[QGIS Commit] r10228 - docs/branches/1.0.0/german/user_guide
svn_qgis at osgeo.org
Tue Feb 24 03:00:42 EST 2009
Author: dassau
Date: 2009-02-24 03:00:41 -0500 (Tue, 24 Feb 2009)
New Revision: 10228
docs/branches/1.0.0/german/user_guide/Makefile
docs/branches/1.0.0/german/user_guide/creating_pyqgis_applications.tex
docs/branches/1.0.0/german/user_guide/preamble.tex
pyqgis chapter translated by Florian Hillen (figures missing)
added Florian to translator list
Modified: docs/branches/1.0.0/german/user_guide/Makefile
--- docs/branches/1.0.0/german/user_guide/Makefile 2009-02-24 07:26:09 UTC (rev 10227)
+++ docs/branches/1.0.0/german/user_guide/Makefile 2009-02-24 08:00:41 UTC (rev 10228)
@@ -16,8 +16,8 @@
# Name of latex main file to compile
# Für deutsche Ãbersetzung nur des Anwenderteils
-FILE=handbuch
-#FILE=user_guide
+#FILE=handbuch
+FILE=user_guide
# Path to QGIS source plugin folder for 'make updateicon'
QGISPLUGINSOURCE=/software/qgis_head/src/plugins
Modified: docs/branches/1.0.0/german/user_guide/creating_pyqgis_applications.tex
--- docs/branches/1.0.0/german/user_guide/creating_pyqgis_applications.tex 2009-02-24 07:26:09 UTC (rev 10227)
+++ docs/branches/1.0.0/german/user_guide/creating_pyqgis_applications.tex 2009-02-24 08:00:41 UTC (rev 10228)
@@ -1,394 +1,408 @@
-% vim: set textwidth=78 autoindent:
-\section{Creating PyQGIS Applications}
-% when the revision of a section has been finalized,
-% comment out the following line:
-% \updatedisclaimer
-One of the goals of QGIS is to provide not only an application, but a set of
-libraries that can be used to create new applications. This goal has been
-realized with the refactoring of libraries that took place after the release
-of 0.8. Since the release of 0.9, development of standalone applications using
-either C++ or Python is possible. We recommend you use QGIS 1.0.0 or greater
-as the basis for your pythong applications because since this version we now
-provide a stable consistent API.
-In this chapter we'll take a brief look at the process for creating a
-standalone Python application. The QGIS blog has several examples of creating
-PyQGIS\footnote{An application created using Python and the QGIS bindings}
-applications. We'll use one of them as a starting point to get a look at how
-to create an application.
-The features we want in the application are:
-\begin{itemize}
-\item Load a vector layer
-\item Pan
-\item Zoom in and out
-\item Zoom to the full extent of the layer
-\item Set custom colors when the layer is loaded
-\end{itemize}
-This is a pretty minimal feature set. Let's start by designing the GUI using
-Qt Designer.
-\subsection{Designing the GUI}
-Since we are creating a minimalistic application, we'll take the same
-approach with the GUI. Using Qt Designer, we create a simple MainWindow with
-no menu or toolbars. This gives us a blank slate to work with. To create the
-MainWindow:
-\begin{enumerate}
-\item Create a directory for developing the application and change to it
-\item Run Qt Designer
-\item The \qtdialog{New Form} dialog should appear. If it doesn't, choose
-\qtdropmenuopt{New Form...} from the \qtmainmenuopt{File} menu.
-\item Choose \qtdropmenuopt{Main Window} from
-the \qtdropmenuopt{templates/forms} list
-\item Click \qtdropmenuopt{Create}
-\item Resize the new window to something manageable
-\item Find the \qtdropmenuopt{Frame} widget in the list
-(under \qtdropmenuopt{Containers}) and drag it to
-the main window you just created
-\item Click outside the frame to select the main window area
-\item Click on the \qtdropmenuopt{Lay Out in a Grid} tool. When you do, the frame
-will expand to fill your entire main window
-\item Save the form as \usertext{mainwindow.ui}
-\item \qtdropmenuopt{Exit} Qt Designer
-\end{enumerate}
-Now compile the form using the PyQt interface compiler:
-\begin{verbatim}
- pyuic4 -o mainwindow_ui.py mainwindow.ui
-\end{verbatim}
-This creates the Python source for the main window GUI. Next we need to create
-the application code to fill the blank slate with some tools we can use.
-\subsection{Creating the MainWindow}
-Now we are ready to write the \classname{MainWindow} class that will do the real work.
