[QGIS Commit] r11404 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Aug 17 04:48:21 EDT 2009
Author: homann
Date: 2009-08-17 04:48:20 -0400 (Mon, 17 Aug 2009)
New Revision: 11404
   trunk/qgis/src/core/qgscoordinatetransform.cpp
Cleaned up debugging output of CRS transform
Modified: trunk/qgis/src/core/qgscoordinatetransform.cpp
--- trunk/qgis/src/core/qgscoordinatetransform.cpp	2009-08-17 06:40:17 UTC (rev 11403)
+++ trunk/qgis/src/core/qgscoordinatetransform.cpp	2009-08-17 08:48:20 UTC (rev 11404)
@@ -32,7 +32,7 @@
 // if defined shows all information about transform to stdout
-#undef COORDINATE_TRANSFORM_VERBOSE
+// #define COORDINATE_TRANSFORM_VERBOSE
@@ -106,7 +106,6 @@
 void QgsCoordinateTransform::setDestCRS( const QgsCoordinateReferenceSystem& theCRS )
-  QgsDebugMsg( "entered." );
   mDestCRS = theCRS;
   initialise();
@@ -115,7 +114,6 @@
 void QgsCoordinateTransform::setDestCRSID( long theCRSID )
   //!todo Add some logic here to determine if the srsid is a system or user one
   mDestCRS.createFromSrsId( theCRSID );
   initialise();
@@ -152,6 +150,11 @@
   mDestinationProjection = pj_init_plus( mDestCRS.toProj4().toUtf8() );
   mSourceProjection = pj_init_plus( mSourceCRS.toProj4().toUtf8() );
+#ifdef COORDINATE_TRANSFORM_VERBOSE
+  QgsDebugMsg( "From proj : " + mSourceCRS.toProj4() );
+  QgsDebugMsg( "To proj   : " + mDestCRS.toProj4() );
+#endif
   mInitialisedFlag = true;
   if ( mDestinationProjection == NULL )
@@ -197,6 +200,7 @@
     // Transform must take place
     mShortCircuit = false;
+    QgsDebugMsg( "Source/Dest CRS UNequal, shortcircuit is NOt set." );
@@ -227,9 +231,6 @@
     throw cse;
-#ifdef QGISDEBUG
-// QgsDebugMsg(QString("Point projection...X : %1-->%2, Y: %3 -->%4").arg(thePoint.x()).arg(x).arg(thePoint.y()).arg(y));
-#endif
   return QgsPoint( x, y );
@@ -273,7 +274,7 @@
     throw cse;
-#ifdef QGISDEBUG
   QgsDebugMsg( "Rect projection..." );
   QgsLogger::debug( "Xmin : ", theRect.xMinimum(), 1, __FILE__, __FUNCTION__, __LINE__ );
   QgsLogger::debug( "-->", x1, 1, __FILE__, __FUNCTION__, __LINE__ );
@@ -428,11 +429,12 @@
     return;
-#ifdef QGISDEBUG
-  //double xorg = x;
-  //double yorg = y;
-// QgsDebugMsg(QString("[[[[[[Number of points to transform: %1]]]]]]").arg(numPoints));
+  double xorg = *x;
+  double yorg = *y;
+  QgsDebugMsg( QString( "[[[[[[ Number of points to transform: %1 ]]]]]]" ).arg( numPoints ) );
 #endif
   // use proj4 to do the transform
   QString dir;
   // if the source/destination projection is lat/long, convert the points to radians
@@ -451,24 +453,11 @@
   int projResult;
   if ( direction == ReverseTransform )
-#if 0
-    QgsDebugMsg( "!!!! ReverseTransform PROJ4 TRANSFORM !!!!" );
-    QgsDebugMsg( QString( "     numPoint: %1" ).arg( numPoints ) );
-    QgsDebugMsg( QString( "     x       : %1" ).arg( x ) );
-    QgsDebugMsg( QString( "     y       : %1" ).arg( y ) );
-#endif
     projResult = pj_transform( mDestinationProjection, mSourceProjection, numPoints, 0, x, y, z );
     dir = "inverse";
   else
-#if 0
-    QgsDebugMsg( "!!!! ForwardTransform PROJ4 TRANSFORM !!!!" );
-    QgsDebugMsg( QString( "     z       : %1" ).arg( z ) );
-#endif
     assert( mSourceProjection != 0 );
     assert( mDestinationProjection != 0 );
     projResult = pj_transform( mSourceProjection, mDestinationProjection, numPoints, 0, x, y, z );
@@ -503,6 +492,7 @@
     QgsLogger::warning( "Throwing exception " + QString( __FILE__ ) + QString::number( __LINE__ ) );
     throw  QgsCsException( msg );
   // if the result is lat/long, convert the results from radians back
   // to degrees
   if (( pj_is_latlong( mDestinationProjection ) && ( direction == ForwardTransform ) )
@@ -515,8 +505,10 @@
       z[i] *= RAD_TO_DEG;
-#ifdef QGISDEBUG
-// QgsDebugMsg(QString("[[[[[[ Projected %1, %2 to %3, %4 ]]]]]]").arg(xorg).arg(yorg).arg(x).arg(y));
+  QgsDebugMsg( QString( "[[[[[[ Projected %1, %2 to %3, %4 ]]]]]]" )
+               .arg( xorg, 0, 'g', 15 ).arg( yorg, 0, 'g', 15 )
+               .arg( *x, 0, 'g', 15 ).arg( *y, 0, 'g', 15 ) );
 #endif
More information about the QGIS-commit mailing list
