[QGIS Commit] r14039 - in docs/trunk/english_us/user_guide: .
features_at_a_glance_screenies getting_started_screenies
working_with_vector_screenies
svn_qgis at osgeo.org
Tue Aug 10 05:28:41 EDT 2010
Author: dassau
Date: 2010-08-10 09:28:41 +0000 (Tue, 10 Aug 2010)
New Revision: 14039
Added:
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_angle.png
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_area.png
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_line.png
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/proxy-settings.png
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
docs/trunk/english_us/user_guide/getting_started.tex
docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
docs/trunk/english_us/user_guide/working_with_vector.tex
docs/trunk/english_us/user_guide/working_with_vector_screenies/addvectorlayerdialog.png
more feature updates
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-08-10 07:34:11 UTC (rev 14038)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-08-10 09:28:41 UTC (rev 14039)
@@ -305,23 +305,23 @@
\dropmenuopttwo{mActionSelect}{Select Features}
\> \> \dropmenucheck{Attributes} \\
-\dropmenuopttwo{mActionDeselectAll}{Deselect Features}
+\dropmenuopttwo{mActionDeselectAll}{Deselect Features from all layers}
\dropmenuopttwo{mActionIdentify}{Identify Features}
- \> \keystroke{I}
+ \> \keystroke{Ctrl-Alt-I}
\dropmenuopttwo{mActionMeasure}{Measure Line}
- \> \keystroke{M}
+ \> \keystroke{Ctrl-Alt-M}
\dropmenuopttwo{mActionMeasureArea}{Measure Area}
- \> \keystroke{J}
+ \> \keystroke{Ctrl-Alt-J}
\dropmenuopttwo{mActionMeasureAngle}{Measure Angle}
\dropmenuopttwo{mActionOpenTable}{Zoom Full}
- \> \keystroke{F}
+ \> \keystroke{Ctrl-Alt-F}
\> \> \dropmenucheck{Map Navigation} \\
\dropmenuopttwo{mActionZoomToLayer}{Zoom To Layer}
@@ -346,7 +346,7 @@
\> see Section \ref{sec:bookmarks}
\dropmenuopttwo{mActionShowBookmarks}{Show Bookmarks}
- \> \keystroke{B}
+ \> \keystroke{Ctrl-Alt-B}
\dropmenuopttwo{mActionDraw}{Refresh}
@@ -395,6 +395,9 @@
\dropmenuopttwo{mActionOpenTable}{Open Attribute Table}
+\dropmenuopttwo{mActionFileSave}{Save edits}
+ \> \dropmenucheck{Digitizing} \\
\dropmenuopttwo{mActionToggleEditing}{Toggle editing}
@@ -427,7 +430,7 @@
\> \dropmenucheck{Manage Layers} \\
\dropmenuopttwo{mActionShowAllLayers}{Show All Layers}
- \> \keystroke{Ctrl+Shift+S}
+ \> \keystroke{Ctrl+Shift+U}
\dropmenuopttwo{labeling}{Labeling}
@@ -448,27 +451,20 @@
\mainmenuopt{Toggle Full Screen Mode}
+ \>\keystroke{Ctrl-F}
\dropmenuopttwo{mActionProjectProperties}{Project Properties}
- \> \keystroke{P}
- \> see Section \ref{sec:projects}
-\dropmenuopttwo{mActionOptions}{Options}
- \> \> see Section \ref{subsec:gui_options}
+ \> \keystroke{Ctrl-Alt-P}
+ \> see Section \ref{sec:projects} \\
+\dropmenuopttwo{mActionCustomProjection}{Custom CRS}
+ \> \> see Section \ref{sec:customprojections} \\
+\mainmenuopt{Style Manager}
\dropmenuopttwo{mActionOptions}{Configure shortcuts}
-\mainmenuopt{Style Manager}
-\dropmenuopttwo{mActionCustomProjection}{Custom CRS}
- \> \> see Section \ref{sec:customprojections}
+\dropmenuopttwo{mActionOptions}{Options}
+ \> \> see Section \ref{subsec:gui_options} \\
\end{tabbing}
\item \mainmenuopt{Plugins} - (Futher menu items are added by plugins as they are loaded.)
