[QGIS Commit] r9315 - trunk/qgis/ms-windows
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Sep 13 10:25:44 EDT 2008
Author: marcopx
Date: 2008-09-13 10:25:44 -0400 (Sat, 13 Sep 2008)
New Revision: 9315
Added:
   trunk/qgis/ms-windows/QGIS-Installer.nsi
Added new MS-Windows installer script
Added: trunk/qgis/ms-windows/QGIS-Installer.nsi
--- trunk/qgis/ms-windows/QGIS-Installer.nsi	                        (rev 0)
+++ trunk/qgis/ms-windows/QGIS-Installer.nsi	2008-09-13 14:25:44 UTC (rev 9315)
@@ -0,0 +1,564 @@
+;Quantum GIS Installer for Windows
+;Written by Marco Pasetti
+;Last Update: 17 July 2008
+;Mail to: marco.pasetti at alice.it
+;Select if you are building a "Development Version" or a "Release Version" of the Quantum GIS Installer
+;Change the INSTALLER_TYPE variable to Release or Development
+!define INSTALLER_TYPE "Release"
+;Version variables
+!define RELEASE_VERSION_NUMBER "0.11.0"
+!define RELEASE_VERSION_NAME "Metis"
+!define RELEASE_SVN_REVISION "8811"
+!define RELEASE_BINARY_REVISION "2"
+!define DEV_VERSION_NUMBER ""
+!define DEV_VERSION_NAME ""
+!define DEV_SVN_REVISION ""
+!define DEV_BINARY_REVISION ""
+;Don't modify the following lines
+;NSIS Includes
+!include "MUI2.nsh"
+!include "LogicLib.nsh"
+;define the QGIS Base Name
+!define RELEASE_QGIS_BASE "Quantum GIS"
+!define DEV_QGIS_BASE "QGIS-Dev"
+;Set the installer variables, depending on the selected version to build
+!if ${INSTALLER_TYPE} == "Release"
+	!define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
+	!define VERSION_NAME "${RELEASE_VERSION_NAME}"
+	!define COMPLETE_NAME "${RELEASE_QGIS_BASE} ${RELEASE_VERSION_NUMBER} ${RELEASE_VERSION_NAME}"
+	!define SVN_REVISION "${RELEASE_SVN_REVISION}"
+	!define BINARY_REVISION "${RELEASE_BINARY_REVISION}"
+	!define QGIS_BASE "${RELEASE_QGIS_BASE}"
+	!define INSTALLER_NAME "QGIS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
+	!define DISPLAYED_NAME "${RELEASE_QGIS_BASE} ${VERSION_NUMBER}-${BINARY_REVISION}"
+	!define CHECK_INSTALL_NAME "${RELEASE_QGIS_BASE}"
+	!define INSTALLER_DISPLAYED_NAME "${COMPLETE_NAME}"
+	!define PACKAGE_FOLDER ".\QGIS-Release-Package"
+!else if ${INSTALLER_TYPE} == "Development"
+	!define VERSION_NUMBER "${DEV_VERSION_NUMBER}"
+	!define VERSION_NAME "${DEV_VERSION_NAME}"
+	!define COMPLETE_NAME "${DEV_QGIS_BASE} ${DEV_VERSION_NUMBER} ${DEV_VERSION_NAME}"
+	!define SVN_REVISION "${DEV_SVN_REVISION}"
+	!define BINARY_REVISION "${DEV_BINARY_REVISION}"
+	!define QGIS_BASE "${DEV_QGIS_BASE}"
+	!define INSTALLER_NAME "QGIS-Dev-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
+	!define DISPLAYED_NAME "${DEV_QGIS_BASE} ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+	!define CHECK_INSTALL_NAME "${DEV_QGIS_BASE}"
+	!define INSTALLER_DISPLAYED_NAME "${DISPLAYED_NAME}"
+	!define PACKAGE_FOLDER ".\QGIS-Dev-Package"
+!endif
+;Publisher variables
+!define PUBLISHER "QGIS Development Team"
+!define WEB_SITE "http://www.qgis.org"
+!define WIKI_PAGE "http://wiki.qgis.org/qgiswiki"
+;General Definitions
+;Name of the application shown during install
+Name "${INSTALLER_DISPLAYED_NAME}"
+;Name of the output file (installer executable)
+OutFile "${INSTALLER_NAME}"
+;Define installation folder
+InstallDir "$PROGRAMFILES\${QGIS_BASE}"
+;Request application privileges for Windows Vista
+RequestExecutionLevel user
+;Tell the installer to show Install and Uninstall details as default
+ShowInstDetails show
+ShowUnInstDetails show
+;.onInit Function (called when the installer is nearly finished initializing)
+;Check if QGIS is already installed on the system and, if yes, what version and binary release;
+;depending on that, select the install procedure:
+;1. first installation = if QGIS is not already installed
+;install QGIS asking for the install PATH
+;2. upgrade installation = if an older release of QGIS is already installed
