[QGIS Commit] r9372 - in docs/trunk/english_us/user_guide: .
grass_integration_screenies image_templates
svn_qgis at osgeo.org
Mon Sep 22 09:50:03 EDT 2008
Author: dassau
Date: 2008-09-22 09:50:03 -0400 (Mon, 22 Sep 2008)
New Revision: 9372
Added:
docs/trunk/english_us/user_guide/grass_integration_screenies/grass_location.png
docs/trunk/english_us/user_guide/image_templates/
docs/trunk/english_us/user_guide/image_templates/README.txt
docs/trunk/english_us/user_guide/image_templates/grass_location.odg
docs/trunk/english_us/user_guide/cited_lit.bib
docs/trunk/english_us/user_guide/grass_integration.tex
docs/trunk/english_us/user_guide/grass_integration_screenies/Makefile
added folder image_templates for figures created with external software
finished grass_integration chapter, now ready for proof reading
Modified: docs/trunk/english_us/user_guide/cited_lit.bib
--- docs/trunk/english_us/user_guide/cited_lit.bib 2008-09-21 19:45:54 UTC (rev 9371)
+++ docs/trunk/english_us/user_guide/cited_lit.bib 2008-09-22 13:50:03 UTC (rev 9372)
@@ -17,3 +17,9 @@
Conference Victoria, BC},
YEAR = 2007,
+ at BOOKLET {neteler_mitasova07,
+AUTHOR = {M. Neteler and H. Mitasova},
+TITLE = {Open Source GIS: A GRASS GIS Approach. 3. Edition, Springer, New York},
+YEAR = 2007,
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex 2008-09-21 19:45:54 UTC (rev 9371)
+++ docs/trunk/english_us/user_guide/grass_integration.tex 2008-09-22 13:50:03 UTC (rev 9372)
@@ -7,7 +7,7 @@
The GRASS plugin provides access to GRASS GIS~\cite{GRASSweb} databases and functionalities. This includes visualization of GRASS raster and vector layers, digitizing vector layers, editing vector attributes, creating new vector layers and analysing GRASS 2D and 3D data with more than 300 GRASS modules.
In this Section we'll introduce the plugin functionalities and give some
-examples on managing and working with GRASS data. Following main features are provided with the toolbar menu, when you start the GRASS plugin, as described in Section~\ref{starting_grass}:
+examples on managing and working with GRASS data. Following main features are provided with the toolbar menu, when you start the GRASS plugin, as described in Section~\ref{sec:starting_grass}:
\begin{itemize}
\item \toolbtntwo{grass_open_mapset}{Open mapset}
@@ -28,15 +28,15 @@
To use GRASS functionalities and/or visualize GRASS vector and raster layers in QGIS, you must select and load the GRASS plugin with the Plugin Manager. Therefore click the menu \mainmenuopt{Plugins} > \mainmenuopt{Manage Plugins}, select \dropmenuopt{GRASS} and click \button{OK}.
-You can now start loading raster and vector layers from an existing GRASS location (see Section \ref{sec:load_grassdata}). Or you create a new GRASS \filename{location} with QGIS (see Section \ref{sec:create_loc}) and import some raster and vector data (see Section \ref{sec:import_loc_data}) for further analysis with the GRASS Toolbox (see Section \ref{subsec:grass_toolbox}).
+You can now start loading raster and vector layers from an existing GRASS \filename{LOCATION} (see Section \ref{sec:load_grassdata}). Or you create a new GRASS \filename{LOCATION} with QGIS (see Section \ref{sec:create_loc}) and import some raster and vector data (see Section \ref{sec:import_loc_data}) for further analysis with the GRASS Toolbox (see Section \ref{subsec:grass_toolbox}).
\subsection{Loading GRASS raster and vector layers}\label{sec:load_grassdata}\index{GRASS!loading
data}
With the GRASS plugin, you can load vector or raster layers using the
-appropriate button on the toolbar. As an example we use the QGIS alaska
-dataset. It includes a small sample GRASS location with 3 vector layers and 1
-raster elevation map (see Section \ref{label_sampledata}).
+appropriate button on the toolbar menu. As an example we use the QGIS alaska
+dataset (see Section \ref{label_sampledata}). It includes a small sample GRASS
+\filename{LOCATION} with 3 vector layers and 1 raster elevation map.
\begin{enumerate}
\item Create a new folder \filename{grassdata}, download the QGIS alaska
@@ -46,21 +46,20 @@
\item Start QGIS.
\item If not already done in a previous QGIS session, load the GRASS plugin
clicking on \mainmenuopt{Plugins} > \mainmenuopt{Manage Plugins} and
- selecting \dropmenuopt{GRASS}. The GRASS toolbar appears on the user
- interface.
