[QGIS Commit] r11865 - in trunk/qgis: images/themes/default src/app src/app/composer src/core/composer src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Oct 29 09:17:58 EDT 2009
Author: mhugent
Date: 2009-10-29 09:17:57 -0400 (Thu, 29 Oct 2009)
New Revision: 11865
Added:
   trunk/qgis/images/themes/default/mActionNewComposer.png
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/composer/qgscomposer.h
   trunk/qgis/src/app/composer/qgscomposermapwidget.cpp
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgisappinterface.cpp
   trunk/qgis/src/core/composer/qgscomposeritem.cpp
   trunk/qgis/src/core/composer/qgscomposition.h
   trunk/qgis/src/ui/qgscomposerbase.ui
[FEATURE]: Possibility to have several composers in one project
Added: trunk/qgis/images/themes/default/mActionNewComposer.png
(Binary files differ)
Property changes on: trunk/qgis/images/themes/default/mActionNewComposer.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2009-10-29 13:17:57 UTC (rev 11865)
@@ -65,9 +65,10 @@
 #include <QSizeGrip>
 #include "qgslogger.h"
-QgsComposer::QgsComposer( QgisApp *qgis ): QMainWindow(), mFirstPaint( true )
+QgsComposer::QgsComposer( QgisApp *qgis, const QString& id ): QMainWindow(), mId( id )
   setupUi( this );
+  setAttribute( Qt::WA_DeleteOnClose );
   setupTheme();
   QToolButton* orderingToolButton = new QToolButton( this );
@@ -106,7 +107,7 @@
   toggleActionGroup->addAction( mActionSelectMoveItem );
   toggleActionGroup->setExclusive( true );
-  setWindowTitle( tr( "QGIS - print composer" ) );
+  setWindowTitle( mId );
   mActionAddNewMap->setCheckable( true );
   mActionAddNewLabel->setCheckable( true );
@@ -116,17 +117,21 @@
   mActionAddImage->setCheckable( true );
   mActionMoveItemContent->setCheckable( true );
+#ifdef Q_WS_MAC
   QMenu *appMenu = menuBar()->addMenu( tr( "QGIS" ) );
   appMenu->addAction( QgisApp::instance()->actionAbout() );
   appMenu->addAction( QgisApp::instance()->actionOptions() );
+#endif
   QMenu *fileMenu = menuBar()->addMenu( tr( "File" ) );
-  fileMenu->addAction( tr( "Close" ), this, SLOT( close() ), tr( "Ctrl+W" ) );
   fileMenu->addAction( mActionExportAsImage );
   fileMenu->addAction( mActionExportAsPDF );
   fileMenu->addAction( mActionExportAsSVG );
   fileMenu->addSeparator();
   fileMenu->addAction( mActionPrint );
+  fileMenu->addSeparator();
+  fileMenu->addAction( mActionQuit );
+  QObject::connect( mActionQuit, SIGNAL( triggered() ), this, SLOT( close() ) );
   QMenu *viewMenu = menuBar()->addMenu( tr( "View" ) );
   viewMenu->addAction( mActionZoomIn );
@@ -159,14 +164,13 @@
 #endif
 #endif
+  mQgis = qgis;
+  mFirstTime = true;
-  // Create action to select this window and add it to Window menu
+  // Create action to select this window
   mWindowAction = new QAction( windowTitle(), this );
   connect( mWindowAction, SIGNAL( triggered() ), this, SLOT( activate() ) );
-  mQgis = qgis;
-  mFirstTime = true;
   QgsDebugMsg( "entered." );
   setMouseTracking( true );
@@ -188,8 +192,6 @@
   mCompositionOptionsLayout->setMargin( 0 );
   mCompositionOptionsLayout->addWidget( compositionWidget );
-  mPrinter = 0;
   QGridLayout *l = new QGridLayout( mViewFrame );
   l->setMargin( 0 );
   l->addWidget( mView, 0, 0 );
@@ -206,10 +208,9 @@
   mView->setFocus();
-  //connect with signals from QgsProject to read/write project files
+  //connect with signals from QgsProject to write project files
   if ( QgsProject::instance() )
-    connect( QgsProject::instance(), SIGNAL( readProject( const QDomDocument& ) ), this, SLOT( readXML( const QDomDocument& ) ) );
     connect( QgsProject::instance(), SIGNAL( writeProject( QDomDocument& ) ), this, SLOT( writeXML( QDomDocument& ) ) );
@@ -229,6 +230,7 @@
   //now set all the icons - getThemeIcon will fall back to default theme if its
   //missing from active theme
+  mActionQuit->setIcon( QgisApp::getThemeIcon( "/mActionFileExit.png" ) );
   mActionLoadFromTemplate->setIcon( QgisApp::getThemeIcon( "/mActionFileOpen.png" ) );
   mActionSaveAsTemplate->setIcon( QgisApp::getThemeIcon( "/mActionFileSaveAs.png" ) );
   mActionExportAsImage->setIcon( QgisApp::getThemeIcon( "/mActionSaveMapAsImage.png" ) );
@@ -290,29 +292,6 @@
-void QgsComposer::paintEvent( QPaintEvent* event )
-  QMainWindow::paintEvent( event );
-#if 0 //MH: disabled for now as there are segfaults on some systems
-  //The cached content of the composer maps need to be recreated it is the first paint event of the composer after reading from XML file.