+;call the uninstaller of the currently installed QGIS release
+;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
+;QGIS will be installed in the same PATH of the previous installation
+;3. downgrade installation = if a newer release of QGIS is already installed
+;4. repair installation = if the same release of QGIS is already installed
+;if the uninstall procedure succeeded, call the current installer asking for the install PATH
+;the currently installed release of QGIS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+Function .onInit
+	Var /GLOBAL ASK_FOR_PATH
+	StrCpy $ASK_FOR_PATH "YES"
+	Var /GLOBAL UNINSTALL_STRING
+	Var /GLOBAL INSTALL_PATH
+	Var /GLOBAL INSTALLED_VERSION_NUMBER
+	Var /GLOBAL INSTALLED_SVN_REVISION
+	Var /GLOBAL INSTALLED_BINARY_REVISION
+	Var /GLOBAL DISPLAYED_INSTALLED_VERSION
+	Var /GLOBAL MESSAGE_0_
+	Var /GLOBAL MESSAGE_1_
+	Var /GLOBAL MESSAGE_2_
+	Var /GLOBAL MESSAGE_3_
+	ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "UninstallString"
+	ReadRegStr $INSTALL_PATH HKLM "Software\${QGIS_BASE}" "InstallPath"
+	ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${QGIS_BASE}" "VersionNumber"
+	ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${QGIS_BASE}" "SvnRevision"
+	${If} $INSTALLED_SVN_REVISION == ""
+		ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${QGIS_BASE}" "Revision"
+	${EndIf}
+	ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${QGIS_BASE}" "BinaryRevision"
+	StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
+	StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
+	!if ${INSTALLER_TYPE} == "Release"
+		${If} $INSTALLED_BINARY_REVISION == ""
+			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
+		${Else}
+			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
+		${EndIf}
+	!else
+		StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
+	!endif
+	StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall Quantum GIS $DISPLAYED_INSTALLED_VERSION"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
+	StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall Quantum GIS $DISPLAYED_INSTALLED_VERSION"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
+	StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
+	IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
+	IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
+	IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+	!define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
+	${If} $INSTALLED_VERSION_NUMBER == ""
+	${Else}
+		${If} $INSTALLED_VERSION < ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
+			upgrade:
+				StrCpy $ASK_FOR_PATH "NO"
+				ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
+				Goto continue_upgrade
+			quit_upgrade:
+				Abort
+			continue_upgrade:
+		${ElseIf} $INSTALLED_VERSION > ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
+			downgrade:
+				Goto continue_downgrade
+			quit_downgrade:
+				Abort
+			continue_downgrade:
+		${ElseIf} $INSTALLED_VERSION = ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
+			reinstall:
+				Goto continue_reinstall
+			quit_reinstall:
+				Abort
+			continue_reinstall:
+		${EndIf}
+	${EndIf}
+	${Else}
+		${If} $0 = 0
+		${Else}
+			Abort
+		${EndIf}
+	${EndIf}
+FunctionEnd
+;CheckUpdate Function
+;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
+Function CheckUpdate
+	${If} $ASK_FOR_PATH == "NO"
+		Abort
+	${EndIf}
+FunctionEnd
+;Interface Settings
+!define MUI_ABORTWARNING
+!define MUI_ICON ".\Installer-Files\Install_QGIS.ico"
+!define MUI_UNICON ".\Installer-Files\Uninstall_QGIS.ico"
+!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
+!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
+!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
+!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
