[QGIS Commit] r10281 - in trunk/qgis/src/plugins/grass: config modules
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 16 06:31:45 EDT 2009
Author: pcav
Date: 2009-03-16 06:31:44 -0400 (Mon, 16 Mar 2009)
New Revision: 10281
   trunk/qgis/src/plugins/grass/config/default.qgc
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
New GRASS modules to convert loaded rater and vectors
Modified: trunk/qgis/src/plugins/grass/config/default.qgc
--- trunk/qgis/src/plugins/grass/config/default.qgc	2009-03-15 21:00:09 UTC (rev 10280)
+++ trunk/qgis/src/plugins/grass/config/default.qgc	2009-03-16 10:31:44 UTC (rev 10281)
@@ -8,6 +8,8 @@
 	<section label="File">
 		<section label="Import">
 			<section label="Import raster">
+                                <grass name="r.in.gdal.qgis"/>
+                                <grass name="r.in.gdal.qgis.loc"/>
 				<grass name="r.in.gdal"/>
 				<grass name="r.in.gdal.loc"/>
 				<grass name="r.in.ascii"/>
@@ -19,6 +21,21 @@
 				<grass name="r.in.srtm"/>
 				<grass name="r.in.aster"/>
 			</section>
+			 <section label="Import vector">
+                                <grass name="v.in.ogr.qgis"/>
+                                <grass name="v.in.ogr"/>
+                                <grass name="v.in.ogr.qgis.loc"/>
+                                <grass name="v.in.ogr.loc"/>
+                                <grass name="v.in.ogr.all"/>
+				<grass name="v.in.ogr.all.loc"/>
+                                <grass name="v.in.dxf"/>
+                                <grass name="v.in.e00"/>
+                                <grass name="v.in.mapgen"/>
+                                <grass name="v.in.db"/>
+                                <grass name="v.in.garmin"/>
+                                <grass name="v.in.gpsbabel"/>
+                        </section>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm	2009-03-15 21:00:09 UTC (rev 10280)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm	2009-03-16 10:31:44 UTC (rev 10281)
@@ -1,7 +1,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Import GDAL supported raster and create fitted location" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster and create a fitted location" module="r.in.gdal">
 	<flag key="o" answer="off" hidden="yes" />
 	<flag key="e" answer="on" hidden="yes" />
 	<file key="input" />
More information about the QGIS-commit mailing list