- \item In the GRASS toolbar, click on the \toolbtntwo{grass_open_mapset}{Open
- mapset} icon to bring up the mapset wizard.
+ selecting \dropmenuopt{GRASS}. The GRASS toolbar appears on the toolbar menu.
+ \item In the GRASS toolbar, click the \toolbtntwo{grass_open_mapset}{Open
+ mapset} icon to bring up the \filename{MAPSET} wizard.
\item For \filename{Gisdbase} browse and select or enter the path to the
newly created folder \filename{grassdata}.
- \item You should now be able to select the location \filename{alaska}
- and the mapset \filename{demo}.
- \item Click \button{OK}. Notice that some of the tools in the GRASS toolbar
- that were disabled are now enabled.
+ \item You should now be able to select the \filename{LOCATION alaska}
+ and the MAPSET \filename{demo}.
+ \item Click \button{OK}. Notice that some previously disabled tools in the
+ GRASS toolbar are now enabled.
\item Click on \toolbtntwo{grass_add_raster}{Add GRASS raster layer},
choose the map name \filename{gtopo30} and click \button{OK}. The elevation
- layer will be visualized.
+ layer will be visualized.
\item Click on \toolbtntwo{grass_add_vector}{Add GRASS vector layer},
- choose the map name \filename{alaska} and click \button{OK}. Now the alaska
+ choose the map name \filename{alaska} and click \button{OK}. The alaska
boundary vector layer will be overlayed on top of the gtopo30 map. You can
now adapt the layer properties as described in chapter \ref{sec:vectorprops},
e.g. change opacity, fill and outline color.
@@ -69,9 +68,7 @@
\end{enumerate}
As you see, it is very simple to load GRASS raster and vector layers in QGIS.
-See following sections for editing GRASS data and creating new locations.
-More sample GRASS locations are available at the GRASS website at
-\url{http://grass.osgeo.org/download/data.php}.
+See following Sections for editing GRASS data and creating a new \filename{LOCATION}. More sample GRASS \filename{LOCATIONs} are available at the GRASS website at \url{http://grass.osgeo.org/download/data.php}.
\begin{Tip}\caption{\textsc{GRASS Data Loading}}
\qgistip{If you have problems loading data or QGIS terminates abnormally,
@@ -80,91 +77,115 @@
\end{Tip}
-\subsection{Creating a GRASS location and new mapsets}\label{sec:create_loc}
+\subsection{GRASS LOCATION and MAPSET}\label{sec:create_loc}
-In order to analyse your vector and raster layers with GRASS modules, you
-must import your data into a GRASS database, called \filename{location}.\footnote{This is not strictly true - with the GRASS modules \filename{r.external} and \filename{v.external} you can create read-only links to external GDAL/OGR-supported data sets without importing them. Because this is not the usual way for beginners to work with GRASS, we will not describe this functionality here.} A
-location represents a specific area with a specific coordinate
-system.
+GRASS data are stored in a directory referred to as GISDBASE. This directory often called \filename{grassdata}, must be created before you start working with the GRASS plugin in QGIS. Within this directory, the GRASS GIS data
+are organized by projects stored in subdirectories called \filename{LOCATION}. Each \filename{LOCATION} is defined by its coordinate system, map projection
+and geographical boundaries. Each \filename{LOCATION} can have several
+\filename{MAPSETs} (subdirectories of the \filename{LOCATION}) that are used
+to subdivide the project into different topics, subregions, or as workspaces
+for individual team members (Neteler \& Mitasova 2007 \cite{neteler_mitasova07}). In order to analyse vector and raster layers with GRASS modules, you must import them into a GRASS \filename{LOCATION}.\footnote{This is not strictly true - with the GRASS modules \filename{r.external} and \filename{v.external} you can create read-only links to external GDAL/OGR-supported data sets without importing them. But because this is not the usual way for beginners to work with GRASS, this functionality will not be described here.}
\begin{figure}[ht]
\begin{center}
-\caption{Creating a new GRASS location or a new mapset in QGIS \nixcaption}\label{fig:grass_location}\smallskip
-\includegraphics[clip=true]{create_grass_location}
+\caption{GRASS data organized in the alaska LOCATION (adapted from Neteler \& Mitasova 2007 \cite{neteler_mitasova07})}\label{fig:grass_location}\smallskip
+\includegraphics[clip=true]{grass_location}
\end{center}
\end{figure}
+\subsubsection{Creating a new GRASS LOCATION}\label{sec:create_loc}
As an an example you find the instructions how the sample GRASS
-location \filename{alaska}, which is projected in Albers Equal Area
+\filename{LOCATION alaska}, which is projected in Albers Equal Area
projection with unit meter was created for the QGIS sample dataset. This
-sample GRASS location \filename{alaska} will be used for all examples and
-exercises in the following GRASS GIS related chapters, so it is useful to
+sample GRASS \filename{LOCATION alaska} will be used for all examples and
+exercises in the following GRASS GIS related chapters. It is useful to
download and install the dataset on your computer \ref{label_sampledata}).
