[QGIS Commit] r11974 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 7 14:20:13 EST 2009
Author: timlinux
Date: 2009-11-07 14:20:13 -0500 (Sat, 07 Nov 2009)
New Revision: 11974
   trunk/qgis/src/ui/qgscomposerbase.ui
   trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui
   trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui
   trunk/qgis/src/ui/qgscompositionbase.ui
   trunk/qgis/src/ui/qgscompositionwidgetbase.ui
Further ui cleanups for map composer
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui	2009-11-07 19:16:42 UTC (rev 11973)
+++ trunk/qgis/src/ui/qgscomposerbase.ui	2009-11-07 19:20:13 UTC (rev 11974)
@@ -60,7 +60,7 @@
         </size>
        </property>
        <property name="currentIndex">
-        <number>1</number>
+        <number>0</number>
        </property>
        <widget class="QWidget" name="tab">
         <attribute name="title">
@@ -445,9 +445,9 @@
   </action>
  </widget>
  <tabstops>
+  <tabstop>buttonBox</tabstop>
+  <tabstop>mCompositionNameComboBox</tabstop>
   <tabstop>mOptionsTabWidget</tabstop>
-  <tabstop>mCompositionNameComboBox</tabstop>
-  <tabstop>mSplitter</tabstop>
  </tabstops>
  <resources/>
  <connections>
Modified: trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui	2009-11-07 19:16:42 UTC (rev 11973)
+++ trunk/qgis/src/ui/qgscomposeritemwidgetbase.ui	2009-11-07 19:20:13 UTC (rev 11974)
@@ -28,6 +28,9 @@
         <property name="text">
          <string>Color</string>
         </property>
+        <property name="wordWrap">
+         <bool>true</bool>
+        </property>
         <property name="buddy">
          <cstring>mFrameColorButton</cstring>
         </property>
@@ -52,6 +55,9 @@
          <string>Opacity</string>
         </property>
+         <bool>true</bool>
+        </property>
          <cstring>mOpacitySlider</cstring>
         </property>
@@ -72,6 +78,9 @@
          <string>Outline width</string>
         </property>
+         <bool>true</bool>
+        </property>
          <cstring>mOutlineWidthSpinBox</cstring>
         </property>
@@ -94,6 +103,19 @@
         </property>
        </widget>
       </item>
+      <item row="9" column="0">
+       <spacer name="verticalSpacer">
+        <property name="orientation">
+         <enum>Qt::Vertical</enum>
+        </property>
+        <property name="sizeHint" stdset="0">
+         <size>
+          <width>20</width>
+          <height>40</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
      </layout>
     </widget>
    </item>
Modified: trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui	2009-11-07 19:16:42 UTC (rev 11973)
+++ trunk/qgis/src/ui/qgscomposerlabelwidgetbase.ui	2009-11-07 19:20:13 UTC (rev 11974)
@@ -1,60 +1,64 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsComposerLabelWidgetBase</class>
- <widget class="QWidget" name="QgsComposerLabelWidgetBase" >
-  <property name="geometry" >
+ <widget class="QWidget" name="QgsComposerLabelWidgetBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
     <width>217</width>
-    <height>274</height>
+    <height>302</height>
    </rect>
   </property>
-  <property name="sizePolicy" >
-   <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+  <property name="sizePolicy">
+   <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
     <horstretch>0</horstretch>
     <verstretch>0</verstretch>
    </sizepolicy>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Label Options</string>
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" colspan="2" >
-    <widget class="QTextEdit" name="mTextEdit" >
-     <property name="lineWrapMode" >
+  <layout class="QGridLayout" name="gridLayout">
+   <property name="margin">
+   </property>
+   <item row="0" column="0">
+    <widget class="QTextEdit" name="mTextEdit">
+     <property name="lineWrapMode">
       <enum>QTextEdit::NoWrap</enum>
      </property>
     </widget>
    </item>
-   <item row="1" column="0" colspan="2" >
-    <widget class="QPushButton" name="mFontButton" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
+   <item row="1" column="0">
+    <widget class="QPushButton" name="mFontButton">
+      <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
       </sizepolicy>
      </property>
-     <property name="text" >
+     <property name="text">
       <string>Font</string>
      </property>
     </widget>
    </item>
-   <item row="2" column="0" >
-    <widget class="QLabel" name="mMarginTextLabel" >
+   <item row="2" column="0">
+    <widget class="QLabel" name="mMarginTextLabel">
       <string>Margin (mm)</string>
      </property>
-     <property name="buddy" >
+     <property name="buddy">
