawRect( 5, 5, theQPainter->window().width() - 10, 60 );
-  theQPainter->setBrush( Qt::NoBrush ); // do not fill
-  theQPainter->drawText( 10, 20, "QPainter: "
-                         + QString::number( theQPainter->window().width() ) + " x " + QString::number( theQPainter->window().height() ) );
-  theQPainter->drawText( 10, 32, tr( "Raster Extent: " )
-                         + QString::number( theRasterViewPort->drawableAreaXDim )
-                         + "," + QString::number( theRasterViewPort->drawableAreaYDim ) );
-  theQPainter->drawText( 10, 44, tr( "Clipped area: " )
-                         + QString::number( theRasterViewPort->clippedXMin )
-                         + "," + QString::number( theRasterViewPort->clippedYMin )
-                         + " - " + QString::number( theRasterViewPort->clippedXMax )
-                         + "," + QString::number( theRasterViewPort->clippedYMin ) );
-  return;
-}                               //end of main draw method
 const QgsRasterBandStats QgsRasterLayer::getRasterBandStats( QString const & theBandName )
@@ -3834,7 +3796,6 @@
   <zorder>0</zorder>
   <transparencyLevelInt>255</transparencyLevelInt>
   <rasterproperties>
-  <mDebugOverlayFlag boolean="false"/>
   <drawingStyle>SINGLE_BAND_GRAY</drawingStyle>
   <mInvertPixelsFlag boolean="false"/>
   <mStandardDeviations>0</mStandardDeviations>
@@ -3912,14 +3873,8 @@
   QDomNode mnl = layer_node.namedItem( "rasterproperties" );
-  QDomNode snode = mnl.namedItem( "mDebugOverlayFlag" );
+  QDomNode snode = mnl.namedItem( "drawingStyle" );
   QDomElement myElement = snode.toElement();
-  QVariant myQVariant = ( QVariant ) myElement.attribute( "boolean" );
-  setShowDebugOverlayFlag( myQVariant.toBool() );
-  snode = mnl.namedItem( "drawingStyle" );
-  myElement = snode.toElement();
   setDrawingStyle( myElement.text() );
   snode = mnl.namedItem( "mColorShadingAlgorithm" );
@@ -3928,8 +3883,8 @@
   snode = mnl.namedItem( "mInvertPixelsFlag" );
-  myQVariant = ( QVariant ) myElement.attribute( "boolean" );
-  setInvertHistogramFlag( myQVariant.toBool() );
+  QVariant myVariant = ( QVariant ) myElement.attribute( "boolean" );
+  setInvertHistogramFlag( myVariant.toBool() );
   snode = mnl.namedItem( "mRedBandName" );
@@ -3954,23 +3909,23 @@
   snode = mnl.namedItem( "mUserDefinedRGBMinMaxFlag" );
-  setUserDefinedRGBMinMax( myQVariant.toBool() );
+  myVariant = ( QVariant ) myElement.attribute( "boolean" );
+  setUserDefinedRGBMinMax( myVariant.toBool() );
   snode = mnl.namedItem( "mRGBActualMinimumMaximum" );
-  setActualRGBMinMaxFlag( myQVariant.toBool() );
+  setActualRGBMinMaxFlag( myVariant.toBool() );
   snode = mnl.namedItem( "mUserDefinedGrayMinMaxFlag" );
-  setUserDefinedGrayMinMax( myQVariant.toBool() );
+  setUserDefinedGrayMinMax( myVariant.toBool() );
   snode = mnl.namedItem( "mGrayActualMinimumMaximum" );
-  setActualGrayMinMaxFlag( myQVariant.toBool() );
+  setActualGrayMinMaxFlag( myVariant.toBool() );
   snode = mnl.namedItem( "mContrastEnhancementAlgorithm" );
@@ -4172,20 +4127,6 @@
-  // <mDebugOverlayFlag>
-  QDomElement mDebugOverlayFlagElement = document.createElement( "mDebugOverlayFlag" );
-  if ( getShowDebugOverlayFlag() )
-    mDebugOverlayFlagElement.setAttribute( "boolean", "true" );
-  else
-    mDebugOverlayFlagElement.setAttribute( "boolean", "false" );
-  rasterPropertiesElement.appendChild( mDebugOverlayFlagElement );
   // <drawingStyle>
   QDomElement drawStyleElement = document.createElement( "drawingStyle" );
   QDomText    drawStyleText    = document.createTextNode( getDrawingStyleAsQString() );
@@ -4610,7 +4551,6 @@
     : QgsMapLayer( RASTER, baseName, rasterLayerPath ),
     mProviderKey( providerKey ),
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-09-12 19:57:38 UTC (rev 9308)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h	2008-09-12 20:29:55 UTC (rev 9309)
@@ -429,19 +429,6 @@
     /** \brief Mutator for gray band name mapping.  */
     void setGrayBandName( const QString & theBandName );
-    // Accessor and mutator for mDebugOverlayFlag
-    /** \brief Accessor for a flag that determines whether to show some debug info on the image.  */
-    bool getShowDebugOverlayFlag()
-      return mDebugOverlayFlag;
-    /** \brief Mutator for a flag that determines whether to show some debug info on the image.  */
-    void setShowDebugOverlayFlag( bool theFlag )
-      mDebugOverlayFlag = theFlag;
     // Accessor and mutator for minimum maximum values
     //TODO: Move these out of the header file...
@@ -912,8 +899,6 @@
     // Private methods
-    /** \brief Paint debug information onto the output image.  */
-    void showDebugOverlay( QPainter * theQPainter, QgsRasterViewPort * theRasterViewPort );
     // Grayscale Imagery
@@ -1033,8 +1018,6 @@
     double mNoDataValue;
     /** \brief Flag indicating if the nodatavalue is valid*/
     bool mValidNoDataValue;
-    /** \brief Flag to indicate whether debug info overlay should be rendered onto the raster.  */
-    bool mDebugOverlayFlag;
     /** \brief Pointer to the gdaldataset.  */
     GDALDatasetH mGdalBaseDataset;
     /** \brief Pointer to the gdaldataset (possibly warped vrt).  */
More information about the QGIS-commit mailing list