-Since it takes up quite a few lines, we'll look at it in chunks, starting
-with the import section and environment setup:
-\begin{verbatim}
-1 # Loosely based on:
-2 # Original C++ Tutorial 2 by Tim Sutton
-3 # ported to Python by Martin Dobias
-4 # with enhancements by Gary Sherman for FOSS4G2007
-5 # Licensed under the terms of GNU GPL 2
-6
-7 from PyQt4.QtCore import *
-8 from PyQt4.QtGui import *
-9 from qgis.core import *
-10 from qgis.gui import *
-11 import sys
-12 import os
-13 # Import our GUI
-14 from mainwindow_ui import Ui_MainWindow
-15
-16 # Environment variable QGISHOME must be set to the 1.0 install directory
-17 # before running this application
-18 qgis_prefix = os.getenv("QGISHOME")
-\end{verbatim}
-Some of this should look familiar from our plugin, especially the PyQt4 and
-QGIS imports. Some specific things to note are the import of our GUI in line
-14 and the import of our CORE library on line 9.
-Our application needs to know where to find the QGIS installation. Because
-of this, we set the \usertext{QGISHOME} environment variable to point to the
-install directory of QGIS 1.x In line 20 we store this value from
-the environment for later use.
-Next we need to create our \classname{MainWindow} class which will contain
-all the logic of our application.
-\begin{verbatim}
-21 class MainWindow(QMainWindow, Ui_MainWindow):
-22
-23 def __init__(self):
-24 QMainWindow.__init__(self)
-25
-26 # Required by Qt4 to initialize the UI
-27 self.setupUi(self)
-28
-29 # Set the title for the app
-30 self.setWindowTitle("QGIS Demo App")
-31
-32 # Create the map canvas
-33 self.canvas = QgsMapCanvas()
-34 # Set the background color to light blue something
-35 self.canvas.setCanvasColor(QColor(200,200,255))
-36 self.canvas.enableAntiAliasing(True)
-37 self.canvas.useQImageToRender(False)
-38 self.canvas.show()
-39
-40 # Lay our widgets out in the main window using a
-41 # vertical box layout
-42 self.layout = QVBoxLayout(self.frame)
-43 self.layout.addWidget(self.canvas)
-44
-45 # Create the actions for our tools and connect each to the appropriate
-46 # method
-47 self.actionAddLayer = QAction(QIcon("(qgis_prefix + "/share/qgis/themes/classic/mActionAddLayer.png"),
-48 \
-49 "Add Layer", self.frame)
-50 self.connect(self.actionAddLayer, SIGNAL("activated()"), self.addLayer)
-51 self.actionZoomIn = QAction(QIcon("(qgis_prefix + "/share/qgis/themes/classic/mActionZoomIn.png"), \
-52 "Zoom In", self.frame)
-53 self.connect(self.actionZoomIn, SIGNAL("activated()"), self.zoomIn)
-54 self.actionZoomOut = QAction(QIcon("(qgis_prefix + "/share/qgis/themes/classic/mActionZoomOut.png"), \
-55 "Zoom Out", self.frame)
-56 self.connect(self.actionZoomOut, SIGNAL("activated()"), self.zoomOut)
-57 self.actionPan = QAction(QIcon("(qgis_prefix + "/share/qgis/themes/classic/mActionPan.png"), \
-58 "Pan", self.frame)
-59 self.connect(self.actionPan, SIGNAL("activated()"), self.pan)
-60 self.actionZoomFull = QAction(QIcon("(qgis_prefix + "/share/qgis/themes/classic/mActionZoomFullExtent.png"), \
-61 "Zoom Full Extent", self.frame)
-62 self.connect(self.actionZoomFull, SIGNAL("activated()"),
-63 self.zoomFull)
-64
-65 # Create a toolbar
-66 self.toolbar = self.addToolBar("Map")
-67 # Add the actions to the toolbar
-68 self.toolbar.addAction(self.actionAddLayer)
-69 self.toolbar.addAction(self.actionZoomIn)
-70 self.toolbar.addAction(self.actionZoomOut);
-71 self.toolbar.addAction(self.actionPan);
-72 self.toolbar.addAction(self.actionZoomFull);
-73
-74 # Create the map tools
-75 self.toolPan = QgsMapToolPan(self.canvas)
-76 self.toolZoomIn = QgsMapToolZoom(self.canvas, False) # false = in
-77 self.toolZoomOut = QgsMapToolZoom(self.canvas, True) # true = out
-\end{verbatim}
-Lines 21 through 27 are the basic declaration and initialization of the
-\classname{MainWindow} and the set up of the user interface using the
-\method{setupUi} method. This is required for all applications.
-Next we set the title for the application so it says something more
-interesting than \usertext{MainWindow} (line 30). Once that is
-complete, we are ready to complete the user interface. When we created it in
-Designer, we left it very sparse---just a main window and a frame. You could
-have added a menu and the toolbar using Designer, however we'll do it with
-Python.
-In lines 33 through 38 we set up the map canvas, set the background color to a
-light blue, and enable antialiasing. We also tell it not to use a
-\classname{QImage} for rendering (trust me on this one) and then set the
-canvas to visible by calling the \method{show} method.
-Next we set the layer to use a vertical box layout within the frame and add
-the map canvas to it in line 43.
