[QGIS Commit] r10754 -
docs/trunk/english_us/coding-compilation_guide
svn_qgis at osgeo.org
Thu May 7 13:36:49 EDT 2009
Author: cfarmer
Date: 2009-05-07 13:36:49 -0400 (Thu, 07 May 2009)
New Revision: 10754
docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_cpp.tex
docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_python.tex
updates to both plugin chapters of coding and compilation guide
Modified: docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_cpp.tex
--- docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_cpp.tex 2009-05-07 16:26:07 UTC (rev 10753)
+++ docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_cpp.tex 2009-05-07 17:36:49 UTC (rev 10754)
@@ -10,13 +10,13 @@
C++ plugin. It is based on a workshop held by Dr. Marco Hugentobler.
QGIS C++ plugins are dynamically linked libraries (.so or .dll). They are
-linked to QGIS at runtime when requested in the plugin manager and extend the
-functionality of QGIS. They have access to the QGIS GUI and can be devided
+linked to QGIS at runtime when requested in the Plugin Manager, and extend the
+functionality of QGIS via access to the QGIS GUI. In general, they can be devided
into core and external plugins.
-Technically the QGIS plugin manager looks in the lib/qgis directory for all
+Technically the QGIS Plugin Manager looks in the lib/qgis directory for all
.so files and loads them when it is started. When it is closed they are
-unloaded again, except the ones with a checked box. For newly loaded plugins,
+unloaded again, except the ones enabled by the user (See User Manual). For newly loaded plugins,
the \method{classFactory} method creates an instance of the plugin class and
the \method{initGui} method of the plugin is called to show the GUI elements
in the plugin menu and toolbar. The \method{unload()} function of the plugin
@@ -31,9 +31,9 @@
as well. It is an object-oriented programming (OOP) language that is prefered
by many developers for creating large-scale applications.
-QGIS C++ plugins use the functionalities of libqgis*.so libraries. As they are
-licensed under the GNU GPL, QGIS C++ plugins must also be licenced under the GPL.
-This means that you may use your plugins for any purpose and you are not required to
+QGIS C++ plugins take advantage of the functionalities provided by the libqgis*.so libraries.
+As these libraries licensed under the GNU GPL, QGIS C++ plugins must also be licenced under
+the GPL. This means that you may use your plugins for any purpose and you are not required to
publish them. If you do publish them however, they must be published under
the conditions of the GPL license.
@@ -41,18 +41,18 @@
The C++ plugin example covered in this manual is a point converter plugin and intentionally kept simple.
The plugin searches the active vector layer in QGIS, converts all vertices of
-the layer's features to point features keeping the attributes, and finally
+the layer's features to point features (keeping the attributes), and finally
writes the point features to a delimited text file. The new layer can then
be loaded into QGIS using the delimited text plugin (see User Manual).
\minisec{Step 1: Make the plugin manager recognise the plugin}
As a first step we create the \filename{QgsPointConverter.h} and
-\filename{QgsPointConverter.cpp} files. Then we add virtual methods inherited
-from QgisPlugin (but leave them empty for now), create necessary external 'C'
-methods and a .pro file, which is a Qt mechanism to easily create Makefiles.
-Then we compile the sources, move the compiled library into the plugin folder
-and load it in the QGIS plugin manager.
+\filename{QgsPointConverter.cpp} files. We then add virtual methods inherited
+from QgisPlugin (but leave them empty for now), create the necessary external 'C'
+methods, and a .pro file (which is a Qt mechanism to easily create Makefiles).
+Then we compile the sources, move the compiled library into the plugin folder,
+and load it in the QGIS Plugin Manager.
\textbf{a) Create new pointconverter.pro file and add}:
@@ -520,10 +520,10 @@
\minisec{Step 4: Copy the feature attributes to the text file}
-At the end we extract the attributes from the active layer using
-QgsVectorDataProvider::fieldNameMap(). For each feature we extract the field
-values using QgsFeature::attributeMap() and add the contents comma separated
-behind the x- and y-coordinates for each new point feature. For this step
+At the end we extract the attributes from the active layer using
+QgsVectorDataProvider::fieldNameMap(). For each feature we extract the field
+values using QgsFeature::attributeMap() and add the contents (comma separated)
+behind the x- and y-coordinates for each new point feature. For this step
there is no need for any furter change in \filename{qgspointconverterplugin.h}
\textbf{h) Open qgspointconverterplugin.cpp again and extend existing content
@@ -828,9 +828,9 @@
\subsection{Further information}
-As you can see, you need information from different sources to write QGIS C++
-plugins. Plugin writers need to know C++, the QGIS plugin interface as
-well as Qt4 classes and tools. At the beginning it is best to learn from
+As you can see, you need information from many different sources to write QGIS C++
+plugins. Plugin writers need to know C++, the QGIS plugin interface as
+well as Qt4 classes and tools. At the beginning it is best to learn from
examples and copy the mechanism of existing plugins.
