[QGIS Commit] r9310 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Fri Sep 12 18:19:55 EDT 2008
Author: timlinux
Date: 2008-09-12 18:19:54 -0400 (Fri, 12 Sep 2008)
New Revision: 9310
Added:
trunk/qgis/python/plugins/plugin_installer/PluginInstaller.png
trunk/qgis/python/plugins/plugin_installer/fetchingbase.ui
trunk/qgis/python/plugins/plugin_installer/repoUnavailable.png
trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/fetchingbase.py
trunk/qgis/python/plugins/plugin_installer/guibase.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
trunk/qgis/python/plugins/plugin_installer/installingbase.py
trunk/qgis/python/plugins/plugin_installer/pluginerrorbase.py
trunk/qgis/python/plugins/plugin_installer/repositorybase.py
trunk/qgis/python/plugins/plugin_installer/resources_rc.py
Updates for Borys and added some missing files
Modified: trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt
--- trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/CMakeLists.txt 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,30 +2,33 @@
# file or the ui change
SET(INSTALLER_FILES
dialog.py
+fetchingbase.py
+fetchingbase.ui
+guibase.py
+guibase.ui
gui.py
icon.xpm
__init__.py
+installer_data.py
+installer_gui.py
installer_plugin.py
-qgis_plugins.py
-resources.py
-repository_ui.py
-repository_dialog.py
+installingbase.py
installingbase.ui
-fetchingbase.py
-guibase.py
-repositorybase.py
+pluginerrorbase.py
+pluginerrorbase.ui
-unzip.py
-installer_gui.py
-installingbase.py
-pluginerrorbase.ui
-installer_data.py
+qgis_plugins.py
-guibase.ui
-pluginerrorbase.py
+repositorybase.py
repositorybase.ui
+repository_dialog.py
+repository_ui.py
+resources.py
resources_rc.py
+unzip.py
INSTALL(FILES ${INSTALLER_FILES} DESTINATION ${QGIS_DATA_DIR}/python/plugins/plugin_installer)
Added: trunk/qgis/python/plugins/plugin_installer/PluginInstaller.png
(Binary files differ)
Property changes on: trunk/qgis/python/plugins/plugin_installer/PluginInstaller.png
___________________________________________________________________
+ application/octet-stream
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -20,7 +20,7 @@
return "perrygeo, borysiasty"
def version():
- return "Version 0.05.6"
+ return "Version 0.06.1"
def classFactory(iface):
from installer_plugin import InstallerPlugin
Modified: trunk/qgis/python/plugins/plugin_installer/fetchingbase.py
--- trunk/qgis/python/plugins/plugin_installer/fetchingbase.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/fetchingbase.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,7 +2,7 @@
# Form implementation generated from reading ui file 'fetchingbase.ui'
-# Created: Sun Sep 7 16:22:19 2008
+# Created: Fri Sep 12 19:21:37 2008
# by: PyQt4 UI code generator 4.3
# WARNING! All changes made in this file will be lost!
Added: trunk/qgis/python/plugins/plugin_installer/fetchingbase.ui
--- trunk/qgis/python/plugins/plugin_installer/fetchingbase.ui (rev 0)
+++ trunk/qgis/python/plugins/plugin_installer/fetchingbase.ui 2008-09-12 22:19:54 UTC (rev 9310)
@@ -0,0 +1,200 @@
+<ui version="4.0" >
+ <author>Matthew Perry, Borys Jurgiel</author>
+ <class>QgsPluginInstallerFetchingDialog</class>
+ <widget class="QDialog" name="QgsPluginInstallerFetchingDialog" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>521</width>
+ <height>332</height>
+ </rect>
+ </property>
+ <property name="windowTitle" >
+ <string>Fetching repositories</string>
+ </property>
+ <property name="windowIcon" >
+ <iconset resource="resources.qrc" >:/plugins/installer/qgis-icon.png</iconset>
+ </property>
+ <layout class="QGridLayout" >
+ <item row="1" column="0" >
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeType" >
+ <enum>QSizePolicy::Fixed</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>249</width>
+ <height>10</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QLabel" name="label1" >
+ <property name="text" >
+ <string>Overall progress:</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0" >
+ <widget class="QProgressBar" name="progressBar" >
+ <property name="value" >
+ <number>24</number>
+ </property>
+ <property name="alignment" >
+ <set>Qt::AlignHCenter</set>
+ </property>
+ <property name="textDirection" >
+ <enum>QProgressBar::TopToBottom</enum>
+ </property>
+ <property name="format" >
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0" >