@@ -868,14 +864,18 @@
cross-shaped. Click to draw the first segment of the angle you wish to
measure, then move the the cursor to draw the desired angle. The measure
is displayed in a popup dialog.
\begin{figure}[ht]
\centering
\subfloat[Measure lines] {\label{subfig:measure_line}\includegraphics[clip=true, width=0.3\textwidth]{measure_line}}
- \hspace{1cm}
+ \hspace{0.33cm}
\subfloat[Measure areas]{\label{subfig:measure_area}\includegraphics[clip=true, width=0.3\textwidth]{measure_area}}
+ \hspace{0.33cm}
+ \subfloat[Measure angles]{\label{subfig:measure_angle}\includegraphics[clip=true, width=0.3\textwidth]{measure_angle}}
\caption{Measure tools in action \nixcaption} \label{fig:measure}
\end{figure}
\section{Projects}\label{sec:projects}\index{projects}
The state of your QGIS session is considered a Project. QGIS
@@ -966,16 +966,18 @@
\item \checkbox{Promt to save project changes when required}
\item \checkbox{Warn when opening a project file saved with an older version of QGIS}
\item Change Selection and backgroud Color
-\item Change the icon theme (choose between default, classic, gis and nkids)
+\item Change the icon theme (choose between default, classic, gis and newgis)
\item \checkbox{Capitalise layer names in legend}
\item \checkbox{Display classification attribute names in legend}
+\item \checkbox{Create raster icons in legend}
\item \checkbox{Hide splash screen at startup}
\item \checkbox{Open identify results in a dock window (QGIS restart
required)}
\item \checkbox{Open attribute table in a dock window}
\item \checkbox{Add PostGIS layers with double click and select in extended mode}
-% \item Define attribute table behavior (choose between show all features, show
-% selected features and show features in current canvas)
+\item \checkbox{Add new layers to selected group}
+\item Attribute table behavior (choose between Show all features (default), Show selected features,
+show features in current canvas)
\end{itemize}
\minisec{Rendering \& SVG Tab}
@@ -988,8 +990,7 @@
performance}
\item \checkbox{Fix problems with incorrectly filled polygons}
\item \checkbox{Use new generation symbology for rendering}
-\item Add and remove path(s) to search for Scalable Vector Graphics (SVG)
-symbols
+\item Add/remove path(s) to search for Scalable Vector Graphics (SVG) symbols
\end{itemize}
Additionally you can define wether to save the path for svg textures
@@ -1006,10 +1007,12 @@
layers (see the Project properties section under: \ref{sec:projects} to set
which layers are identifiable) will be shown with the Identify tool.
\item \checkbox{Open feature form, if a single feature is identified}
-\item Define search radius as a percentage of the map width
+\item Define search radius for identifying and displaying map tips as a
+percentage of the map width
\item Define ellipsoid for distance calculations
\item Define rubberband color for measure tools
-\item Define preferred measurement units (meters or feet)
+\item \radiobuttonon{Define preferred measurement units (meters or feet)}
+\item \radiobuttonon{Define preferred angle units (Degrees, Radians or Gon)}
\item Define Mouse wheel action (Zoom, Zoom and recenter, Zoom to mouse
cursor, Nothing)
\item Define Zoom factor for wheel mouse
@@ -1025,22 +1028,22 @@
\minisec{Digitizing Tab}
\begin{itemize}
-\item Define Rubberband Color and line width for Digitizing
+\item Define Rubberband line color and line width
\item Define default snap mode (to vertex, to segment, to vertex and segment)
\item Define default snapping tolerance in map units or pixel
\item Define search radius for vertex edits in map units or pixel
\item \checkbox{Show markers only for selected features}
\item Define vertex marker style (cross (default), semi transparent circle or
-none) and size
+none) and vertex marker size
\item \checkbox{Suppress attributes pop-up windows after each created feature}
\end{itemize}
\minisec{CRS Tab}
\begin{itemize}
-\item \checkbox{Prompt for Coordinate Reference System (CRS)}
-\item \checkbox{Project wide default Coordinate Reference System (CRS) will be used}
-\item \checkbox{Global default Coordinate Reference System (CRS) displayed below will be used}
+\item \radiobuttonoff{Prompt for Coordinate Reference System (CRS)}
+\item \radiobuttonoff{Project wide default Coordinate Reference System (CRS) will be used}
+\item \radiobuttonon{Global default Coordinate Reference System (CRS) displayed below will be used}
\item Select global default Coordinate Reference System (CRS)
\end{itemize}
Added: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_angle.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_angle.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_area.png
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_line.png
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/proxy-settings.png
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/startup.png
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex 2010-08-10 07:34:11 UTC (rev 14038)
+++ docs/trunk/english_us/user_guide/getting_started.tex 2010-08-10 09:28:41 UTC (rev 14039)
@@ -17,12 +17,12 @@
available for MS Windows and Mac OS X. For many flavors of GNU/Linux binary
packages (rpm and deb) or software repositories to add to your installation
manager are provided. Get the latest information on binary packages at the
-\qg website at \url{http://\qg.osgeo.org/download/}.
