[QGIS Commit] r11189 - trunk/qgis/src/core/raster
svn_qgis at osgeo.org
Mon Jul 27 22:51:09 EDT 2009
Author: ersts
Date: 2009-07-27 22:51:08 -0400 (Mon, 27 Jul 2009)
New Revision: 11189
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
-Fix no data value from being included in histogram and stats
-Closes ticket #1380
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2009-07-28 02:04:46 UTC (rev 11188)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2009-07-28 02:51:08 UTC (rev 11189)
@@ -70,6 +70,13 @@
# endif
#endif
+// Comparison value for equality; i.e., we shouldn't directly compare two
+// floats so it's better to take their difference and see if they're within
+// a certain range -- in this case twenty times the smallest value that
+// doubles can take for the current system. (Yes, 20 was arbitrary.)
+#define TINY_VALUE std::numeric_limits<double>::epsilon() * 20
QgsRasterLayer::QgsRasterLayer(
QString const & path,
QString const & baseName,
@@ -106,7 +113,7 @@
mBandCount = 0;
mHasPyramids = false;
- mNoDataValue = -9999;
+ mNoDataValue = -9999.0;
mValidNoDataValue = false;
mGdalBaseDataset = 0;
@@ -759,18 +766,11 @@
myNXBlocks = ( GDALGetRasterXSize( myGdalBand ) + myXBlockSize - 1 ) / myXBlockSize;
myNYBlocks = ( GDALGetRasterYSize( myGdalBand ) + myYBlockSize - 1 ) / myYBlockSize;
- void *myData = CPLMalloc( myXBlockSize * myYBlockSize * GDALGetDataTypeSize( myDataType ) / 8 );
+ void *myData = CPLMalloc( myXBlockSize * myYBlockSize * ( GDALGetDataTypeSize( myDataType ) / 8 ) );
// unfortunately we need to make two passes through the data to calculate stddev
bool myFirstIterationFlag = true;
- // Comparison value for equality; i.e., we shouldn't directly compare two
- // floats so it's better to take their difference and see if they're within
- // a certain range -- in this case twenty times the smallest value that
- // doubles can take for the current system. (Yes, 20 was arbitrary.)
- double myPrecision = std::numeric_limits<double>::epsilon() * 20;
- Q_UNUSED( myPrecision );
//ifdefs below to remove compiler warning about unused vars
#ifdef QGISDEBUG
int success;
@@ -841,10 +841,9 @@
for ( int iX = 0; iX < nXValid; iX++ )
- double my = readValue( myData, myDataType, iX + iY * myXBlockSize );
+ double myValue = readValue( myData, myDataType, iX + ( iY * myXBlockSize ) );
- //if ( mValidNoDataValue && (fabs(my - mNoDataValue) < myPrecision || my == mNoDataValue || my != my))
- if ( mValidNoDataValue && ( my == mNoDataValue || my != my ) )
+ if ( mValidNoDataValue && ( fabs( myValue - mNoDataValue ) <= TINY_VALUE || myValue != myValue ) )
continue; // NULL
@@ -854,23 +853,23 @@
//this is the first iteration so initialise vars
myFirstIterationFlag = false;
- myRasterBandStats.minimumValue = my;
- myRasterBandStats.maximumValue = my;
+ myRasterBandStats.minimumValue = myValue;
+ myRasterBandStats.maximumValue = myValue;
++myRasterBandStats.elementCount;
} //end of true part for first iteration check
else
//this is done for all subsequent iterations
- if ( my < myRasterBandStats.minimumValue )
+ if ( myValue < myRasterBandStats.minimumValue )
- if ( my > myRasterBandStats.maximumValue )
+ if ( myValue > myRasterBandStats.maximumValue )
- myRasterBandStats.sum += my;
+ myRasterBandStats.sum += myValue;
} //end of false part for first iteration check
@@ -912,16 +911,15 @@
continue; // NULL
myRasterBandStats.sumOfSquares += static_cast < double >
- ( pow( my - myRasterBandStats.mean, 2 ) );
+ ( pow( myValue - myRasterBandStats.mean, 2 ) );
} //end of column wise loop
@@ -1893,7 +1891,7 @@
#endif
QString v;
- if ( mValidNoDataValue && ( mNoDataValue == value || value != value ) )
+ if ( mValidNoDataValue && ( fabs( value - mNoDataValue ) <= TINY_VALUE || value != value ) )
v = tr( "null (no data)" );
@@ -3071,7 +3069,8 @@
void QgsRasterLayer::resetNoDataValue()
+ mNoDataValue = std::numeric_limits<int>::max();
+ mValidNoDataValue = false;
if ( mGdalDataset != NULL && GDALGetRasterCount( mGdalDataset ) > 0 )
int myRequestValid;
@@ -3084,7 +3083,7 @@
else
- setNoDataValue( myValue );
+ setNoDataValue( -9999.0 );
@@ -4340,7 +4339,7 @@
myBlueValue = readValue( myGdalBlueData, ( GDALDataType )myBlueType,
myRow * theRasterViewPort->drawableAreaXDim + myColumn );
- if ( mValidNoDataValue && (( myRedValue == mNoDataValue || myRedValue != myRedValue ) || ( myGreenValue == mNoDataValue || myGreenValue != myGreenValue ) || ( myBlueValue == mNoDataValue || myBlueValue != myBlueValue ) ) )
+ if ( mValidNoDataValue && (( fabs( myRedValue - mNoDataValue ) <= TINY_VALUE || myRedValue != myRedValue ) || ( fabs( myGreenValue - mNoDataValue ) <= TINY_VALUE || myGreenValue != myGreenValue ) || ( fabs( myBlueValue - mNoDataValue ) <= TINY_VALUE || myBlueValue != myBlueValue ) ) )
myLineBuffer[ myColumn ] = myDefaultColor;
continue;
@@ -4466,7 +4465,7 @@
myPixelValue = readValue( myGdalScanData, ( GDALDataType )myDataType,
- if ( mValidNoDataValue && ( myPixelValue == mNoDataValue || myPixelValue != myPixelValue ) )
+ if ( mValidNoDataValue && ( fabs( myPixelValue - mNoDataValue ) <= TINY_VALUE || myPixelValue != myPixelValue ) )
continue;
@@ -4554,7 +4553,7 @@
continue;
@@ -4664,7 +4663,7 @@
continue;
@@ -4773,7 +4772,8 @@
// against myGrayVal will always fail ( nan==nan always
// returns false, by design), hence the slightly odd comparison
// of myGrayVal against itself.
- if ( mValidNoDataValue && ( myGrayValue == mNoDataValue || myGrayValue != myGrayValue ) )
+ if ( mValidNoDataValue && ( fabs( myGrayValue - mNoDataValue ) <= TINY_VALUE || myGrayValue != myGrayValue ) )
continue;
@@ -4876,7 +4876,7 @@
myPixelValue = readValue( myGdalScanData, myDataType,
continue;
@@ -5198,7 +5198,7 @@
// Determin the nodatavalue
- mNoDataValue = -9999; //Standard default?
+ mNoDataValue = -9999.0; //Standard default?
int isValid = false;
double myNoDataValue = GDALGetRasterNoDataValue( GDALGetRasterBand( mGdalDataset, 1 ), &isValid );
