[QGIS Commit] r9316 - trunk/qgis/ms-windows/Installer-Files
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Sep 13 10:27:21 EDT 2008
Author: marcopx
Date: 2008-09-13 10:27:21 -0400 (Sat, 13 Sep 2008)
New Revision: 9316
Added:
   trunk/qgis/ms-windows/Installer-Files/InstallHeaderImage.bmp
   trunk/qgis/ms-windows/Installer-Files/Install_QGIS.ico
   trunk/qgis/ms-windows/Installer-Files/LICENSE.txt
   trunk/qgis/ms-windows/Installer-Files/QGIS-WebSite.URL
   trunk/qgis/ms-windows/Installer-Files/QGIS.ico
   trunk/qgis/ms-windows/Installer-Files/QGIS_Web.ico
   trunk/qgis/ms-windows/Installer-Files/UnInstallHeaderImage.bmp
   trunk/qgis/ms-windows/Installer-Files/UnWelcomeFinishPage.bmp
   trunk/qgis/ms-windows/Installer-Files/Uninstall_QGIS.ico
   trunk/qgis/ms-windows/Installer-Files/WelcomeFinishPage.bmp
Added new MS-Windows installer resources
Added: trunk/qgis/ms-windows/Installer-Files/InstallHeaderImage.bmp
(Binary files differ)
Property changes on: trunk/qgis/ms-windows/Installer-Files/InstallHeaderImage.bmp
___________________________________________________________________
   + application/octet-stream
Added: trunk/qgis/ms-windows/Installer-Files/Install_QGIS.ico
Property changes on: trunk/qgis/ms-windows/Installer-Files/Install_QGIS.ico
Added: trunk/qgis/ms-windows/Installer-Files/LICENSE.txt
--- trunk/qgis/ms-windows/Installer-Files/LICENSE.txt	                        (rev 0)
+++ trunk/qgis/ms-windows/Installer-Files/LICENSE.txt	2008-09-13 14:27:21 UTC (rev 9316)
@@ -0,0 +1,30 @@
+              QGIS is Copyright (C) QGIS Development Team
+                   and the respective authors, 2004.
+    This program is free software; you can redistribute it and/or modify
+    it under the terms of the GNU General Public License as published by
+    the Free Software Foundation; either version 2 of the License, or
+    (at your option) any later version.
+    This program is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+    GNU General Public License for more details.
+    You should have received a copy of the GNU General Public License
+    along with this program; if not, write to the Free Software
+    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
+   In addition, as a special exception, the QGIS Development Team gives
+   permission to link the code of this program with the Qt library,
+   including but not limited to the following versions (both free and
+   commercial): Qt/Non-commerical Windows, Qt/Windows, Qt/X11, Qt/Mac,
+   and Qt/Embedded (or with modified versions of Qt that use the same
+   license as Qt), and distribute linked combinations including the two.
+   You must obey the GNU General Public License in all respects for all
+   of the code used other than Qt. If you modify this file, you may
+   extend this exception to your version of the file, but you are not
+   obligated to do so. If you do not wish to do so, delete this exception
+   statement from your version.
Added: trunk/qgis/ms-windows/Installer-Files/QGIS-WebSite.URL
--- trunk/qgis/ms-windows/Installer-Files/QGIS-WebSite.URL	                        (rev 0)
+++ trunk/qgis/ms-windows/Installer-Files/QGIS-WebSite.URL	2008-09-13 14:27:21 UTC (rev 9316)
@@ -0,0 +1,2 @@
+[InternetShortcut]
+URL=http://qgis.org/
Added: trunk/qgis/ms-windows/Installer-Files/QGIS.ico
Property changes on: trunk/qgis/ms-windows/Installer-Files/QGIS.ico
Added: trunk/qgis/ms-windows/Installer-Files/QGIS_Web.ico
Property changes on: trunk/qgis/ms-windows/Installer-Files/QGIS_Web.ico
Added: trunk/qgis/ms-windows/Installer-Files/UnInstallHeaderImage.bmp
Property changes on: trunk/qgis/ms-windows/Installer-Files/UnInstallHeaderImage.bmp
Added: trunk/qgis/ms-windows/Installer-Files/UnWelcomeFinishPage.bmp
Property changes on: trunk/qgis/ms-windows/Installer-Files/UnWelcomeFinishPage.bmp
Added: trunk/qgis/ms-windows/Installer-Files/Uninstall_QGIS.ico
Property changes on: trunk/qgis/ms-windows/Installer-Files/Uninstall_QGIS.ico
Added: trunk/qgis/ms-windows/Installer-Files/WelcomeFinishPage.bmp
Property changes on: trunk/qgis/ms-windows/Installer-Files/WelcomeFinishPage.bmp
More information about the QGIS-commit mailing list
