[QGIS Commit] r13227 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sat Apr 3 06:40:05 EDT 2010
Author: jef
Date: 2010-04-03 06:39:59 -0400 (Sat, 03 Apr 2010)
New Revision: 13227
trunk/qgis/src/app/qgscustomprojectiondialog.cpp
trunk/qgis/src/app/qgscustomprojectiondialog.h
cleanup and fix #2619
Modified: trunk/qgis/src/app/qgscustomprojectiondialog.cpp
--- trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2010-04-02 19:03:56 UTC (rev 13226)
+++ trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2010-04-03 10:39:59 UTC (rev 13227)
@@ -30,7 +30,6 @@
#include <QLocale>
//stdc++ includes
-#include <cassert>
#include <fstream>
#include <sqlite3.h>
#include "qgslogger.h"
@@ -116,10 +115,10 @@
QgsDebugMsg( QString( "Can't open database: %1" ).arg( sqlite3_errmsg( myDatabase ) ) );
// XXX This will likely never happen since on open, sqlite creates the
// database if it does not exist.
- assert( myResult == SQLITE_OK );
+ Q_ASSERT( myResult == SQLITE_OK );
// Set up the query to retrieve the projection information needed to populate the ELLIPSOID list
- QString mySql = "delete from tbl_srs where srs_id='" + mCurrentRecordId + "'";
+ QString mySql = "delete from tbl_srs where srs_id=" + quotedValue( mCurrentRecordId );
myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.toUtf8().length(), &myPreparedStatement, &myTail );
// XXX Need to free memory from the error msg if one is set
QgsDebugMsg( QString( "Query to delete current:%1" ).arg( mySql ) );
@@ -152,14 +151,6 @@
return ;
-void QgsCustomProjectionDialog::on_pbnClose_clicked()
- close();
long QgsCustomProjectionDialog::getRecordCount()
sqlite3 *myDatabase;
@@ -174,7 +165,7 @@
QString mySql = "select count(*) from tbl_srs";
@@ -209,10 +200,10 @@
// Set up the query to retrieve the projection information needed to populate the PROJECTION list
- QString mySql = "select name from tbl_projection where acronym='" + theProjectionFamilyAcronym + "'";
+ QString mySql = "select name from tbl_projection where acronym=" + quotedValue( theProjectionFamilyAcronym );
if ( myResult == SQLITE_OK )
@@ -240,10 +231,10 @@
- QString mySql = "select name from tbl_ellipsoid where acronym='" + theEllipsoidAcronym + "'";
+ QString mySql = "select name from tbl_ellipsoid where acronym=" + quotedValue( theEllipsoidAcronym );
@@ -271,10 +262,10 @@
- QString mySql = "select acronym from tbl_projection where name='" + theProjectionFamilyName + "'";
+ QString mySql = "select acronym from tbl_projection where name=" + quotedValue( theProjectionFamilyName );
@@ -302,10 +293,10 @@
- QString mySql = "select acronym from tbl_ellipsoid where name='" + theEllipsoidName + "'";
+ QString mySql = "select acronym from tbl_ellipsoid where name=" + quotedValue( theEllipsoidName );
@@ -334,7 +325,7 @@
QString mySql = "select * from tbl_srs order by srs_id limit 1";
@@ -406,7 +397,7 @@
QString mySql = "select * from tbl_srs where srs_id < " + mCurrentRecordId + " order by srs_id desc limit 1";
@@ -479,7 +470,7 @@
QString mySql = "select * from tbl_srs where srs_id > " + mCurrentRecordId + " order by srs_id asc limit 1";
@@ -548,7 +539,7 @@
QString mySql = "select * from tbl_srs order by srs_id desc limit 1";
@@ -733,28 +724,33 @@
//the autoinc related system tables.