+\begin{figure}[ht]
+\begin{center}
+\caption{Creating a new GRASS LOCATION or a new MAPSET in QGIS \nixcaption}\label{fig:create_grass_location}\smallskip
+\includegraphics[clip=true]{create_grass_location}
+\end{center}
+\end{figure}
\begin{enumerate}
\item Start QGIS and make sure the GRASS plugin is loaded
- \item Visualize the \filename{alaska.shp} shapefile (see Section
- \ref{sec:load_shapefile}) from the QGIS alaska dataset.
+ \item Visualize the \filename{alaska.shp} Shapefile (see Section
+ \ref{sec:load_shapefile}) from the QGIS alaska dataset~\ref{label_sampledata}.
- \item Each location is stored in a directory usually named
- \filename{grassdata}. Select an existing GRASS database folder, usually
- named \filename{grassdata} or create one for storing the new location.
- \item Click \button{Next}.
- \item We can use this wizard to create a new mapset within an existing
- location or to create a new location altogether. Click on the radio button
- \radiobuttonon{Create new location} (see Figure \ref{fig:grass_location}).
- \item Enter a name for the location - we used alaska
+ \item Select an existing GRASS database (GISDBASE) folder
+ \filename{grassdata} or create one for the new \filename{LOCATION} using a
+ file manager on your computer. Then click \button{Next}.
+ \item We can use this wizard to create a new \filename{MAPSET} within an
+ existing \filename{LOCATION} (see Section~\ref{sec:add_mapset}) or to create
+ a new \filename{LOCATION} altogether. Click on the radio button
+ \radiobuttonon{Create new location} (see Figure \ref{fig:create_grass_location}).
+ \item Enter a name for the \filename{LOCATION} - we used alaska and click
+ \button{Next}
\item Define the projection by clicking on the radio button
\radiobuttonon{Projection} to enable the projection list
\item We are using Albers Equal Area Alaska (meters) projection. Since we
happen to know that it is represented by the EPSG ID 5000, we enter it in
- the search box. (If you want to repeat this process for another location
- and projection and haven't memorized the EPSG ID, click on the
+ the search box. (Note: If you want to repeat this process for another
+ \filename{LOCATION} and projection and haven't memorized the EPSG ID,
+ click on the
\toolbtntwo{mIconProjectionEnabled}{projector} icon in the lower right-hand
- corner of the status bar (see Section \ref{label_projstart}).
+ corner of the status bar (see Section \ref{label_projstart})).
\item Click \button{Find} to select the projection
- \item To define the default region, we have to enter the boundaries in the
- north, south, east, and west direction. Here we simply click on the button
- \button{Set current QGIS extent}, to apply the extend of the loaded layer
- \filename{alaska.shp} as the GRASS default region extend.
+ \item To define the default region, we have to enter the \filename{LOCATION} bounds in north, south, east, and west direction. Here we simply click on the button \button{Set current QGIS extent}, to apply the extend of the loaded layer \filename{alaska.shp} as the GRASS default region extend.
- \item We need to define a mapset within our new location. You can name it
- whatever you like - we used demo. Later you will see, that another standard
- mapset named \filename{PERMANENT} was automatically created, too. It has to
- exist and includes important definitions and configurations for the
- location.
+ \item We also need to define a \filename{MAPSET} within our new \filename{LOCATION}. You can name it whatever you like - we used demo.\footnote{When creating a new \filename{LOCATION}, GRASS automatically creates a special \filename{MAPSET} called \filename{PERMANENT} designed to
+ store the core data for the project, its default spatial extend and coordinate system definitions (Neteler \& Mitasova 2007 \cite{neteler_mitasova07}).}
\item Check out the summary to make sure it's correct and click
\button{Finish}
- \item The new location \filename{alaska} and two mapsets \filename{demo}
+ \item The new \filename{LOCATION alaska} and two \filename{MAPSETs} \filename{demo}
and \filename{PERMANENT} are created. The currently opened working set is
- mapset \filename{demo}, as you defined.
+ \filename{MAPSET demo}, as you defined.
\item Notice that some of the tools in the GRASS toolbar that were
- disabled are now enabled for us to use.