-Lines 48 to 63 set up the actions and connections for the tools in our
-toolbar. For each tool, we create a \classname{QAction} using the icon we
-defined in the QGIS classic theme. Then we connect up the
-\usertext{activated} signal from the tool to the method in our class that will
-handle the action. This is similar to how we set things up in the plugin
-example.
-Once we have the actions and connections, we need to add them to the toolbar.
-In lines 66 through 72 we create the toolbar and add each tool to it.
-Lastly we create the three map tools for the application (lines 75 through
-77). We'll use the map tools in a moment when we define the methods to make
-our application functional. Let's look at the methods for the map tools.
-\begin{verbatim}
-78 # Set the map tool to zoom in
-79 def zoomIn(self):
-80 self.canvas.setMapTool(self.toolZoomIn)
-81
-82 # Set the map tool to zoom out
-83 def zoomOut(self):
-84 self.canvas.setMapTool(self.toolZoomOut)
-85
-86 # Set the map tool to
-87 def pan(self):
-88 self.canvas.setMapTool(self.toolPan)
-89
-90 # Zoom to full extent of layer
-91 def zoomFull(self):
-92 self.canvas.zoomFullExtent()
-\end{verbatim}
-For each map tool, we need a method that corresponds to the connection we made
-for each action. In lines 79 through 88 we set up a method for each of the
- three tools that interact with the map. When a tool is activated by clicking
- on it in the toolbar, the corresponding method is called that ``tells'' the
- map canvas it is the active tool. The active tool governs what happens when
- the mouse is clicked on the canvas.
-The \usertext{zoom to full extent} tool isn't a map tool---it does its job
-without requiring a click on the map. When it is activated, we call the
-\method{zoomFullExtent} method of the map canvas (line 92). This completes
-the implementation of all our tools except one---the \usertext{Add Layer}
-tool. %FIXME
-Let's look at it next:
-\begin{verbatim}
-93 # Add an OGR layer to the map
-94 def addLayer(self):
-95 file = QFileDialog.getOpenFileName(self, "Open Shapefile", ".", "Shapefiles
-96 (*.shp)")
-97 fileInfo = QFileInfo(file)
-98
-99 # Add the layer
-100 layer = QgsVectorLayer(file, fileInfo.fileName(), "ogr")
-101
-102 if not layer.isValid():
-103 return
-104
-105 # Change the color of the layer to gray
-106 symbols = layer.renderer().symbols()
-107 symbol = symbols[0]
-108 symbol.setFillColor(QColor.fromRgb(192,192,192))
-109
-110 # Add layer to the registry
-111 QgsMapLayerRegistry.instance().addMapLayer(layer);
-112
-113 # Set extent to the extent of our layer
-114 self.canvas.setExtent(layer.extent())
-115
-116 # Set up the map canvas layer set
-117 cl = QgsMapCanvasLayer(layer)
-118 layers = [cl]
-119 self.canvas.setLayerSet(layers)
-\end{verbatim}
-In the \method{addLayer} method we use a \classname{QFileDialog} to get the
-name of the shapefile to load. This is done in line 96.
-Notice that we specify a ``filter'' so the dialog will only show files of
-type \filename{.shp}.
-Next in line 97 we create a \classname{QFileInfo} object from the shapefile
-path. Now the layer is ready to be created in line 100. Using the
-\classname{QFileInfo} object to get the file name from the path we specify it
-for the name of the layer when it is created. To make sure that the layer is
-valid and won't cause any problems when loading, we check it in line 102. If
-it's bad, we bail out and don't add it to the map canvas.
-Normally layers are added with a random color. Here we want to tweak the
-colors for the layer to make a more pleasing display. Plus we know we are
-going to add the \filename{world\_borders} layer to the map and this will make
-it look nice on our blue background. To change the color, we need to get the
-symbol used for rendering and use it to set a new fill color. This is done in
-lines 106 through 108.
-All that's left is to actually add the layer to the registry and a few other
-housekeeping items (lines 111 through 119). This stuff is standard for adding
-a layer and the end result is the world borders on a light blue background.
-The only thing you may not want to do is set the extent to the layer, if you
-are going to be adding more than one layer in your application.
-That's the heart of the application and completes the \classname{MainWindow} class.
-\subsection{Finishing Up}
-The remainder of the code shown below creates the \object{QgsApplication}
-object, sets the path to the QGIS install, sets up the \method{main} method
-and then starts the application. The only other thing to note is that we move
-the application window to the upper left of the display. We could get fancy
-and use the Qt API to center it on the screen.
-\begin{verbatim}
-120 def main(argv):
-121 # create Qt application
-122 app = QApplication(argv)
-123
-124 # Initialize qgis libraries
-125 QgsApplication.setPrefixPath(qgis_prefix, True)
-126 QgsApplication.initQgis()
-127
-128 # create main window
-129 wnd = MainWindow()
-130 # Move the app window to upper left
-131 wnd.move(100,100)
-132 wnd.show()
-133
-134 # run!
