[QGIS Commit] r12272 - in docs/trunk/english_us/user_guide: . features_at_a_glance_screenies getting_started_screenies plugins_openstreetmap_images working_with_vector_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 28 10:26:56 EST 2009
Author: dassau
Date: 2009-11-28 10:26:56 -0500 (Sat, 28 Nov 2009)
New Revision: 12272
Added:
   docs/trunk/english_us/user_guide/plugins_openstreetmap_images/osm_icon.png
   docs/trunk/english_us/user_guide/core_plugins.tex
   docs/trunk/english_us/user_guide/features_at_a_glance.tex
   docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
   docs/trunk/english_us/user_guide/getting_started.tex
   docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
   docs/trunk/english_us/user_guide/plugins_decorations.tex
   docs/trunk/english_us/user_guide/plugins_evis.tex
   docs/trunk/english_us/user_guide/plugins_interpolation.tex
   docs/trunk/english_us/user_guide/plugins_ogr_converter.tex
   docs/trunk/english_us/user_guide/plugins_openstreetmap_images/Makefile
   docs/trunk/english_us/user_guide/plugins_openstreetmap_images/osm_createLine.png
   docs/trunk/english_us/user_guide/working_with_ogc.tex
   docs/trunk/english_us/user_guide/working_with_vector.tex
   docs/trunk/english_us/user_guide/working_with_vector_screenies/shapefileloaded.png
final revision before release of the 1.3 manual
Modified: docs/trunk/english_us/user_guide/core_plugins.tex
--- docs/trunk/english_us/user_guide/core_plugins.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/core_plugins.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -6,9 +6,8 @@
 % comment out the following line:
 %\updatedisclaimer
-QGIS currently contains 19 core plugins that can be loaded using the Plugin Manager.
-Table \ref{tab:core_plugins} lists each of the core plugins along with a
-description of their purpose and the toolbar-icon.
+QGIS \CURRENT contains 22 core plugins that can be loaded using the Plugin
+Manager (see Table \ref{tab:core_plugins}).
 % minipage is needed to appear the footnote under the table
 % SH
@@ -35,6 +34,9 @@
 \includegraphics[width=0.6cm]{dxf2shp_converter}
  & DXF2Shape Converter \index{plugins!DXF2Shape}& Converts from DXF to SHP file format\\
 \hline
+\includegraphics[width=0.6cm]{evis_icon}
+ & eVis & Event Visualization Tool \\
+\hline
 \includegraphics[width=0.6cm, height=0.6cm]{ftoolslogo}
  & fTools \index{plugins!ftools}& A suite of analysis, geometry, geoprocessing, and research tools\\
 \hline
@@ -64,6 +66,9 @@
  & OGR Layer Converter \index{plugins!OGR converter} & Translate vector
 layers between OGR suported formats\\
 \hline
+\includegraphics[width=0.6cm]{osm_icon}
+ & OpenStreetMap & Visualize and edit OpenStreetMap data \\
+\hline
 \includegraphics[width=0.6cm]{oracle_raster}
  & Oracle Georaster \index{plugins!georaster}& Access Oracle Spatial GeoRasters\\
 \hline
@@ -83,15 +88,8 @@
 \includegraphics[width=0.6cm]{mIconAddWfsLayer}
  & WFS & Load and display WFS layer \\
 \hline
-\includegraphics[width=0.6cm]{evis_icon}
- & eVis & Event Visualization Tool \\
-\hline
 \end{tabular}
 \end{table}
 \end{minipage}
 \normalsize
-\begin{Tip}\caption{\textsc{Plugins Settings Saved to Project}}\index{plugins settings}
-\qgistip{When you save a .qgs project, any changes you have made to NorthArrow, ScaleBar and Copyright plugins will be saved in the project and restored next time you load the project.}
-\end{Tip}
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -113,7 +113,7 @@
 \begin{figure}[ht]
    \begin{center}
-   \caption{QGIS GUI with Alaska sample data \nixcaption (GNOME))}
+   \caption{QGIS GUI with Alaska sample data \nixcaption (KDE)}
 	 \label{fig:startup}
    \includegraphics[clip=true, width=17cm]{startup}
 \end{center}
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/getting_started.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -100,6 +100,13 @@
 \item \osx{Double click the icon in your Applications folder.}
 \end{itemize}
+\begin{figure}[ht]
+   \begin{center}
+   \caption{A Simple QGIS Session \nixcaption}\label{fig:simple_session}\smallskip
+   \includegraphics[clip=true, width=12cm]{simple_session}
+\end{center}
+\end{figure}
 \minisec{Load raster and vector layers from the sample dataset}
 \begin{enumerate}
@@ -129,13 +136,6 @@
 click \button{OK}.
 \end{enumerate}
-\begin{figure}[ht]
-   \begin{center}
-   \caption{A Simple QGIS Session \nixcaption}\label{fig:simple_session}\smallskip
-   \includegraphics[clip=true, width=12cm]{simple_session}
-\end{center}
-\end{figure}
 You can see how easy it is to visualize raster and vector layers in
 QGIS. Let's move on to the sections that follow to learn more about the
 available functionality, features and settings and how to use them.