+ disabled are now enabled.
\end{enumerate}
If that seemed like a lot of steps, it's really not all that bad and a very
-quick way to create a location. The location \filename{alaska} is now ready for data import (see Section \ref{sec:import_loc_data}).
-Or you can use the already existing vector and raster data in the sample
-GRASS location \filename{alaska} included in the QGIS alaska dataset \ref{label_sampledata} and move on to Section \ref{label_vectmodel}.
+quick way to create a \filename{LOCATION}. The \filename{LOCATION alaska} is now ready for data import (see Section \ref{sec:import_loc_data}).
+You can also use the already existing vector and raster data in the sample GRASS \filename{LOCATION alaska} included in the QGIS alaska dataset \ref{label_sampledata} and move on to Section \ref{label_vectmodel}.
-\subsection{Importing data into a GRASS location}\label{sec:import_loc_data}
+\subsubsection{Adding a new MAPSET}\label{sec:add_mapset}
-This Section gives an example how to import raster and vector data into the \filename{alaska} GRASS location provided by the QGIS alaska dataset. Therefore we use a landcover raster map \filename{landcover.tif} and a vector polygone Shape \filename{lakes.shp} from the QGIS alaska dataset \ref{label_sampledata}.
+A user has only write access to a GRASS \filename{MAPSET} he created. This means, besides access to his own \filename{MAPSET}, each user can also read maps in other user's \filename{MAPSETs}, but he can modify or remove only the maps in his own \filename{MAPSET}. All \filename{MAPSETs} include a \filename{WIND} file that stores the current boundary coordinate values and
+the currently selected raster resolution (Neteler \& Mitasova 2007 \cite{neteler_mitasova07}, see Section \ref{sec:grass_region}).
\begin{enumerate}
+ \item Start QGIS and make sure the GRASS plugin is loaded
+ \item In the GRASS toolbar, click on the \toolbtntwo{grass_open_mapset}{Open
+ \item Select the GRASS database (GISDBASE) folder \filename{grassdata}
+ with the \filename{LOCATION alaska}, where we want to add a further \filename{MAPSET}, called test.
+ \item Click \button{Next}.
+ \item We can use this wizard to create a new \filename{MAPSET} within an existing \filename{LOCATION} or to create a new \filename{LOCATION} altogether. Click on the radio button \radiobuttonon{Select location}
+ (see Figure \ref{fig:create_grass_location}) and click \button{Next}.
+ \item Enter the name \filename{text} for the new \filename{MAPSET}. Below
+ in the wizard you see a list of existing \filename{MAPSETs} and its owners.
+ \item Click \button{Next}, check out the summary to make sure it's all correct and click \button{Finish}
+\end{enumerate}
+\subsection{Importing data into a GRASS LOCATION}\label{sec:import_loc_data}
+This Section gives an example how to import raster and vector data into the \filename{alaska} GRASS \filename{LOCATION} provided by the QGIS alaska dataset. Therefore we use a landcover raster map \filename{landcover.tif} and a vector polygone Shape \filename{lakes.shp} from the QGIS alaska dataset \ref{label_sampledata}.
+\begin{enumerate}
\item Start QGIS and make sure the GRASS plugin is loaded.
- \item Select as GRASS database the folder \filename{grassdata} in the QGIS alaska dataset, as location \filename{alaska}, as mapset \filename{demo} and click \button{OK}.
+ MAPSET} icon to bring up the \filename{MAPSET} wizard.
+ \item Select as GRASS database the folder \filename{grassdata} in the QGIS alaska dataset, as \filename{LOCATION alaska}, as \filename{MAPSET} \filename{demo} and click \button{OK}.
\item Now click the \toolbtntwo{grass_tools}{Open GRASS tools} icon. The GRASS Toolbox (see Section \ref{subsec:grass_toolbox}) dialog appears.
- \item To import the raster map \filename{landcover.tif}, click the module \filename{r.in.gdal} in the \tab{Modules Tree} tab. This GRASS module allows to import GDAL supported raster files into a GRASS location. The module dialog for \filename{r.in.gdal} appears.
+ \item To import the raster map \filename{landcover.tif}, click the module \filename{r.in.gdal} in the \tab{Modules Tree} tab. This GRASS module allows to import GDAL supported raster files into a GRASS \filename{LOCATION}. The module dialog for \filename{r.in.gdal} appears.
\item Browse to the folder \filename{raster} in the QGIS alaska dataset and select the file \filename{landcover.tif}.
\item As raster output name define \filename{landcover\_grass} and click \button{Run}. In the \tab{Output} tab you see the currently running GRASS command \filename{r.in.gdal -o input=/path/to/landcover.tif output=landcover\_grass}.