+ <spacer>
+ </property>
+ </property>
+ <size>
+ <width>248</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="5" column="0" >
+ <layout class="QHBoxLayout" >
+ <item>
+ <spacer>
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <enum>QSizePolicy::MinimumExpanding</enum>
+ </property>
+ <size>
+ <width>140</width>
+ <height>27</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QPushButton" name="buttonSkip" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="minimumSize" >
+ <size>
+ <width>180</width>
+ <height>0</height>
+ </size>
+ </property>
+ <property name="focusPolicy" >
+ <enum>Qt::NoFocus</enum>
+ </property>
+ <string>Abort fetching</string>
+ </property>
+ <property name="autoDefault" >
+ <bool>false</bool>
+ </property>
+ <property name="default" >
+ </property>
+ <property name="flat" >
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer>
+ </property>
+ </property>
+ <size>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </item>
+ <item row="0" column="0" >
+ <widget class="QTreeWidget" name="treeWidget" >
+ <property name="enabled" >
+ <bool>true</bool>
+ </property>
+ <property name="horizontalScrollBarPolicy" >
+ <enum>Qt::ScrollBarAsNeeded</enum>
+ </property>
+ <property name="showDropIndicator" stdset="0" >
+ </property>
+ <property name="selectionMode" >
+ <enum>QAbstractItemView::NoSelection</enum>
+ </property>
+ <property name="horizontalScrollMode" >
+ <enum>QAbstractItemView::ScrollPerItem</enum>
+ </property>
+ <property name="rootIsDecorated" >
+ </property>
+ <property name="itemsExpandable" >
+ </property>
+ <column>
+ <string>Repository</string>
+ </property>
+ </column>
+ <column>
+ <string>State</string>
+ </property>
+ </column>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <resources>
+ <include location="resources.qrc" />
+ </resources>
+ <connections>
+ <connection>
+ <sender>buttonSkip</sender>
+ <signal>clicked()</signal>
+ <receiver>QgsPluginInstallerFetchingDialog</receiver>
+ <slot>reject()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>350</x>
+ <y>321</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>250</x>
+ <y>76</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
Modified: trunk/qgis/python/plugins/plugin_installer/guibase.py
--- trunk/qgis/python/plugins/plugin_installer/guibase.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/guibase.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,7 +2,7 @@
# Form implementation generated from reading ui file 'guibase.ui'
-# Created: Sun Sep 7 21:28:01 2008
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -229,7 +229,6 @@
def xmlDownloaded(self,nr,state):
- #print reposName, nr, state
if not self.httpId.has_key(nr):
return
reposName = self.httpId[nr]
@@ -296,8 +295,8 @@
- def firstByName(self, name):
- plugins = [i for i in self.mPlugins if self.mPlugins[i]["name"] == name]
+ def keyByUrl(self, name):
+ plugins = [i for i in self.mPlugins if self.mPlugins[i]["url"] == name]
if plugins:
return plugins[0]
return None
@@ -421,6 +420,11 @@
+ def remove(self, key):
+ del self.mPlugins[key]
def updatePlugin(self, key, readOnly):
try:
exec("import "+ key)
@@ -452,6 +456,11 @@
desc = ""
auth = ""
homepage = ""
+ if readOnly:
+ path = QgsApplication.pkgDataPath()
+ else:
+ path = QgsApplication.qgisSettingsDirPath()
+ path = QDir.cleanPath(unicode(path,"utf-8") + "python/plugins/" + key)
normVer = self.normalizeVersion(QString(ver))
plugin = {
"name" : nam,
@@ -461,7 +470,7 @@
"desc_repo" : "",
"author" : auth,
"homepage" : homepage,
- "url" : "",
+ "url" : path,
"filename" : "",
"status" : stat,
"repository" : "",
@@ -478,10 +487,6 @@
self.mPlugins[key]["name"] = plugin["name"] # local name has higher priority, except invalid plugins
self.mPlugins[key]["version_inst"] = plugin["version_inst"]
self.mPlugins[key]["desc_local"] = plugin["desc_local"]
- if plugin["author"]:
- self.mPlugins[key]["author"] = plugin["author"] #local author name has higher priority, if exists
- if plugin["homepage"]:
- self.mPlugins[key]["homepage"] = plugin["homepage"] # local homepage adress has higher priority, if exists
# set status
# installed available status
@@ -509,7 +514,6 @@
def getAllInstalled(self):
""" update the mPlugins dict with alredy installed plugins """
- #print "getting list of installed plugins"
