[QGIS Commit] r10882 - in trunk/qgis/src: app core ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jun 5 04:11:40 EDT 2009
Author: mhugent
Date: 2009-06-05 04:11:40 -0400 (Fri, 05 Jun 2009)
New Revision: 10882
   trunk/qgis/src/app/qgsoptions.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
   trunk/qgis/src/ui/qgsoptionsbase.ui
[FEATURE] Added option to show only markers of selected features in editing mode.
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp	2009-06-03 13:34:35 UTC (rev 10881)
+++ trunk/qgis/src/app/qgsoptions.cpp	2009-06-05 08:11:40 UTC (rev 10882)
@@ -218,6 +218,8 @@
   mSearchRadiusVertexEditComboBox->setCurrentIndex( settings.value( "/qgis/digitizing/search_radius_vertex_edit_unit", 0 ).toInt() );
   //vertex marker
+  mMarkersOnlyForSelectedCheckBox->setChecked(settings.value( "/qgis/digitizing/marker_only_for_selected", false ).toBool());
   mMarkerStyleComboBox->addItem( tr( "Semi transparent circle" ) );
   mMarkerStyleComboBox->addItem( tr( "Cross" ) );
   mMarkerStyleComboBox->addItem( tr( "None" ) );
@@ -436,6 +438,7 @@
   settings.setValue( "/qgis/digitizing/search_radius_vertex_edit_unit",
                      ( mSearchRadiusVertexEditComboBox->currentIndex()  == 0 ? QgsTolerance::MapUnits : QgsTolerance::Pixels ) );
+  settings.setValue( "/qgis/digitizing/marker_only_for_selected", mMarkersOnlyForSelectedCheckBox->isChecked() );
   QString markerComboText = mMarkerStyleComboBox->currentText();
   if ( markerComboText == tr( "Semi transparent circle" ) )
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2009-06-03 13:34:35 UTC (rev 10881)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2009-06-05 08:11:40 UTC (rev 10882)
@@ -101,6 +101,7 @@
     mRenderer( 0 ),
     mLabel( 0 ),
     mLabelOn( false ),
+    mVertexMarkerOnlyForSelection(false),
     mFetching( false )
   mActions = new QgsAttributeAction;
@@ -439,13 +440,12 @@
   // draw vertex markers if in editing mode, but only to the main canvas
   if ( mEditable && drawingToEditingCanvas )
-    QgsVectorLayer::VertexMarkerType markerType = currentVertexMarkerType();
     std::vector<double>::const_iterator xIt;
     std::vector<double>::const_iterator yIt;
     for ( xIt = x.begin(), yIt = y.begin(); xIt != x.end(); ++xIt, ++yIt )
-      drawVertexMarker(( int )( *xIt ), ( int )( *yIt ), *p, markerType );
+      drawVertexMarker(( int )( *xIt ), ( int )( *yIt ), *p, mCurrentVertexMarkerType );
@@ -662,12 +662,10 @@
       for ( int i = 0; i < path.elementCount(); ++i )
         const QPainterPath::Element & e = path.elementAt( i );
-        drawVertexMarker(( int )e.x, ( int )e.y, *p, markerType );
+        drawVertexMarker(( int )e.x, ( int )e.y, *p, mCurrentVertexMarkerType );
@@ -702,13 +700,16 @@
     QPen pen;
     /*Pointer to a marker image*/
     QImage marker;
+    //vertex marker type for selection
+    QgsVectorLayer::VertexMarkerType vertexMarker;
     if ( mEditable )
       // Destroy all cached geometries and clear the references to them
       deleteCachedGeometries();
       mCachedGeometriesRect = rendererContext.extent();
+      vertexMarker = currentVertexMarkerType();
+      mVertexMarkerOnlyForSelection = settings.value( "/qgis/digitizing/marker_only_for_selected", false ).toBool();
     updateFeatureCount();
@@ -744,17 +745,28 @@
         Q_UNUSED( totalFeatures );
 #endif //Q_WS_MAC
+        // check if feature is selected
+        // only show selections of the current layer
+        // TODO: create a mechanism to let layer know whether it's current layer or not [MD]
+        bool sel = mSelectedFeatureIds.contains( fet.id() );
         if ( mEditable )
           // Cache this for the use of (e.g.) modifying the feature's uncommitted geometry.