\item When it says \textbf{Succesfully finished} click \button{View output}. The \filename{landcover\_grass} raster layer is now imported into GRASS and will be visualized in the QGIS canvas.
- \item To import the vector shape \filename{lakes.shp}, click the module \filename{v.in.ogr} in the \tab{Modules Tree} tab. This GRASS module allows to import OGR supported vector files into a GRASS location. The module dialog for \filename{v.in.ogr} appears.
+ \item To import the vector shape \filename{lakes.shp}, click the module \filename{v.in.ogr} in the \tab{Modules Tree} tab. This GRASS module allows to import OGR supported vector files into a GRASS \filename{LOCATION}. The module dialog for \filename{v.in.ogr} appears.
\item Browse to the folder \filename{vmap0\_shapefiles} in the QGIS alaska dataset and select the file \filename{lakes.shp} as OGR file.
\item As vector output name define \filename{lakes\_grass} and click \button{Run}. You don't have to care about the other options in this example. In the \tab{Output} tab you see the currently running GRASS command \filename{v.in.ogr -o dsn=/path/to/lakes.shp output=lakes\_grass}.
\item When it says \textbf{Succesfully finished} click \button{View output}. The \filename{lakes\_grass} vector layer is now imported into GRASS and will be visualized in the QGIS canvas.
@@ -204,7 +225,7 @@
For now, it can be only a number, in the future GRASS will also support
names as fields in the user interface.
-Attributes can be stored inside the GRASS location as DBase or SQLITE3 or in
+Attributes can be stored inside the GRASS \filename{LOCATION} as DBase or SQLITE3 or in
external database tables, for example PostgreSQL, MySQL, Oracle,
etc.\index{GRASS!attribute storage}
@@ -226,7 +247,7 @@
To create a new GRASS vector layer with the GRASS plugin click the \toolbtntwo{grass_new_vector_layer}{Create new GRASS vector} toolbar icon. Enter a name in the text box and you can start digitizing point, line or polygone geometries, following the procedure described in Section \ref{grass_digitising}.
-In GRASS it is possible to organize all sort of geometry types (point, line and area) in one layer, because GRASS uses a topological vector model, so you don't need to select the geometry type when creating a new GRASS vector. This only applies to Shapefile creation with QGIS, because Shapefiles use the Simple Feature vector model (see Section \ref{sec:create shape}).
+In GRASS it is possible to organize all sort of geometry types (point, line and area) in one layer, because GRASS uses a topological vector model, so you don't need to select the geometry type when creating a new GRASS vector. This is different from Shapefile creation with QGIS, because Shapefiles use the Simple Feature vector model (see Section \ref{sec:create shape}).
\begin{Tip}\caption{\textsc{Creating an attribute table for a new GRASS vector layer}}
\qgistip{
@@ -234,8 +255,6 @@
\end{Tip}
-If you encounter a greyed-out button, make sure you have a working mapset enabled. If you forgot how to enable a mapset have a look at Section \ref{sec:load_grassdata}.
\subsection{Digitizing and editing a GRASS vector layer}\index{GRASS!digitizing tools}\label{grass_digitising}
The digitizing tools for GRASS vector layers are accessed using the
@@ -290,15 +309,14 @@
& Edit attributes of selected element (note that one element can represent
more features, see above)\\
\hline \includegraphics[width=0.7cm]{grass_close_edit} & Close & Close
-digitizing session and save current status (rebuilds topology afterwards)\\
+session and save current status (rebuilds topology afterwards)\\
\hline
\end{tabular}
\end{table}
\minisec{Category Tab}\index{GRASS!category settings}
-The \tab{Category} tab allows you to set the way in which the category will
-be assigned to each new feature and/or assign a category to a feature.
+The \tab{Category} tab allows you to define the way in which the category values will be assigned to a new geometry element.
\begin{figure}[h]
\begin{center}
@@ -308,17 +326,17 @@
\end{figure}
\begin{itemize}
-\item \textbf{Mode}: what category value shall be applied to geometry element
+\item \textbf{Mode}: what category value shall be applied to new geometry elements.
\begin{itemize}
\item Next not used - apply next not yet used category value to geometry
-element
+element.
\item Manual entry - manually define the category value for the geometry
-element in the 'Category'-entry field
+element in the 'Category'-entry field.
\item No category - Do not apply a category value to the geometry element.
This is e.g. used for area boundaries, because the category values are
connected via the centroid.
\end{itemize}
-\item \textbf{Category} - A number (ID) attached to each digitized geometry
+\item \textbf{Category} - A number (ID) is attached to each digitized geometry
element. It is used to connect each geometry element with its attributes.