if ( getRecordCount() == 0 )
- mySql = QString( "insert into tbl_srs (srs_id,description,projection_acronym,ellipsoid_acronym,parameters,is_geo) " )
- + " values (" + QString::number( USER_CRS_START_ID ) + ",'"
- + sqlSafeString( myName ) + "','" + myProjectionAcronym
- + "','" + myEllipsoidAcronym + "','" + sqlSafeString( myParameters )
- + "',0)"; // <-- is_geo shamelessly hard coded for now
+ mySql = "insert into tbl_srs (srs_id,description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values ("
+ + QString::number( USER_CRS_START_ID )
+ + "," + quotedValue( myName )
+ + "," + quotedValue( myProjectionAcronym )
+ + "," + quotedValue( myEllipsoidAcronym )
+ + "," + quotedValue( myParameters )
+ + ",0)"; // <-- is_geo shamelessly hard coded for now
else
- mySql = "insert into tbl_srs (description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values ('"
+ mySql = "insert into tbl_srs (description,projection_acronym,ellipsoid_acronym,parameters,is_geo) values ("
+ + quotedValue( myName )
else //user is updating an existing record
- mySql = "update tbl_srs set description='" + sqlSafeString( myName )
- + "',projection_acronym='" + myProjectionAcronym
- + "',ellipsoid_acronym='" + myEllipsoidAcronym
- + "',parameters='" + sqlSafeString( myParameters ) + "' "
+ mySql = "update tbl_srs set description="
+ + ",projection_acronym=" + quotedValue( myProjectionAcronym )
+ + ",ellipsoid_acronym=" + quotedValue( myEllipsoidAcronym )
+ + ",parameters=" + quotedValue( myParameters )
+ ",is_geo=0" // <--shamelessly hard coded for now
- + " where srs_id='" + mCurrentRecordId + "'"
+ + " where srs_id=" + quotedValue( mCurrentRecordId )
@@ -762,21 +758,20 @@
sqlite3_stmt *myPreparedStatement;
int myResult;
//check the db is available
- myResult = sqlite3_open( QgsApplication::qgisUserDbFilePath().toUtf8().data(), &myDatabase );
+ myResult = sqlite3_open( QgsApplication::qgisUserDbFilePath().toUtf8(), &myDatabase );
if ( myResult != SQLITE_OK )
QgsDebugMsg( QString( "Can't open database: %1 \n please notify QGIS developers of this error \n %2 (file name) " ).arg( sqlite3_errmsg( myDatabase ) ).arg( QgsApplication::qgisUserDbFilePath() ) );
- QgsDebugMsg( QString( "Update or insert sql \n%1" ).arg( mySql ) );
sqlite3_step( myPreparedStatement );
- QgsDebugMsg( "Update or insert failed in custom projection dialog " );
+ QgsDebugMsg( QString( "update or insert failed in custom projection dialog: %1 [%2]" ).arg( mySql ).arg( sqlite3_errmsg( myDatabase ) ) );
//reinstate button if we were doing an insert
else if ( pbnNew->text() == tr( "Abort" ) )
@@ -794,49 +789,56 @@
// This is a must, or else we can't select it from the vw_srs table.
// Actually, add it always and let the SQL PRIMARY KEY remove duplicates.
- sqlite3 *srsDatabase;
- const char *srsTail;
- sqlite3_stmt *srsPreparedStatement;
- int srsResult;
- srsResult = sqlite3_open( QgsApplication::srsDbFilePath().toUtf8().data(), &srsDatabase );
- if ( myResult != SQLITE_OK )
+ sqlite3 *srsDatabase;
+ int srsResult = sqlite3_open( QgsApplication::srsDbFilePath().toUtf8(), &srsDatabase );
+ if ( myResult == SQLITE_OK )
- QgsDebugMsg( QString( "Can't open database: %1" ).arg( sqlite3_errmsg( srsDatabase ) ) );
- // XXX This will likely never happen since on open, sqlite creates the
- // database if it does not exist.
- // Set up the query to retrieve the projection information needed to populate the PROJECTION list
- QString srsSql = "select * from tbl_projection where acronym='" + myProjectionAcronym + "'";
- srsResult = sqlite3_prepare( srsDatabase, srsSql.toUtf8(), srsSql.length(), &srsPreparedStatement, &srsTail );
- // XXX Need to free memory from the error msg if one is set
- if ( srsResult == SQLITE_OK )
- if ( sqlite3_step( srsPreparedStatement ) == SQLITE_ROW )
+ // Set up the query to retrieve the projection information needed to populate the PROJECTION list
+ QString srsSql = "select acronym,name,notes,parameters from tbl_projection where acronym=" + quotedValue( myProjectionAcronym );
+ const char *srsTail;
+ sqlite3_stmt *srsPreparedStatement;
+ srsResult = sqlite3_prepare( srsDatabase, srsSql.toUtf8(), srsSql.length(), &srsPreparedStatement, &srsTail );
+ // XXX Need to free memory from the error msg if one is set
+ if ( srsResult == SQLITE_OK )
- QgsDebugMsg( "Trying to insert projection" );
- // We have the result from system srs.db. Now insert into user db.