# first, try to add the read-only plugins...
try:
pluginDir = QDir.cleanPath(unicode(QgsApplication.pkgDataPath(),'utf-8') + "/python/plugins")
@@ -537,7 +541,6 @@
def markNews(self):
""" mark all new plugins as new """
- #print "marking the new plugins"
settings = QSettings()
seenPlugins = settings.value(seenPluginGroup, QVariant(QStringList(self.mPlugins.keys()))).toStringList()
if len(seenPlugins) > 0:
@@ -549,7 +552,6 @@
def updateSeenPluginsList(self):
""" update the list of all seen plugins """
- #print "updating the list of seen plugins"
for i in self.mPlugins.keys():
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -15,7 +15,7 @@
from PyQt4.QtCore import *
from PyQt4.QtGui import *
from qgis.core import QgsApplication, QgsContextHelp
-import sys
+import sys, time
from fetchingbase import Ui_QgsPluginInstallerFetchingDialog
from installingbase import Ui_QgsPluginInstallerInstallingDialog
from repositorybase import Ui_QgsPluginInstallerRepositoryDetailsDialog
@@ -24,6 +24,7 @@
from installer_data import *
# --- common functions ------------------------------------------------------------------- #
def removeDir(path):
result = QString()
@@ -44,11 +45,15 @@
iterator = QDirIterator(path, fltr, QDirIterator.Subdirectories)
while iterator.hasNext():
item = iterator.next()
- if QDir(item).rmpath("."):
+ if QDir().rmpath(item):
#print " Directory removing successfull: %s" % item
pass
if QFile(path).exists():
result = QCoreApplication.translate("QgsPluginInstaller","Failed to remove directory")+" "+path+" \n"+QCoreApplication.translate("QgsPluginInstaller","Check permissions or remove it manually")
+ # restore plugin directory if removed by QDir().rmpath()
+ pluginDir = unicode(QFileInfo(QgsApplication.qgisUserDbFilePath()).path()+"/python/plugins")
+ if not QDir(pluginDir).exists():
+ QDir().mkpath(pluginDir)
return result
# --- /common functions ------------------------------------------------------------------ #
@@ -189,23 +194,18 @@
# make sure that the parent directory exists
- QDir(pluginDir).mkpath(".")
#print "Extracting to plugin directory (%s)" % pluginDir
- #try:
- un = unzip()
- un.extract(tmpPath, pluginDir) # test extract. If fails, then exception will be raised and no removing occurs
- #print "Removing old plugin files if exist"
- removeDir(QDir.cleanPath(pluginDir+"/"+self.plugin["localdir"])) # remove old plugin if exists
- un.extract(tmpPath, pluginDir) # final extract.
- #except:
- #self.mResult = self.tr("Failed to unzip file to ") + pluginDir + "\n" + self.tr("check permissions")
- #self.reject()
- #return
+ try:
+ un = unzip()
+ un.extract(tmpPath, pluginDir) # test extract. If fails, then exception will be raised and no removing occurs
+ #print "Removing old plugin files if exist"
+ removeDir(QDir.cleanPath(pluginDir+"/"+self.plugin["localdir"])) # remove old plugin if exists
+ un.extract(tmpPath, pluginDir) # final extract.
