[QGIS Commit] r10755 - in docs/trunk/english_us/coding-compilation_guide: . images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu May 7 18:49:37 EDT 2009
Author: cfarmer
Date: 2009-05-07 18:49:37 -0400 (Thu, 07 May 2009)
New Revision: 10755
Added:
   docs/trunk/english_us/coding-compilation_guide/images/python1_application.png
   docs/trunk/english_us/coding-compilation_guide/images/python2_application.png
   docs/trunk/english_us/coding-compilation_guide/creating_cpp_applications.tex
   docs/trunk/english_us/coding-compilation_guide/creating_pyqgis_applications.tex
   docs/trunk/english_us/coding-compilation_guide/images/Makefile
finish coding and compilation manual plugin sections
Modified: docs/trunk/english_us/coding-compilation_guide/creating_cpp_applications.tex
--- docs/trunk/english_us/coding-compilation_guide/creating_cpp_applications.tex	2009-05-07 17:36:49 UTC (rev 10754)
+++ docs/trunk/english_us/coding-compilation_guide/creating_cpp_applications.tex	2009-05-07 22:49:37 UTC (rev 10755)
@@ -3,22 +3,19 @@
 Not everyone wants a full blown GIS desktop application. Sometimes you want
 to just have a widget inside your application that displays a map while the
 main goal of the application lies elsewhere. Perhaps a database frontend with
-a map display? This Section provides two simple code examples by Tim Sutton.
-They are available in the qgis subversion repository together with more
-interesting tutorials. Check out the whole repository from:
-\filename{https://svn.osgeo.org/qgis/trunk/code\_examples/}
+a map display? This Section provides two simple code examples by Tim Sutton,
+based on earlier work by Francis Bolduc. They are available in the qgis
+subversion repository together with more interesting tutorials. Check out
+the whole repository from: \filename{https://svn.osgeo.org/qgis/trunk/code\_examples/}
 \subsection{Creating a simple mapping widget}\label{subsec:simple_widget}
-With this first tutorial we take a little walk through creating a simple mapping
-widget. It won't do anything much - just load a shape file and display it in
-a random colour.
-But it should give you an idea of the potential for using QGIS as an embedded
-mapping component. Before we carry on, many thanks to Francis Bolduc who wrote
-the beginnings of this demo. He kindly agreed to make his work generally
-available.
+With this tutorial we will create a simple mapping widget. It won't do
+anything much - just load a shape file and display it in a random colour.
+This should give you an idea of the potential for using QGIS as an embedded
+mapping component.
-We start with typical adding the neccessary includes for our app:
+We start by adding the neccessary includes for our app:
 \begin{verbatim}
@@ -38,9 +35,8 @@
 #include <QWidget>
 \end{verbatim}
-We use QgsApplication instead of Qt's QApplication, and get some added
-benifits of various static methods that can be used to locate library paths
-and so on.
+We use QgsApplication instead of Qt's QApplication, to take advantage of
+various static methods that can be used to locate library paths and so on.
 The provider registry is a singleton that keeps track of vector data provider
 plugins. It does all the work for you of loading the plugins and so on. The
@@ -53,8 +49,8 @@
 vector layer class inherits from maplayer and extends it to include
 specialist functionality for vector data.
-Finally the mapcanvas is really the nub of the matter. Its the drawable
-widget that our map will be drawn onto.
+Finally, the mapcanvas is our main map area. Its the drawable
+widget that our map will be dispalyed on.
 Now we can move on to initialising our application....
@@ -71,15 +67,15 @@
 \end{verbatim}
-So now we have a qgsapplication and we have defined some variables. Since I
-tested this on the Ubuntu 8.10, I just specified the location of the vector
-provider plugins as being inside the my development install directory. It
-would probaby make more sense in general to keep the QGIS libs in one of the
+We now have a qgsapplication and we have defined several variables. Since this
+tutorial was initially tested on Ubuntu Linux 8.10, we have specified the
+location of the vector provider plugins as being inside our development install
+directory. It would probaby make more sense in general to keep the QGIS libs in one of the
 standard library search paths on your system (e.g. /usr/lib) but this way
 will do for now.