-135 retval = app.exec_()
-136
-137 # exit
-138 QgsApplication.exitQgis()
-139 sys.exit(retval)
-140
-141
-142 if __name__ == "__main__":
-143 main(sys.argv)
-\end{verbatim}
-\subsection{Running the Application}
-Now we can run the application and see what happens. Of course if you are like
-most developers, you've been testing it out as you went along.
-Before we can run the application, we need to set some environment variables.
-\nix{}\osx{}
-\begin{verbatim}
-export LD_LIBRARY_PATH=$HOME/qgis/lib%$
-export PYTHONPATH=$HOME/qgis/share/qgis/python
-export QGISHOME=$HOME/qgis%$
-\end{verbatim}
-\win{}
-\begin{verbatim}
-set PATH=C:\qgis;%PATH%
-set PYTHONPATH=C:\qgis\python
-set QGISHOME=C:\qgis
-\end{verbatim}
-We assume
-\begin{itemize}
-\item\nix{}\osx{}QGIS is installed in
-your home directory in
-\filename{qgis}.
-\item\win{}QGIS is installed in \filename{C:\textbackslash qgis}.
-\end{itemize}
-When the application starts up, it looks like this:
-%\begin{figure}[ht]
-%\begin{center}
-% \caption{Starting the new demo application}\label{fig:demo_app_startup}%\smallskip
-% \includegraphics[scale=0.8]{getdsn}
-%\end{center}
-%\end{figure}
-To add the \filename{world\_borders} layer, click on the
-\usertext{Add Layer} tool and navigate to the data directory.
-Select the shapefile and click \button{Open} to add it to the map.
-Our custom fill color is applied and the result is:
-%\begin{center}
-% \caption{Adding a layer the demo application}\label{fig:demo_app_done}%\smallskip
-%\end{center}
-%\end{figure}
-Creating a PyQGIS application is really pretty simple. In less than 150 lines
-of code we have an application that can load a shapefile and navigate the map.
-If you play around with the map, you'll notice that some of the built-in
-features of the canvas also work, including mouse wheel scrolling and panning
-by holding down the \keystroke{Space} bar and moving the mouse.
-Some sophisticated applications have been created with PyQGIS and more are in
-the works. This is pretty impressive, considering that this development has
-taken place even before the official release of QGIS 1.0.
-\begin{Tip}\caption{\textsc{Documentation For PyQGIS}}
-\qgistip{Whether you are writing a plugin or a PyQGIS application, you are
-going to need to refer to both the QGIS API documentation
-(\url{http://doc.qgis.org}) and the PyQt Python Bindings Reference Guide
-(\url{http://www.riverbankcomputing.com/Docs/PyQt4/pyqt4ref.html}). These
-documents provide information about the classes and methods you'll use to
-bring your Python creation to life.
-\end{Tip}
+% vim: set textwidth=78 autoindent:
+\section{Erstellung von PyQGIS Anwendungen}
+% when the revision of a section has been finalized,
+% comment out the following line:
+% \updatedisclaimer
+Eines der Ziele von QGIS ist es nicht nur eine Anwendung bereitzustellen, sondern
+eine Sammlung von Bibliotheken, die zur Entwicklung neuer Anwendungen benutzt werden
+können. Dieses Ziel wurde durch die Umgestaltung der Bibliotheken nach dem Release 0.8
+realisiert. Seit dem Release 0.9 ist die Entwicklung unabhängiger Anwendungen durch die
+Verwendung von C++ oder Python möglich. Wir empfehlen QGIS 1.0.0 oder höher als Basis
+für Python Anwendungen, da seit dieser Version eine stabile, konstistente API
+vorliegt.
+In diesem Kapitel werden wir einen kurzer Blick auf das Verfahren zur Erstellung
+unabhängiger Python Anwendungen werfen. Der QGIS Blog enthält einige Beispiele
+für die Erstellung von PyQGIS\footnote{Eine Anwendung unter Verwendung von Python und QGIS Referenzen}
+Anwendungen. Wir werden eines dieser Beispiele benutzen um einen
+Einblick in die Entwicklung von Anwendungen zu kriegen.
+Unsere Anwendung soll folgende Punkte erfüllen:
+\begin{itemize}
+\item Einen Vektor Layer laden
+\item Pan
+\item rein und raus Zoomen
+\item Auf die gesamte Ausdehnung des Layers zoomen
+\item Bestimmen eigener Farben, wenn der Layer geladen ist
+\end{itemize}
+Das ist sind ziemlich geringe Anforderungen. Wir starten mit der Gestaltung des
+GUI mit der Hilfe von Qt Designer.
+\subsection{Gestaltung des GUI}
+Da wir eine kleine Anwendung erstellen, werden wir ebenso mit dem GUI verfahren.
+Mit dem Qt Designer erstellen wir ein einfaches Hauptfenster ohne Menü oder Toolbars.