-  //Otherwise the resolution of the composer map is not suitable for screen
-  if ( mFirstPaint )
-    QMap<QgsComposerItem*, QWidget*>::iterator it = mItemWidgetMap.begin();
-    for ( ; it != mItemWidgetMap.constEnd(); ++it )
-      QgsComposerMap* cm = qobject_cast<QgsComposerMap *>( it.key() );
-      if ( cm )
-        mFirstPaint = false;
-        cm->cache();
-        cm->update();
-#endif //0
 void QgsComposer::activate()
   raise();
@@ -320,6 +299,26 @@
   activateWindow();
+void QgsComposer::closeEvent( QCloseEvent *event )
+  if ( QMessageBox::warning( 0, tr( "Remove composer?" ), tr( "Do you really want to remove the composer instance '%1'?" ).arg( mId ), QMessageBox::Ok | QMessageBox::Cancel, QMessageBox::Cancel ) == QMessageBox::Ok )
+    mQgis->checkOutComposer( this );
+    event->accept();
+  else
+    event->ignore();
+#if 0
+  QMainWindow::closeEvent( event );
+  if ( event->isAccepted() )
+    QgisApp::instance()->removeWindow( mWindowAction );
+#endif //0
 #ifdef Q_WS_MAC
 void QgsComposer::changeEvent( QEvent* event )
@@ -338,15 +337,6 @@
-void QgsComposer::closeEvent( QCloseEvent *event )
-  QMainWindow::closeEvent( event );
-  if ( event->isAccepted() )
-    QgisApp::instance()->removeWindow( mWindowAction );
 void QgsComposer::showEvent( QShowEvent *event )
   QMainWindow::showEvent( event );
@@ -1031,6 +1021,7 @@
 void QgsComposer::writeXML( QDomNode& parentNode, QDomDocument& doc )
   QDomElement composerElem = doc.createElement( "Composer" );
+  composerElem.setAttribute( "id", mId );
   parentNode.appendChild( composerElem );
   //store composer items:
@@ -1051,6 +1042,145 @@
 void QgsComposer::readXML( const QDomDocument& doc )
+  QDomNodeList composerNodeList = doc.elementsByTagName( "Composer" );
+  if ( composerNodeList.size() < 1 )
+    return;
+  readXML( composerNodeList.at( 0 ).toElement(), doc );
+void QgsComposer::readXML( const QDomElement& composerElem, const QDomDocument& doc )
+  mId = composerElem.attribute( "id", "" );
+  delete mWindowAction;
+  mWindowAction = new QAction( windowTitle(), this );
+  connect( mWindowAction, SIGNAL( triggered() ), this, SLOT( activate() ) );
+  //delete composer view and composition
+  delete mView;
+  mView = 0;
+  //delete every child of mViewFrame
+  QObjectList viewFrameChildren = mViewFrame->children();
+  QObjectList::iterator it = viewFrameChildren.begin();
+  for ( ; it != viewFrameChildren.end(); ++it )
+    delete( *it );
+  //delete composition widget
+  QgsCompositionWidget* oldCompositionWidget = qobject_cast<QgsCompositionWidget *>( mCompositionOptionsFrame->children().at( 0 ) );
+  delete oldCompositionWidget;
+  delete mCompositionOptionsLayout;
+  mCompositionOptionsLayout = 0;
+  mView = new QgsComposerView( mViewFrame );
+  connectSlots();
+  mComposition = new QgsComposition( mQgis->mapCanvas()->mapRenderer() );
+  mComposition->readXML( composerElem, doc );
+  QGridLayout *l = new QGridLayout( mViewFrame );
+  l->setMargin( 0 );
+  l->addWidget( mView, 0, 0 );
+  //create compositionwidget
+  QgsCompositionWidget* compositionWidget = new QgsCompositionWidget( mCompositionOptionsFrame, mComposition );
+  QObject::connect( mComposition, SIGNAL( paperSizeChanged() ), compositionWidget, SLOT( displayCompositionWidthHeight() ) );
+  compositionWidget->show();
+  mCompositionOptionsLayout = new QGridLayout( mCompositionOptionsFrame );
+  mCompositionOptionsLayout->setMargin( 0 );
+  mCompositionOptionsLayout->addWidget( compositionWidget );
+  //read and restore all the items
+  //composer labels
+  QDomNodeList composerLabelList = composerElem.elementsByTagName( "ComposerLabel" );
+  for ( int i = 0; i < composerLabelList.size(); ++i )
+    QDomElement currentComposerLabelElem = composerLabelList.at( i ).toElement();
+    QgsComposerLabel* newLabel = new QgsComposerLabel( mComposition );
+    newLabel->readXML( currentComposerLabelElem, doc );
+    addComposerLabel( newLabel );
+    mComposition->addItem( newLabel );
+    mComposition->update();
+    mComposition->clearSelection();
+    newLabel->setSelected( true );
+    showItemOptions( newLabel );
+  //composer maps
+  QDomNodeList composerMapList = composerElem.elementsByTagName( "ComposerMap" );
+  for ( int i = 0; i < composerMapList.size(); ++i )
+    QDomElement currentComposerMapElem = composerMapList.at( i ).toElement();
+    QgsComposerMap* newMap = new QgsComposerMap( mComposition );
+    newMap->readXML( currentComposerMapElem, doc );
+    addComposerMap( newMap );
+    mComposition->addItem( newMap );
+    newMap->setSelected( true );
+    showItemOptions( newMap );
+  //composer scalebars
+  QDomNodeList composerScaleBarList = composerElem.elementsByTagName( "ComposerScaleBar" );
+  for ( int i = 0; i < composerScaleBarList.size(); ++i )
+    QDomElement currentScaleBarElem = composerScaleBarList.at( i ).toElement();
+    QgsComposerScaleBar* newScaleBar = new QgsComposerScaleBar( mComposition );
+    newScaleBar->readXML( currentScaleBarElem, doc );
+    addComposerScaleBar( newScaleBar );
+    mComposition->addItem( newScaleBar );
+    newScaleBar->setSelected( true );
+    showItemOptions( newScaleBar );
+  //composer legends
+  QDomNodeList composerLegendList = composerElem.elementsByTagName( "ComposerLegend" );
+  for ( int i = 0; i < composerLegendList.size(); ++i )
+    QDomElement currentLegendElem = composerLegendList.at( i ).toElement();
+    QgsComposerLegend* newLegend = new QgsComposerLegend( mComposition );
+    newLegend->readXML( currentLegendElem, doc );
+    addComposerLegend( newLegend );
+    mComposition->addItem( newLegend );
+    newLegend->setSelected( true );
+    showItemOptions( newLegend );
+  //composer pictures
+  QDomNodeList composerPictureList = composerElem.elementsByTagName( "ComposerPicture" );
+  for ( int i = 0; i < composerPictureList.size(); ++i )
+    QDomElement currentPictureElem = composerPictureList.at( i ).toElement();
+    QgsComposerPicture* newPicture = new QgsComposerPicture( mComposition );
+    newPicture->readXML( currentPictureElem, doc );
+    addComposerPicture( newPicture );
+    mComposition->addItem( newPicture );
+    newPicture->setSelected( true );
+    showItemOptions( newPicture );
+  mComposition->sortZList();
+  mView->setComposition( mComposition );
+  setSelectionTool();
+#if 0
+void QgsComposer::readXML( const QDomDocument& doc )
   //look for Composer element
   QDomNodeList nl = doc.elementsByTagName( "Composer" );
   if ( nl.size() < 1 )
@@ -1058,6 +1188,7 @@
     return; //nothing to do...
   QDomElement composerElem = nl.at( 0 ).toElement();
   //look for Composition element
   QDomNodeList cnl = composerElem.elementsByTagName( "Composition" );
@@ -1187,6 +1318,7 @@
   setSelectionTool();
+#endif //0
 void QgsComposer::addComposerMap( QgsComposerMap* map )
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/app/composer/qgscomposer.h	2009-10-29 13:17:57 UTC (rev 11865)
@@ -31,7 +31,6 @@
 class QgsMapCanvas;
 class QGridLayout;
-class QPrinter;
 class QDomNode;
 class QDomDocument;
 class QMoveEvent;
@@ -47,7 +46,7 @@
     Q_OBJECT
   public:
-    QgsComposer( QgisApp *qgis );
+    QgsComposer( QgisApp *qgis, const QString& id );
     ~QgsComposer();
     //! Set the pixmap / icons on the toolbar buttons
@@ -74,6 +73,10 @@
     //! Restore the window and toolbar state
     void restoreWindowState();
+    QAction* windowAction() {return mWindowAction;}
+    QString id() const {return mId;}
   protected:
     //! Move event
     virtual void moveEvent( QMoveEvent * );
@@ -81,13 +84,13 @@
     //! Resize event
     virtual void resizeEvent( QResizeEvent * );
+    //! Close event (remove window from menu)
+    virtual void closeEvent( QCloseEvent * );
 #ifdef Q_WS_MAC
     //! Change event (update window menu on ActivationChange)
     virtual void changeEvent( QEvent * );
-    //! Close event (remove window from menu)
-    virtual void closeEvent( QCloseEvent * );
     //! Show event (add window to menu)
     virtual void showEvent( QShowEvent * );
 #endif
@@ -218,13 +221,10 @@
     //! Sets state from Dom document
     void readXML( const QDomDocument& doc );
+    void readXML( const QDomElement& composerElem, const QDomDocument& doc );
     void setSelectionTool();
-  protected:
-    void paintEvent( QPaintEvent* event );
   private slots:
     //! Raise, unminimize and activate this window
@@ -235,9 +235,6 @@
     /**Establishes the signal slot connection for the class*/
     void connectSlots();
-    //! returns new world matrix for canvas view after zoom with factor scaleChange
-    QMatrix updateMatrix( double scaleChange );
     //! True if a composer map contains a WMS layer
     bool containsWMSLayer() const;
@@ -252,15 +249,16 @@
     //! Writes state under DOM element
     void writeXML( QDomNode& parentNode, QDomDocument& doc );
+    /**Identification string*/
+    QString mId;
     //! Pointer to composer view
     QgsComposerView *mView;
     //! Current composition
     QgsComposition *mComposition;
-    //! Printer
-    QPrinter *mPrinter;
     //! Pointer to QGIS application
     QgisApp *mQgis;
@@ -282,9 +280,6 @@
     //! Window menu action to select this window
     QAction *mWindowAction;
-    /**False if first paint already happened (used to create cache of composer maps for screen resolution after reading from project files)*/
-    bool mFirstPaint;
     //! Help context id
     static const int context_id = 985715179;
Modified: trunk/qgis/src/app/composer/qgscomposermapwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposermapwidget.cpp	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/app/composer/qgscomposermapwidget.cpp	2009-10-29 13:17:57 UTC (rev 11865)
@@ -702,5 +702,6 @@
     return;
   mComposerMap->setGridAnnotationPrecision( value );
+  mComposerMap->updateBoundingRect();
   mComposerMap->update();
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-10-29 13:17:57 UTC (rev 11865)
@@ -327,7 +327,6 @@
 QgisApp::QgisApp( QSplashScreen *splash, QWidget * parent, Qt::WFlags fl )
     : QMainWindow( parent, fl ),
     mSplash( splash ),
-    mComposer( 0 ),
     mPythonConsole( NULL ),
     mPythonUtils( NULL )
@@ -372,7 +371,6 @@
   readSettings();
   updateRecentProjectPaths();
-  mComposer = new QgsComposer( this ); // Map composer
   mInternalClipboard = new QgsClipboard; // create clipboard
   mQgisInterface = new QgisAppInterface( this ); // create the interfce
@@ -464,9 +462,9 @@
   qApp->processEvents();
   //finally show all the application settings as initialised above
-  QgsDebugMsg( "\n\n\nApplication Settings:\n--------------------------\n");
+  QgsDebugMsg( "\n\n\nApplication Settings:\n--------------------------\n" );
   QgsDebugMsg( QgsApplication::showSettings() );
-  QgsDebugMsg( "\n--------------------------\n\n\n");
+  QgsDebugMsg( "\n--------------------------\n\n\n" );
   mMapCanvas->freeze( false );
 } // QgisApp ctor
@@ -503,6 +501,8 @@
   delete mPythonConsole;
   delete mPythonUtils;
+  deletePrintComposers();
   // delete map layer registry and provider registry
   QgsApplication::exitQgis();
@@ -591,10 +591,10 @@
   mActionSaveMapAsImage->setStatusTip( tr( "Save map as image" ) );
   connect( mActionSaveMapAsImage, SIGNAL( triggered() ), this, SLOT( saveMapAsImage() ) );
-  mActionPrintComposer = new QAction( getThemeIcon( "mActionFilePrint.png" ), tr( "&Print Composer" ), this );
-  shortcuts->registerAction( mActionPrintComposer, tr( "Ctrl+P", "Print Composer" ) );
-  mActionPrintComposer->setStatusTip( tr( "Print Composer" ) );
-  connect( mActionPrintComposer, SIGNAL( triggered() ), this, SLOT( filePrint() ) );
+  mActionNewPrintComposer = new QAction( getThemeIcon( "mActionFilePrint.png" ), tr( "&New Print Composer" ), this );
+  shortcuts->registerAction( mActionNewPrintComposer, tr( "Ctrl+P", "New Print Composer" ) );
+  mActionNewPrintComposer->setStatusTip( tr( "New Print Composer" ) );
+  connect( mActionNewPrintComposer, SIGNAL( triggered() ), this, SLOT( newPrintComposer() ) );
   mActionExit = new QAction( getThemeIcon( "mActionFileExit.png" ), tr( "Exit" ), this );
   shortcuts->registerAction( mActionExit, tr( "Ctrl+Q", "Exit QGIS" ) );
@@ -1166,7 +1166,7 @@
     mActionFileSeparator3 = mFileMenu->addSeparator();
-  mFileMenu->addAction( mActionPrintComposer );
+  mFileMenu->addAction( mActionNewPrintComposer );
   mActionFileSeparator4 = mFileMenu->addSeparator();
   mFileMenu->addAction( mActionExit );
@@ -1332,6 +1332,10 @@
   mActionWindowSeparator2 = mWindowMenu->addSeparator();
 #endif
+  //Print composers menu
+  mPrintComposersMenu = menuBar()->addMenu( tr( "Print Composers" ) );
   // Help Menu
   menuBar()->addSeparator();
@@ -1364,7 +1368,7 @@
   mFileToolBar->addAction( mActionOpenProject );
   mFileToolBar->addAction( mActionSaveProject );
   mFileToolBar->addAction( mActionSaveProjectAs );
-  mFileToolBar->addAction( mActionPrintComposer );
+  mFileToolBar->addAction( mActionNewPrintComposer );
   mFileToolBar->addAction( mActionAddOgrLayer );
   mFileToolBar->addAction( mActionAddRasterLayer );
 #ifdef HAVE_POSTGRESQL
@@ -1629,7 +1633,7 @@
   mActionOpenProject->setIcon( getThemeIcon( "/mActionFileOpen.png" ) );
   mActionSaveProject->setIcon( getThemeIcon( "/mActionFileSave.png" ) );
   mActionSaveProjectAs->setIcon( getThemeIcon( "/mActionFileSaveAs.png" ) );
-  mActionPrintComposer->setIcon( getThemeIcon( "/mActionFilePrint.png" ) );
+  mActionNewPrintComposer->setIcon( getThemeIcon( "/mActionNewComposer.png" ) );
   mActionSaveMapAsImage->setIcon( getThemeIcon( "/mActionSaveMapAsImage.png" ) );
   mActionExit->setIcon( getThemeIcon( "/mActionFileExit.png" ) );
   mActionAddOgrLayer->setIcon( getThemeIcon( "/mActionAddOgrLayer.png" ) );
@@ -1695,10 +1699,13 @@
   mActionAddWmsLayer->setIcon( getThemeIcon( "/mActionAddWmsLayer.png" ) );
   mActionAddToOverview->setIcon( getThemeIcon( "/mActionInOverview.png" ) );
-  if ( mComposer )
+  //change themes of all composers
+  QMap<QString, QgsComposer*>::iterator composerIt = mPrintComposers.begin();
+  for ( ; composerIt != mPrintComposers.end(); ++composerIt )
-    mComposer->setupTheme();
+    composerIt.value()->setupTheme();
   emit currentThemeChanged( theThemeName );
@@ -3056,9 +3063,7 @@
   if ( saveDirty() )
-    delete mComposer;
-    mComposer = 0;
     mMapCanvas->freeze( true );
     removeAllLayers();
     qApp->exit( 0 );
@@ -3081,8 +3086,7 @@
     return;
-  delete mComposer;
   if ( thePromptToSaveFlag )
@@ -3299,9 +3303,7 @@
     // Persist last used project dir
     settings.setValue( "/UI/lastProjectDir", myPath );
-    delete mComposer;
     // clear out any stuff from previous project
     removeAllLayers();
@@ -3347,6 +3349,9 @@
     // project so that they can check any project
     // specific plug-in state
+    //load the composers in the project
+    loadComposersFromProject( fullPath );
     // add this to the list of recently used project files
     saveRecentProjectPath( fullPath, settings );
@@ -3367,10 +3372,7 @@
   QApplication::setOverrideCursor( Qt::WaitCursor );
-  //clear the composer
-  delete mComposer;
   // clear the map canvas
   removeAllLayers();
@@ -3442,6 +3444,8 @@
+  loadComposersFromProject( projectFile );
   QSettings settings;
   saveRecentProjectPath( projectFile, settings );
@@ -3680,13 +3684,41 @@
   return ok;
-void QgisApp::filePrint()
+void QgisApp::newPrintComposer()
   if ( mMapCanvas && mMapCanvas->isDrawing() )
     return;
-  mComposer->open();
+  //ask user about name
+  bool composerExists = true;
+  QString composerId;
+  while ( composerExists )
+    composerId = QInputDialog::getText( 0, tr( "Enter id string for composer" ), tr( "id:" ) );
+    if ( composerId.isNull() )
+      return;
+    if ( mPrintComposers.contains( composerId ) )
+      QMessageBox::critical( 0, tr( "Composer id already exists" ), tr( "The entered composer id '%1' already exists. Please enter a different id" ).arg( composerId ) );
+    else
+      composerExists = false;
+  //create new composer object
+  QgsComposer* newComposerObject = new QgsComposer( this, composerId );
+  //add it to the map of existing print composers
+  mPrintComposers.insert( composerId, newComposerObject );
+  //and place action into print composers menu
+  mPrintComposersMenu->addAction( newComposerObject->windowAction() );
+  newComposerObject->open();
 void QgisApp::saveMapAsImage()
@@ -4167,6 +4199,65 @@
   return unionGeom;
+QList<QgsComposer*> QgisApp::printComposers()
+  QList<QgsComposer*> composerList;
+  QMap<QString, QgsComposer*>::iterator it = mPrintComposers.begin();
+  for ( ; it != mPrintComposers.end(); ++it )
+    composerList.push_back( it.value() );
+  return composerList;
+void QgisApp::checkOutComposer( QgsComposer* c )
+  if ( !c )
+    return;
+  mPrintComposers.remove( c->id() );
+  mPrintComposersMenu->removeAction( c->windowAction() );
+bool QgisApp::loadComposersFromProject( const QString& projectFilePath )
+  //create dom document from file
+  QDomDocument projectDom;
+  QFile projectFile( projectFilePath );
+  if ( !projectFile.open( QIODevice::ReadOnly ) )
+    return false;
+  if ( !projectDom.setContent( &projectFile, false ) )
+    return false;
+  //restore each composer
+  QDomNodeList composerNodes = projectDom.elementsByTagName( "Composer" );
+  for ( int i = 0; i < composerNodes.size(); ++i )
+    QgsComposer* composer = new QgsComposer( this, "" );
+    composer->readXML( composerNodes.at( i ).toElement(), projectDom );
+    mPrintComposers.insert( composer->id(), composer );
+    mPrintComposersMenu->addAction( composer->windowAction() );
+    composer->showMinimized();
+    composer->zoomFull();
+void QgisApp::deletePrintComposers()
+    delete it.value();
+  mPrintComposers.clear();
 void QgisApp::mergeSelectedFeatures()
   //get active layer (hopefully vector)
@@ -5596,9 +5687,9 @@
       //merge tool needs editable layer and provider with the capability of adding and deleting features
       if ( vlayer->isEditable() &&
-           (dprovider->capabilities() & QgsVectorDataProvider::DeleteFeatures) &&
-           (dprovider->capabilities() & QgsVectorDataProvider::ChangeAttributeValues) &&
-           (dprovider->capabilities() & QgsVectorDataProvider::AddFeatures) )