\item \textbf{Field (layer)} - Each geometry element can be connected with
several attribute tables using different GRASS geometry layers. Default layer
@@ -337,7 +355,7 @@
The \tab{Settings} tab allows you to set the snapping in screen pixels. The
threshold defines at what distance new points or line ends are snapped to
-existing nodes. This helps prevent gaps or dangles between boundaries. The
+existing nodes. This helps to prevent gaps or dangles between boundaries. The
default is set to 10 pixels.
\begin{figure}[h]
@@ -363,8 +381,8 @@
\minisec{Table Tab} \index{GRASS!table editing}
The \tab{Table} tab provides information about the database table for
-a given 'layer'. Here you can add new colums to an existing attribute table,
-or create a new database table for a new GRASS vector layer.
+a given 'layer'. Here you can add new columns to an existing attribute table,
+or create a new database table for a new GRASS vector layer (see Section \ref{sec:creating_new_grass_vectors}).
\begin{figure}[h]
\begin{center}
@@ -375,22 +393,21 @@
\begin{Tip}\caption{\textsc{GRASS Edit Permissions}}\index{GRASS!edit
permissions}
-\qgistip{You must be the owner of the GRASS mapset you want to edit. It is
-impossible to edit vectors in mapsets which are not yours, even if you have
-write permissions.
+\qgistip{You must be the owner of the GRASS \filename{MAPSET} you want to edit. It is
+impossible to edit data layers in a \filename{MAPSET} that is not yours, even if you have write permissions.
\end{Tip}
-\subsection{The GRASS region tool}\index{GRASS!region}
+\subsection{The GRASS region tool}\label{sec:grass_region}\index{GRASS!region}
-The region definition (setting a spatial working window) in GRASS is only,
-but very important for all raster analysis. Vector analysis are not limited
+The region definition (setting a spatial working window) in GRASS is important
+for working with raster layers. Vector analysis is per default not limited
to any defined region definitions. All newly-created rasters will have the
spatial extension and resolution of the currently defined GRASS region,
regardless of their original extension and resolution. The current GRASS
-region is stored in \filename{\$LOCATION/\$MAPSET/WIND} file, and it defines
-north, south, east, west, number of columns, number of rows, horizontal and
-vertical spatial resolution.
+region is stored in the \filename{\$LOCATION/\$MAPSET/WIND} file, and it defines
+north, south, east and west bounds, number of columns and rows, horizontal
+and vertical spatial resolution.
It is possible to switch on/off the visualization of the GRASS region in the
QGIS canvas using the \toolbtntwo{grass_region}{Display current GRASS region}
@@ -398,17 +415,16 @@
With the \toolbtntwo{grass_region_edit}{Edit current GRASS region} icon you
can open a dialog to change the current region and the symbology of the GRASS region rectangle in the QGIS canvas. Type in the new region bounds and
-resolution and click \button{OK}. It also allows to select a new region interactively with your mouse on the QGIS canvas. Therefore click with the left mouse button in the QGIS canvas, open a rectangle, close it using the left mouse button again and click \button{OK}.
-\index{GRASS!region!editing}
+resolution and click \button{OK}. It also allows to select a new region interactively with your mouse on the QGIS canvas. Therefore click with the left mouse button in the QGIS canvas, open a rectangle, close it using the left mouse button again and click \button{OK}.\index{GRASS!region!editing} The GRASS module \filename{g.region} provide a lot more parameters to define an appropriate region extend and resolution for your raster analysis. You can use these parameters with the GRASS Toolbox, described in Section \ref{subsec:grass_toolbox}.
\subsection{The GRASS toolbox}\label{subsec:grass_toolbox}\index{GRASS!toolbox}
The \toolbtntwo{grass_tools}{Open GRASS Tools} box provides GRASS
-module functionalities to work with data inside a selected GRASS location
-and mapset. To use the GRASS toolbox you need to open a location and mapset where
-you have write-permission (usually granted, if you created the mapset). This is
+module functionalities to work with data inside a selected GRASS \filename{LOCATION}
+and \filename{MAPSET}. To use the GRASS toolbox you need to open a \filename{LOCATION} and \filename{MAPSET} where
+you have write-permission (usually granted, if you created the \filename{MAPSET}). This is
necessary, because new raster or vector layers created during analysis need to
-be written to the currently selected location mapset.
+be written to the currently selected \filename{LOCATION} and \filename{MAPSET}.