+Wir erhalten eine freie Fläche auf der wir arbeiten können. Um das Hauptfenster
+zu erstellen:
+\begin{enumerate}
+\item Erstelle ein Verzeichnis für die Entwicklung der Anwendung und wechsel in dieses
+\item Starte den Qt Designer
+\item Das \qtdialog{Neues Formular} Fenster sollte erscheinen. Sollte dies nicht der Fall sein,
+wähle \qtdropmenuopt{Neu...} unter \qtmainmenuopt{Datei} in der Menüleiste.
+\item Wähle \qtdropmenuopt{Main Window} aus der \qtdropmenuopt{templates/forms} Liste
+\item Klicke \qtdropmenuopt{Neu von Vorlage}
+\item Passe die Größe des neuen Fensters entsprechend an
+\item Finde den Eintrag \qtdropmenuopt{Frame} in der Liste
+(unter \qtdropmenuopt{Containers}) und ziehe diesen in das eben erstellte Fenster
+\item Klicke ausserhalb des Frames um das Hauptfenster zu selektieren
+\item Klicke auf das \qtdropmenuopt{Objekte tabellarisch anordnen} Tool im
+Menü \mainmenuopt{Formular}. Die Größe des Frames wird nun an das Hauptfenster angepasst und füllt dieses komplett aus.
+\item Speicher dies im Menü \mainmenuopt{Datei} als \usertext{mainwindow.ui}
+\item Qt Designer \qtdropmenuopt{Beenden}
+\end{enumerate}
+Kompiliere nun das erstelle Formular mit PyQt:
+\begin{verbatim}
+ pyuic4 -o mainwindow_ui.py mainwindow.ui
+\end{verbatim}
+Dieser Befehl erstellt den Python Quellcode für das Hauptfenster GUI.
+Als nächstes müssen wir den Anwendungscode erstellen, um die freie Fläche des
+Hauptfensters mit sinnvollen Tools zu füllen.
+\subsection{Erstellung des Hauptfensters}
+Jetzt sind wir bereit, die Klasse \classname{MainWindow}, die die wirkliche Arbeit
+verrichtet, zu schreiben.
+Da einige Zeilen Quellcode nötig sind, werden wir die Klasse in Einzelteile betrachten,
+beginnend mit dem Import Bereich und den Umgebungseinstellungen:
+\begin{verbatim}
+1 # Basiert auf:
+2 # Original C++ Tutorial 2 von Tim Sutton
+3 # Überführung zu Python von Martin Dobias
+4 # mit Verbesserungen von Gary Sherman für die FOSS4G2007
+5 # Lizensiert unter den Bedingungen der GNU GPL 2
+6
+7 from PyQt4.QtCore import *
+8 from PyQt4.QtGui import *
+9 from qgis.core import *
+10 from qgis.gui import *
+11 import sys
+12 import os
+13 # Import unseres GUIs
+14 from mainwindow_ui import Ui_MainWindow
+15
+16 # Umgebungsvariable QGISHOME muss auf das Installationsverzeichnis
+17 # 1.0 gesetzt werden bevor die Anwendung gestartet wird
+18 qgis_prefix = os.getenv("QGISHOME")
+\end{verbatim}
+Einiges hiervon sollte uns von unserem Plugin bekannt vorkommen, besonders
+die PyQt4 und QGIS Importe. Speziell zu erwähnen ist der Import unseres GUIs
+in Zeile 14 und der Import der CORE Bibliothek in Zeile 9.
+Unsere Anwendung muss wissen, wo sie die QGIS Installation finden kann.
+Aus diesem Grund setzen wir die Umgebungvariable \usertext{QGISHOME} auf das
+Installationverzeichnis von QGIS 1.x. In Zeile 20 speichern wir diesen Wert
+für den späteren Gebrauch.
+Als nächstes müssen wir die Klasse \classname{MainWindow} erstellen, welche
+die gesamte Logik unserer Anwendung enthält.