+           ( dprovider->capabilities() & QgsVectorDataProvider::DeleteFeatures ) &&
+           ( dprovider->capabilities() & QgsVectorDataProvider::ChangeAttributeValues ) &&
+           ( dprovider->capabilities() & QgsVectorDataProvider::AddFeatures ) )
         mActionMergeFeatures->setEnabled( layerHasSelection );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/app/qgisapp.h	2009-10-29 13:17:57 UTC (rev 11865)
@@ -143,8 +143,6 @@
     /** Get the mapcanvas object from the app */
     QgsMapCanvas * mapCanvas() { return mMapCanvas; };
-    QgsComposer* printComposer() {return mComposer;}
     //! Set theme (icons)
     void setTheme( QString themeName = "default" );
     //! Setup the toolbar popup menus for a given theme
@@ -196,6 +194,12 @@
      * windows which are hidden rather than deleted when closed. */
     void removeWindow( QAction *action );
+    /**Returns the print composers*/
+    QList<QgsComposer*> printComposers();
+    /**Unregisters a composer instance but does _not_ delete it. This method is usually called from within QgsComposer::closeEvent before
+    the composer deletes itself using the Qt::WA_DeleteOnClose flag*/
+    void checkOutComposer( QgsComposer* c );
     //! Actions to be inserted in menus and toolbars
     QAction *actionNewProject() { return mActionNewProject; }
     QAction *actionOpenProject() { return mActionOpenProject; }
@@ -206,7 +210,7 @@
     QAction *actionFileSeparator2() { return mActionFileSeparator2; }
     QAction *actionProjectProperties() { return mActionProjectProperties; }
     QAction *actionFileSeparator3() { return mActionFileSeparator3; }
-    QAction *actionPrintComposer() { return mActionPrintComposer; }
+    QAction *actionNewPrintComposer() { return mActionNewPrintComposer; }
     QAction *actionFileSeparator4() { return mActionFileSeparator4; }
     QAction *actionExit() { return mActionExit; }
@@ -315,6 +319,7 @@
     QMenu *firstRightStandardMenu() { return mHelpMenu; }
     QMenu *windowMenu() { return NULL; }
 #endif
+    QMenu *printComposersMenu() {return mPrintComposersMenu;}
     QMenu *helpMenu() { return mHelpMenu; }
     //! Toolbars
@@ -443,7 +448,7 @@
     //! Create a new empty vector layer
     void newVectorLayer();
     //! Print the current map view frame
-    void filePrint();
+    void newPrintComposer();
     //! Add all loaded layers into the overview - overides qgisappbase method
     void addAllToOverview();
     //! Remove all loaded layers from the overview - overides qgisappbase method
@@ -675,6 +680,11 @@
       @return 0 in case of error*/
     QgsGeometry* unionGeometries( const QgsVectorLayer* vl, QgsFeatureList& featureList );
+    /**Deletes all the composer objects and clears mPrintComposers*/
+    void deletePrintComposers();
+    /**Creates the composer instances in a project file and adds them to the menu*/
+    bool loadComposersFromProject( const QString& projectFilePath );
     /// QgisApp aren't copyable
     QgisApp( QgisApp const & );
@@ -715,7 +725,7 @@
     QAction *mActionFileSeparator2;
     QAction *mActionProjectProperties;
     QAction *mActionFileSeparator3;
-    QAction *mActionPrintComposer;
+    QAction *mActionNewPrintComposer;
     QAction *mActionFileSeparator4;
     QAction *mActionExit;
@@ -831,6 +841,7 @@
 #ifdef Q_WS_MAC
     QMenu *mWindowMenu;
 #endif
+    QMenu *mPrintComposersMenu;
     QMenu *mHelpMenu;
     // docks ------------------------------------------
@@ -932,8 +943,8 @@
     QgsHelpViewer *mHelpViewer;
     //! list of recently opened/saved project files
     QStringList mRecentProjectPaths;
-    //! Map composer
-    QgsComposer *mComposer;
+    //! Print composers of this project, accessible by id string
+    QMap<QString, QgsComposer*> mPrintComposers;
     //! How to determine the number of decimal places used to
     //! display the mouse position
     bool mMousePrecisionAutomatic;
Modified: trunk/qgis/src/app/qgisappinterface.cpp
--- trunk/qgis/src/app/qgisappinterface.cpp	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/app/qgisappinterface.cpp	2009-10-29 13:17:57 UTC (rev 11865)
@@ -152,13 +152,17 @@
   QList<QgsComposerView*> composerViewList;
   if ( qgis )
-    QgsComposer* c = qgis->printComposer();
-    if ( c )
+    QList<QgsComposer*> composerList = qgis->printComposers();
+    QList<QgsComposer*>::iterator it = composerList.begin();
+    for ( ; it != composerList.end(); ++it )
-      QgsComposerView* v = c->view();
-      if ( v )
+      if ( *it )
-        composerViewList.push_back( v );
+        QgsComposerView* v = ( *it )->view();
+        if ( v )
+          composerViewList.push_back( v );
@@ -228,7 +232,7 @@
 QAction *QgisAppInterface::actionFileSeparator2() { return qgis->actionFileSeparator2(); }
 QAction *QgisAppInterface::actionProjectProperties() { return qgis->actionProjectProperties(); }
 QAction *QgisAppInterface::actionFileSeparator3() { return qgis->actionFileSeparator3(); }
-QAction *QgisAppInterface::actionPrintComposer() { return qgis->actionPrintComposer(); }
+QAction *QgisAppInterface::actionPrintComposer() { return qgis->actionNewPrintComposer(); }
 QAction *QgisAppInterface::actionFileSeparator4() { return qgis->actionFileSeparator4(); }
 QAction *QgisAppInterface::actionExit() { return qgis->actionExit(); }
Modified: trunk/qgis/src/core/composer/qgscomposeritem.cpp
--- trunk/qgis/src/core/composer/qgscomposeritem.cpp	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/core/composer/qgscomposeritem.cpp	2009-10-29 13:17:57 UTC (rev 11865)
@@ -204,11 +204,11 @@
     return false;
+  mLastValidViewScaleFactor = itemElem.attribute( "lastValidViewScaleFactor", "-1" ).toDouble();
   setSceneRect( QRectF( x, y, width, height ) );
   setZValue( itemElem.attribute( "zValue" ).toDouble() );
-  mLastValidViewScaleFactor = itemElem.attribute( "lastValidViewScaleFactor", "-1" ).toDouble();
