[QGIS Commit] r14040 - in docs/trunk/english_us/user_guide: .
plugins_decorations_images plugins_ftools_images
svn_qgis at osgeo.org
Tue Aug 10 06:09:53 EDT 2010
Author: dassau
Date: 2010-08-10 10:09:53 +0000 (Tue, 10 Aug 2010)
New Revision: 14040
Added:
docs/trunk/english_us/user_guide/plugins_ftools_images/merge_shapes.png
docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
docs/trunk/english_us/user_guide/plugins_ftools.tex
docs/trunk/english_us/user_guide/qgis_style.sty
docs/trunk/english_us/user_guide/user_guide.tex
docs/trunk/english_us/user_guide/working_with_ogc.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
more updates
Modified: docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/plugins_ftools.tex
--- docs/trunk/english_us/user_guide/plugins_ftools.tex 2010-08-10 09:28:41 UTC (rev 14039)
+++ docs/trunk/english_us/user_guide/plugins_ftools.tex 2010-08-10 10:09:53 UTC (rev 14040)
@@ -158,6 +158,9 @@
table of another layer and exported as a shapefile \\
\hline \includegraphics[width=0.7cm]{split_layer} & Split vector layer &
Split input layer into multiple separate layers based on input field. \\
+ \hline \includegraphics[width=0.7cm]{merge_shapes} & Merge shapefiles &
+Merge several shapefiles within a folder into a new shapefile based on the
+layer type (point, line, area) \\
\hline
\end{tabular}
\caption{fTools Data management tools}\label{tab:fTool_data_management}
Added: docs/trunk/english_us/user_guide/plugins_ftools_images/merge_shapes.png
Property changes on: docs/trunk/english_us/user_guide/plugins_ftools_images/merge_shapes.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: docs/trunk/english_us/user_guide/qgis_style.sty
--- docs/trunk/english_us/user_guide/qgis_style.sty 2010-08-10 09:28:41 UTC (rev 14039)
+++ docs/trunk/english_us/user_guide/qgis_style.sty 2010-08-10 10:09:53 UTC (rev 14040)
@@ -130,7 +130,7 @@
\def\OLD{1.4.0\xspace}
\def\VERYOLD{1.0\xspace}
-%%% Shortcuts
+%%% Shortcuts (don't use it within \url strings)
\newcommand{\qg}{QGIS\xspace}
\newcommand{\QG}{Quantum GIS\xspace}
\newcommand{\pg}{PostGIS\xspace}
Modified: docs/trunk/english_us/user_guide/user_guide.tex
--- docs/trunk/english_us/user_guide/user_guide.tex 2010-08-10 09:28:41 UTC (rev 14039)
+++ docs/trunk/english_us/user_guide/user_guide.tex 2010-08-10 10:09:53 UTC (rev 14040)
@@ -56,7 +56,6 @@
\input{plugins_quick_print}
\input{other_core_plugins}
\input{external_plugins}
-\input{plugins_ftools}
\input{plugins_table_manager}
\input{plugins_raster_algebra}
\input{plugins_gdaltools}
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex 2010-08-10 09:28:41 UTC (rev 14039)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex 2010-08-10 10:09:53 UTC (rev 14040)
@@ -260,9 +260,9 @@
\index{WMS!search}
\index{OGC!search}
-Within QGIS 1.1.X you can search for WMS-servers.
-Figure \ref{fig:searchtab} shows the newly created \tab{search}-tab with
-the \dialog{Add Layer(s) from a Server}-dialog.
+Within QGIS you can search for WMS-servers. Figure \ref{fig:searchtab} shows
+the newly created \tab{search}-tab with the \dialog{Add Layer(s) from a
+Server}-dialog.
\begin{figure}[ht]
\centering
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2010-08-10 09:28:41 UTC (rev 14039)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2010-08-10 10:09:53 UTC (rev 14040)
@@ -463,7 +463,7 @@
A workaround is to transform the longitude values using PostGIS and the
\textbf{ST\textunderscore Shift\textunderscore Longitude}
-\footnote{\url{http://postgis.refractions.net/documentation/manual-1.4/ST_Shift_Longitude.html}}
+\footnote{\url{http://postgis.refractions.net/documentation/manual-1.4/ST\_Shift\_Longitude.html}}
function. This function reads every point/vertex in every component of every
feature in a geometry, and if the longitude coordinate is < \degrees{0} adds
\degrees{360} to it. The result would be a \degrees{0} - \degrees{360} version of
@@ -1142,7 +1142,7 @@
\filename{lakes} layer. First we need to determine the URL needed to perform a search on a
keyword. This is easily done by just going to Google and doing a simple
search, then grabbing the URL from the address bar in your browser. From this
-little effort we see that the format is: \url{http://google.com/search?q=\qg},
+little effort we see that the format is: \url{http://google.com/search?q=qgis},
where \usertext{\qg} is the search term. Armed with this information, we can
proceed:
