[QGIS Commit] r12273 - in trunk/qgis: cmake python src/analysis src/app src/core src/gui src/plugins/diagram_overlay src/plugins/dxf2shp_converter src/plugins/evis src/plugins/grass src/plugins/ogr_converter src/plugins/spit src/providers/delimitedtext src/providers/gpx src/providers/grass src/providers/memory src/providers/ogr src/providers/osm src/providers/postgres src/providers/spatialite src/providers/wfs src/providers/wms src/python
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Nov 28 11:02:16 EST 2009
Author: jef
Date: 2009-11-28 11:02:15 -0500 (Sat, 28 Nov 2009)
New Revision: 12273
   trunk/qgis/cmake/FindGRASS.cmake
   trunk/qgis/python/configure.py.in
   trunk/qgis/src/analysis/CMakeLists.txt
   trunk/qgis/src/app/CMakeLists.txt
   trunk/qgis/src/core/CMakeLists.txt
   trunk/qgis/src/gui/CMakeLists.txt
   trunk/qgis/src/plugins/diagram_overlay/CMakeLists.txt
   trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt
   trunk/qgis/src/plugins/evis/CMakeLists.txt
   trunk/qgis/src/plugins/grass/CMakeLists.txt
   trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt
   trunk/qgis/src/plugins/spit/CMakeLists.txt
   trunk/qgis/src/providers/delimitedtext/CMakeLists.txt
   trunk/qgis/src/providers/gpx/CMakeLists.txt
   trunk/qgis/src/providers/grass/CMakeLists.txt
   trunk/qgis/src/providers/memory/CMakeLists.txt
   trunk/qgis/src/providers/ogr/CMakeLists.txt
   trunk/qgis/src/providers/osm/CMakeLists.txt
   trunk/qgis/src/providers/postgres/CMakeLists.txt
   trunk/qgis/src/providers/spatialite/CMakeLists.txt
   trunk/qgis/src/providers/wfs/CMakeLists.txt
   trunk/qgis/src/providers/wms/CMakeLists.txt
   trunk/qgis/src/python/CMakeLists.txt
remove unnecessary linkages
Modified: trunk/qgis/cmake/FindGRASS.cmake
--- trunk/qgis/cmake/FindGRASS.cmake	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/cmake/FindGRASS.cmake	2009-11-28 16:02:15 UTC (rev 12273)
@@ -5,20 +5,20 @@
   FIND_PATH (GRASS_INCLUDE_DIR grass/version.h ${G_PREFIX}/include)
+  SET (GRASS_LIBRARIES_FOUND TRUE)
   SET (GRASS_LIB_NAMES gis vect dig2 dbmiclient dbmibase shape dgl rtree datetime linkm form gproj)
-  SET (GRASS_LIBRARIES "")
   FOREACH (LIB ${GRASS_LIB_NAMES})
+    MARK_AS_ADVANCED ( GRASS_LIBRARY_${LIB} )
     SET(LIB_PATH NOTFOUND)
     FIND_LIBRARY(LIB_PATH NAMES grass_${LIB} PATHS ${G_PREFIX}/lib NO_DEFAULT_PATH)
     IF (LIB_PATH)
-      IF (NOT GRASS_LIBRARIES STREQUAL NOTFOUND)
-        SET (GRASS_LIBRARIES ${GRASS_LIBRARIES} ${LIB_PATH})
-      ENDIF (NOT GRASS_LIBRARIES STREQUAL NOTFOUND)
+      SET (GRASS_LIBRARY_${LIB} ${LIB_PATH})
     ELSE (LIB_PATH)
-      SET (GRASS_LIBRARIES NOTFOUND)
+      SET (GRASS_LIBRARY_${LIB} NOTFOUND)
+      SET (GRASS_LIBRARIES_FOUND FALSE)
     ENDIF (LIB_PATH)
   ENDFOREACH (LIB)
@@ -26,15 +26,12 @@
   # LIB_PATH is only temporary variable, so hide it (is it possible to delete a variable?)
   MARK_AS_ADVANCED(LIB_PATH)
-  IF (GRASS_INCLUDE_DIR AND GRASS_LIBRARIES)
+  IF (GRASS_INCLUDE_DIR AND GRASS_LIBRARIES_FOUND)
     SET (GRASS_FOUND TRUE)
     SET (GRASS_PREFIX ${G_PREFIX})
-  ENDIF (GRASS_INCLUDE_DIR AND GRASS_LIBRARIES)
+  ENDIF (GRASS_INCLUDE_DIR AND GRASS_LIBRARIES_FOUND)
-  MARK_AS_ADVANCED (
-    GRASS_INCLUDE_DIR
-    GRASS_LIBRARIES
+  MARK_AS_ADVANCED ( GRASS_INCLUDE_DIR )
 ENDMACRO (CHECK_GRASS)
@@ -80,22 +77,6 @@
       MESSAGE(STATUS "Found GRASS: ${GRASS_PREFIX} (${GRASS_VERSION})")
    ENDIF (NOT GRASS_FIND_QUIETLY)
-  # openpty is currently needed for GRASS shell
-  INCLUDE(CheckFunctionExists)
-  IF (APPLE)
-  SET (CMAKE_REQUIRED_INCLUDES util.h)
-  ELSE (APPLE)
-  SET (CMAKE_REQUIRED_INCLUDES pty.h)
-  SET (CMAKE_REQUIRED_LIBRARIES util)
-  ENDIF (APPLE)
-  CHECK_FUNCTION_EXISTS(openpty HAVE_OPENPTY)
-  # add 'util' library to the dependencies
-  IF (HAVE_OPENPTY AND NOT APPLE)
-    FIND_LIBRARY(OPENPTY_LIBRARY NAMES util PATHS /usr/local/lib /usr/lib c:/msys/local/lib)
-    SET (GRASS_LIBRARIES ${GRASS_LIBRARIES} ${OPENPTY_LIBRARY})
-  ENDIF (HAVE_OPENPTY AND NOT APPLE)
 ELSE (GRASS_FOUND)
    IF (WITH_GRASS)
Modified: trunk/qgis/python/configure.py.in
--- trunk/qgis/python/configure.py.in	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/python/configure.py.in	2009-11-28 16:02:15 UTC (rev 12273)
@@ -37,9 +37,9 @@
 if not os.path.isdir("./core"):
   os.mkdir("./core")
 if not os.path.isdir("./gui"):
-    os.mkdir("./gui")
+  os.mkdir("./gui")
 if not os.path.isdir("./analysis"):
-    os.mkdir("./analysis")
+  os.mkdir("./analysis")
 # SIP -> *.CPP + *.H
Modified: trunk/qgis/src/analysis/CMakeLists.txt
--- trunk/qgis/src/analysis/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/analysis/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -69,24 +69,8 @@
 SET_TARGET_PROPERTIES(qgis_analysis PROPERTIES VERSION ${COMPLETE_VERSION} SOVERSION ${COMPLETE_VERSION})
-# because of htonl
-IF (WIN32)
-  SET(PLATFORM_LIBRARIES wsock32)
-  IF (MSVC)
-    #needed for linking to gdal which needs odbc
-    SET(PLATFORM_LIBRARIES ${PLATFORM_LIBRARIES} odbc32 odbccp32)
-  ENDIF (MSVC)
-ENDIF (WIN32)
 TARGET_LINK_LIBRARIES(qgis_analysis
   qgis_core
-  ${QT_QTCORE_LIBRARY}
-  ${QT_QTGUI_LIBRARY}
-  ${QT_QTMAIN_LIBRARY}
-  ${PROJ_LIBRARY}
-  ${GEOS_LIBRARY}
-  ${GDAL_LIBRARY}
-  ${PLATFORM_LIBRARIES}
 IF (APPLE)
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/app/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -298,18 +298,13 @@
 ENDIF (WIN32)
-  ${QT_QTXML_LIBRARY}
-  ${QT_QTSVG_LIBRARY}
-  ${QT_QTNETWORK_LIBRARY}
   ${QT_QTSQL_LIBRARY}
   ${QT_QTUITOOLS_LIBRARY}
   #should only be needed for win
   qgis_core
   qgis_gui
 IF(NOT WITH_INTERNAL_SPATIALITE)
   TARGET_LINK_LIBRARIES(qgis ${SQLITE_LIBRARY})
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/core/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -279,24 +279,24 @@
 # because of htonl
 IF (WIN32)
+  TARGET_LINK_LIBRARIES(qgis_core wsock32)
   IF (MSVC)
+    # needed for linking to gdal which needs odbc
+    # TARGET_LINK_LIBRARIES(qgis_core odbc32 odbccp32)
   ENDIF (MSVC)
 ENDIF (WIN32)
+  ${QT_QTMAIN_LIBRARY}
+  ${QT_QTXML_LIBRARY}
   ${QT_QTGUI_LIBRARY}
+  ${QT_QTNETWORK_LIBRARY}
   ${QT_QTSVG_LIBRARY}
   ${PROJ_LIBRARY}
   ${GEOS_LIBRARY}
   ${GDAL_LIBRARY}
 IF (WITH_INTERNAL_SPATIALITE)
@@ -323,82 +323,82 @@
 # Added by Tim to install headers
 SET(QGIS_CORE_HDRS
-qgis.h
-qgsapplication.h
-qgsattributeaction.h
-qgscentralpointpositionmanager.h
-qgsclipper.h
-qgscontexthelp.h
-qgscoordinatetransform.h
-qgsdatasourceuri.h
-qgsdistancearea.h
-qgscsexception.h
-qgsexception.h
-qgsfeature.h
-qgsfield.h
-qgsgeometry.h
-qgshttptransaction.h
-qgslabel.h
-qgslabelattributes.h
-qgslogger.h
-qgsmaplayer.h
-qgsmaplayerregistry.h
-qgsmaprenderer.h
-qgsmaptopixel.h
-qgsmessageoutput.h
-qgsoverlayobjectpositionmanager.h
-qgspalobjectpositionmanager.h
-qgspoint.h
-qgsproject.h
-qgsprojectfiletransform.h
-qgsprojectproperty.h
-qgsprojectversion.h
-qgsprovidercountcalcevent.h
-qgsproviderextentcalcevent.h
-qgsprovidermetadata.h
-qgsproviderregistry.h
-qgsrasterdataprovider.h
-qgsrectangle.h
-qgsrendercontext.h
-qgsrunprocess.h
-qgsscalecalculator.h
-qgssearchstring.h
-qgssearchtreenode.h
-qgssnapper.h
-qgscoordinatereferencesystem.h
-qgsvectordataprovider.h
-qgsvectorfilewriter.h
-qgsvectorlayer.h
-qgsvectoroverlay.h
-qgstolerance.h
+  qgis.h
+  qgsapplication.h
+  qgsattributeaction.h
+  qgscentralpointpositionmanager.h
+  qgsclipper.h
+  qgscontexthelp.h
+  qgscoordinatetransform.h
+  qgsdatasourceuri.h
+  qgsdistancearea.h
+  qgscsexception.h
+  qgsexception.h
+  qgsfeature.h
+  qgsfield.h
+  qgsgeometry.h
+  qgshttptransaction.h
+  qgslabel.h
+  qgslabelattributes.h
+  qgslogger.h
+  qgsmaplayer.h
+  qgsmaplayerregistry.h
+  qgsmaprenderer.h
+  qgsmaptopixel.h
+  qgsmessageoutput.h
+  qgsoverlayobjectpositionmanager.h
+  qgspalobjectpositionmanager.h
+  qgspoint.h
+  qgsproject.h
+  qgsprojectfiletransform.h
+  qgsprojectproperty.h
+  qgsprojectversion.h
+  qgsprovidercountcalcevent.h
+  qgsproviderextentcalcevent.h
+  qgsprovidermetadata.h
+  qgsproviderregistry.h
+  qgsrasterdataprovider.h
+  qgsrectangle.h
+  qgsrendercontext.h
+  qgsrunprocess.h
+  qgsscalecalculator.h
+  qgssearchstring.h
+  qgssearchtreenode.h
+  qgssnapper.h
+  qgscoordinatereferencesystem.h
+  qgsvectordataprovider.h
+  qgsvectorfilewriter.h
+  qgsvectorlayer.h
+  qgsvectoroverlay.h
+  qgstolerance.h
-raster/qgscliptominmaxenhancement.h
-raster/qgscolorrampshader.h
-raster/qgscontrastenhancement.h
-raster/qgscontrastenhancementfunction.h
-raster/qgsfreakoutshader.h
-raster/qgslinearminmaxenhancement.h
-raster/qgslinearminmaxenhancementwithclip.h
-raster/qgspseudocolorshader.h
-raster/qgsrasterbandstats.h
-raster/qgsrasterlayer.h
-raster/qgsrastertransparency.h
-raster/qgsrastershader.h
-raster/qgsrastershaderfunction.h
-raster/qgsrasterviewport.h
+  raster/qgscliptominmaxenhancement.h
+  raster/qgscolorrampshader.h
+  raster/qgscontrastenhancement.h
+  raster/qgscontrastenhancementfunction.h
+  raster/qgsfreakoutshader.h
+  raster/qgslinearminmaxenhancement.h
+  raster/qgslinearminmaxenhancementwithclip.h
+  raster/qgspseudocolorshader.h
+  raster/qgsrasterbandstats.h
+  raster/qgsrasterlayer.h
+  raster/qgsrastertransparency.h
+  raster/qgsrastershader.h
+  raster/qgsrastershaderfunction.h
+  raster/qgsrasterviewport.h
+  renderer/qgscontinuouscolorrenderer.h
+  renderer/qgsgraduatedsymbolrenderer.h
+  renderer/qgsrenderer.h
+  renderer/qgssinglesymbolrenderer.h
+  renderer/qgsuniquevaluerenderer.h
-renderer/qgscontinuouscolorrenderer.h
-renderer/qgsgraduatedsymbolrenderer.h
-renderer/qgsrenderer.h
-renderer/qgssinglesymbolrenderer.h
-renderer/qgsuniquevaluerenderer.h
+  symbology/qgsmarkercatalogue.h
+  symbology/qgssymbol.h
+  symbology/qgssymbologyutils.h
-symbology/qgsmarkercatalogue.h
-symbology/qgssymbol.h
-symbology/qgssymbologyutils.h
-spatialindex/qgsspatialindex.h
+  spatialindex/qgsspatialindex.h
 INSTALL(CODE "MESSAGE(\"Installing CORE headers...\")")
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/gui/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -111,11 +111,6 @@
 ADD_DEPENDENCIES(qgis_gui ui)
 TARGET_LINK_LIBRARIES(qgis_gui
   qgis_core
Modified: trunk/qgis/src/plugins/diagram_overlay/CMakeLists.txt
--- trunk/qgis/src/plugins/diagram_overlay/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/plugins/diagram_overlay/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -47,7 +47,6 @@
 TARGET_LINK_LIBRARIES(diagramoverlay
-  ${QT_LIBRARIES}
   qgis_core
   qgis_gui
Modified: trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt
--- trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -42,7 +42,6 @@
 TARGET_LINK_LIBRARIES(dxf2shpconverterplugin
-  ${QT_LIBRARIES}
   qgis_core
   qgis_gui
Modified: trunk/qgis/src/plugins/evis/CMakeLists.txt
--- trunk/qgis/src/plugins/evis/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/plugins/evis/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -1,16 +1,3 @@
-IF (WIN32)
-  IF (MSVC)
-    ADD_DEFINITIONS("-DGUI_EXPORT=__declspec(dllimport)")
-    ADD_DEFINITIONS("-DCORE_EXPORT=__declspec(dllimport)")
-  ELSE (MSVC)
-    ADD_DEFINITIONS("\"-DGUI_EXPORT=__declspec(dllimport)\"")
-    ADD_DEFINITIONS("\"-DCORE_EXPORT=__declspec(dllimport)\"")
-  ENDIF (MSVC)
-ELSE (WIN32)
-  ADD_DEFINITIONS(-DGUI_EXPORT=)
-  ADD_DEFINITIONS(-DCORE_EXPORT=)
-ENDIF (WIN32)
 # Files
@@ -48,14 +35,6 @@
 SET (evis_RCCS resources/evis.qrc)
-SET (QT_USE_QT3SUPPORT FALSE)
-SET (QT_USE_QTGUI TRUE)
-SET (QT_USE_QTSQL TRUE)
-SET (QT_USE_QTSVG TRUE)
-SET (QT_USE_QTXML TRUE)
-SET (QT_USE_QTNETWORK TRUE)
-FIND_PACKAGE(Qt4 REQUIRED)
-INCLUDE( ${QT_USE_FILE} )
 # Build
@@ -83,9 +62,9 @@
 TARGET_LINK_LIBRARIES(evis
-  ${QT_LIBRARIES}
   qgis_core
   qgis_gui
+  ${QT_QTSQL_LIBRARY}
Modified: trunk/qgis/src/plugins/grass/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/plugins/grass/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -147,14 +147,9 @@
      qtermwidget
 TARGET_LINK_LIBRARIES(grassplugin
-  qgis_core
-  qgis_gui
   qgisgrass
-  ${QT_QTSQL_LIBRARY}
-  ${GRASS_LIBRARIES}
+  qgis_gui
Modified: trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt
--- trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/plugins/ogr_converter/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -52,7 +52,6 @@
 TARGET_LINK_LIBRARIES(${OGR_CONVERTER_PLUGIN}
-    ${GDAL_LIBRARY}
     qgis_core
     qgis_gui
Modified: trunk/qgis/src/plugins/spit/CMakeLists.txt
--- trunk/qgis/src/plugins/spit/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/plugins/spit/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -63,7 +63,6 @@
 TARGET_LINK_LIBRARIES(spitplugin
   ${POSTGRES_LIBRARY}
-  ${GDAL_LIBRARY}
   qgis_core
   qgis_gui
Modified: trunk/qgis/src/providers/delimitedtext/CMakeLists.txt
--- trunk/qgis/src/providers/delimitedtext/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/delimitedtext/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -21,10 +21,6 @@
 ADD_LIBRARY(delimitedtextprovider MODULE ${DTEXT_SRCS} ${DTEXT_MOC_SRCS})
 TARGET_LINK_LIBRARIES(delimitedtextprovider
-  ${GDAL_LIBRARY}
-  ${GEOS_LIBRARY}
   qgis_core
Modified: trunk/qgis/src/providers/gpx/CMakeLists.txt
--- trunk/qgis/src/providers/gpx/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/gpx/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -22,9 +22,6 @@
 ADD_LIBRARY(gpxprovider MODULE ${GPX_SRCS} ${GPX_MOC_SRCS})
 TARGET_LINK_LIBRARIES(gpxprovider
-  ${GEOS_LIBRARY}
   ${EXPAT_LIBRARY}
   qgis_core
Modified: trunk/qgis/src/providers/grass/CMakeLists.txt
--- trunk/qgis/src/providers/grass/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/grass/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -30,10 +30,12 @@
 ENDIF (WIN32)
 TARGET_LINK_LIBRARIES (qgisgrass
   qgis_core
+  ${GRASS_LIBRARY_gis}
+  ${GRASS_LIBRARY_vect}
+  ${GRASS_LIBRARY_dbmibase}
+  ${GRASS_LIBRARY_dbmiclient}
+  ${GRASS_LIBRARY_gproj}
 IF (APPLE)
@@ -49,9 +51,6 @@
 ENDIF (WIN32)
 TARGET_LINK_LIBRARIES (grassprovider
-  qgis_core
   qgisgrass
Modified: trunk/qgis/src/providers/memory/CMakeLists.txt
--- trunk/qgis/src/providers/memory/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/memory/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -10,9 +10,6 @@
 ADD_LIBRARY(memoryprovider MODULE ${MEMORY_SRCS})
 TARGET_LINK_LIBRARIES(memoryprovider
-# ${GDAL_LIBRARY}
-#  ${GEOS_LIBRARY}
   qgis_core
Modified: trunk/qgis/src/providers/ogr/CMakeLists.txt
--- trunk/qgis/src/providers/ogr/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/ogr/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -19,10 +19,6 @@
 ADD_LIBRARY(ogrprovider MODULE ${OGR_SRCS} ${OGR_MOC_SRCS})
 TARGET_LINK_LIBRARIES(ogrprovider
-  ${GDAL_LIBRARY}
-  ${GEOS_LIBRARY}
   qgis_core
 IF (MSVC)
Modified: trunk/qgis/src/providers/osm/CMakeLists.txt
--- trunk/qgis/src/providers/osm/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/osm/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -32,8 +32,6 @@
 ADD_LIBRARY (osmprovider MODULE ${OSM_SRCS} ${OSM_MOC_SRCS})
 TARGET_LINK_LIBRARIES (osmprovider
   qgis_core
Modified: trunk/qgis/src/providers/postgres/CMakeLists.txt
--- trunk/qgis/src/providers/postgres/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/postgres/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -27,8 +27,6 @@
 ADD_LIBRARY (postgresprovider MODULE ${PG_SRCS} ${PG_MOC_SRCS})
 TARGET_LINK_LIBRARIES (postgresprovider
   ${POSTGRES_LIBRARY}
   qgis_core
Modified: trunk/qgis/src/providers/spatialite/CMakeLists.txt
--- trunk/qgis/src/providers/spatialite/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/spatialite/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -21,8 +21,6 @@
 ADD_LIBRARY (spatialiteprovider MODULE ${SPATIALITE_SRCS} ${SPATIALITE_MOC_SRCS})
 TARGET_LINK_LIBRARIES(spatialiteprovider
   qgis_core
Modified: trunk/qgis/src/providers/wfs/CMakeLists.txt
--- trunk/qgis/src/providers/wfs/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/wfs/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -31,9 +31,6 @@
 ADD_LIBRARY (wfsprovider MODULE ${WFS_SRCS} ${WFS_MOC_SRCS})
 TARGET_LINK_LIBRARIES (wfsprovider
-  ${GEOS_LIBRARY}
   ${EXPAT_LIBRARY}
   qgis_core
Modified: trunk/qgis/src/providers/wms/CMakeLists.txt
--- trunk/qgis/src/providers/wms/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/providers/wms/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -9,8 +9,6 @@
 ADD_LIBRARY(wmsprovider MODULE ${WMS_SRCS} ${WMS_MOC_SRCS})
 TARGET_LINK_LIBRARIES(wmsprovider
   qgis_core
Modified: trunk/qgis/src/python/CMakeLists.txt
--- trunk/qgis/src/python/CMakeLists.txt	2009-11-28 15:26:56 UTC (rev 12272)
+++ trunk/qgis/src/python/CMakeLists.txt	2009-11-28 16:02:15 UTC (rev 12273)
@@ -17,17 +17,16 @@
   ../core/renderer
   ../core/symbology
   ../gui
-  ${PYTHON_INCLUDE_PATH})
+  ${PYTHON_INCLUDE_PATH}
 ADD_LIBRARY (qgispython SHARED ${QGISPYTHON_SRCS})
 SET_TARGET_PROPERTIES(qgispython PROPERTIES VERSION ${COMPLETE_VERSION} SOVERSION ${COMPLETE_VERSION})
 TARGET_LINK_LIBRARIES(qgispython
-  ${PYTHON_LIBRARIES}
   qgis_core
+  ${PYTHON_LIBRARY}
 IF (APPLE)
More information about the QGIS-commit mailing list