+\qg website at \url{http://qgis.osgeo.org/download/}.
\minisec{Installation from source}
If you need to build \qg from source, please refer to the coding and
-compiling guide available at \url{http://\qg.osgeo.org/documentation/}.
+compiling guide available at \url{http://qgis.osgeo.org/documentation/}.
The installation instructions are also distributed with the \qg source
code.
@@ -39,8 +39,7 @@
during the initial \qg installation, you can either
\begin{itemize}[label=--]
\item use GIS data that you already have;
-\item download the sample data from the \qg website
- \url{http://\qg.osgeo.org/download}; or
+\item download the sample data from the qgis website at \url{http://qgis.osgeo.org/download}; or
\item uninstall \qg and reinstall with the data download option checked, only if
the above solutions are unsuccessful.
\end{itemize}
@@ -48,10 +47,10 @@
\nix \osx For GNU/Linux and Mac OSX there are not yet dataset installation
packages available as rpm, deb or dmg. To use the sample dataset download the
file \filename{\qg\_sample\_data} as ZIP or TAR archive from
-\url{http://download.osgeo.org/\qg/data/} and unzip or untar the archive on
+\url{http://download.osgeo.org/qgis/data/} and unzip or untar the archive on
your system. The Alaska dataset includes all GIS data that are used as
examples and screenshots in the user guide, and also includes a small GRASS
-database. The projection for the \qg sample dataset is Alaska Albers Equal
+database. The projection for the qgis sample dataset is Alaska Albers Equal
Area with unit feet. The EPSG code is 2964.
\begin{verbatim}
Modified: docs/trunk/english_us/user_guide/getting_started_screenies/simple_session.png
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2010-08-10 07:34:11 UTC (rev 14038)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2010-08-10 09:28:41 UTC (rev 14039)
@@ -210,10 +210,6 @@
\hline Database \index{PostgreSQL!database} & Name of the database. \\
\hline Port \index{PostgreSQL!port}& Port number the PostgreSQL database
server listens on. The default port is 5432.\\
-\hline Username \index{PostgreSQL!username}& User name used to login to the
-database. \\
-\hline Password \index{PostgreSQL!password}& Password used with
-\textsl{Username} to connect to the database.\\
\hline SSL mode \index{PostgreSQL!sslmode}& How the SSL connection will be negotiated with the server. These are the options:
\begin {itemize}
\item disable: only try an unencrypted SSL connection;
@@ -222,6 +218,10 @@
\item require: only try an SSL connection.
\end {itemize}
Note that massive speedups in PostGIS layer rendering can be achieved by disabling SSL in the connection editor. \\
+\hline Username \index{PostgreSQL!username}& User name used to login to the
+database. \\
+\hline Password \index{PostgreSQL!password}& Password used with
+\textsl{Username} to connect to the database.\\
\hline
\end{tabular}
\end{table}
@@ -229,9 +229,11 @@
Optional you can activate follwing checkboxes:
+\item \checkbox{Save Username}
\item \checkbox{Save Password}
\item \checkbox{Only look in the geometry\_columns table}
\item \checkbox{Only look in the 'public' schema}
+\item \checkbox{Use estimated table metadata}
\end{itemize}
Once all parameters and options are set, you can test the connection by
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/addvectorlayerdialog.png
