[QGIS Commit] r13228 - trunk/qgis/src/app/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 3 11:49:50 EDT 2010
Author: mhugent
Date: 2010-04-03 11:49:48 -0400 (Sat, 03 Apr 2010)
New Revision: 13228
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/composer/qgscomposermanager.cpp
   trunk/qgis/src/app/composer/qgscomposermanager.h
[FEATURE]: implement possibility to place a set of default composer templates in pkgDataPath/composer_templates
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2010-04-03 10:39:59 UTC (rev 13227)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2010-04-03 15:49:48 UTC (rev 13228)
@@ -903,9 +903,6 @@
   deleteItems();
   readXML( templateDocument );
-  //clean up after template read (e.g. legend and map extent)
-  cleanupAfterTemplateRead();
 void QgsComposer::on_mActionMoveItemContent_triggered()
@@ -1103,6 +1100,7 @@
     return;
   readXML( composerNodeList.at( 0 ).toElement(), doc, true );
+  cleanupAfterTemplateRead();
 void QgsComposer::readXML( const QDomElement& composerElem, const QDomDocument& doc, bool fromTemplate )
Modified: trunk/qgis/src/app/composer/qgscomposermanager.cpp
--- trunk/qgis/src/app/composer/qgscomposermanager.cpp	2010-04-03 10:39:59 UTC (rev 13227)
+++ trunk/qgis/src/app/composer/qgscomposermanager.cpp	2010-04-03 15:49:48 UTC (rev 13228)
@@ -16,7 +16,10 @@
 #include "qgscomposermanager.h"
 #include "qgisapp.h"
+#include "qgsapplication.h"
 #include "qgscomposer.h"
+#include "qgslogger.h"
+#include <QDir>
 #include <QInputDialog>
 #include <QListWidgetItem>
 #include <QMessageBox>
@@ -48,6 +51,26 @@
     item->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsEditable );
     mItemComposerMap.insert( item, *it );
+  //search for default templates in $pkgDataPath/composer_templates
+  QDir defaultTemplateDir( QgsApplication::pkgDataPath() + "/composer_templates" );
+  if ( !defaultTemplateDir.exists() )
+    return;
+  QFileInfoList defaultTemplateFiles = defaultTemplateDir.entryInfoList( QDir::Files );
+  QFileInfoList::const_iterator fileIt = defaultTemplateFiles.constBegin();
+  for ( ; fileIt != defaultTemplateFiles.constEnd(); ++fileIt )
+    mDefaultTemplateMap.insert( fileIt->baseName(), fileIt->absoluteFilePath() );
+    if ( mComposerListWidget->findItems( fileIt->baseName(), Qt::MatchExactly ).size() < 1 )
+      QListWidgetItem* item = new QListWidgetItem( fileIt->baseName(), mComposerListWidget );
+      mItemComposerMap.insert( item, 0 );
 void QgsComposerManager::on_mAddButton_clicked()
@@ -110,13 +133,48 @@
     return;
-  //delete composer
   QMap<QListWidgetItem*, QgsComposer*>::iterator it = mItemComposerMap.find( item );
   if ( it != mItemComposerMap.end() )
-    it.value()->show();
-    it.value()->activate();
-    it.value()->stackUnder( this );
+    QgsComposer* c = 0;
+    if ( it.value() ) //a normal composer
+      c = it.value();
+      it.value()->show();
+    else //create composer from default template
+      QMap<QString, QString>::const_iterator templateIt = mDefaultTemplateMap.find( it.key()->text() );
+      if ( templateIt == mDefaultTemplateMap.constEnd() )
+        return;
+      QDomDocument templateDoc;
+      QFile templateFile( templateIt.value() );
+      if ( !templateFile.open( QIODevice::ReadOnly ) )
+        return;
+      if ( !templateDoc.setContent( &templateFile, false ) )
+        return;
+      c = mQgisApp->createNewComposer();
+      c->setTitle( it.key()->text() );
+      if ( c )
+        c->readXML( templateDoc );
+    if ( c )
+      c->show();
+      c->activate();
+      c->stackUnder( this );
@@ -157,3 +215,19 @@
     it.value()->setTitle( item->text() );
+void QgsComposerManager::on_mComposerListWidget_currentItemChanged( QListWidgetItem* current, QListWidgetItem* previous )
+  if ( !current )
+    return;
+  if ( mDefaultTemplateMap.contains( current->text() ) )
+    mRenamePushButton->setEnabled( false );
+  else
+    mRenamePushButton->setEnabled( true );
Modified: trunk/qgis/src/app/composer/qgscomposermanager.h
--- trunk/qgis/src/app/composer/qgscomposermanager.h	2010-04-03 10:39:59 UTC (rev 13227)
+++ trunk/qgis/src/app/composer/qgscomposermanager.h	2010-04-03 15:49:48 UTC (rev 13228)
@@ -35,8 +35,12 @@
   private:
     QgisApp* mQgisApp;
-    /**Stores the relation between items and composer pointers */
+    /**Stores the relation between items and composer pointers. A 0 pointer for the composer means that
+      this composer needs to be created from a default template*/
     QMap<QListWidgetItem*, QgsComposer*> mItemComposerMap;
+    /**Key: name of the default template (=filename without suffix). Value: absolute path of the template*/
+    QMap<QString, QString > mDefaultTemplateMap;
     /**Enters the composer instances and created the item-composer map*/
     void initialize();
@@ -46,6 +50,7 @@
     void on_mShowPushButton_clicked();
     void on_mRenamePushButton_clicked();
     void on_mComposerListWidget_itemChanged( QListWidgetItem * item );
+    void on_mComposerListWidget_currentItemChanged( QListWidgetItem* current, QListWidgetItem* previous );
 #endif // QGSCOMPOSERMANAGER_H
More information about the QGIS-commit mailing list
