[QGIS Commit] r10883 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jun 5 05:24:00 EDT 2009
Author: mhugent
Date: 2009-06-05 05:24:00 -0400 (Fri, 05 Jun 2009)
New Revision: 10883
   trunk/qgis/src/app/qgsprojectproperties.cpp
More robust parsing of project snapping options
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp	2009-06-05 08:11:40 UTC (rev 10882)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp	2009-06-05 09:24:00 UTC (rev 10883)
@@ -120,13 +120,12 @@
     mAvoidIntersectionsCheckBox->setCheckState( Qt::Unchecked );
-  bool ok;
-  bool toleranceUnitOk; //1.0 project files may not have a unit entry
-  QStringList layerIdList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingList", &ok );
-  QStringList enabledList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingEnabledList", &ok );
-  QStringList toleranceList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceList", &ok );
-  QStringList toleranceUnitList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceUnitList", &toleranceUnitOk );
-  QStringList snapToList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnapToList", &ok );
+  bool layerIdListOk, enabledListOk, toleranceListOk, toleranceUnitListOk, snapToListOk;
+  QStringList layerIdList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingList", &layerIdListOk );
+  QStringList enabledList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingEnabledList", &enabledListOk );
+  QStringList toleranceList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceList", & toleranceListOk);
+  QStringList toleranceUnitList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceUnitList", & toleranceUnitListOk);
+  QStringList snapToList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnapToList", &snapToListOk );
   QStringList::const_iterator idIter = layerIdList.constBegin();
   QStringList::const_iterator enabledIter = enabledList.constBegin();
@@ -139,33 +138,62 @@
   //create the new layer entries
   for ( ; idIter != layerIdList.constEnd(); ++idIter, ++enabledIter, ++tolIter, ++tolUnitIter, ++snapToIter )
-    currentLayer = QgsMapLayerRegistry::instance()->mapLayer( *idIter );
+    if(layerIdListOk)
+      currentLayer = QgsMapLayerRegistry::instance()->mapLayer( *idIter );
+    else
+      break;
     if ( currentLayer )
       LayerEntry newEntry;
       newEntry.layerName = currentLayer->name();
-      if (( *enabledIter ) == "enabled" )
+      newEntry.checked = false;
+      if(enabledListOk && enabledIter != enabledList.constEnd())
-        newEntry.checked = true;
+        if (( *enabledIter ) == "enabled" )
+          newEntry.checked = true;
-      else
+      //snap to vertex / segment / vertex and segment
+      if(snapToListOk &&snapToIter != snapToList.constEnd())
-        newEntry.checked = false;
+        if (( *snapToIter ) == "to_vertex" )
+          newEntry.snapTo = 0;
+        else if (( *snapToIter ) == "to_segment" )
+          newEntry.snapTo = 1;
+        else //to vertex and segment
+          newEntry.snapTo = 2;
-      if (( *snapToIter ) == "to_vertex" )
+      else
-      else if (( *snapToIter ) == "to_segment" )
+      //snap tolerance
+      if(toleranceListOk && tolIter != toleranceList.constEnd())
-        newEntry.snapTo = 1;
+        newEntry.tolerance = tolIter->toDouble();
-      else //to vertex and segment
+      else
-        newEntry.snapTo = 2;
+        newEntry.tolerance = 0;
-      newEntry.tolerance = tolIter->toDouble();
-      if ( toleranceUnitOk )
+      //snap tolerance unit
+      if (toleranceUnitListOk && tolUnitIter != toleranceUnitList.constEnd())
         newEntry.toleranceUnit = tolUnitIter->toInt();
More information about the QGIS-commit mailing list