       <cstring>mMarginDoubleSpinBox</cstring>
      </property>
     </widget>
    </item>
-   <item row="2" column="1" >
-    <widget class="QDoubleSpinBox" name="mMarginDoubleSpinBox" />
+   <item row="3" column="0">
+    <widget class="QDoubleSpinBox" name="mMarginDoubleSpinBox"/>
    </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
  <tabstops>
   <tabstop>mTextEdit</tabstop>
   <tabstop>mFontButton</tabstop>
Modified: trunk/qgis/src/ui/qgscompositionbase.ui
--- trunk/qgis/src/ui/qgscompositionbase.ui	2009-11-07 19:16:42 UTC (rev 11973)
+++ trunk/qgis/src/ui/qgscompositionbase.ui	2009-11-07 19:20:13 UTC (rev 11974)
@@ -1,213 +1,199 @@
+<ui version="4.0">
  <class>QgsCompositionBase</class>
- <widget class="QWidget" name="QgsCompositionBase" >
+ <widget class="QWidget" name="QgsCompositionBase">
    <rect>
     <x>0</x>
     <y>0</y>
     <width>243</width>
-    <height>422</height>
+    <height>354</height>
    </rect>
   </property>
    </sizepolicy>
   </property>
    <string>Composition</string>
   </property>
-   <property name="leftMargin" >
-    <number>9</number>
+  <layout class="QGridLayout">
    </property>
-   <property name="topMargin" >
-   </property>
-   <property name="rightMargin" >
-   </property>
-   <property name="bottomMargin" >
-   </property>
-   <property name="horizontalSpacing" >
+   <property name="spacing">
     <number>6</number>
    </property>
-   <property name="verticalSpacing" >
-    <number>6</number>
-   </property>
-    <widget class="QGroupBox" name="groupBox" >
-     <property name="title" >
+   <item row="0" column="0" colspan="2">
+    <widget class="QGroupBox" name="groupBox">
+     <property name="title">
       <string>Paper</string>
      </property>
       </property>
-      </property>
-      </property>
-      </property>
-      </property>
-      </property>
-      <item row="4" column="1" >
-       <widget class="QComboBox" name="mPaperOrientationComboBox" >
-        <property name="enabled" >
-         <bool>true</bool>
-        </property>
-         <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+       <widget class="QLabel" name="textLabel3">
+         <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
          </sizepolicy>
         </property>
-       </widget>
-      </item>
-      <item row="3" column="1" >
-       <widget class="QLineEdit" name="mPaperHeightLineEdit" />
-      </item>
-       <widget class="QLineEdit" name="mPaperWidthLineEdit" />
-      </item>
-      <item row="1" column="1" >
-       <widget class="QComboBox" name="mPaperUnitsComboBox" >
-         <bool>false</bool>
+         <string>Size</string>
         </property>
-          <horstretch>0</horstretch>
-          <verstretch>0</verstretch>
-         </sizepolicy>
+         <bool>true</bool>
         </property>
+         <cstring>mPaperSizeComboBox</cstring>
+        </property>
        </widget>
       </item>
-      <item row="0" column="1" >
-       <widget class="QComboBox" name="mPaperSizeComboBox" >
+      <item row="1" column="0" colspan="2">
+       <widget class="QComboBox" name="mPaperSizeComboBox">
+        <property name="enabled">
          <bool>true</bool>
         </property>
+         <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
          </sizepolicy>
         </property>
        </widget>
       </item>
-      <item row="4" column="0" >
-       <widget class="QLabel" name="textLabel7" >
-         <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
+       <widget class="QLabel" name="textLabel5">
          </sizepolicy>
         </property>
-         <string>Orientation</string>
+         <string>Units</string>
         </property>
-         <cstring>mPaperOrientationComboBox</cstring>
+         <bool>true</bool>
         </property>
+         <cstring>mPaperUnitsComboBox</cstring>
+        </property>
        </widget>
       </item>
-      <item row="3" column="0" >
-       <widget class="QLabel" name="textLabel6" >
+      <item row="3" column="0" colspan="2">
+       <widget class="QComboBox" name="mPaperUnitsComboBox">
+         <bool>false</bool>
+        </property>
          </sizepolicy>
         </property>
-         <string>Height</string>
-        </property>
-         <cstring>mPaperHeightLineEdit</cstring>
-        </property>
        </widget>
       </item>
-       <widget class="QLabel" name="textLabel4" >
+      <item row="4" column="0">
+       <widget class="QLabel" name="textLabel4">
          </sizepolicy>
         </property>
          <string>Width</string>
         </property>
+         <bool>true</bool>
+        </property>
          <cstring>mPaperWidthLineEdit</cstring>
