[QGIS Commit] r10396 - in branches/Version-1_0/src: app ui
svn_qgis at osgeo.org
Sat Mar 21 19:54:30 EDT 2009
Author: timlinux
Date: 2009-03-21 19:54:30 -0400 (Sat, 21 Mar 2009)
New Revision: 10396
branches/Version-1_0/src/app/qgsvectorlayerproperties.cpp
branches/Version-1_0/src/ui/qgsvectorlayerpropertiesbase.ui
Backported disable labels options when labels are not checked to stable branch
Modified: branches/Version-1_0/src/app/qgsvectorlayerproperties.cpp
--- branches/Version-1_0/src/app/qgsvectorlayerproperties.cpp 2009-03-21 23:44:22 UTC (rev 10395)
+++ branches/Version-1_0/src/app/qgsvectorlayerproperties.cpp 2009-03-21 23:54:30 UTC (rev 10396)
@@ -447,6 +447,7 @@
actionDialog->init();
labelDialog->init();
labelCheckBox->setChecked( layer->hasLabelsEnabled() );
+ labelOptionsFrame->setEnabled ( layer->hasLabelsEnabled() );
//set the transparency slider
sliderTransparency->setValue( 255 - layer->getTransparency() );
//update the transparency percentage label
Modified: branches/Version-1_0/src/ui/qgsvectorlayerpropertiesbase.ui
--- branches/Version-1_0/src/ui/qgsvectorlayerpropertiesbase.ui 2009-03-21 23:44:22 UTC (rev 10395)
+++ branches/Version-1_0/src/ui/qgsvectorlayerpropertiesbase.ui 2009-03-21 23:54:30 UTC (rev 10396)
@@ -19,9 +19,7 @@
<string>Layer Properties</string>
</property>
<property name="windowIcon" >
- <iconset>
- <normaloff/>
- </iconset>
+ <iconset/>
</property>
<property name="modal" >
<bool>true</bool>
@@ -32,9 +30,18 @@
<property name="spacing" >
<number>3</number>
</property>
- <property name="margin" >
+ <property name="leftMargin" >
<number>1</number>
</property>
+ <property name="topMargin" >
+ <number>1</number>
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
<item>
<widget class="QPushButton" name="pbnLoadDefaultStyle" >
<property name="text" >
@@ -71,7 +78,7 @@
<enum>Qt::Horizontal</enum>
</property>
<property name="standardButtons" >
- <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
+ <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
@@ -93,17 +100,9 @@
<enum>QTabWidget::Rounded</enum>
</property>
<property name="currentIndex" >
- <number>5</number>
+ <number>3</number>
</property>
<widget class="QWidget" name="tab1" >
- <property name="geometry" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>817</width>
- <height>557</height>
- </rect>
- </property>
<attribute name="title" >
<string>General</string>
</attribute>
@@ -183,9 +182,18 @@
<bool>true</bool>
</property>
<layout class="QGridLayout" >
<number>11</number>
</property>
+ <number>11</number>
+ </property>
+ </property>
+ </property>
<item row="0" column="2" >
<widget class="QLabel" name="textLabel1_2_2" >
@@ -241,9 +249,18 @@
<string>Subset</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="0" column="0" colspan="2" >
<widget class="QTextEdit" name="txtSubsetSQL" >
<property name="enabled" >
@@ -265,7 +282,7 @@
<property name="sizeType" >
<enum>QSizePolicy::Expanding</enum>
</property>
- <property name="sizeHint" stdset="0" >
+ <property name="sizeHint" >
<size>
<width>480</width>
<height>21</height>
@@ -286,14 +303,6 @@
</layout>
</widget>
<widget class="QWidget" name="tab2" >
- <rect>
- <x>0</x>
- <y>0</y>
- <height>552</height>
- </rect>
- </property>
<property name="sizePolicy" >
<sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
<horstretch>0</horstretch>
@@ -400,46 +409,29 @@
<number>1</number>
</property>
- <widget class="QWidget" name="page" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>100</width>
- <height>30</height>
- </rect>
- </property>
- </widget>
- <widget class="QWidget" name="page_2" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>799</width>
- <height>502</height>
- </rect>
- </property>
- </widget>
+ <widget class="QWidget" name="page" />
+ <widget class="QWidget" name="page_2" />
</widget>
</item>
</layout>
</widget>
<widget class="QWidget" name="tab3" >
- <rect>
- <x>0</x>
- <y>0</y>
- </rect>
- </property>
<string>Metadata</string>
</attribute>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="0" column="0" >
<widget class="QTextEdit" name="teMetadata" >
<property name="lineWidth" >
@@ -453,14 +445,6 @@
</layout>
</widget>
<widget class="QWidget" name="tab4" >
- <rect>
- <x>0</x>
- <y>0</y>
- </rect>
- </property>
<string>Labels</string>
</attribute>
@@ -480,6 +464,9 @@
</item>
<item row="1" column="0" >
<widget class="QFrame" name="labelOptionsFrame" >
+ <property name="enabled" >
+ <bool>false</bool>
+ </property>
@@ -497,14 +484,6 @@
</layout>
</widget>
<widget class="QWidget" name="tab5" >
- <rect>
- <x>0</x>
- <y>0</y>
- </rect>
- </property>
<string>Actions</string>
</attribute>
@@ -528,20 +507,12 @@
</layout>
</widget>
<widget class="QWidget" name="tab6" >
- <rect>
- <x>0</x>
- <y>0</y>
- </rect>
- </property>
<string>Attributes</string>
</attribute>
- <layout class="QVBoxLayout" name="verticalLayout" >
+ <layout class="QVBoxLayout" >
<item>
- <layout class="QHBoxLayout" name="horizontalLayout" >
+ <layout class="QHBoxLayout" >
<property name="sizeConstraint" >
<enum>QLayout::SetNoConstraint</enum>
</property>
@@ -560,8 +531,7 @@
<string/>
</property>
<property name="icon" >
- <iconset>
- <normaloff>../xpm/new_attribute.png</normaloff>../xpm/new_attribute.png</iconset>
+ <iconset>../xpm/new_attribute.png</iconset>
</property>
<property name="shortcut" >
<string>Ctrl+N</string>
@@ -577,8 +547,7 @@
<string/>
</property>
- <iconset>
- <normaloff>../xpm/delete_attribute.png</normaloff>../xpm/delete_attribute.png</iconset>
+ <iconset>../xpm/delete_attribute.png</iconset>
</property>
<string>Ctrl+X</string>
@@ -602,11 +571,11 @@
</widget>
</item>
<item>
- <spacer name="horizontalSpacer" >
+ <spacer>
<property name="orientation" >
</property>
<size>
<width>40</width>
<height>20</height>
@@ -636,8 +605,6 @@
</widget>
</item>
</layout>
- <zorder>tblAttributes</zorder>
- <zorder></zorder>
</widget>
</widget>
</item>
@@ -667,5 +634,22 @@
<tabstop>tabWidget</tabstop>
</tabstops>
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>labelCheckBox</sender>
+ <signal>clicked(bool)</signal>
+ <receiver>labelOptionsFrame</receiver>
+ <slot>setEnabled(bool)</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>60</x>
+ <y>53</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>61</x>
+ <y>68</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