- mySql = QString( "INSERT INTO tbl_projection VALUES('%1','%2','%3','%4')" )
- .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 0 ) ) )
- .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 1 ) ) )
- .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 2 ) ) )
- .arg( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 3 ) ) );
- myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail );
- sqlite3_step( myPreparedStatement );
+ if ( sqlite3_step( srsPreparedStatement ) == SQLITE_ROW )
- QgsDebugMsg( "Update or insert failed in custom projection dialog: " + mySql );
+ QgsDebugMsg( "Trying to insert projection" );
+ // We have the result from system srs.db. Now insert into user db.
+ mySql = "insert into tbl_projection(acronym,name,notes,parameters) values ("
+ + quotedValue( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 0 ) ) )
+ + "," + quotedValue( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 1 ) ) )
+ + "," + quotedValue( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 2 ) ) )
+ + "," + quotedValue( QString::fromUtf8(( char * )sqlite3_column_text( srsPreparedStatement, 3 ) ) )
+ myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail );
+ sqlite3_step( myPreparedStatement );
+ if ( myResult != SQLITE_OK )
+ QgsDebugMsg( QString( "Update or insert failed in custom projection dialog: %1 [%2]" ).arg( mySql ).arg( sqlite3_errmsg( myDatabase ) ) );
+ sqlite3_finalize( myPreparedStatement );
- sqlite3_finalize( myPreparedStatement );
+ sqlite3_finalize( srsPreparedStatement );
+ else
+ QgsDebugMsg( QString( "prepare failed: %1 [%2]" ).arg( srsSql ).arg( sqlite3_errmsg( srsDatabase ) ) );
+ sqlite3_close( srsDatabase );
+ else
+ QgsDebugMsg( QString( "Can't open database %1 [%2]" ).arg( QgsApplication::srsDbFilePath() ).arg( sqlite3_errmsg( srsDatabase ) ) );
- // close the user and srs sqlite3 db
+ // close sqlite3 db
sqlite3_close( myDatabase );
- sqlite3_finalize( srsPreparedStatement );
- sqlite3_close( srsDatabase );
pbnDelete->setEnabled( true );
@@ -957,44 +959,9 @@
-* \brief Make the string safe for use in SQL statements.
-* This involves escaping single quotes, double quotes, backslashes,
-* and optionally, percentage symbols. Percentage symbols are used
-* as wildcards sometimes and so when using the string as part of the
-* LIKE phrase of a select statement, should be escaped.
-* \arg const QString in The input string to make safe.
-* \return The string made safe for SQL statements.
-const QString QgsCustomProjectionDialog::sqlSafeString( const QString theSQL )
+QString QgsCustomProjectionDialog::quotedValue( QString value )
- QString myRetval;
- QChar *it = ( QChar * )theSQL.unicode();
- for ( int i = 0; i < theSQL.length(); i++ )
- if ( *it == '\"' )
- myRetval += "\\\"";
- else if ( *it == '\'' )
- myRetval += "\\'";
- else if ( *it == '\\' )
- myRetval += "\\\\";
- else if ( *it == '%' )
- myRetval += "\\%";
- else
- myRetval += *it;
- it++;
- return myRetval;
+ value.replace( "'", "''" );
+ return value.prepend( "'" ).append( "'" );
Modified: trunk/qgis/src/app/qgscustomprojectiondialog.h
--- trunk/qgis/src/app/qgscustomprojectiondialog.h 2010-04-02 19:03:56 UTC (rev 13226)
+++ trunk/qgis/src/app/qgscustomprojectiondialog.h 2010-04-03 10:39:59 UTC (rev 13227)
@@ -37,7 +37,6 @@
//a recursive function to make a directory and its ancestors
public slots:
void on_pbnCalculate_clicked();
- void on_pbnClose_clicked();
void on_pbnDelete_clicked();
// Database navigation controles
@@ -67,15 +66,13 @@
QString getProjFromParameters();
QString getEllipseFromParameters();
QString mCurrentRecordId;
long mCurrentRecordLong;
//the record previous to starting an insert operation
//so that we can return to it if the record insert is aborted
long mLastRecordLong;
long mRecordCountLong;
- const QString sqlSafeString( const QString theSQL );
+ QString quotedValue( QString value );
#endif