         </property>
        </widget>
       </item>
-      <item row="1" column="0" >
-       <widget class="QLabel" name="textLabel5" >
+      <item row="5" column="0" colspan="2">
+       <widget class="QLineEdit" name="mPaperWidthLineEdit"/>
+      </item>
+      <item row="6" column="0" colspan="2">
+       <widget class="QLabel" name="textLabel6">
          </sizepolicy>
         </property>
-         <string>Units</string>
+         <string>Height</string>
         </property>
-         <cstring>mPaperUnitsComboBox</cstring>
+         <bool>true</bool>
         </property>
+         <cstring>mPaperHeightLineEdit</cstring>
+        </property>
        </widget>
       </item>
-      <item row="0" column="0" >
-       <widget class="QLabel" name="textLabel3" >
+      <item row="7" column="0" colspan="2">
+       <widget class="QLineEdit" name="mPaperHeightLineEdit"/>
+      </item>
+      <item row="8" column="0" colspan="2">
+       <widget class="QLabel" name="textLabel7">
          </sizepolicy>
         </property>
-         <string>Size</string>
+         <string>Orientation</string>
         </property>
-         <cstring>mPaperSizeComboBox</cstring>
+         <bool>true</bool>
         </property>
+         <cstring>mPaperOrientationComboBox</cstring>
+        </property>
        </widget>
       </item>
+      <item row="9" column="0" colspan="2">
+       <widget class="QComboBox" name="mPaperOrientationComboBox">
+         <bool>true</bool>
+        </property>
+          <horstretch>0</horstretch>
+          <verstretch>0</verstretch>
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
+      <item row="10" column="1">
+        </property>
+         <size>
+          <width>20</width>
+          <height>50</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
      </layout>
     </widget>
    </item>
-   <item rowspan="2" row="1" column="0" colspan="2" >
-    <spacer>
-     <property name="orientation" >
-      <enum>Qt::Vertical</enum>
-     </property>
-     <property name="sizeType" >
-      <enum>QSizePolicy::Expanding</enum>
-     </property>
-     <property name="sizeHint" >
-      <size>
-       <width>223</width>
-       <height>41</height>
-      </size>
-     </property>
-    </spacer>
-   </item>
   </layout>
  </widget>
  <resources/>
  <connections/>
 </ui>
Modified: trunk/qgis/src/ui/qgscompositionwidgetbase.ui
--- trunk/qgis/src/ui/qgscompositionwidgetbase.ui	2009-11-07 19:16:42 UTC (rev 11973)
+++ trunk/qgis/src/ui/qgscompositionwidgetbase.ui	2009-11-07 19:20:13 UTC (rev 11974)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>284</width>
-    <height>530</height>
+    <width>514</width>
+    <height>535</height>
    </rect>
   </property>
@@ -19,277 +19,323 @@
   </property>
-  <layout class="QGridLayout">
-   <item row="0" column="0" colspan="2">
-    <widget class="QGroupBox" name="groupBox">
-     <property name="maximumSize">
-      <size>
-       <width>999</width>
-       <height>300</height>
-      </size>
+  <layout class="QGridLayout" name="gridLayout_4">
+   </property>
+    <widget class="QScrollArea" name="scrollArea">
+     <property name="widgetResizable">
+      <bool>true</bool>
      </property>
-     <property name="title">
-      <string>Paper</string>
-     </property>
-      <property name="margin">
+     <widget class="QWidget" name="scrollAreaWidgetContents">
+       <rect>
+        <x>0</x>
+        <y>-290</y>
+        <width>491</width>
+        <height>823</height>
+       </rect>
       </property>
-      <property name="spacing">
-      </property>
-      <item row="4" column="1">
-       <widget class="QComboBox" name="mPaperOrientationComboBox">
-        <property name="enabled">
-         <bool>true</bool>
-        </property>
-        <property name="sizePolicy">
-         <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
-      <item row="3" column="1">
-       <widget class="QLineEdit" name="mPaperHeightLineEdit"/>
-      </item>
-      <item row="2" column="1">
-       <widget class="QLineEdit" name="mPaperWidthLineEdit"/>
-      </item>
-      <item row="1" column="1">
-       <widget class="QComboBox" name="mPaperUnitsComboBox">
-        </property>
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
-      <item row="0" column="1">
-       <widget class="QComboBox" name="mPaperSizeComboBox">
-         <bool>true</bool>
-        </property>
-         </sizepolicy>
-        </property>
-       </widget>
-      </item>
-      <item row="4" column="0">
-       <widget class="QLabel" name="textLabel7">
-         <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
-         </sizepolicy>