   //pen
   QDomNodeList frameColorList = itemElem.elementsByTagName( "FrameColor" );
   if ( frameColorList.size() > 0 )
Modified: trunk/qgis/src/core/composer/qgscomposition.h
--- trunk/qgis/src/core/composer/qgscomposition.h	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/core/composer/qgscomposition.h	2009-10-29 13:17:57 UTC (rev 11865)
@@ -16,6 +16,7 @@
 #ifndef QGSCOMPOSITION_H
 #define QGSCOMPOSITION_H
+#include <QDomDocument>
 #include <QGraphicsScene>
 #include <QLinkedList>
@@ -25,7 +26,6 @@
 class QGraphicsRectItem;
 class QgsMapRenderer;
-class QDomDocument;
 class QDomElement;
 /** \ingroup MapComposer
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui	2009-10-29 11:48:15 UTC (rev 11864)
+++ trunk/qgis/src/ui/qgscomposerbase.ui	2009-10-29 13:17:57 UTC (rev 11865)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsComposerBase</class>
- <widget class="QMainWindow" name="QgsComposerBase" >
-  <property name="geometry" >
+ <widget class="QMainWindow" name="QgsComposerBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -9,146 +10,122 @@
     <height>609</height>
    </rect>
   </property>
-  <property name="mouseTracking" >
+  <property name="mouseTracking">
    <bool>true</bool>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>MainWindow</string>
   </property>
-  <widget class="QWidget" name="centralwidget" >
+  <widget class="QWidget" name="centralwidget">
     <bool>true</bool>
    </property>
-   <layout class="QGridLayout" >
-    <item row="0" column="0" >
-     <widget class="QSplitter" name="mSplitter" >
+   <layout class="QGridLayout">
+    <item row="0" column="0">
+     <widget class="QSplitter" name="mSplitter">
        <bool>true</bool>
       </property>
-      <property name="orientation" >
+      <property name="orientation">
        <enum>Qt::Horizontal</enum>
       </property>
-      <widget class="QFrame" name="mViewFrame" >
+      <widget class="QFrame" name="mViewFrame">
         <bool>true</bool>
        </property>
-       <property name="frameShape" >
+       <property name="frameShape">
         <enum>QFrame::StyledPanel</enum>
        </property>
-       <property name="frameShadow" >
+       <property name="frameShadow">
         <enum>QFrame::Raised</enum>
        </property>
       </widget>
-      <widget class="QTabWidget" name="mOptionsTabWidget" >
-       <property name="sizePolicy" >
-        <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+      <widget class="QTabWidget" name="mOptionsTabWidget">
+       <property name="sizePolicy">
+        <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
          <horstretch>0</horstretch>
          <verstretch>0</verstretch>
         </sizepolicy>
        </property>
-       <property name="minimumSize" >
+       <property name="minimumSize">
         <size>
          <width>150</width>
          <height>10</height>
         </size>
        </property>
-       <property name="maximumSize" >
+       <property name="maximumSize">
         <size>
          <width>32767</width>
          <height>32767</height>
         </size>
        </property>
-       <property name="currentIndex" >
+       <property name="currentIndex">
         <number>1</number>
        </property>
-       <widget class="QWidget" name="tab" >
-        <attribute name="title" >
+       <widget class="QWidget" name="tab">
+        <attribute name="title">
          <string>General</string>
         </attribute>
-         <property name="leftMargin" >
+         <property name="margin">
           <number>9</number>
          </property>
-         <property name="topMargin" >
-          <number>9</number>
-         </property>
-         <property name="rightMargin" >
-         </property>
-         <property name="bottomMargin" >
-         </property>
-         <property name="horizontalSpacing" >
+         <property name="spacing">
           <number>6</number>
          </property>
-         <property name="verticalSpacing" >
-          <number>6</number>
-         </property>
-         <item row="1" column="0" colspan="2" >
-          <widget class="QFrame" name="mCompositionOptionsFrame" >
+         <item row="1" column="0" colspan="2">
+          <widget class="QFrame" name="mCompositionOptionsFrame">
            </property>
            </property>
           </widget>
          </item>
-         <item row="0" column="1" >
-          <widget class="QComboBox" name="mCompositionNameComboBox" >
-           <property name="enabled" >
+         <item row="0" column="1">
+          <widget class="QComboBox" name="mCompositionNameComboBox">
+           <property name="enabled">
             <bool>false</bool>
            </property>
-            <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+            <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
             </sizepolicy>
            </property>
           </widget>
          </item>
-          <widget class="QLabel" name="textLabel1" >
-            <sizepolicy vsizetype="Preferred" hsizetype="Expanding" >
+          <widget class="QLabel" name="textLabel1">
+            <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
             </sizepolicy>
            </property>
-           <property name="text" >
+           <property name="text">
             <string>Composition</string>
            </property>
           </widget>
          </item>
         </layout>
        </widget>
-       <widget class="QWidget" name="tab_2" >
+       <widget class="QWidget" name="tab_2">
          <string>Item</string>
         </attribute>
           <number>9</number>
          </property>
-         </property>
-         </property>
-         </property>
           <number>6</number>
          </property>
-         </property>
