[QGIS Commit] r11190 - trunk/qgis/src/core/composer
svn_qgis at osgeo.org
Tue Jul 28 04:04:27 EDT 2009
Author: mhugent
Date: 2009-07-28 04:04:26 -0400 (Tue, 28 Jul 2009)
New Revision: 11190
trunk/qgis/src/core/composer/qgscomposermap.cpp
Slightly better fix for composer map crash
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2009-07-28 02:51:08 UTC (rev 11189)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2009-07-28 08:04:26 UTC (rev 11190)
@@ -103,13 +103,6 @@
return;
- if ( mDrawing )
- return;
- mDrawing = true;
QgsMapRenderer theMapRenderer;
theMapRenderer.setExtent( extent );
theMapRenderer.setOutputSize( size, dpi );
@@ -145,8 +138,6 @@
theMapRenderer.setScale( scale() );
theMapRenderer.render( painter );
theMapRenderer.setScale( bk_scale );
- mDrawing = false;
void QgsComposerMap::cache( void )
@@ -156,6 +147,13 @@
return;
+ if ( mDrawing )
+ return;
+ mDrawing = true;
int w = rect().width() * horizontalViewScaleFactor();
int h = rect().height() * horizontalViewScaleFactor();
@@ -181,6 +179,8 @@
draw( &p, mExtent, QSize( w, h ), mCacheImage.logicalDpiX() );
p.end();
mCacheUpdated = true;
+ mDrawing = false;
void QgsComposerMap::paint( QPainter* painter, const QStyleOptionGraphicsItem* itemStyle, QWidget* pWidget )
@@ -307,7 +307,7 @@
void QgsComposerMap::zoomContent( int delta, double x, double y )
- if(mDrawing)
+ if ( mDrawing )
return;