-        </property>
-        <property name="text">
-        </property>
-        <property name="buddy">
-        </property>
-       </widget>
-      </item>
-      <item row="3" column="0">
-       <widget class="QLabel" name="textLabel6">
-         </sizepolicy>
-        </property>
-        </property>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="0">
-       <widget class="QLabel" name="textLabel4">
-         </sizepolicy>
-        </property>
-         <string>Width</string>
-        </property>
-         <cstring>mPaperWidthLineEdit</cstring>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="0">
-       <widget class="QLabel" name="textLabel5">
-         </sizepolicy>
-        </property>
-        </property>
-        </property>
-       </widget>
-      </item>
-      <item row="0" column="0">
-       <widget class="QLabel" name="textLabel3">
-         </sizepolicy>
-        </property>
-        </property>
-        </property>
-       </widget>
-      </item>
-     </layout>
+      <layout class="QGridLayout" name="gridLayout_3">
+          <string>Paper and quality</string>
+         </property>
+             </sizepolicy>
+            </property>
+            </property>
+             <bool>true</bool>
+            </property>
+            </property>
+           </widget>
+          </item>
+             <bool>true</bool>
+            </property>
+             </sizepolicy>
+            </property>
+           </widget>
+          </item>
+             </sizepolicy>
+            </property>
+            </property>
+             <bool>true</bool>
+            </property>
+            </property>
+           </widget>
+          </item>
+            </property>
+             </sizepolicy>
+            </property>
+           </widget>
+          </item>
+             </sizepolicy>
+            </property>
+             <string>Width</string>
+            </property>
+             <bool>true</bool>
+            </property>
+             <cstring>mPaperWidthLineEdit</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="5" column="0">
+          </item>
+          <item row="6" column="0">
+             </sizepolicy>
+            </property>
+            </property>
+             <bool>true</bool>
+            </property>
+            </property>
+           </widget>
+          </item>
+          <item row="7" column="0">
+          </item>
+          <item row="8" column="0">
+             </sizepolicy>
+            </property>
+            </property>
+             <bool>true</bool>
+            </property>
+            </property>
+           </widget>
+          </item>
+             <bool>true</bool>
+            </property>
+             </sizepolicy>
+            </property>
+           </widget>
+          </item>
+          <item row="10" column="0">
+           <widget class="QLabel" name="mResolutionLabel">
+             </sizepolicy>
+            </property>
+             <string>Print quality (dpi)</string>
+            </property>
+             <bool>true</bool>
+            </property>
+             <cstring>mResolutionLineEdit</cstring>
+            </property>
+           </widget>
+          </item>
+          <item row="11" column="0">
+           <widget class="QLineEdit" name="mResolutionLineEdit"/>
+          </item>
+          <item row="12" column="0">
+           <widget class="QCheckBox" name="mPrintAsRasterCheckBox">
+             <string>Print as raster</string>
+            </property>
+           </widget>
+          </item>
+         </layout>
+        </widget>
+       </item>
+        <widget class="QGroupBox" name="mSnapGroupBox">
+          <string>Snapping</string>
+         </property>
+         <layout class="QGridLayout" name="gridLayout_2">
+           <widget class="QCheckBox" name="mSnapToGridCheckBox">
+             <string>Snap to grid</string>
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="mResolutionLabel_2">
+             </sizepolicy>
+            </property>
+             <string>Grid resolution</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+           <widget class="QDoubleSpinBox" name="mResolutionSpinBox"/>
+          </item>
+           <widget class="QLabel" name="mXOffsetLabel">
+             </sizepolicy>
+            </property>
+             <string>Offset x</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+           <widget class="QDoubleSpinBox" name="mOffsetXSpinBox"/>
+          </item>
+           <widget class="QLabel" name="mYOffsetLabel">
+             <string>Offset y</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+           <widget class="QDoubleSpinBox" name="mOffsetYSpinBox"/>
