[QGIS Commit] r13352 - in trunk/qgis/src: core core/symbology-ng
gui/symbology-ng
svn_qgis at osgeo.org
Fri Apr 23 11:06:53 EDT 2010
Author: wonder
Date: 2010-04-23 11:06:52 -0400 (Fri, 23 Apr 2010)
New Revision: 13352
trunk/qgis/src/core/qgsapplication.cpp
trunk/qgis/src/core/qgsapplication.h
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h
trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp
Added QgsApplication::iconPath utility function (and removed its declaration from QgsSymbolLayerV2Utils)
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp 2010-04-23 10:36:34 UTC (rev 13351)
+++ trunk/qgis/src/core/qgsapplication.cpp 2010-04-23 15:06:52 UTC (rev 13352)
@@ -159,6 +159,18 @@
return ":/images/themes/" + mThemeName + "/";
+QString QgsApplication::iconPath( QString iconFile )
+ // try active theme
+ QString path = activeThemePath();
+ if ( QFile::exists( path + iconFile ) )
+ return path + iconFile;
+ // use default theme
+ return defaultThemePath() + iconFile;
Set the theme path to the specified theme.
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h 2010-04-23 10:36:34 UTC (rev 13351)
+++ trunk/qgis/src/core/qgsapplication.h 2010-04-23 15:06:52 UTC (rev 13352)
@@ -131,6 +131,11 @@
//! Returns the path to the default theme directory.
static const QString defaultThemePath();
+ //! Returns path to the desired icon file.
+ //! First it tries to use the active theme path, then default theme path
+ //! @note Added in 1.5
+ static QString iconPath( QString iconFile );
//! Returns the path to user's style. Added in QGIS 1.4
static const QString userStyleV2Path();
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h 2010-04-23 10:36:34 UTC (rev 13351)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h 2010-04-23 15:06:52 UTC (rev 13352)
@@ -79,8 +79,6 @@
/**Creates a render context for a pixel based device*/
static QgsRenderContext createRenderContext( QPainter* p );
- static QString iconPath( QString iconFile );
/**Multiplies opacity of image pixel values with a (global) transparency value*/
static void multiplyImageOpacity( QImage* image, qreal alpha );
Modified: trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp 2010-04-23 10:36:34 UTC (rev 13351)
+++ trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp 2010-04-23 15:06:52 UTC (rev 13352)
@@ -19,19 +19,7 @@
#include "qgslogger.h"
-static QString iconPath( QString iconFile )
- // try active theme
- QString path = QgsApplication::activeThemePath();
- if ( QFile::exists( path + iconFile ) )
- return path + iconFile;
- // use default theme
- return QgsApplication::defaultThemePath() + iconFile;
QgsStyleV2ManagerDialog::QgsStyleV2ManagerDialog( QgsStyleV2* style, QWidget* parent )
: QDialog( parent ), mStyle( style ), mModified( false )
@@ -39,9 +27,9 @@
setupUi( this );
// setup icons
- btnAddItem->setIcon( QIcon( iconPath( "symbologyAdd.png" ) ) );
- btnEditItem->setIcon( QIcon( iconPath( "symbologyEdit.png" ) ) );
- btnRemoveItem->setIcon( QIcon( iconPath( "symbologyRemove.png" ) ) );
+ btnAddItem->setIcon( QIcon( QgsApplication::iconPath( "symbologyAdd.png" ) ) );
+ btnEditItem->setIcon( QIcon( QgsApplication::iconPath( "symbologyEdit.png" ) ) );
+ btnRemoveItem->setIcon( QIcon( QgsApplication::iconPath( "symbologyRemove.png" ) ) );
connect( this, SIGNAL( finished( int ) ), this, SLOT( onFinished() ) );
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp 2010-04-23 10:36:34 UTC (rev 13351)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp 2010-04-23 15:06:52 UTC (rev 13352)
@@ -57,19 +57,7 @@
static bool _initWidgetFunction( QString name, QgsSymbolLayerV2WidgetFunc f )
QgsSymbolLayerV2Registry* reg = QgsSymbolLayerV2Registry::instance();
@@ -119,11 +107,11 @@
setupUi( this );
// setup icons
- btnAddLayer->setIcon( QIcon( iconPath( "symbologyAdd.png" ) ) );
- btnRemoveLayer->setIcon( QIcon( iconPath( "symbologyRemove.png" ) ) );
- btnLock->setIcon( QIcon( iconPath( "symbologyLock.png" ) ) );
- btnUp->setIcon( QIcon( iconPath( "symbologyUp.png" ) ) );
- btnDown->setIcon( QIcon( iconPath( "symbologyDown.png" ) ) );
+ btnAddLayer->setIcon( QIcon( QgsApplication::iconPath( "symbologyAdd.png" ) ) );
+ btnRemoveLayer->setIcon( QIcon( QgsApplication::iconPath( "symbologyRemove.png" ) ) );
+ btnLock->setIcon( QIcon( QgsApplication::iconPath( "symbologyLock.png" ) ) );
+ btnUp->setIcon( QIcon( QgsApplication::iconPath( "symbologyUp.png" ) ) );
+ btnDown->setIcon( QIcon( QgsApplication::iconPath( "symbologyDown.png" ) ) );
// set widget functions
// (should be probably moved somewhere else)
