[QGIS Commit] r9324 - in docs/trunk/english_us/user_guide: . getting_started_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Sep 14 00:50:28 EDT 2008
Author: taraathan
Date: 2008-09-14 00:50:28 -0400 (Sun, 14 Sep 2008)
New Revision: 9324
Added:
   docs/trunk/english_us/user_guide/getting_started_screenies/startup1_0_0.png
   docs/trunk/english_us/user_guide/Makefile
   docs/trunk/english_us/user_guide/getting_started.tex
   docs/trunk/english_us/user_guide/getting_started_screenies/Makefile
added the startup figure to the getting_started section.
This required adding the image into the getting_started_screenies folder and modifying the Makefile.
Also modified the sample data description, and partially revised the listing of menu items for consistency with v1.0.0
Modified: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile	2008-09-14 04:45:18 UTC (rev 9323)
+++ docs/trunk/english_us/user_guide/Makefile	2008-09-14 04:50:28 UTC (rev 9324)
@@ -80,7 +80,7 @@
 	(cd ./plugins_quick_print_images && make)
 	(cd ./plugins_spit_images && make)
 #	(cd ./plugins_python_images && make)
-#	(cd ./getting_started_screenies && make)
+	(cd ./getting_started_screenies && make)
 	(cd ./working_with_vector_screenies && make)
 	(cd ./working_with_raster_screenies && make)
 #	(cd ./working_with_ogc_screenies && make)
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex	2008-09-14 04:45:18 UTC (rev 9323)
+++ docs/trunk/english_us/user_guide/getting_started.tex	2008-09-14 04:50:28 UTC (rev 9324)
@@ -10,8 +10,8 @@
 \subsection{Installation}\label{label_installation}
 \index{installation}
-Building QGIS from source is documented in Appendix \ref{sec:install_windows} for windows,
-Appendix \ref{sec:install_macosx} for Mac OSX and Appendix \ref{sec:install_linux} for GNU/Linux.
+Building QGIS from source is documented in \win Appendix \ref{sec:install_windows} for windows,
+\osx Appendix \ref{sec:install_macosx} for Mac OSX and \nix Appendix \ref{sec:install_linux} for GNU/Linux.
 The Installation instructions are distributed with the QGIS source code and also available
 at \url{http://qgis.org}.
@@ -22,10 +22,25 @@
 \subsection{Sample Data}\label{label_sampledata}
 \index{data!sample}
-If you do not have any GIS data handy, you can obtain an Alaska
-dataset from the QGIS web site at \url{http://qgis.org}. The projection
-for the data is Alaska Albers Equal Area with unit meter:
+The user guide contains examples based on the QGIS sample dataset.
+\win The Windows installer has an option to download the QGIS sample dataset.
+If checked, the data will be downloaded to your "My Documents" folder and placed
+in a folder called "GIS Database".
+You may use Windows Explorer to move this folder to any convenient location.
+If you did not select the checkbox to install the sample dataset
+during the initial QGIS installation, you can either
+\begin{itemize}
+\item{use GIS data that you already have;}
+\item{download the sample data from the QGIS website
+ \url{http://qgis.org} on the Downloads page; or}
+\item{uninstall QGIS and reinstall with the data download option checked.}
+\end{itemize}
+%FIXME- what about Mac and *nix?
+The projection
+for the QGIS sample dataset is Alaska Albers Equal Area with unit meter:
 \begin{verbatim}
 PROJCS["NAD_1927_Albers",
     GEOGCS["GCS_North_American_1927",
@@ -42,34 +57,35 @@
     PARAMETER ["Latitude_Of_Origin",50.0],
     UNIT["Meter",1.0]]
 \end{verbatim}
+The Alaska dataset includes all GIS data that are used as examples and
+screenshots in the user guide, and includes a GRASS database.
-For use with GRASS, a sample GRASS database (e.g. Spearfish) can be obtained
-from the official GRASS GIS-website \url{http://grass.osgeo.org/download/data.php}.
-The projection of the Spearfish dataset is UTM Zone 13, Northern Hemisphere:
+%Additional GRASS data sets (e.g. Spearfish, South Dakota) can be obtained
+%from the official GRASS GIS-website \url{http://grass.osgeo.org/download/data.php}.
+%The Spearfish data set is used in GRASS tutorials
+%The projection of the Spearfish dataset is UTM Zone 13, Northern Hemisphere:
+%\begin{verbatim}
+%PROJCS["UTM Zone 13, Northern Hemisphere",
+%    GEOGCS["clark66",
+%        DATUM["North_American_Datum_1927",
+%            SPHEROID["clark66",6378206.4,294.9786982]],
+%        PRIMEM["Greenwich",0],
+%        UNIT["degree",0.0174532925199433]],
+%    PROJECTION["Transverse_Mercator"],
+%    PARAMETER["latitude_of_origin",0],
+%    PARAMETER["central_meridian",-105],
+%    PARAMETER["scale_factor",0.9996],
+%    PARAMETER["false_easting",500000],
+%    PARAMETER["false_northing",0],
+%    UNIT["meter",1]]
+%\end{verbatim}
-\begin{verbatim}
-PROJCS["UTM Zone 13, Northern Hemisphere",
-    GEOGCS["clark66",
-        DATUM["North_American_Datum_1927",
-            SPHEROID["clark66",6378206.4,294.9786982]],
-        PRIMEM["Greenwich",0],
-        UNIT["degree",0.0174532925199433]],
-    PROJECTION["Transverse_Mercator"],
-    PARAMETER["latitude_of_origin",0],
-    PARAMETER["central_meridian",-105],
-    PARAMETER["scale_factor",0.9996],
-    PARAMETER["false_easting",500000],
-    PARAMETER["false_northing",0],
-    UNIT["meter",1]]
-\end{verbatim}
-These data sets will be used as a basis for many of the examples and
-screenshots in this document.