There is a a collection of online documentation that may be usefull for
Modified: docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_python.tex
--- docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_python.tex 2009-05-07 16:26:07 UTC (rev 10753)
+++ docs/trunk/english_us/coding-compilation_guide/plugins_writing_in_python.tex 2009-05-07 17:36:49 UTC (rev 10754)
@@ -6,35 +6,34 @@
% comment out the following line:
% \updatedisclaimer
-In this section you find a beginner's tutorial for writing a QGIS Python
-plugins. It is based on the workshop "Extending the Functionality of QGIS
+In this section we provide a beginner's tutorial for writing a simple QGIS Python
+plugin. It is based on the workshop "Extending the Functionality of QGIS
with Python Plugins" held at FOSS4G 2008 by Dr. Marco Hugentobler, Dr. Horst
D\"uster and Tim Sutton.
Apart from writing a QGIS Python plugin, it is also possible to use PyQGIS
-from a python command line console which is mainly interesting for debugging
-or to write standalone applications in Python with their own user interfaces
-using the functionality of the QGIS core library.
+from a python command line console which is useful for debugging or writing
+standalone applications in Python, with their own user interfaces
+based on the functionality of the QGIS core library.
\subsection{Why Python and what about licensing}
-Python is a scripting language which was designed with the goal of being easy
-to program. It has a mechanism that automatically releases memory that is no
+Python is a scripting language that was designed with the goal of being easy
+to program. It has a mechanism for automatically releasing memory that is no
longer used (garbagge collector). A further advantage is that many programs
that are written in C++ or Java offer the possibility to write extensions in
Python, e.g. OpenOffice or Gimp. Therefore it is a good investment of time to
learn the Python language.
-PyQGIS plugins use functionality of libqgis\_core.so and libqgis\_gui.so. As
-both are licensed under GNU GPL, QGIS Python plugins must be licenced under the
-GPL, too. This means you may use your plugins for any purpose and you are not
-forced to publish them. If you do publish them however, they must be
-published under the conditions of the GPL license.
+PyQGIS plugins take advantage of the functionality of libqgis\_core.so and libqgis\_gui.so.
+As both libqgis\_core.so and libqgis\_gui.so are licensed under GNU GPL, QGIS Python
+plugins must also be licenced under the GPL. This means you may use your plugins
+for any purpose, and you are not forced to publish them. If you do publish them however,
+they must be published under the conditions of the GPL license.
\subsection{What needs to be installed to get started}
-If you program Python plugins at home, you will need the following libraries
-and programs:
+You will need the following libraries and programs to create QGIS python plugins yourself:
\begin{itemize}
\item QGIS
@@ -45,13 +44,12 @@
\end{itemize}
If you use Linux, there are binary packages for all major distributions. For
-Windows, the PyQt installer already contains Qt, PyQt and the PyQt
-development tools.
+Windows, the PyQt installer contains Qt, PyQt and the PyQt development tools.
\subsection{Programming a simple PyQGIS Plugin in four steps}\label{subsec:pyfoursteps}
-The example plugin is intentionally kept simple. It adds a button to the menu
-bar of QGIS. If the button is clicked, a file dialog appears where the user
+The example plugin demonstrated here is intentionally kept simple. It adds a button to the menu
+bar of QGIS. When the button is clicked, a file dialog appears where the user
may load a shape file.
For each python plugin, a dedicated folder that contains the plugin files
@@ -77,7 +75,7 @@
\end{itemize}
-Once that's done, the plugin will show up in the
+Once that is done, the plugin will show up in the
\dropmenuopttwo{mActionShowPluginManager}{Plugin Manager...}
To provide the neccessary information for QGIS, the plugin needs to implement
@@ -89,7 +87,7 @@
plugin to access functions of the QGIS instance. We are going to work with
this object in step 2.
