[QGIS Commit] r11405 - trunk/qgis/src/app/legend
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Aug 17 05:52:13 EDT 2009
Author: homann
Date: 2009-08-17 05:52:12 -0400 (Mon, 17 Aug 2009)
New Revision: 11405
   trunk/qgis/src/app/legend/qgslegend.cpp
Adding connection of signals when reading legend layers from project XML file. Fixes #1760
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp	2009-08-17 08:48:20 UTC (rev 11404)
+++ trunk/qgis/src/app/legend/qgslegend.cpp	2009-08-17 09:52:12 UTC (rev 11405)
@@ -616,11 +616,12 @@
   doItemsLayout();
   // setup connections that will update the layer icons
-  if( dynamic_cast<QgsVectorLayer *>( layer ) )
+  if ( dynamic_cast<QgsVectorLayer *>( layer ) )
+    QgsDebugMsg( "Connecting signals for updating icons, layer " + layer->name() );
     connect( layer, SIGNAL( editingStarted() ), llayer, SLOT( updateIcon() ) );
     connect( layer, SIGNAL( editingStopped() ), llayer, SLOT( updateIcon() ) );
 QgsLegendLayerFile* QgsLegend::currentLayerFile()
@@ -1216,6 +1217,14 @@
           theLegendLayerFile->updateLegendItem();
           refreshLayerSymbology( theMapLayer->getLayerID() );
+          // setup connections that will update the layer icons
+          if ( dynamic_cast<QgsVectorLayer *>( theMapLayer ) )
+            QgsDebugMsg( "Connecting signals for updating icons, layer " + theMapLayer->name() );
+            connect( theMapLayer, SIGNAL( editingStarted() ), lastLayer, SLOT( updateIcon() ) );
+            connect( theMapLayer, SIGNAL( editingStopped() ), lastLayer, SLOT( updateIcon() ) );
       else if ( childelem.tagName() == "filegroup" )
More information about the QGIS-commit mailing list