 \subsection{Starting QGIS}\label{label_startinqgis}
 \begin{itemize}
-\item \nix{assuming that QGIS is installed in the PATH, you can start QGIS by typing: \usertext{qgis}  at a command prompt or by double clicking on the QGIS
+\item \nix{assuming that QGIS is installed in the PATH, you can start QGIS
+by typing: \usertext{qgis}  at a command prompt or by double clicking on the QGIS
 application link (or shortcut) on the desktop.}
 \item \win{start QGIS using the Start menu or desktop shortcut.}
 \item \osx{double click the icon in your Applications folder.}
@@ -78,14 +94,14 @@
 \subsubsection{Command Line Options}\index{command line options}
 \label{label_commandline}
-QGIS supports a number of options when started from the command line. To
+\nix QGIS supports a number of options when started from the command line. To
 get a list of the options, enter \usertext{qgis ---help} on the command line.
 The usage statement for QGIS is:
 \small
 \begin{verbatim}
 qgis --help
-Quantum GIS - 0.9.0 'Ganymede'
+Quantum GIS - 1.0.0 'Kore'
 Quantum GIS (QGIS) is a viewer for spatial data sets, including
 raster and vector data.
 Usage: qgis [options] [FILES]
@@ -152,12 +168,13 @@
 (the numbers 1 through 6 in blue ovals refer to the six major areas of the
 interface as discussed below):
-%\begin{figure}[ht]
-%   \begin{center}
-%   \caption{Main window with alaska sample data (GNU/Linux with KDE)}\label{fig:startup}
-%   \includegraphics[clip=true, width=17cm]{startup09}
-%\end{center}
-%\end{figure}
+\begin{figure}[ht]
+   \begin{center}
+   \caption{QGIS GUI with Alaska sample data \wincaption}
+	 \label{fig:startup}
+   \includegraphics[clip=true, width=17cm]{startup1_0_0}
+\end{center}
+\end{figure}
 \textbf{Note:} Your window decorations (title bar, etc.) may appear
 different depending on your operating system and window manager.
@@ -189,23 +206,48 @@
 \item \dropmenuopt{Save Project}         - see Section \ref{sec:projects}
 \item \dropmenuopt{Save Project As}      - see Section \ref{sec:projects}
 \item \dropmenuopt{Save as Image}
-\item \dropmenuopt{Export to MapServer Map}       - see Section \ref{sec:mapserver_export}
-\item \dropmenuopt{Print}                         - see Section \ref{label_mapcomposer}
+%\item \dropmenuopt{Export to MapServer Map}       - see Section \ref{sec:mapserver_export}
+\item \dropmenuopt{Print Composer}                         - see Section \ref{label_mapcomposer}
 \item \dropmenuopt{Exit}
 \end{itemize}
+\item \mainmenuopt{Edit}  -see Section \ref{sec:edit_existing_layer}
+\begin{itemize}
+\item Cut Features
+\item Copy Features
+\item Paste Features
+\item Capture Point
+\item Capture Line
+\item Capture Polygon
+\item Move Feature
+\item Split Features
+\item Delete Selected
+\item Add Vertex
+\item Move Vertex
+\item Delete Vertex
+\item Add Ring
+\item Add Island
+\end{itemize}
 \item \mainmenuopt{View}
 \begin{itemize}
+\item \dropmenuopt{Pan Map}
+\item \dropmenuopt{Zoom In}
+\item \dropmenuopt{Zoom Out}
+\item \dropmenuopt{Select Features}
+\item \dropmenuopt{Identify Features}
+\item \dropmenuopt{Measure Line}
+\item \dropmenuopt{Measure Area}
 \item \dropmenuopt{Zoom Full}
+\item \dropmenuopt{Zoom To Layer}
 \item \dropmenuopt{Zoom To Selection}
-\item \dropmenuopt{Zoom To Layer}
 \item \dropmenuopt{Zoom Last}
+\item \dropmenuopt{Zoom Actual Size}
+\item \dropmenuopt{Map Tips}
+\item \dropmenuopt{New Bookmark}
+\item \dropmenuopt{Show Bookmarks}
 \item \dropmenuopt{Refresh}
-\item \dropmenuopt{Show Bookmarks}
-\item \dropmenuopt{New Bookmark}
-\item \dropmenuopt{Show most toolbars}
-\item \dropmenuopt{Hide most toolbars}
-\item \dropmenuopt{Toolbar Visibility}
 \end{itemize}
 \item \mainmenuopt{Layer}
Modified: docs/trunk/english_us/user_guide/getting_started_screenies/Makefile
--- docs/trunk/english_us/user_guide/getting_started_screenies/Makefile	2008-09-14 04:45:18 UTC (rev 9323)
+++ docs/trunk/english_us/user_guide/getting_started_screenies/Makefile	2008-09-14 04:50:28 UTC (rev 9324)
@@ -10,7 +10,7 @@
 # with .eps extension:
 # JPG=qgis_icon_new_verylarge.eps\
-#PNG=startup09.eps\
+PNG=startup1_0_0.eps\
 ##### TARGETS #####
Added: docs/trunk/english_us/user_guide/getting_started_screenies/startup1_0_0.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/getting_started_screenies/startup1_0_0.png
___________________________________________________________________
   + image/png
More information about the QGIS-commit mailing list