\subsubsection{Working with GRASS modules}\index{GRASS!toolbox}
@@ -423,18 +439,17 @@
than 300) GRASS modules in command line modus. To offer a more user
friendly working environment, about 200 of the available GRASS modules and
functionalities are also provided by graphical dialogs. These dialogs are
-grouped in thematic blocks and searchable. You find a complete list of modules
-available in QGIS version \CURRENT in appendix \ref{appdx_grass_toolbox_modules}.
-It is also possible to customize the GRASS Toolbox content. It is described in
-Section \ref{sec:toolbox-customizing}.
+grouped in thematic blocks, but are searchable as well. You find a complete
+list of GRASS modules available in QGIS version \CURRENT
+in appendix \ref{appdx_grass_toolbox_modules}. It is also possible to
+customize the GRASS Toolbox content. It is described in Section \ref{sec:toolbox-customizing}.
-As shown in Figure \ref{fig:grass_modules}, you can look for the appropriate GRASS module
-using the thematically grouped \tab{Modules Tree} or the searchable \tab{Modules List} tab.
+As shown in Figure \ref{fig:grass_modules}, you can look for the appropriate GRASS module using the thematically grouped \tab{Modules Tree} or the searchable \tab{Modules List} tab.
-Clicking on a grapical module icon a new tab will be added to the toolbox dialog
-providing three new sub-tabs \tab{Options}, \tab{Output} and \tab{Manual}.
+Clicking on a grapical module icon a new tab will be added to the toolbox dialog providing three new sub-tabs \tab{Options}, \tab{Output} and
+\tab{Manual}. In Figure \ref{fig:grass_module_dialog} you see an example
+for the GRASS module \filename{v.buffer}.
\begin{figure}[h]
\centering
\caption{GRASS Toolbox Module Dialogs \nixcaption}\label{fig:grass_module_dialog}
@@ -445,26 +460,22 @@
\minisec{Options}
-The \tab{Options} tab provides a simplified module dialog where you need to
-select necessary map visualized in the QGIS canvas and enter parameters to run
-the module. The provided module parameters are often not complete to keep the dialog
-clear. If you want to use further module parameters and flags, you need to start the
-GRASS Shell and run the module in the command line.
+The \tab{Options} tab provides a simplified module dialog where you can
+usually select a raster or vector layer visualized in the QGIS canvas and
+enter further module specific parameters to run the module. The provided
+module parameters are often not complete to keep the dialog
+clear. If you want to use further module parameters and flags, you need to start the GRASS Shell and run the module in the command line.
\minisec{Output}
-The \tab{Output} tab provides information about the output status of the module. After
-you click the \button{Run} button, the module switches to the Output-tab and you see
-information about the analysis process. If all goes well, you will finally see a
-\usertext{Successfully finished} message at the end.
+The \tab{Output} tab provides information about the output status of the module. When you click the \button{Run} button, the module switches to the
+\tab{Output} tab and you see information about the analysis process. If all works well, you will finally see a \usertext{Successfully finished} message.
\minisec{Manual}
-The \tab{Manual} tab shows the HTML help page of the GRASS module. You can use it to
-check further module parameters and flags or to get a deeper knowledge about the
-purpose of the module. At the end of each module manual page you see further links to
-the \filename{Main index}, a \filename{Thematic index} and a \filename{Full index}.
-These links provide the same information as if you use the module \filename{g.manual}
+The \tab{Manual} tab shows the HTML help page of the GRASS module. You can
+use it to check further module parameters and flags or to get a deeper knowledge about the purpose of the module. At the end of each module
+manual page you see further links to the \filename{Main Help index}, the \filename{Thematic index} and the \filename{Full index}. These links provide the same information as if you use the module \filename{g.manual}
\begin{Tip}\caption{\textsc{Display results immediately}}\index{GRASS!display results}
\qgistip{If you want to display your calculation results immediately in your map canvas, you can use the 'View Output' button at the bottom of the
@@ -472,22 +483,22 @@
\end{Tip}
-\subsubsection{Working with the GRASS location browser} \index{GRASS!toolbox!Browser}
+\subsubsection{Working with the GRASS LOCATION browser} \index{GRASS!toolbox!Browser}
-Another useful feature inside the GRASS Toolbox is the GRASS location browser. In Figure~\ref{fig:grass_mapset_browser} you can see the current working location with its mapsets.
+Another useful feature inside the GRASS Toolbox is the GRASS \filename{LOCATION} browser. In Figure~\ref{fig:grass_mapset_browser} you can see the current working \filename{LOCATION} with its \filename{MAPSETs}.
-In the left browser windows you can browse through all your mapsets inside your location. The right browser window shows some meta information for the selected raster or vector layer, e.g. resolution, bounding box, data source, connected attribute table for vector data and a command history.