-The next two variables defined here just point to the shapefile I am going to
-be using (and you should substitute your own data here).
+The next two variables defined here point to the shapefile that is going to
+be used (though you will likely want to substitute your own data here).
 The provider name is important - it tells qgis which data provider to use to
 load the file. Typically you will use 'ogr' or 'postgres'.
@@ -122,15 +118,12 @@
 \end{verbatim}
 The code is fairly self explanatory here. We create a layer using the
-variables
-we defined earlier. Then we assign the layer a renderer. When we create a
-renderer, we need to specify the geometry type, which do do by asking the
-vector layer for its geometry type. Next we add the layer to a layerset
-(which
-is used by the QgsMapCanvas to keep track of which layers to render and in
-what
-order) and to the maplayer registry. Finally we make sure the layer will be
-visible.
+variables we defined earlier. Then we assign the layer a renderer.
+When we create a renderer, we need to specify the geometry type, which
+we do by asking the vector layer for its geometry type. Next we add
+the layer to a layerset (which is used by the QgsMapCanvas to keep
+track of which layers to render and in what order) and to the maplayer
+registry. Finally we make sure the layer will be visible.
 Now we create a map canvas on to which we can draw the layer.
@@ -160,7 +153,7 @@
 \end{verbatim}
-In the last step we simply start the Qt event loop and we are all done. You
+In the last step we simply start the Qt event loop and we are done. You
 can check out, compile and run this example using cmake like this:
 \begin{verbatim}
@@ -189,17 +182,15 @@
 \subsection{Working with QgsMapCanvas}
-In Section~\ref{subsec:simple_widget} we showed you the usage of the
-QgsMapCanvas api to create a simple application that loads a shapefile and
+In the previous Section (Section~\ref{subsec:simple_widget}) we showed you how to use
+the QgsMapCanvas API to create a simple application that loads a shapefile and
 displays the points in it. But what good is a map that you can't interact
 with?
-In this second tutorial I will extend the last tutorial by making it a
+In this second tutorial we will extend the previous tutorial by making it a
 QMainWindow application with a menu, toolbar and canvas area. We show you how
-to use QgsMapTool - the base class for all tools that need to interact with
-the map canvas.
-The purpose is to provide a demonstrator project, so I wont promise to write the most
-elegant or robust C++ code. The project will provide 4 toolbar icons for
+to use QgsMapTool - the base class for all tools that are used to interact with
+the map canvas. The project will provide 4 toolbar icons for
 \begin{itemize}
  \item loading a map layer (layer name is hard coded in the application
@@ -215,12 +206,12 @@
 \textbf{Note:} You will need to edit the .pro file in the above svn directory to
 match your system.
-Since much of the code is the same as the previous tutorial, I will focus on
+Since much of the code is the same as the previous tutorial, we will focus on
 the MapTool specifics - the rest of the implementation details can be
 investigated by checking out the project form SVN. A QgsMapTool is a class that
 interacts with the MapCanvas using the mouse pointer. QGIS has a number of
 QgsMapTools implemented, and you can subclass QgsMapTool to create your own. In
-mainwindow.cpp you will see I include the headers for the QgsMapTools near the
+mainwindow.cpp you will see we have included the headers for the QgsMapTools near the
 start of the file:
 \begin{verbatim}
@@ -264,8 +255,7 @@
      mpMapToolBar->addAction(mpActionPan);
 \end{verbatim}
-Thats really pretty straightforward Qt stuff too. Now we create our three map
-tools:
+Now we create our three map tools:
 \begin{verbatim}
      //create the maptools
@@ -293,7 +283,7 @@
    \begin{center}
    \caption{QMainWindow application with a menu, toolbar and canvas area
 \osxcaption}\label{fig:cpp2_application}\smallskip
-   \includegraphics[clip=true, width=\textwidth]{cpp2_application}
+   \includegraphics[clip=true, width=12cm]{cpp2_application}
 \end{center}
 \end{figure}
Modified: docs/trunk/english_us/coding-compilation_guide/creating_pyqgis_applications.tex
--- docs/trunk/english_us/coding-compilation_guide/creating_pyqgis_applications.tex	2009-05-07 17:36:49 UTC (rev 10754)
+++ docs/trunk/english_us/coding-compilation_guide/creating_pyqgis_applications.tex	2009-05-07 22:49:37 UTC (rev 10755)
@@ -11,11 +11,11 @@
 realized with the refactoring of libraries that took place after the release
 of 0.8. Since the release of 0.9, development of standalone applications using
 either C++ or Python is possible. We recommend you use QGIS 1.0.0 or greater
-as the basis for your pythong applications because since this version we now
+as the basis for your python applications because since this version we now
 provide a stable consistent API.
