[QGIS Commit] r11866 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Fri Oct 30 03:20:29 EDT 2009
Author: mhugent
Date: 2009-10-30 03:20:26 -0400 (Fri, 30 Oct 2009)
New Revision: 11866
trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
Rename option to lock layers
Modified: trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposermapwidgetbase.ui 2009-10-29 13:17:57 UTC (rev 11865)
+++ trunk/qgis/src/ui/qgscomposermapwidgetbase.ui 2009-10-30 07:20:26 UTC (rev 11866)
@@ -238,7 +238,7 @@
<item row="3" column="0">
<widget class="QCheckBox" name="mKeepLayerListCheckBox">
<property name="text">
- <string>Keep layer list</string>
+ <string>Lock layers for map item</string>
</property>
</widget>
</item>