-          <widget class="QStackedWidget" name="mItemStackedWidget" >
-           <widget class="QWidget" name="page" />
-           <widget class="QWidget" name="page_2" />
+          <widget class="QStackedWidget" name="mItemStackedWidget">
+           <widget class="QWidget" name="page"/>
+           <widget class="QWidget" name="page_2"/>
           </widget>
          </item>
         </layout>
@@ -156,291 +133,316 @@
       </widget>
      </widget>
     </item>
-    <item row="1" column="0" >
-     <widget class="QDialogButtonBox" name="buttonBox" >
-      <property name="standardButtons" >
-       <set>QDialogButtonBox::Close|QDialogButtonBox::Help|QDialogButtonBox::NoButton</set>
+    <item row="1" column="0">
+     <widget class="QDialogButtonBox" name="buttonBox">
+      <property name="standardButtons">
+       <set>QDialogButtonBox::Help</set>
       </property>
      </widget>
     </item>
    </layout>
   </widget>
-  <widget class="QToolBar" name="toolBar" >
+  <widget class="QToolBar" name="toolBar">
    </property>
-   <attribute name="toolBarArea" >
+   <attribute name="toolBarArea">
     <enum>TopToolBarArea</enum>
    </attribute>
-   <attribute name="toolBarBreak" >
+   <attribute name="toolBarBreak">
     <bool>false</bool>
    </attribute>
-   <addaction name="mActionLoadFromTemplate" />
-   <addaction name="mActionSaveAsTemplate" />
-   <addaction name="mActionExportAsImage" />
-   <addaction name="mActionExportAsPDF" />
-   <addaction name="mActionExportAsSVG" />
-   <addaction name="mActionPrint" />
-   <addaction name="separator" />
-   <addaction name="mActionZoomAll" />
-   <addaction name="mActionZoomIn" />
-   <addaction name="mActionZoomOut" />
-   <addaction name="mActionRefreshView" />
-   <addaction name="mActionAddNewMap" />
-   <addaction name="mActionAddImage" />
-   <addaction name="mActionAddNewLabel" />
-   <addaction name="mActionAddNewLegend" />
-   <addaction name="mActionAddNewScalebar" />
-   <addaction name="mActionSelectMoveItem" />
-   <addaction name="mActionMoveItemContent" />
-   <addaction name="mActionGroupItems" />
-   <addaction name="mActionUngroupItems" />
+   <addaction name="mActionLoadFromTemplate"/>
+   <addaction name="mActionSaveAsTemplate"/>
+   <addaction name="mActionExportAsImage"/>
+   <addaction name="mActionExportAsPDF"/>
+   <addaction name="mActionExportAsSVG"/>
+   <addaction name="mActionPrint"/>
+   <addaction name="separator"/>
+   <addaction name="mActionZoomAll"/>
+   <addaction name="mActionZoomIn"/>
+   <addaction name="mActionZoomOut"/>
+   <addaction name="mActionRefreshView"/>
+   <addaction name="mActionAddNewMap"/>
+   <addaction name="mActionAddImage"/>
+   <addaction name="mActionAddNewLabel"/>
+   <addaction name="mActionAddNewLegend"/>
+   <addaction name="mActionAddNewScalebar"/>
+   <addaction name="mActionSelectMoveItem"/>
+   <addaction name="mActionMoveItemContent"/>
+   <addaction name="mActionGroupItems"/>
+   <addaction name="mActionUngroupItems"/>
   </widget>
-  <action name="mActionPrint" >
-   <property name="icon" >
-    <iconset>../themes/default/mActionFilePrint.png</iconset>
+  <action name="mActionPrint">
+   <property name="icon">
+    <iconset>
+     <normaloff>../themes/default/mActionFilePrint.png</normaloff>../themes/default/mActionFilePrint.png</iconset>
    </property>
     <string>&amp;Print...</string>
    </property>
   </action>
-  <action name="mActionZoomAll" >
-    <iconset>../themes/default/mActionZoomFullExtent.png</iconset>
+  <action name="mActionZoomAll">
+    <iconset>
+     <normaloff>../themes/default/mActionZoomFullExtent.png</normaloff>../themes/default/mActionZoomFullExtent.png</iconset>
    </property>
     <string>Zoom Full</string>
    </property>
   </action>
-  <action name="mActionZoomIn" >
-    <iconset>../themes/default/mActionZoomIn.png</iconset>
+  <action name="mActionZoomIn">
+    <iconset>
+     <normaloff>../themes/default/mActionZoomIn.png</normaloff>../themes/default/mActionZoomIn.png</iconset>
    </property>
     <string>Zoom In</string>
    </property>
   </action>
-  <action name="mActionZoomOut" >
-    <iconset>../themes/default/mActionZoomOut.png</iconset>
+  <action name="mActionZoomOut">
+    <iconset>
+     <normaloff>../themes/default/mActionZoomOut.png</normaloff>../themes/default/mActionZoomOut.png</iconset>
    </property>
     <string>Zoom Out</string>
    </property>
   </action>
-  <action name="mActionAddNewMap" >
-    <iconset>../themes/default/mActionAddMap.png</iconset>
+  <action name="mActionAddNewMap">
+    <iconset>
+     <normaloff>../themes/default/mActionAddMap.png</normaloff>../themes/default/mActionAddMap.png</iconset>
    </property>
     <string>Add Map</string>
    </property>
-   <property name="toolTip" >
+   <property name="toolTip">
     <string>Add new map</string>
    </property>
   </action>
-  <action name="mActionAddNewLabel" >
-    <iconset>../themes/default/mActionLabel.png</iconset>
+  <action name="mActionAddNewLabel">
+    <iconset>
+     <normaloff>../themes/default/mActionLabel.png</normaloff>../themes/default/mActionLabel.png</iconset>
    </property>
     <string>Add Label</string>
    </property>
     <string>Add new label</string>
    </property>
   </action>
-  <action name="mActionAddNewLegend" >
-    <iconset>../themes/default/mActionAddLegend.png</iconset>
+  <action name="mActionAddNewLegend">
+    <iconset>
+     <normaloff>../themes/default/mActionAddLegend.png</normaloff>../themes/default/mActionAddLegend.png</iconset>
    </property>
     <string>Add Vector Legend</string>
    </property>
     <string>Add new vect legend</string>
    </property>
   </action>
-  <action name="mActionSelectMoveItem" >
-    <iconset>../themes/default/mActionPan.png</iconset>
+  <action name="mActionSelectMoveItem">
+    <iconset>