-In this chapter we'll take a brief look at the process for creating a
-standalone Python application. The QGIS blog has several examples of creating
+In this chapter we'll take a brief look at the process of creating a
+standalone Python application. The QGIS blog has several examples for creating
 PyQGIS\footnote{An application created using Python and the QGIS bindings}
 applications. We'll use one of them as a starting point to get a look at how
 to create an application.
@@ -354,25 +354,18 @@
 When the application starts up, it looks like this:
-%\begin{figure}[ht]
-%\begin{center}
-%  \caption{Starting the new demo application}\label{fig:demo_app_startup}%\smallskip
-%  \includegraphics[scale=0.8]{getdsn}
-%\end{center}
-%\end{figure}
+\begin{figure}[ht]
+\begin{center}
+  \caption{Starting the new demo application \nixcaption} \label{fig:demo_app_startup}
+  \includegraphics[clip=true, width=12cm]{python1_application}
+\end{center}
+\end{figure}
 To add the \filename{world\_borders} layer, click on the
 \usertext{Add Layer} tool and navigate to the data directory.
 Select the shapefile and click \button{Open} to add it to the map.
-Our custom fill color is applied and the result is:
+Our custom fill color is applied and the result is shown in Figure \ref{fig:demo_app_done}.
-%\begin{center}
-%  \caption{Adding a layer the demo application}\label{fig:demo_app_done}%\smallskip
-%\end{center}
-%\end{figure}
 Creating a PyQGIS application is really pretty simple.  In less than 150 lines
 of code we have an application that can load a shapefile and navigate the map.
 If you play around with the map, you'll notice that some of the built-in
@@ -383,3 +376,10 @@
 the works. This is pretty impressive, considering that this development has
 taken place even before the official release of QGIS 1.0.
+\begin{figure}[ht]
+\begin{center}
+  \caption{Adding a layer the demo application \nixcaption} \label{fig:demo_app_done}
+  \includegraphics[clip=true, width=12cm]{python2_application}
+\end{center}
+\end{figure}
Modified: docs/trunk/english_us/coding-compilation_guide/images/Makefile
--- docs/trunk/english_us/coding-compilation_guide/images/Makefile	2009-05-07 17:36:49 UTC (rev 10754)
+++ docs/trunk/english_us/coding-compilation_guide/images/Makefile	2009-05-07 22:49:37 UTC (rev 10755)
@@ -13,8 +13,9 @@
 PNG=cpp1_application.eps\
     cpp2_application.eps\
     mActionShowPluginManager.eps\
+    python1_application.eps\
+    python2_application.eps\
 JPG=qgis_icon_new_verylarge.eps\
Added: docs/trunk/english_us/coding-compilation_guide/images/python1_application.png
(Binary files differ)
Property changes on: docs/trunk/english_us/coding-compilation_guide/images/python1_application.png
___________________________________________________________________
   + application/octet-stream
Added: docs/trunk/english_us/coding-compilation_guide/images/python2_application.png
Property changes on: docs/trunk/english_us/coding-compilation_guide/images/python2_application.png
More information about the QGIS-commit mailing list