+\begin{verbatim}
+21 class MainWindow(QMainWindow, Ui_MainWindow):
+22
+23 def __init__(self):
+24 QMainWindow.__init__(self)
+25
+26 # Notwendig für Qt4 zur Initialisierung der Benutzeroberfläche
+27 self.setupUi(self)
+28
+29 # Setzt den Titel der Anwendung
+30 self.setWindowTitle("QGIS Demo App")
+31
+32 # Erstellt den Map Canvas
+33 self.canvas = QgsMapCanvas()
+34 # Setzt die Hintergrundfarbe zu einem hellen blau
+35 self.canvas.setCanvasColor(QColor(200,200,255))
+36 self.canvas.enableAntiAliasing(True)
+37 self.canvas.useQImageToRender(False)
+38 self.canvas.show()
+39
+40 # Setzt unsere Dinge in das Hauptfenster unter Verwendung
+41 # eines vertikalen box layouts
+42 self.layout = QVBoxLayout(self.frame)
+43 self.layout.addWidget(self.canvas)
+44
+45 # Erstellt die Aktionen für unsere Tools und verbindet diese mit den
+46 # zugehörigen Methoden
+47 self.actionAddLayer = QAction(QIcon("(qgis_prefix + \
+48 \
+49 "Add Layer", self.frame)
+50 self.connect(self.actionAddLayer, SIGNAL("activated()"), self.addLayer)
+51 self.actionZoomIn = QAction(QIcon("(qgis_prefix + \
+52 "Zoom In", self.frame)
+53 self.connect(self.actionZoomIn, SIGNAL("activated()"), self.zoomIn)
+54 self.actionZoomOut = QAction(QIcon("(qgis_prefix + \
+55 "Zoom Out", self.frame)
+56 self.connect(self.actionZoomOut, SIGNAL("activated()"), self.zoomOut)
+57 self.actionPan = QAction(QIcon("(qgis_prefix + \
+58 "Pan", self.frame)
+59 self.connect(self.actionPan, SIGNAL("activated()"), self.pan)
+60 self.actionZoomFull = QAction(QIcon("(qgis_prefix + \
+61 "Zoom Full Extent", self.frame)
+62 self.connect(self.actionZoomFull, SIGNAL("activated()"),
+63 self.zoomFull)
+64
+65 # Erstellt eine Toolbar
+66 self.toolbar = self.addToolBar("Map")
+67 # Fügt die Aktionen der Toolbar hinzu
+68 self.toolbar.addAction(self.actionAddLayer)
+69 self.toolbar.addAction(self.actionZoomIn)
+70 self.toolbar.addAction(self.actionZoomOut);
+71 self.toolbar.addAction(self.actionPan);
+72 self.toolbar.addAction(self.actionZoomFull);
+73
+74 # Erstellt die Kartentools
+75 self.toolPan = QgsMapToolPan(self.canvas)
+76 self.toolZoomIn = QgsMapToolZoom(self.canvas, False) # false = in
+77 self.toolZoomOut = QgsMapToolZoom(self.canvas, True) # true = out
+\end{verbatim}
+In den Zeilen 21 bis 27 sind die grundlegenden Deklarationen und Initialisierungen
+der Klasse \classname{MainWindow} und der Aufbau der Benutzeroberfläche durch die
+Methode \method{setupUi}. Dies ist für alle Anwendungen erforderlich.
+Als nächstes setzen wir etwas interessanteres als \usertext{MainWindow} in den
+Titel der Anwendung (Zeile 30). Sobald dies erledigt ist, können wir die
+Benutzeroberfläche fertigstellen. Im Designer haben wir diese sehr spärlich
+erstellt---nur ein Hauptfenster und ein Rahmen. Man hätte mit dem Designer ein
+Menü und eine Toolbar hinzufügen können, aber wir machen das mit Python.
+In den Zeilen 33 bis 38 erstellen wir den Map Canvas, setzen die Hintergrundfarbe
+auf ein helles blau und aktivieren Antialiasing. Ebenso sagen wir, dass
+\classname{QImage} nicht zum rendern benutzt werden soll (vertraut mir hierbei)
+und lassen den Canvas sichtbar werden durch die Methode \method{show}.
+Als nächstes definieren ein vertikales Box Layout innerhalb des Frames
+und fügen den Map Canvas hinzu (Zeile 43).
+In den Zeilen 48 bis 63 werden die Aktionen und Verbindungen für die Tools
+aus unserer Toolbar gesetzt. Für jedes Tool erstellen wir eine \classname{QAction}
+mit dem Symbol, welches wir im QGIS classic theme definiert haben. Dann verbinden
+wir das Signal \usertext{activated} des Tools mit der Methode unserer Klasse,
+die die Aktion weiter verarbeitet. Dies ist vergleichbar mit dem Plugin Beispiel.
+Sobald wir die Aktionen und Verbindungen erstellt haben, müssen wir diese zu der
+Toolbar hinzufügen. In den Zeilen 66 bis 72 erstellen wir die Toolbar und fügen
+ihr jedes einzelne Tool hinzu. Schließlich erstellen wir die drei Kartentools für die
+Anwendung (Zeilen 75 bis 77). Wir werden die Kartentools gleich benutzen, wenn wir die Methoden
+definieren, die unsere Anwendung funktionsfähig machen. Sehen wir uns nun die
+Methoden für die Kartentools an.
+\begin{verbatim}
+78 # Definiert das Kartentool zum hinein zoomen
+79 def zoomIn(self):
+80 self.canvas.setMapTool(self.toolZoomIn)
+81
+82 # Definiert das Kartentool zum heraus zoomen
+83 def zoomOut(self):
+84 self.canvas.setMapTool(self.toolZoomOut)
+85
+86 # Definiert das Kartentool zum Panning
+87 def pan(self):
+88 self.canvas.setMapTool(self.toolPan)
+89
+90 # Zoomt zum vollen Kartenausschnitt
+91 def zoomFull(self):
+92 self.canvas.zoomFullExtent()
+\end{verbatim}
+Für jedes Kartentool brauchen wir eine Methode, die mit der von uns erstellten
+Verbindung übereinstimmt. In den Zeilen 79 bis 88 erstellen wir eine Methode für
+jedes der drei Tools, die mit der Karte interagieren. Durch Anklicken in der Toolbar
+wir das Tool aktiviert und die zugehörige Methode aufgerufen, die wiederum
+dem Map Canvas über das aktuelle Tool informiert. Das aktive Tool reagiert auf
+die Klicks der Maus in dem Canvas.