+;Installer Pages
+!insertmacro MUI_PAGE_WELCOME
+!insertmacro MUI_PAGE_LICENSE ".\Installer-Files\LICENSE.txt"
+!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
+!insertmacro MUI_PAGE_DIRECTORY
+!insertmacro MUI_PAGE_COMPONENTS
+!insertmacro MUI_PAGE_INSTFILES
+!insertmacro MUI_PAGE_FINISH
+!insertmacro MUI_UNPAGE_WELCOME
+!insertmacro MUI_UNPAGE_CONFIRM
+!insertmacro MUI_UNPAGE_INSTFILES
+!insertmacro MUI_UNPAGE_FINISH
+; Language files
+!insertmacro MUI_LANGUAGE "English"
+;Installer Sections
+;Declares the variables for optional Sample Data Sections
+Var /GLOBAL HTTP_PATH
+Var /GLOBAL ARCHIVE_NAME
+Var /GLOBAL EXTENDED_ARCHIVE_NAME
+Var /GLOBAL ORIGINAL_UNTAR_FOLDER
+Var /GLOBAL CUSTOM_UNTAR_FOLDER
+Var /GLOBAL ARCHIVE_SIZE_KB
+Var /GLOBAL ARCHIVE_SIZE_MB
+Var /GLOBAL DOWNLOAD_MESSAGE_
+Section "Quantum GIS" SecQGIS
+	SectionIn RO
+	;Set the INSTALL_DIR variable
+	Var /GLOBAL INSTALL_DIR
+		StrCpy $INSTALL_DIR "$INSTALL_PATH"
+	${Else}
+		StrCpy $INSTALL_DIR "$INSTDIR"
+	${EndIf}
+	;Set to try to overwrite existing files
+	SetOverwrite try
+	;Set the GIS_DATABASE directory
+	SetShellVarContext current
+	Var /GLOBAL GIS_DATABASE
+	StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
+	;Create the GIS_DATABASE directory
+	CreateDirectory "$GIS_DATABASE"
+	;add Installer files
+	SetOutPath "$INSTALL_DIR\icons"
+	File .\Installer-Files\QGIS.ico
+	File .\Installer-Files\QGIS_Web.ico
+	SetOutPath "$INSTALL_DIR"
+	File .\Installer-Files\QGIS-WebSite.url
+	;add Quantum GIS files
+	File /r ${PACKAGE_FOLDER}\*.*
+	;Create the Uninstaller
+	WriteUninstaller "$INSTALL_DIR\Uninstall-QGIS.exe"
+	;Registry Key Entries
+	;HKEY_LOCAL_MACHINE Install entries
+	;Set the Name, Version and Revision of QGIS+ PublisherInfo + InstallPath
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "Name" "${QGIS_BASE}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "VersionName" "${VERSION_NAME}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "SvnRevision" "${SVN_REVISION}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "Publisher" "${PUBLISHER}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "WebSite" "${WEB_SITE}"
+	WriteRegStr HKLM "Software\${QGIS_BASE}" "InstallPath" "$INSTALL_DIR"
+	;HKEY_LOCAL_MACHINE Uninstall entries
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "DisplayName" "${COMPLETE_NAME}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-QGIS.exe"
+		WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}"\
+		"DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
+	!else
+		"DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+	!endif
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "DisplayIcon" "$INSTALL_DIR\icons\QGIS.ico"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "EstimatedSize" 1
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "HelpLink" "${WIKI_PAGE}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "URLInfoAbout" "${WEB_SITE}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}" "Publisher" "${PUBLISHER}"
+	;Create the Desktop Shortcut
+	CreateShortCut "$DESKTOP\${QGIS_BASE}.lnk" "$INSTALL_DIR\qgis.exe" ""\
+	"$INSTALL_DIR\icons\QGIS.ico" "" SW_SHOWNORMAL "" "Launch ${COMPLETE_NAME}"
+	;Create the Windows Start Menu Shortcuts
+	SetShellVarContext all
+	CreateDirectory "$SMPROGRAMS\${QGIS_BASE}"
+	CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\${QGIS_BASE}.lnk" "$INSTALL_DIR\qgis.exe" ""\
+	CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\Quantum GIS Web Site.lnk" "$INSTALL_DIR\QGIS-WebSite.url" ""\
+	"$INSTALL_DIR\icons\QGIS_Web.ico" "" SW_SHOWNORMAL "" "Visit the Quantum GIS Web Site"
+	CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\Uninstall ${QGIS_BASE}.lnk" "$INSTALL_DIR\Uninstall-QGIS.exe" ""\
+	"$INSTALL_DIR\Uninstall-QGIS.exe" "" SW_SHOWNORMAL "" "Uninstall ${COMPLETE_NAME}"