           mCachedGeometries[fet.id()] = *fet.geometry();
+          if(mVertexMarkerOnlyForSelection && !sel)
+            mCurrentVertexMarkerType = QgsVectorLayer::NoMarker;
+          else
+            mCurrentVertexMarkerType = vertexMarker;
-        // check if feature is selected
-        // only show selections of the current layer
-        // TODO: create a mechanism to let layer know whether it's current layer or not [MD]
-        bool sel = mSelectedFeatureIds.contains( fet.id() );
         //QgsDebugMsg(QString("markerScale before renderFeature(): %1").arg(markerScaleFactor));
         // markerScalerFactore reflects the wanted scaling of the marker
         mRenderer->renderFeature(
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2009-06-03 13:34:35 UTC (rev 10881)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2009-06-05 08:11:40 UTC (rev 10882)
@@ -654,6 +654,12 @@
     /** Display labels */
     bool mLabelOn;
+    /**The current type of editing marker*/
+    QgsVectorLayer::VertexMarkerType mCurrentVertexMarkerType;
+    /**Flag if the vertex markers should be drawn only for selection (true) or for all features (false)*/
+    bool mVertexMarkerOnlyForSelection;
     /**List of overlays. Vector overlays will be rendered on top of all maplayers*/
     QList<QgsVectorOverlay*> mOverlays;
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui	2009-06-03 13:34:35 UTC (rev 10881)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui	2009-06-05 08:11:40 UTC (rev 10882)
@@ -13,7 +13,9 @@
    <string>QGIS Options</string>
   </property>
   <property name="windowIcon" >
-   <iconset/>
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
   <property name="sizeGripEnabled" >
    <bool>true</bool>
@@ -28,7 +30,7 @@
       <enum>Qt::Horizontal</enum>
      </property>
      <property name="standardButtons" >
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
@@ -48,18 +50,9 @@
           <string>Project files</string>
          </property>
          <layout class="QVBoxLayout" >
-          <property name="leftMargin" >
+          <property name="margin" >
            <number>11</number>
           </property>
-          <property name="topMargin" >
-           <number>11</number>
-          </property>
-          <property name="rightMargin" >
-          </property>
-          <property name="bottomMargin" >
-          </property>
           <item>
            <widget class="QCheckBox" name="chbAskToSaveProjectChanges" >
             <property name="text" >
@@ -98,7 +91,7 @@
             <property name="orientation" >
             </property>
-            <property name="sizeHint" >
+            <property name="sizeHint" stdset="0" >
              <size>
               <width>40</width>
               <height>20</height>
@@ -134,7 +127,7 @@
             </property>
              <size>
               <width>40</width>
               <height>20</height>
@@ -241,7 +234,7 @@
          <property name="sizeType" >
           <enum>QSizePolicy::Minimum</enum>
          </property>
           <size>
            <width>577</width>
            <height>21</height>
@@ -308,18 +301,9 @@
           <string>Rendering quality</string>
          </property>
            <number>11</number>
           </property>
-          </property>
-          </property>
-          </property>
           <item>
            <widget class="QCheckBox" name="chkAntiAliasing" >
@@ -345,7 +329,7 @@
           <enum>Qt::Vertical</enum>
          </property>
           <size>
            <width>20</width>
            <height>40</height>
@@ -360,36 +344,18 @@
        <string>&amp;Map tools</string>
       </attribute>
       <layout class="QGridLayout" >
         <number>11</number>
        </property>
-       </property>
-       </property>
-       </property>
        <item row="2" column="0" >
         <widget class="QGroupBox" name="groupBox_10" >
          <property name="title" >
           <string>Panning and zooming</string>
          </property>
            <number>11</number>
           </property>
-          </property>
-          </property>
-          </property>
           <item row="0" column="1" >
            <widget class="QComboBox" name="cmbWheelAction" >
             <item>
@@ -450,24 +416,15 @@
           <string>Measure tool</string>
          </property>
            <number>11</number>
           </property>
-          </property>
-          </property>
-          </property>
           <item row="1" column="2" >
            <spacer>
             </property>
              <size>
               <width>191</width>
