[QGIS Commit] r13353 - trunk/qgis/python/core
svn_qgis at osgeo.org
Fri Apr 23 11:20:25 EDT 2010
Author: wonder
Date: 2010-04-23 11:20:24 -0400 (Fri, 23 Apr 2010)
New Revision: 13353
trunk/qgis/python/core/qgsapplication.sip
trunk/qgis/python/core/symbology-ng-core.sip
Added python wrappers from QgsSymbolLayerV2Utils
Modified: trunk/qgis/python/core/qgsapplication.sip
--- trunk/qgis/python/core/qgsapplication.sip 2010-04-23 15:06:52 UTC (rev 13352)
+++ trunk/qgis/python/core/qgsapplication.sip 2010-04-23 15:20:24 UTC (rev 13353)
@@ -104,6 +104,12 @@
//! Returns the path to the authors file.
static const QString authorsFilePath();
+ /** Returns the path to the contributors file.
+ * Contributors are people who have submitted patches
+ * but don't have svn write access.
+ * @note this function was added in version 1.3 */
+ static const QString contributorsFilePath();
/**Returns the path to the sponsors file.
@note this function was added in version 1.2*/
static const QString sponsorsFilePath();
@@ -160,12 +166,6 @@
//! @note deprecated
static const QString svgPath();
- //! Returns the path to user's style. Added in QGIS 1.4
- static const QString userStyleV2Path();
- //! Returns the path to default style (works as a starting point). Added in QGIS 1.4
- static const QString defaultStyleV2Path();
//! Returns the path to the application prefix directory.
static const QString prefixPath();
@@ -181,6 +181,17 @@
//! Returns the path to the default theme directory.
static const QString defaultThemePath();
+ //! Returns path to the desired icon file.
+ //! First it tries to use the active theme path, then default theme path
+ //! @note Added in 1.5
+ static QString iconPath( QString iconFile );
+ //! Returns the path to user's style. Added in QGIS 1.4
+ static const QString userStyleV2Path();
+ //! Returns the path to default style (works as a starting point). Added in QGIS 1.4
+ static const QString defaultStyleV2Path();
//! Alters prefix path - used by 3rd party apps
static void setPrefixPath(const QString thePrefixPath, bool useDefaultPaths = FALSE);
Modified: trunk/qgis/python/core/symbology-ng-core.sip
--- trunk/qgis/python/core/symbology-ng-core.sip 2010-04-23 15:06:52 UTC (rev 13352)
+++ trunk/qgis/python/core/symbology-ng-core.sip 2010-04-23 15:20:24 UTC (rev 13353)
@@ -900,3 +900,70 @@
+typedef QMap<QString, QgsSymbolV2* > QgsSymbolV2Map;
+class QgsSymbolLayerV2Utils
+%TypeHeaderCode
+#include <qgssymbollayerv2utils.h>
+%End
+ public:
+ static QString encodeColor( QColor color );
+ static QColor decodeColor( QString str );
+ static QString encodePenStyle( Qt::PenStyle style );
+ static Qt::PenStyle decodePenStyle( QString str );
+ static QString encodePenJoinStyle( Qt::PenJoinStyle style );
+ static Qt::PenJoinStyle decodePenJoinStyle( QString str );
+ static QString encodePenCapStyle( Qt::PenCapStyle style );
+ static Qt::PenCapStyle decodePenCapStyle( QString str );
+ static QString encodeBrushStyle( Qt::BrushStyle style );
+ static Qt::BrushStyle decodeBrushStyle( QString str );
+ static QString encodePoint( QPointF point );
+ static QPointF decodePoint( QString str );
+ static QString encodeRealVector( const QVector<qreal>& v );
+ static QVector<qreal> decodeRealVector( const QString& s );
+ static QString encodeOutputUnit( QgsSymbolV2::OutputUnit unit );
+ static QgsSymbolV2::OutputUnit decodeOutputUnit( QString str );
+ static QIcon symbolPreviewIcon( QgsSymbolV2* symbol, QSize size );
+ static QIcon symbolLayerPreviewIcon( QgsSymbolLayerV2* layer, QgsSymbolV2::OutputUnit u, QSize size );
+ static QIcon colorRampPreviewIcon( QgsVectorColorRampV2* ramp, QSize size );
+ static QPixmap symbolPreviewPixmap( QgsSymbolV2* symbol, QSize size );
+ static QPixmap colorRampPreviewPixmap( QgsVectorColorRampV2* ramp, QSize size );
+ static QgsSymbolV2* loadSymbol( QDomElement& element ) /Factory/;
+ static QgsSymbolLayerV2* loadSymbolLayer( QDomElement& element ) /Factory/;
+ static QDomElement saveSymbol( QString name, QgsSymbolV2* symbol, QDomDocument& doc, QgsSymbolV2Map* subSymbols = NULL );
+ static QgsStringMap parseProperties( QDomElement& element );
+ static void saveProperties( QgsStringMap props, QDomDocument& doc, QDomElement& element );
+ static QgsSymbolV2Map loadSymbols( QDomElement& element ) /Factory/;
+ static QDomElement saveSymbols( QgsSymbolV2Map& symbols, QString tagName, QDomDocument& doc );
+ static void clearSymbolMap( QgsSymbolV2Map& symbols );
+ static QgsVectorColorRampV2* loadColorRamp( QDomElement& element ) /Factory/;
+ static QDomElement saveColorRamp( QString name, QgsVectorColorRampV2* ramp, QDomDocument& doc );
+ /**Returns the line width scale factor depending on the unit and the paint device*/
+ static double lineWidthScaleFactor( QgsRenderContext& c, QgsSymbolV2::OutputUnit u );
+ /**Returns scale factor painter units -> pixel dimensions*/
+ static double pixelSizeScaleFactor( QgsRenderContext& c, QgsSymbolV2::OutputUnit u );
+ /**Creates a render context for a pixel based device*/
+ static QgsRenderContext createRenderContext( QPainter* p );
+ /**Multiplies opacity of image pixel values with a (global) transparency value*/
+ static void multiplyImageOpacity( QImage* image, qreal alpha );