+ except:
+ self.mResult = self.tr("Failed to unzip file to ") + pluginDir + "\n" + self.tr("check permissions")
+ self.reject()
+ return
try:
#print "Cleaning: removing the zip file (%s)" % tmpPath
@@ -414,13 +414,8 @@
p["desc_local"] = self.tr("This plugin seems to be invalid or have unfulfilled dependencies")
p["desc_repo"] = self.tr("This plugin seems to be invalid or have unfulfilled dependencies\nIt has been installed, but can't be loaded")
if p["status"] == "orphan":
- if p["read-only"]:
- url = unicode(QgsApplication.pkgDataPath(),'utf-8') + "/python/plugins/" + p["localdir"]
- else:
- url = unicode(QgsApplication.qgisSettingsDirPath(),'utf-8') + "/python/plugins/" + p["localdir"]
repository = self.tr("only locally available")
else:
- url = p["url"]
repository = p["repository"]
if not p["desc_local"]:
p["desc_local"] = p["desc_repo"]
@@ -438,7 +433,7 @@
else:
a.setToolTip(4,"")
a.setText(5,repository)
- a.setToolTip(5,url)
+ a.setToolTip(5,p["url"])
# set fonts and colours
for i in [0,1,2,3,4,5]:
if p["status"] == "invalid":
@@ -483,7 +478,7 @@
item = self.treePlugins.currentItem()
if not item:
return
- key = plugins.firstByName(item.text(1))
+ key = plugins.keyByUrl(item.toolTip(5))
if not key:
return
plugin = plugins.all()[key]
@@ -501,7 +496,7 @@
""" install currently selected plugin """
if not self.treePlugins.currentItem():
return
- key = plugins.firstByName(self.treePlugins.currentItem().text(1))
+ key = plugins.keyByUrl(self.treePlugins.currentItem().toolTip(5))
if not plugin:
return
@@ -547,7 +542,7 @@
""" uninstall currently selected plugin """
return
if not plugin:
return
@@ -568,9 +563,12 @@
exec ("del sys.modules[%s]" % plugin["localdir"])
except:
pass
- plugins.setPluginData(key, "status", "not installed")
- plugins.setPluginData(key, "version_inst", "")
- plugins.setPluginData(key, "desc_local", "")
+ if plugin["status"] == "orphan":
+ plugins.remove(key)
+ else:
+ plugins.setPluginData(key, "status", "not installed")
+ plugins.setPluginData(key, "version_inst", "")
+ plugins.setPluginData(key, "desc_local", "")
self.populatePluginTree()
QApplication.restoreOverrideCursor()
QMessageBox.information(self, self.tr("QGIS Python Plugin Installer"), self.tr("Plugin uninstalled successfully"))
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -33,14 +33,14 @@
def initGui(self):
""" create action that will start plugin window and then add it to menu """
- self.action = QAction(QIcon(":/plugins/installer/PluginInstaller.png"), QCoreApplication.translate("QgsPluginInstaller","Plugin Installer..."), self.mainWindow())
+ self.action = QAction(QIcon(":/plugins/installer/PluginInstaller.png"), QCoreApplication.translate("QgsPluginInstaller","Fetch Python Plugins..."), self.mainWindow())
self.action.setWhatsThis(QCoreApplication.translate("QgsPluginInstaller","Install more plugins from remote repositories"))
self.action.setStatusTip(QCoreApplication.translate("QgsPluginInstaller","Install more plugins from remote repositories"))
if str(QGis.qgisVersion)[0] == "0":
nextAction = self.mainWindow().menuBar().actions()[4].menu().actions()[1]
self.mainWindow().menuBar().actions()[4].menu().insertAction(nextAction,self.action)
else:
- nextAction = self.iface.actionPluginSeparator1()
+ nextAction = self.iface.actionManagePlugins() #actionPluginSeparator1()
self.iface.pluginMenu().insertAction(nextAction,self.action)
QObject.connect(self.action, SIGNAL("activated()"), self.run)
self.statusLabel = None
Modified: trunk/qgis/python/plugins/plugin_installer/installingbase.py
--- trunk/qgis/python/plugins/plugin_installer/installingbase.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/installingbase.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,7 +2,7 @@
# Form implementation generated from reading ui file 'installingbase.ui'
-# Created: Sun Sep 7 16:22:38 2008
Modified: trunk/qgis/python/plugins/plugin_installer/pluginerrorbase.py
--- trunk/qgis/python/plugins/plugin_installer/pluginerrorbase.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/pluginerrorbase.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,7 +2,7 @@
# Form implementation generated from reading ui file 'pluginerrorbase.ui'
-# Created: Sun Sep 7 16:22:47 2008
Added: trunk/qgis/python/plugins/plugin_installer/repoUnavailable.png
Property changes on: trunk/qgis/python/plugins/plugin_installer/repoUnavailable.png
Modified: trunk/qgis/python/plugins/plugin_installer/repositorybase.py
--- trunk/qgis/python/plugins/plugin_installer/repositorybase.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/repositorybase.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,7 +2,7 @@
# Form implementation generated from reading ui file 'repositorybase.ui'
-# Created: Tue Sep 9 00:09:51 2008
Modified: trunk/qgis/python/plugins/plugin_installer/resources_rc.py
--- trunk/qgis/python/plugins/plugin_installer/resources_rc.py 2008-09-12 20:29:55 UTC (rev 9309)
+++ trunk/qgis/python/plugins/plugin_installer/resources_rc.py 2008-09-12 22:19:54 UTC (rev 9310)
@@ -2,7 +2,7 @@
# Resource object code
-# Created: ?r. wrz 3 18:43:47 2008
+# Created: pt. wrz 12 19:21:37 2008
# by: The Resource Compiler for PyQt (Qt v4.3.2)