+SectionEnd
+Function DownloadDataSet
+	IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
+	StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the ${QGIS_BASE}"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
+	MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
+	download:
+	InitPluginsDir
+	NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+	Pop $0
+	StrCmp $0 "success" download_ok download_failed
+	download_ok:
+	InitPluginsDir
+	untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
+	Pop $0
+	StrCmp $0 "success" untar_ok untar_failed
+	untar_ok:
+	Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
+	Delete "$TEMP\$ARCHIVE_NAME"
+	Goto end
+	download_failed:
+	DetailPrint "$0" ;print error message to log
+	MessageBox MB_OK "Download Failed.$\r$\n${QGIS_BASE} will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+	Goto end
+	cancel_download:
+	MessageBox MB_OK "Download Cancelled.$\r$\n${QGIS_BASE} will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+	Goto end
+	untar_failed:
+	end:
+FunctionEnd
+Section /O "North Carolina Data Set" SecNorthCarolinaSDB
+	;Set the size (in KB)  of the archive file
+	StrCpy $ARCHIVE_SIZE_KB 138629
+	;Set the size (in KB) of the unpacked archive file
+	AddSize 293314
+  	StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
+	StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
+	StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
+	Call DownloadDataSet
+SectionEnd
+Section /O "South Dakota (Spearfish) Data Set" SecSpearfishSDB
+	StrCpy $ARCHIVE_SIZE_KB 20803
+	AddSize 42171
+	StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish)"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
+	StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
+SectionEnd
+Section /O "Alaska Data Set" SecAlaskaSDB
+	StrCpy $ARCHIVE_SIZE_KB 18496
+	AddSize 132477
+	StrCpy $HTTP_PATH "http://download.osgeo.org/qgis/data"
+	StrCpy $ARCHIVE_NAME "qgis_sample_data.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "Alaska"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "qgis_sample_data"
+	StrCpy $CUSTOM_UNTAR_FOLDER "Alaska"
+SectionEnd
+;Uninstaller Section
+Section "Uninstall"
+	;remove files
+	Delete "$INSTDIR\Uninstall-QGIS.exe"
+	Delete "$INSTDIR\qgis.exe"
+	Delete "$INSTDIR\qgis_help.exe"
+	Delete "$INSTDIR\avcexport.exe"
+	Delete "$INSTDIR\avcimport.exe"
+	Delete "$INSTDIR\e00conv.exe"
+	Delete "$INSTDIR\gpsbabel.exe"
+	Delete "$INSTDIR\QGIS-WebSite.url"
+	Delete "$INSTDIR\*.dll"
+	Delete "$INSTDIR\icons\QGIS.ico"
+	Delete "$INSTDIR\icons\QGIS_Web.ico"
+	;remove folders
+	RMDir /r "$INSTDIR\doc"
+	RMDir /r "$INSTDIR\grass"
+	RMDir /r "$INSTDIR\i18n"
+	RMDir /r "$INSTDIR\icons"
+	RMDir /r "$INSTDIR\images"
+	RMDir /r "$INSTDIR\include"
+	RMDir /r "$INSTDIR\lib"
+	RMDir /r "$INSTDIR\msys"
+	RMDir /r "$INSTDIR\plugins"
+	RMDir /r "$INSTDIR\python"
+	RMDir /r "$INSTDIR\resources"
+	RMDir /r "$INSTDIR\svg"
+	RMDir /r "$INSTDIR\themes"
+	;if empty, remove the install folder
+	RMDir "$INSTDIR"
+	;remove the Desktop ShortCut
+	Delete "$DESKTOP\${QGIS_BASE}.lnk"
+	;remove the Programs Start ShortCut
+	RMDir /r "$SMPROGRAMS\${QGIS_BASE}"
+	;remove the Registry Entries
+	DeleteRegKey HKLM "Software\${QGIS_BASE}"
+	DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}"
+SectionEnd
+;Installer Section Descriptions
+!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecQGIS} "Install ${QGIS_BASE}"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina sample data set"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish) sample data set"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecAlaskaSDB} "Download and install the Alaska sample database (shapefiles and TIFF data)"
+!insertmacro MUI_FUNCTION_DESCRIPTION_END
\ No newline at end of file
More information about the QGIS-commit mailing list
