[QGIS Commit] r10431 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri Mar 27 15:16:39 EDT 2009
Author: wonder
Date: 2009-03-27 15:16:39 -0400 (Fri, 27 Mar 2009)
New Revision: 10431
trunk/qgis/src/app/qgspluginmanager.cpp
trunk/qgis/src/app/qgspluginmanager.h
trunk/qgis/src/ui/qgspluginmanagerbase.ui
added button in plugin manager for opening plugin installer (if present).
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp 2009-03-27 19:12:40 UTC (rev 10430)
+++ trunk/qgis/src/app/qgspluginmanager.cpp 2009-03-27 19:16:39 UTC (rev 10431)
@@ -93,6 +93,16 @@
connect( btnClearAll, SIGNAL( clicked() ), this, SLOT( clearAll() ) );
qRegisterMetaType<QgsDetailedItemData>();
+ // check for plugin installer
+ if (checkForPluginInstaller())
+ connect( btnPluginInstaller, SIGNAL( clicked() ), this, SLOT( showPluginInstaller() ));
+ else
+ btnPluginInstaller->setEnabled(false);
@@ -500,3 +510,43 @@
QRegExp myRegExp( theText, myCaseSensitivity, mySyntax );
mModelProxy->setFilterRegExp( myRegExp );
+bool QgsPluginManager::checkForPluginInstaller()
+ // check whether python's enabled
+ if (!mPythonUtils)
+ return false;
+ // check whether python installer is present
+ if (!mPythonUtils->pluginList().contains("plugin_installer"))
+ return false;
+ QString res;
+ // check it's loaded and started
+ bool retval = mPythonUtils->evalString("plugins.has_key('plugin_installer')", res);
+ if (!retval || res != "True")
+ // TODO: try to load the plugin installer!
+ return false;
+ return true;
+void QgsPluginManager::showPluginInstaller()
+ bool res;
+ QString cls, msg;
+ res = mPythonUtils->runStringUnsafe("_qgis_plugin_manager = wrapinstance( " + QString::number((unsigned long)this) + ", QtGui.QWidget )");
+ if (!res)
+ QgsDebugMsg("wrapinstance error: " + cls + " :: " + msg);
+ res = mPythonUtils->runStringUnsafe("plugins['plugin_installer'].run( _qgis_plugin_manager )");
+ if (!res)
+ mPythonUtils->getError(cls, msg);
+ QMessageBox::warning(this, tr("Error"), tr("Failed to open plugin installer!"));
+ mPythonUtils->runStringUnsafe("del _qgis_plugin_manager");
Modified: trunk/qgis/src/app/qgspluginmanager.h
--- trunk/qgis/src/app/qgspluginmanager.h 2009-03-27 19:12:40 UTC (rev 10430)
+++ trunk/qgis/src/app/qgspluginmanager.h 2009-03-27 19:16:39 UTC (rev 10431)
@@ -56,6 +56,8 @@
void resizeColumnsToContents();
//! Sort model by column ascending
void sortModel( int );
+ //! Check whether plugin installer is available (and tries to load it if it's disabled)
+ bool checkForPluginInstaller();
public slots:
//! Enable disable checkbox
void on_vwPlugins_clicked( const QModelIndex & );
@@ -67,6 +69,8 @@
void clearAll();
//! Update the filter when user changes the filter expression
void on_leFilter_textChanged( QString theText );
+ //! Show the plugin installer
+ void showPluginInstaller();
private:
QStandardItemModel *mModelPlugins;
QSortFilterProxyModel * mModelProxy;
Modified: trunk/qgis/src/ui/qgspluginmanagerbase.ui
--- trunk/qgis/src/ui/qgspluginmanagerbase.ui 2009-03-27 19:12:40 UTC (rev 10430)
+++ trunk/qgis/src/ui/qgspluginmanagerbase.ui 2009-03-27 19:16:39 UTC (rev 10431)
@@ -78,7 +78,14 @@
</property>
</widget>
</item>
- <item row="4" column="0" colspan="3" >
+ <item row="4" column="0" colspan="2" >
+ <widget class="QPushButton" name="btnPluginInstaller" >
+ <property name="text" >
+ <string>Plugin Installer</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="2" >
<widget class="QDialogButtonBox" name="buttonBox" >
<property name="standardButtons" >
<set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
@@ -91,6 +98,7 @@
<tabstops>
<tabstop>vwPlugins</tabstop>
<tabstop>leFilter</tabstop>
+ <tabstop>btnPluginInstaller</tabstop>
<tabstop>buttonBox</tabstop>
</tabstops>
<resources/>