Modified: docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
Modified: docs/trunk/english_us/user_guide/plugins_decorations.tex
--- docs/trunk/english_us/user_guide/plugins_decorations.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/plugins_decorations.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -79,3 +79,8 @@
    \includegraphics[clip=true, width=8cm]{scale_bar_dialog}
 \end{center}
 \end{figure}
+\begin{Tip}\caption{\textsc{Plugins Settings Saved to Project}}\index{plugins settings}
+\qgistip{When you save a .qgs project, any changes you have made to NorthArrow, ScaleBar and Copyright plugins will be saved in the project and restored nexttime you load the project.}
+\end{Tip}
Modified: docs/trunk/english_us/user_guide/plugins_evis.tex
--- docs/trunk/english_us/user_guide/plugins_evis.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/plugins_evis.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -354,7 +354,7 @@
 \begin{figure}[htp]
    \begin{center}
 \caption{\label{evispredefined}The \emph{eVis} Perdefined queries tab \nixcaption}
-\includegraphics[clip=true, width=12cm]{evispredefined}
+\includegraphics[clip=true, width=10cm]{evispredefined}
 \end{center}
 \end{figure}
@@ -451,4 +451,4 @@
    <autoconnect>false</autoconnect>
  </query>
 </doc>
-\end{verbatim}
\ No newline at end of file
+\end{verbatim}
Modified: docs/trunk/english_us/user_guide/plugins_interpolation.tex
--- docs/trunk/english_us/user_guide/plugins_interpolation.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/plugins_interpolation.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -58,7 +58,7 @@
 \begin{figure}[ht]
    \begin{center}
    \caption{Interpolation of elevp data using IDW method \nixcaption}\label{fig:interpolation_idw}\smallskip
-   \includegraphics[clip=true, width=12cm]{interpolate_idw}
+   \includegraphics[clip=true, width=10cm]{interpolate_idw}
 \end{center}
 \end{figure}
Modified: docs/trunk/english_us/user_guide/plugins_ogr_converter.tex
--- docs/trunk/english_us/user_guide/plugins_ogr_converter.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/plugins_ogr_converter.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -20,7 +20,7 @@
 \begin{figure}[ht]
    \begin{center}
    \caption{OGR Layer Converter Plugin \nixcaption}\label{fig:ogr_converter_dialog}\smallskip
-   \includegraphics[clip=true, width=9cm]{ogr_converter_dialog}
+   \includegraphics[clip=true, width=7.5cm]{ogr_converter_dialog}
 \end{center}
 \end{figure}
@@ -29,7 +29,7 @@
 \begin{enumerate}
   \item Start QGIS, load the OGR converter plugin in the Plugin Manager (see Section
   \ref{sec:load_core_plugin}) and click on the \toolbtntwo{ogr_converter}{OGR Layer Converter}
-  icon which appears in the QGIS toolbar menu. The OGR Layer Converter plugin dialog appears as shown in Figure \ref{fig:ogrconverter_dialog}.
+  icon which appears in the QGIS toolbar menu. The OGR Layer Converter plugin dialog appears as shown in Figure \ref{fig:ogr_converter_dialog}.
   \item Select the OGR-supported format (e.g., \selectstring{ESRI Shapefile}{\ldots}) and the path to the vector input file (e.g., \filename{alaska.shp}) in the Source area.
   \item Select the OGR-supported format (e.g., \selectstring{GML}{\ldots}) and define a path and the vector output filename (e.g., \filename{alaska.gml}) in the Target area.
   \item Click \button{Ok}.
Modified: docs/trunk/english_us/user_guide/plugins_openstreetmap_images/Makefile
--- docs/trunk/english_us/user_guide/plugins_openstreetmap_images/Makefile	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/plugins_openstreetmap_images/Makefile	2009-11-28 15:26:56 UTC (rev 12272)
@@ -48,6 +48,7 @@
 	osm_savedialog.eps\
 	osm_importtoosmdialog.eps\
 	osm_importdialog.eps\
+	osm_icon.eps\
 ##### TARGETS #####
Modified: docs/trunk/english_us/user_guide/plugins_openstreetmap_images/osm_createLine.png
Added: docs/trunk/english_us/user_guide/plugins_openstreetmap_images/osm_icon.png
Property changes on: docs/trunk/english_us/user_guide/plugins_openstreetmap_images/osm_icon.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -476,7 +476,7 @@
 \begin{figure}[ht]
   \begin{center}
   	\caption{Adding a WFS layer \nixcaption}\label{fig:wfs_dmsolutions}
-	\includegraphics[clip=true,width=0.6\textwidth]{connection_wfs}
+	\includegraphics[clip=true,width=0.45\textwidth]{connection_wfs}
   \end{center}
 \end{figure}
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2009-11-27 16:40:01 UTC (rev 12271)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2009-11-28 15:26:56 UTC (rev 12272)
@@ -463,7 +463,7 @@
 \begin{figure}[ht]
    \begin{center}
    \caption{Map crossing the \degrees{180} longitude line
-after applying the \textbf{ST\textunderscore Shift\textunderscore Longitude}
+after applying the ST\textunderscore Shift\textunderscore Longitude
 function}
 \label{fig:vector_wrapping}\smallskip
    \includegraphics[clip=true, width=9cm]{vectorWrapping}
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/shapefileloaded.png
More information about the QGIS-commit mailing list