+          </item>
+           <widget class="QLabel" name="mPenWidthLabel">
+             <string>Pen width</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+           <widget class="QDoubleSpinBox" name="mPenWidthSpinBox"/>
+          </item>
+           <widget class="QLabel" name="mGridColorLabel">
+             <string>Grid color</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+           <widget class="QgsColorButton" name="mGridColorButton">
+             </sizepolicy>
+            </property>
+             <string/>
+            </property>
+           </widget>
+          </item>
+           <widget class="QLabel" name="mGridStyleLabel">
+             <string>Grid style</string>
+            </property>
+             <bool>true</bool>
+            </property>
+           </widget>
+          </item>
+           <widget class="QComboBox" name="mGridStyleComboBox"/>
+          </item>
+         </layout>
+        </widget>
+       </item>
+      </layout>
+     </widget>
     </widget>
    </item>
-   <item row="1" column="0" colspan="2">
-    <widget class="QGroupBox" name="mSnapGroupBox">
-      <string>Snapping</string>
-     </property>
-       <widget class="QCheckBox" name="mSnapToGridCheckBox">
-         <string>Snap to grid</string>
-        </property>
-       </widget>
-      </item>
-       <widget class="QLabel" name="mResolutionLabel_2">
-         </sizepolicy>
-        </property>
-         <string>Grid resolution</string>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="2">
-       <widget class="QDoubleSpinBox" name="mResolutionSpinBox"/>
-      </item>
-      <item row="2" column="0" colspan="2">
-       <widget class="QLabel" name="mXOffsetLabel">
-         </sizepolicy>
-        </property>
-         <string>Offset x</string>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="2">
-       <widget class="QDoubleSpinBox" name="mOffsetXSpinBox"/>
-      </item>
-      <item row="3" column="0" colspan="2">
-       <widget class="QLabel" name="mYOffsetLabel">
-         <string>Offset y</string>
-        </property>
-       </widget>
-      </item>
-      <item row="3" column="2">
-       <widget class="QDoubleSpinBox" name="mOffsetYSpinBox"/>
-      </item>
-       <widget class="QLabel" name="mPenWidthLabel">
-         <string>Pen width</string>
-        </property>
-       </widget>
-      </item>
-      <item row="4" column="2">
-       <widget class="QDoubleSpinBox" name="mPenWidthSpinBox"/>
-      </item>
-      <item row="5" column="0">
-       <widget class="QLabel" name="mGridColorLabel">
-         <string>Grid color</string>
-        </property>
-       </widget>
-      </item>
-      <item row="5" column="2">
-       <widget class="QgsColorButton" name="mGridColorButton">
-         </sizepolicy>
-        </property>
-         <string/>
-        </property>
-       </widget>
-      </item>
-      <item row="6" column="0">
-       <widget class="QLabel" name="mGridStyleLabel">
-         <string>Grid style</string>
-        </property>
-       </widget>
-      </item>
-      <item row="6" column="1" colspan="2">
-       <widget class="QComboBox" name="mGridStyleComboBox"/>
-      </item>
-     </layout>
-    </widget>
-   </item>
-    <widget class="QLabel" name="mResolutionLabel">
-      <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
-      </sizepolicy>
-     </property>
-      <string>Print quality (dpi)</string>
-     </property>
-      <cstring>mResolutionLineEdit</cstring>
-     </property>
-    </widget>
-   </item>
-    <widget class="QLineEdit" name="mResolutionLineEdit"/>
-   </item>
-    <widget class="QCheckBox" name="mPrintAsRasterCheckBox">
-      <string>Print as raster</string>
-     </property>
-    </widget>
-   </item>
   </layout>
  </widget>
@@ -300,6 +346,23 @@
    <header>qgscolorbutton.h</header>
   </customwidget>
  </customwidgets>
+ <tabstops>
+  <tabstop>scrollArea</tabstop>
+  <tabstop>mPaperSizeComboBox</tabstop>
+  <tabstop>mPaperUnitsComboBox</tabstop>
+  <tabstop>mPaperWidthLineEdit</tabstop>
+  <tabstop>mPaperHeightLineEdit</tabstop>
+  <tabstop>mPaperOrientationComboBox</tabstop>
+  <tabstop>mResolutionLineEdit</tabstop>
+  <tabstop>mPrintAsRasterCheckBox</tabstop>
+  <tabstop>mSnapToGridCheckBox</tabstop>
+  <tabstop>mResolutionSpinBox</tabstop>
+  <tabstop>mOffsetXSpinBox</tabstop>
+  <tabstop>mOffsetYSpinBox</tabstop>
+  <tabstop>mPenWidthSpinBox</tabstop>
+  <tabstop>mGridColorButton</tabstop>
+  <tabstop>mGridStyleComboBox</tabstop>
+ </tabstops>
  <resources/>
  <connections/>
 </ui>
More information about the QGIS-commit mailing list