-Note that, in contrast to other programing languages, indention is very
+Note that in contrast to other programing languages, indention is very
important. The Python interpreter throws an error if it is not correct.
For our plugin we create the plugin folder 'foss4g\_plugin' in
@@ -143,7 +141,7 @@
return FOSS4GPlugin(iface)
\end{verbatim}
-At this point the plugin already the neccessary infrastructure to appear in
+At this point the plugin already has the neccessary infrastructure to appear in
the QGIS \dropmenuopttwo{mActionShowPluginManager}{Plugin Manager...} to be
loaded or unloaded.
@@ -151,16 +149,16 @@
To make the icon graphic available for our program, we need a so-called
resource file. In the resource file, the graphic is contained in hexadecimal
-notation. Fortunately, we don't need to care about its representation because
+notation. Fortunately, we don't need to worry about its representation because
we use the pyrcc compiler, a tool that reads the file
\filename{resources.qrc} and creates a resource file.
The file \filename{foss4g.png} and the \filename{resources.qrc} we use in
-this little workshop can be downloaded from
-\url{http://karlinapp.ethz.ch/python\_foss4g}. Move these 2 files into the
-directory of the example plugin
-\filename{\$HOME/.qgis/python/plugins/foss4g\_plugin} and enter there: pyrcc4 -o
-resources.py resources.qrc.
+this workshop can be downloaded from \url{http://karlinapp.ethz.ch/python\_foss4g}, you
+can also use your own icon if you prefer, you just need to make sure it is named
+\filename{foss4g.png}. Move these 2 files into the directory of the example plugin
+\filename{\$HOME/.qgis/python/plugins/foss4g\_plugin} and enter: \filename{pyrcc4 -o
+resources.py resources.qrc}.
\minisec{Step 3: Add a button and a menu}
@@ -212,34 +210,36 @@
\end{verbatim}
-\subsection{Committing the plugin to repository}
+\subsection{Uploading the plugin to the repository}
If you have written a plugin you consider to be useful and you want to share with
-other users you're welcome to upload it to the QGIS User-Contributed Repository.
+other users you are welcome to upload it to the QGIS User-Contributed Repository.
\begin{itemize}
-\item Prepare a plugin directory containing only necessary files (ensure that there
+\item Prepare a plugin directory containing only the necessary files (ensure that there
is no compiled .pyc files, Subversion .svn directories etc).
\item Make a zip archive of it, including the directory. Be sure the zip file
-name is exactly the same as the directory inside (except the .zip extension of course).
-In other case the Plugin Installer won't be able to relate the available plugin with its
+name is exactly the same as the directory inside (except the .zip extension of course), if not
+the Plugin Installer will be unable to relate the available plugin with its
locally installed instance.
\item Upload it to the repository: \url{http://pyqgis.org/admin/contributed} (you
will need to register at first time). Please pay attention when filling the form.
-Especially the Version Number field is often filled wrongly what confuses the Plugin
-Installer and causes false notifications of available updates.
+The Version Number field is especially important, and if filled out incorrectly it may confuse the Plugin Installer and cause false notifications of available updates.
\end{itemize}
-As you can see, you need information from different sources to write PyQGIS
-plugins. Plugin writers need to know Python and the QGIS plugin interface as
-well as the Qt4 classes and tools. At the beginning it is best to learn from
+As you can see, you need information from many different sources to a write PyQGIS
+plugin. Plugin authors need to know Python, the QGIS plugin interface, as well
+as the Qt4 classes and tools. In the beginning, it is best to learn from
examples and copy the mechanism of existing plugins. Using the QGIS plugin
-installer, which itself is a Python plugin, it is possible to download a lot
-of existing Python plugins and to study their behaviour.
+installer, which itself is a Python plugin, it is possible to download many
+existing Python plugins and to study their behaviour. It is also possible to use
+the on-line Python plugin generator to create a base plugin to work off of. This on-line
+tool will help you to build a minimal plugin that you can use as a starting point in your
+development. The result is a ready to install QGIS 1.0 plugin that implements an
+empty dialog with Ok and Close buttons. It is available here: \url{http://www.pyqgis.org/builder/plugin_builder.py}
-There is a a collection of online documentation that may be usefull for
-PyQGIS programers:
+There is a a collection of on-line documentation that may be useful for PyQGIS programmers:
\begin{itemize}
\item QGIS wiki: \url{http://wiki.qgis.org/qgiswiki/PythonBindings}
