[QGIS Commit] r10483 - in branches/vector_overlay_branch/src: core
plugins/diagram_overlay
svn_qgis at osgeo.org
Mon Apr 6 07:34:08 EDT 2009
Author: mhugent
Date: 2009-04-06 07:34:08 -0400 (Mon, 06 Apr 2009)
New Revision: 10483
branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.h
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.h
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h
Disable diagram dialog if diagram display is unchecked
Modified: branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp
--- branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp 2009-04-06 09:41:30 UTC (rev 10482)
+++ branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp 2009-04-06 11:34:08 UTC (rev 10483)
@@ -58,7 +58,7 @@
return; //error
- pal::Layer* positionLayer = mPositionEngine.addLayer(QString::number(mNumberOfLayers).toLocal8Bit().data(), 0, 1000000, labelArrangement, pal::PIXEL, 0, false, true, true);
+ pal::Layer* positionLayer = mPositionEngine.addLayer(QString::number(mNumberOfLayers).toLocal8Bit().data(), 0, 1000000, labelArrangement, pal::PIXEL, 0.5, true, true, true);
++mNumberOfLayers;
if(!positionLayer)
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp 2009-04-06 09:41:30 UTC (rev 10482)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp 2009-04-06 11:34:08 UTC (rev 10483)
@@ -65,6 +65,7 @@
restoreSettings(previousOverlay);
+ setGuiElementsEnabled(mDisplayDiagramsCheckBox->checkState() == Qt::Checked);
QgsDiagramDialog::QgsDiagramDialog(): mVectorLayer(0)
@@ -138,6 +139,19 @@
+void QgsDiagramDialog::on_mDisplayDiagramsCheckBox_stateChanged(int state)
+ //activate / deactivate all gui items depending on the checkbox state
+ if(state == Qt::Checked)
+ setGuiElementsEnabled(true);
+ else
+ setGuiElementsEnabled(false);
void QgsDiagramDialog::apply() const
if(!mVectorLayer)
@@ -318,5 +332,17 @@
+void QgsDiagramDialog::setGuiElementsEnabled(bool enabled)
+ mDiagramTypeComboBox->setEnabled(enabled);
+ mTypeLabel->setEnabled(enabled);
+ mDiagramFactoryStackedWidget->setEnabled(enabled);
+ mClassificationTypeLabel->setEnabled(enabled);
+ mClassificationTypeComboBox->setEnabled(enabled);
+ mClassificationLabel->setEnabled(enabled);
+ mClassificationComboBox->setEnabled(enabled);
+ mWidgetStackRenderers->setEnabled(enabled);
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.h 2009-04-06 09:41:30 UTC (rev 10482)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.h 2009-04-06 11:34:08 UTC (rev 10483)
@@ -37,6 +37,7 @@
void on_mClassificationTypeComboBox_currentIndexChanged(const QString& newType);
void on_mClassificationComboBox_currentIndexChanged(const QString& newAttribute);
void on_mDiagramTypeComboBox_currentIndexChanged(const QString& text);
+ void on_mDisplayDiagramsCheckBox_stateChanged(int state);
private:
@@ -45,6 +46,8 @@
void restoreSettings(const QgsVectorOverlay* overlay);
/**Vector layer containing the features to be symbolized with diagrams*/
QgsVectorLayer* mVectorLayer;
+ /**Activate / deactivate all the input elements of this dialog*/
+ void setGuiElementsEnabled(bool enabled);
#endif
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-04-06 09:41:30 UTC (rev 10482)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-04-06 11:34:08 UTC (rev 10483)
@@ -49,6 +49,11 @@
mDiagramRenderer = r;
+const QgsDiagramRenderer* QgsDiagramOverlay::diagramRenderer() const
+ return mDiagramRenderer;
void QgsDiagramOverlay::createOverlayObjects(const QgsRenderContext& renderContext)
if(!mDisplayFlag)
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.h 2009-04-06 09:41:30 UTC (rev 10482)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.h 2009-04-06 11:34:08 UTC (rev 10483)
@@ -34,7 +34,7 @@
//setters and getters
QString typeName() const{return "diagram";}
void setDiagramRenderer(QgsDiagramRenderer* r);
- const QgsDiagramRenderer* diagramRenderer() const {return mDiagramRenderer;}
+ const QgsDiagramRenderer* diagramRenderer() const;
bool readXML(const QDomNode& overlayNode);
bool writeXML(QDomNode& layer_node, QDomDocument& doc) const;
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h 2009-04-06 09:41:30 UTC (rev 10482)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.h 2009-04-06 11:34:08 UTC (rev 10483)
@@ -42,7 +42,7 @@
/**Writes the wkn diagram information into a <factory> tag*/
bool writeXML(QDomNode& overlay_node, QDomDocument& doc) const;
/**Possibility for wkn subclasses to write specific information into the XML document*/
- virtual bool _writeXML(QDomNode& factory_node, QDomDocument& doc) const {};
+ virtual bool _writeXML(QDomNode& factory_node, QDomDocument& doc) const {return true;}
/**Returns the property described by the size (e.g. diameter or height). This can be important to
know if e.g. size has to be calculated proportional to pie area*/
virtual QgsDiagramFactory::SizeType sizeType() const = 0;