+Das \usertext{zoom to full extent} Tool ist kein Kartentool---es erfüllt seine
+Aufgabe ohne ein Klick auf die Karte. Bei Aktivierung dieses Tools wird die
+Methode \method{zoomFullExtent} des Map Canvas aufgerufen (Zeile 92). Dies
+vervollständigt die Implementierung aller Tools ausser einem---dem
+\usertext{Add Layer} Tool. %FIXME
+Dieses schauen wir uns als nächstes an:
+\begin{verbatim}
+93 # Fügt ein OGR Layer zur Karte hinzu
+94 def addLayer(self):
+95 file = QFileDialog.getOpenFileName(self, "Open Shapefile", ".", "Shapefiles
+96 (*.shp)")
+97 fileInfo = QFileInfo(file)
+98
+99 # Fügt den Layer hinzu
+100 layer = QgsVectorLayer(file, fileInfo.fileName(), "ogr")
+101
+102 if not layer.isValid():
+103 return
+104
+105 # Ändert die Farbe des Layers auf grau
+106 symbols = layer.renderer().symbols()
+107 symbol = symbols[0]
+108 symbol.setFillColor(QColor.fromRgb(192,192,192))
+109
+110 # Fügt Layer zur Registry hinzu
+111 QgsMapLayerRegistry.instance().addMapLayer(layer);
+112
+113 # Setzt den aktuellen Extent auf den Extent unseres Layers
+114 self.canvas.setExtent(layer.extent())
+115
+116 # Erstellt den Map Canvas Layer Set
+117 cl = QgsMapCanvasLayer(layer)
+118 layers = [cl]
+119 self.canvas.setLayerSet(layers)
+\end{verbatim}
+In der Methode \method{addLayer} verwenden wir einen \classname{QFileDialog}
+um den Namen des zu ladenden Shapefiles zu erhalten (Zeile 96).
+Zu beachten ist, dass wir ein ``Filter'' definieren, so dass der Dialog uns
+nur Dateien vom Typ \filename{.shp} anzeigt.
+In Zeile 97 erstellen wir uns als nächstes ein \classname{QFileInfo} Objekt
+aus dem Pfad des Shapefiles. Jetzt ist der Layer fertig für die Erstellung
+(Zeile 100). Der Layer erhält nach der Erstellung den Namen der Datei, welcher
+über das \classname{QFileInfo} Objekt erfragt werden kann. Um sicher zu gehen,
+dass der Layer gültig ist und ohne Probleme geladen werden kann, wird dieser
+in Zeile 102 überprüft. Wenn die Prüfung fehlschlägt, wird die Weiterverarbeitung
+nicht durchgeführt und der Layer nicht zum Map Canvas hinzugefügt.
+Normalerweise werden Layer mit einer zufälligen Farbe hinzugefügt. Wir wollen
+nun die Farbe des Layers anpassen um die Anzeige angenehmer zu machen. Zudem
+wissen wir, dass wir den \filename{world\_borders} Layer zur Karte hinzufügen
+werden und dass dies gut aussehen wird auf unserem blauen Hintergrund. Um die
+Farbe zu ändern brauchen wir das zum Rendern verwendete Symbol und verwenden
+dieses, um eine neue Füllfarbe zu setzen (Zeilen 106 bis 108).
+Alles was nun noch erledigt werden muss, ist den Layer zu der Registry
+hinzuzufügen und einige andere haushälterischen Dinge zu erledigen (Zeilen
+111 bis 119). Dies ist das Standardvorgehen um einen Layer hinzuzufügen und
+das Ergebnis ist der \filename{world\_borders} Layer auf einem hell blauen
+Hintergrund. Das Einzige was nicht gemacht werden muss, ist das Ändern der
+Ausdehnung auf den Layer, wenn mehr als ein Layer hinzugefügt werden soll.
+Das ist das Herz der Anwendung und vervollständigt die Klasse \classname{MainWindow}.
+\subsection{Fertigstellung}
+Der restliche Code, der unten aufgeführt ist, erstellt das Objekt
+\object{QgsApplication}, setzt den Pfad zur QGIS Installation, setzt die
+Methode \method{main} und startet dann die Anwendung. Erwähnenswert ist noch,
+dass das Anwendungsfenster in die obere linke Ecke des Bildschirms verschoben wird.
+Wir könnten die Qt API dazu nutzen das Fenster wieder auf dem Bildschirm zu
+zentrieren.
