[QGIS Commit] r10397 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sun Mar 22 03:41:36 EDT 2009
Author: timlinux
Date: 2009-03-22 03:41:35 -0400 (Sun, 22 Mar 2009)
New Revision: 10397
trunk/qgis/src/ui/BeataGui.ui
Layout tweaks for new attribute table to remove margin space
Modified: trunk/qgis/src/ui/BeataGui.ui
--- trunk/qgis/src/ui/BeataGui.ui 2009-03-21 23:54:30 UTC (rev 10396)
+++ trunk/qgis/src/ui/BeataGui.ui 2009-03-22 07:41:35 UTC (rev 10397)
@@ -12,11 +12,33 @@
<property name="windowTitle" >
<string>Attribute Table</string>
</property>
- <layout class="QVBoxLayout" >
- <item>
- <widget class="BeataView" name="mView" />
+ <layout class="QGridLayout" >
+ <property name="leftMargin" >
+ <number>0</number>
+ </property>
+ <property name="topMargin" >
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
+ </property>
+ <property name="verticalSpacing" >
+ </property>
+ <item row="0" column="0" >
+ <widget class="BeataView" name="mView" >
+ <property name="alternatingRowColors" >
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
- <item>
+ <item row="1" column="0" >
<layout class="QHBoxLayout" >
<item>
<widget class="QPushButton" name="searchButton" >
@@ -46,53 +68,30 @@
<widget class="QComboBox" name="columnBox" />
</item>
<item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
+ <widget class="QPushButton" name="btnShowAll" >
+ <property name="focusPolicy" >
+ <enum>Qt::NoFocus</enum>
</property>
- <property name="sizeHint" >
- <size>
- <width>40</width>
- <height>20</height>
- </size>
+ <property name="text" >
+ <string>&All</string>
</property>
- </spacer>
+ <property name="checkable" >
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
<item>
- <layout class="QHBoxLayout" >
- <property name="spacing" >
- <number>0</number>
+ <widget class="QPushButton" name="btnShowSelected" >
</property>
- <property name="leftMargin" >
+ <string>S&elected</string>
</property>
- <item>
- <widget class="QPushButton" name="btnShowAll" >
- <property name="focusPolicy" >
- <enum>Qt::NoFocus</enum>
- </property>
- <property name="text" >
- <string>&All</string>
- </property>
- <property name="checkable" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnShowSelected" >
- </property>
- <string>S&elected</string>
- </property>
- <bool>true</bool>
- </property>
- </widget>
- </item>
- </layout>
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
<item>
<widget class="QPushButton" name="actionsButton" >