+     <normaloff>../themes/default/mActionPan.png</normaloff>../themes/default/mActionPan.png</iconset>
    </property>
     <string>Move Item</string>
    </property>
     <string>Select/Move item</string>
    </property>
   </action>
-  <action name="mActionExportAsImage" >
-    <iconset>../themes/default/mActionSaveMapAsImage.png</iconset>
+  <action name="mActionExportAsImage">
+    <iconset>
+     <normaloff>../themes/default/mActionSaveMapAsImage.png</normaloff>../themes/default/mActionSaveMapAsImage.png</iconset>
    </property>
     <string>Export as Image...</string>
    </property>
   </action>
-  <action name="mActionExportAsPDF" >
-    <iconset>../themes/default/mActionSaveAsPDF.png</iconset>
+  <action name="mActionExportAsPDF">
+    <iconset>
+     <normaloff>../themes/default/mActionSaveAsPDF.png</normaloff>../themes/default/mActionSaveAsPDF.png</iconset>
    </property>
     <string>Export as PDF...</string>
    </property>
   </action>
-  <action name="mActionExportAsSVG" >
-    <iconset>../themes/default/mActionSaveAsSVG.png</iconset>
+  <action name="mActionExportAsSVG">
+    <iconset>
+     <normaloff>../themes/default/mActionSaveAsSVG.png</normaloff>../themes/default/mActionSaveAsSVG.png</iconset>
    </property>
     <string>Export as SVG...</string>
    </property>
   </action>
-  <action name="mActionAddNewScalebar" >
-    <iconset>../../plugins/scale_bar/icon.xpm</iconset>
+  <action name="mActionAddNewScalebar">
+    <iconset>
+     <normaloff>../../plugins/scale_bar/icon.xpm</normaloff>../../plugins/scale_bar/icon.xpm</iconset>
    </property>
     <string>Add Scalebar</string>
    </property>
     <string>Add new scalebar</string>
    </property>
   </action>
-  <action name="mActionRefreshView" >
-    <iconset>../themes/default/mActionDraw.png</iconset>
+  <action name="mActionRefreshView">
+    <iconset>
+     <normaloff>../themes/default/mActionDraw.png</normaloff>../themes/default/mActionDraw.png</iconset>
    </property>
     <string>Refresh</string>
    </property>
     <string>Refresh view</string>
    </property>
   </action>
-  <action name="mActionAddImage" >
-    <iconset>../themes/default/mActionAddImage.png</iconset>
+  <action name="mActionAddImage">
+    <iconset>
+     <normaloff>../themes/default/mActionAddImage.png</normaloff>../themes/default/mActionAddImage.png</iconset>
    </property>
     <string>Add Image</string>
    </property>
   </action>
-  <action name="mActionMoveItemContent" >
+  <action name="mActionMoveItemContent">
     <string>Move Content</string>
    </property>
     <string>Move item content</string>
    </property>
   </action>
-  <action name="mActionGroupItems" >
+  <action name="mActionGroupItems">
     <string>Group</string>
    </property>
     <string>Group items</string>
    </property>
   </action>
-  <action name="mActionUngroupItems" >
+  <action name="mActionUngroupItems">
     <string>Ungroup</string>
    </property>
     <string>Ungroup items</string>
    </property>
   </action>
-  <action name="mActionRaiseItems" >
+  <action name="mActionRaiseItems">
     <string>Raise</string>
    </property>
     <string>Raise selected items</string>
    </property>
   </action>
-  <action name="mActionLowerItems" >
+  <action name="mActionLowerItems">
     <string>Lower</string>
    </property>
     <string>Lower selected items</string>
    </property>
   </action>
-  <action name="mActionMoveItemsToTop" >
+  <action name="mActionMoveItemsToTop">
     <string>Bring to Front</string>
    </property>
     <string>Move selected items to top</string>
    </property>
   </action>
-  <action name="mActionMoveItemsToBottom" >
+  <action name="mActionMoveItemsToBottom">
     <string>Send to Back</string>
    </property>
     <string>Move selected items to bottom</string>
    </property>
   </action>
-  <action name="mActionLoadFromTemplate" >
+  <action name="mActionLoadFromTemplate">
     <string>Load From template</string>
    </property>
   </action>
-  <action name="mActionSaveAsTemplate" >
+  <action name="mActionSaveAsTemplate">
     <string>Save as template</string>
    </property>
   </action>
-  <action name="mActionAlignLeft" >
+  <action name="mActionAlignLeft">
     <string>Align left</string>
    </property>
     <string>Align selected items left</string>
    </property>
   </action>
-  <action name="mActionAlignHCenter" >
+  <action name="mActionAlignHCenter">
     <string>Align center</string>
    </property>
     <string>Align center horizontal</string>
    </property>
   </action>
-  <action name="mActionAlignRight" >
+  <action name="mActionAlignRight">
     <string>Align right</string>
    </property>
     <string>Align selected items right</string>
    </property>
   </action>
-  <action name="mActionAlignTop" >
+  <action name="mActionAlignTop">
     <string>Align top</string>
    </property>
     <string>Align selected items to top</string>
    </property>
   </action>
-  <action name="mActionAlignVCenter" >
+  <action name="mActionAlignVCenter">
     <string>Align center vertical</string>
    </property>
    </property>
   </action>
-  <action name="mActionAlignBottom" >
+  <action name="mActionAlignBottom">
     <string>Align bottom</string>
    </property>
     <string>Align selected items bottom</string>
    </property>
   </action>
+  <action name="mActionQuit">
+    <string>&amp;Quit</string>
+   </property>
+    <string>Quit</string>
+   </property>
+   <property name="shortcut">
+    <string>Ctrl+Q</string>
+   </property>
+  </action>
  </widget>
  <tabstops>
   <tabstop>mOptionsTabWidget</tabstop>
@@ -455,11 +457,11 @@
    <receiver>QgsComposerBase</receiver>
    <slot>close()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>612</x>
      <y>583</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>735</x>
      <y>567</y>
     </hint>
More information about the QGIS-commit mailing list