+\begin{verbatim}
+120 def main(argv):
+121 # Erstelle die Qt Anwendung
+122 app = QApplication(argv)
+123
+124 # Initialisiere QGIS Bibliotheken
+125 QgsApplication.setPrefixPath(qgis_prefix, True)
+126 QgsApplication.initQgis()
+127
+128 # Erstelle Hauptfenster
+129 wnd = MainWindow()
+130 # Bewege die Anwendung nach oben links
+131 wnd.move(100,100)
+132 wnd.show()
+133
+134 # Start!
+135 retval = app.exec_()
+136
+137 # Beenden
+138 QgsApplication.exitQgis()
+139 sys.exit(retval)
+140
+141
+142 if __name__ == "__main__":
+143 main(sys.argv)
+\end{verbatim}
+\subsection{Starten der Anwendung}
+Jetzt können wir die Anwendungen starten und sehen was passiert. Selbstverständlich
+wie viele andere Entwickler, testest du laufend während der Entwicklung.
+Bevor wir die Anwendung ausprobieren können, müssen wir einige Umgebungsvariablen
+setzen.
+\nix{}\osx{}
+\begin{verbatim}
+export LD_LIBRARY_PATH=$HOME/qgis/lib%$
+export PYTHONPATH=$HOME/qgis/share/qgis/python
+export QGISHOME=$HOME/qgis%$
+\end{verbatim}
+\win{}
+\begin{verbatim}
+set PATH=C:\qgis;%PATH%
+set PYTHONPATH=C:\qgis\python
+set QGISHOME=C:\qgis
+\end{verbatim}
+Wir gehen davon aus, dass
+\begin{itemize}
+\item\nix{}\osx{}QGIS unter home installiert
+in
+\filename{qgis}.
+\item\win{}QGIS installiert ist in \filename{C:\textbackslash qgis}.
+\end{itemize}
+Wenn die Anwendung startet, sollte es folgendermaßen aussehen:
+%%FIXME
+%\begin{figure}[ht]
+%\begin{center}
+% \caption{Starten der neuen Demo Anwendung}\label{fig:demo_app_startup}%\smallskip
+% \includegraphics[scale=0.8]{cpp1_application}
+%\end{center}
+%\end{figure}
+Um den Layer \filename{world\_borders} hinzuzufügen, klick auf
+das \usertext{Add Layer} Tool und navigiere zum Datenverzeichnis.
+Wähle das Shapefile aus und Klicke auf \button{Open} um es zur
+Karte hinzuzufügen. Unsere angepasste Füllfarbe ist zum Einsatz
+gekommen und das Resultat sieht so aus:
+%% FIXME
+%\begin{center}
+% \caption{Hinzufügen eines Layers zur Demo Anwendung}\label{fig:demo_app_done}%\smallskip
+% \includegraphics[scale=0.8]{cpp2_application}
+%\end{center}
+%\end{figure}
+Die Erstellung von PyQGIS Anwendungen ist sehr einfach. In weniger als 150 Zeilen
+Quellcode haben wir eine Anwendung die Shapefiles laden kann und eine navigierbare
+Karte zur Verfügung stellt. Wenn du ein wenig mit der Karte experimentierst, wirst
+du feststellen, dass manche der eingebauten Funktionen des Canvas ebenfalls
+funktionieren, einschließlich des Mausrad-Scrollens und dem Panning indem man die
+\keystroke{Space} Taste gedrückt hält und die Maus bewegt.
+Einige anspruchsvolle Anwendungen wurden mit PyQGIS entwickelt und einige weitere
+sind in Arbeit. Dies ist ziemlich eindrucksvoll in Anbetracht der Tatsache, dass
+diese Entwicklungen erfolgt sind bevor das offizielle Release von QGIS 1.0.
+erschienen ist.
+\begin{Tip}\caption{\textsc{Dokumentation für PyQGIS}}
+\qgistip{Um ein Plugin oder eine PyQGIS-Anwendung zu schreiben, muss man sich
+sowohl mit der QGIS API Doku (\url{http://doc.qgis.org}) als auch dem PyQt
+Python Bindings Reference Guide befassen
+(\url{http://www.riverbankcomputing.com/Docs/PyQt4/pyqt4ref.html}).
+Diese liefern Informationen über Klassen und Methoden, die notwendig sind, um
+PyQGIS-Anwendung Leben einzuhauchen.
+\end{Tip}
Modified: docs/branches/1.0.0/german/user_guide/preamble.tex
--- docs/branches/1.0.0/german/user_guide/preamble.tex 2009-02-24 07:26:09 UTC (rev 10227)
+++ docs/branches/1.0.0/german/user_guide/preamble.tex 2009-02-24 08:00:41 UTC (rev 10228)
@@ -74,7 +74,7 @@
und Programmierung):}
\begin{tabular}{p{5cm} p{5cm} p{5cm}}
-Otto Dassau & & \\
+Otto Dassau & Florian Hillen & \\
\end{tabular}
\vspace{0.5cm}