               <height>20</height>
@@ -520,18 +477,9 @@
           <string>Search radius</string>
          </property>
            <number>11</number>
           </property>
-          </property>
-          </property>
-          </property>
           <item row="1" column="0" colspan="2" >
            <widget class="QLabel" name="textLabel2" >
@@ -576,7 +524,7 @@
          </property>
           <size>
            <width>20</width>
            <height>40</height>
@@ -627,7 +575,7 @@
            </property>
             <size>
              <width>221</width>
              <height>20</height>
@@ -643,8 +591,8 @@
       <attribute name="title" >
        <string>Digitizing</string>
       </attribute>
-      <layout class="QVBoxLayout" >
-       <item>
+      <layout class="QGridLayout" name="gridLayout_2" >
+       <item row="0" column="0" >
         <widget class="QGroupBox" name="mRubberBandGroupBox" >
           <string>Rubberband</string>
@@ -696,7 +644,7 @@
          </layout>
         </widget>
        </item>
-       <item>
+       <item row="1" column="0" >
         <widget class="QGroupBox" name="mSnappingGroupBox" >
           <string>Snapping</string>
@@ -714,7 +662,7 @@
             </property>
              <size>
               <width>311</width>
               <height>20</height>
@@ -744,7 +692,7 @@
             </property>
              <size>
               <width>241</width>
               <height>20</height>
@@ -774,7 +722,7 @@
             </property>
              <size>
               <width>61</width>
               <height>20</height>
@@ -829,25 +777,32 @@
          </layout>
         </widget>
        </item>
-       <item>
+       <item row="2" column="0" >
         <widget class="QGroupBox" name="mVertexMarkerGroupBox" >
           <string>Vertex markers</string>
          </property>
-         <layout class="QGridLayout" >
-          <item row="0" column="0" >
+         <layout class="QGridLayout" name="gridLayout" >
+          <item row="0" column="0" colspan="2" >
+           <widget class="QCheckBox" name="mMarkersOnlyForSelectedCheckBox" >
+            <property name="text" >
+             <string>Show markers only for selected features</string>
+            </property>
+           </widget>
+          </item>
            <widget class="QLabel" name="mMarkerStyleLabel" >
              <string>Marker style</string>
             </property>
            </widget>
           </item>
-          <item row="0" column="1" >
+          <item row="1" column="1" >
            <spacer>
             </property>
              <size>
               <width>281</width>
               <height>20</height>
@@ -855,7 +810,7 @@
             </property>
            </spacer>
           </item>
-          <item row="0" column="2" >
+          <item row="1" column="2" >
            <widget class="QComboBox" name="mMarkerStyleComboBox" >
             <property name="sizePolicy" >
              <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
@@ -868,7 +823,7 @@
          </layout>
         </widget>
        </item>
-       <item>
+       <item row="3" column="0" >
         <widget class="QGroupBox" name="mEnterAttributeValuesGroupBox" >
           <string>Enter attribute values</string>
@@ -887,12 +842,12 @@
          </layout>
         </widget>
        </item>
-       <item>
+       <item row="4" column="0" >
         <spacer>
          </property>
           <size>
            <width>547</width>
            <height>71</height>
@@ -907,24 +862,15 @@
        <string>CRS</string>
       </attribute>
         <number>11</number>
        </property>
-       </property>
-       </property>
-       </property>
         <spacer>
          </property>
           <size>
            <width>51</width>
            <height>31</height>
@@ -948,18 +894,9 @@
           <string>When layer is loaded that has no coordinate reference system (CRS)</string>
          </property>
            <number>11</number>
           </property>
-          </property>
-          </property>
-          </property>
           <item>
            <widget class="QRadioButton" name="radPromptForProjection" >
@@ -1031,7 +968,7 @@
          </property>
           <size>
            <width>501</width>
            <height>51</height>
@@ -1152,7 +1089,7 @@
             </property>
              <size>
               <width>241</width>
               <height>20</height>
@@ -1186,7 +1123,7 @@
             </property>
              <size>
               <width>391</width>
               <height>20</height>
More information about the QGIS-commit mailing list