+In the left browser windows you can browse through all \filename{MAPSETs} inside the current \filename{LOCATION}. The right browser window shows some meta information for selected raster or vector layers, e.g. resolution, bounding box, data source, connected attribute table for vector data and a command history.
\begin{figure}[h]
\begin{center}
- \caption{GRASS location browser \nixcaption}\label{fig:grass_mapset_browser}
- \includegraphics[clip=true,width=12cm]{grass_mapset_browser}
+ \caption{GRASS LOCATION browser \nixcaption}\label{fig:grass_mapset_browser}
+ \includegraphics[clip=true,width=10cm]{grass_mapset_browser}
\end{center}
\end{figure}
+The toolbar inside the \tab{Browser} tab offers following tools to manage
+the selected \filename{LOCATION}:
-The toolbar inside the \tab{Browser} tab gives you the following tools for the selected location:
\begin{itemize}
\item \toolboxtwo{grass_add_map}{Add selected map to canvas}
\item \toolboxtwo{grass_copy_map}{Copy selected map}
@@ -497,13 +508,14 @@
\item \toolboxtwo{grass_refresh}{Refresh browser window}
\end{itemize}
-The \toolboxtwo{grass_rename_map}{Rename selected map} and \toolboxtwo{grass_delete_map}{Delete selected map} only work with maps inside your currently selected mapset. All other tools also work with raster and vector layers in other mapsets.
+The \toolboxtwo{grass_rename_map}{Rename selected map} and \toolboxtwo{grass_delete_map}{Delete selected map} only work with maps inside your currently selected \filename{MAPSET}. All other tools also work with raster and vector layers in another \filename{MAPSET}.
\subsubsection{Customizing the GRASS Toolbox} \index{GRASS!toolbox!customize}
\label{sec:toolbox-customizing}
Nearly all GRASS modules can be added to the GRASS toolbox. A XML
-interface is provided to parse the very simple XML files which configures the modules appearance and parameters inside the toolbox.
+interface is provided to parse the pretty simple XML files which configures
+the modules appearance and parameters inside the toolbox.
A sample XML file for generating the module \usertext{v.buffer} (v.buffer.qgm) looks like this:
\begin{verbatim}
Modified: docs/trunk/english_us/user_guide/grass_integration_screenies/Makefile
--- docs/trunk/english_us/user_guide/grass_integration_screenies/Makefile 2008-09-21 19:45:54 UTC (rev 9371)
+++ docs/trunk/english_us/user_guide/grass_integration_screenies/Makefile 2008-09-22 13:50:03 UTC (rev 9372)
@@ -24,43 +24,7 @@
grass_module_option.eps\
grass_module_output.eps\
grass_mapset_browser.eps\
-# grasstoolbar.eps\
-# grassbrowser.eps\
-# grassshell.eps\
-# add_grass_raster.eps\
-# add_grass_vector.eps\
-# grass_edit.eps\
-# grass_region_edit.eps\
-# grass_tools.eps \
-# grass_copy_map.eps\
-# grass_delete_map.eps\
-# grass_refresh.eps\
-# grass_add_map.eps\
-# grass_rename_map.eps\
-# grass_region.eps\
-# grass_set_region.eps\
-# vbuffer.eps\
-# grass_delete_vertex.eps\
-# grass_new_line.eps\
-# grass_new_point.eps\
-# grass_split_line.eps\
-# grass_move_vertex.eps\
-# grass_delete_line.eps\
-# grass_close_edit.eps\
-# grass_move_line.eps\
-# grass_new_centroid.eps\
-# grass_add_vertex.eps\
-# grass_edit_attributes.eps\
-# grass_new_boundary.eps\
-# grass_close_mapset.eps\
-# grass_new_mapset.eps\
-# grass_new_vector_layer.eps\
-# grass_open_mapset.eps\
-# create_grass_location.eps\
-# grass_module_error.eps\
-# grass_module_warning.eps\
-# grass_browser_raster_layer.eps\
-# grass_browser_vector_layer.eps\
+ grass_location.eps\
##### TARGETS #####
Added: docs/trunk/english_us/user_guide/grass_integration_screenies/grass_location.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/grass_integration_screenies/grass_location.png
___________________________________________________________________
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/image_templates/README.txt
--- docs/trunk/english_us/user_guide/image_templates/README.txt (rev 0)
+++ docs/trunk/english_us/user_guide/image_templates/README.txt 2008-09-22 13:50:03 UTC (rev 9372)
@@ -0,0 +1 @@
+a) grass_location.odg was created with openoffice DRAW
Added: docs/trunk/english_us/user_guide/image_templates/grass_location.odg
Property changes on: docs/trunk/english_us/user_guide/image_templates/grass_location.odg
