[QGIS Commit] r12671 - in trunk/qgis/src/plugins/grass: . modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jan 5 08:32:39 EST 2010
Author: rblazek
Date: 2010-01-05 08:32:37 -0500 (Tue, 05 Jan 2010)
New Revision: 12671
   trunk/qgis/src/plugins/grass/modules-common/v.out.ascii.qgm
   trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
   trunk/qgis/src/plugins/grass/qgsgrassmodule.h
added support for advanced options and example use in v.out.ascii
Modified: trunk/qgis/src/plugins/grass/modules-common/v.out.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.out.ascii.qgm	2010-01-04 14:43:23 UTC (rev 12670)
+++ trunk/qgis/src/plugins/grass/modules-common/v.out.ascii.qgm	2010-01-05 13:32:37 UTC (rev 12671)
@@ -5,4 +5,5 @@
 	<option key="input" />
 	<option key="format"/>
 	<file key="output" type="new" />
+	<option key="fs" advanced="yes" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2010-01-04 14:43:23 UTC (rev 12670)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2010-01-05 13:32:37 UTC (rev 12671)
@@ -372,7 +372,31 @@
   //transfers frame ownership so no need to call delete
   mypScrollArea->setWidget( mypInnerFrame );
   mypScrollArea->setWidgetResizable( true );
-  QVBoxLayout *layout = new QVBoxLayout( mypInnerFrame );
+  QVBoxLayout *mypInnerFrameLayout = new QVBoxLayout( mypInnerFrame );
+  // Add frames for simple/advanced options
+  QFrame * mypSimpleFrame = new QFrame();
+  mypSimpleFrame->setFrameShape( QFrame::NoFrame );
+  mypSimpleFrame->setFrameShadow( QFrame::Plain );
+  mAdvancedFrame.setFrameShape( QFrame::NoFrame );
+  mAdvancedFrame.setFrameShadow( QFrame::Plain );
+  QFrame * mypAdvancedPushButtonFrame = new QFrame();
+  QHBoxLayout *mypAdvancedPushButtonFrameLayout = new QHBoxLayout( mypAdvancedPushButtonFrame );
+  connect( &mAdvancedPushButton, SIGNAL( clicked() ), this, SLOT( switchAdvanced() ) );
+  mypAdvancedPushButtonFrameLayout->addWidget( &mAdvancedPushButton );
+  mypAdvancedPushButtonFrameLayout->addStretch(1);
+  mypInnerFrameLayout->addWidget( mypSimpleFrame );
+  mypInnerFrameLayout->addWidget( mypAdvancedPushButtonFrame );
+  mypInnerFrameLayout->addWidget( &mAdvancedFrame );
+  mypInnerFrameLayout->addStretch(1);
+  // Hide advanced and set butto next
+  switchAdvanced();
+  QVBoxLayout *mypSimpleLayout = new QVBoxLayout( mypSimpleFrame );
+  QVBoxLayout *mypAdvancedLayout = new QVBoxLayout( &mAdvancedFrame );
+  QVBoxLayout *layout;
   while ( !n.isNull() )
     QDomElement e = n.toElement();
@@ -380,6 +404,13 @@
       QString optionType = e.tagName();
       QgsDebugMsg( "optionType = " + optionType );
+      if ( e.attribute( "advanced", "no" ) == "yes" )
+        layout = mypAdvancedLayout;
+      } else {
+        layout = mypSimpleLayout;
       QString key = e.attribute( "key" );
       QgsDebugMsg( "key = " + key );
@@ -474,6 +505,11 @@
     n = n.nextSibling();
+  if ( mypAdvancedLayout->count() == 0 )
+    mypAdvancedPushButtonFrame->hide();
   // Create list of flags
   n = gDocElem.firstChild();
@@ -498,6 +534,17 @@
   layout->addStretch();
+void QgsGrassModuleStandardOptions::switchAdvanced()
+   if ( mAdvancedFrame.isHidden() ) {
+      mAdvancedFrame.show();
+      mAdvancedPushButton.setText ( tr("<< Hide advanced options") );
+   } else {
+      mAdvancedFrame.hide();
+      mAdvancedPushButton.setText ( tr("Show advanced options >>") );
 QStringList QgsGrassModuleStandardOptions::arguments()
   QStringList arg;
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.h
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.h	2010-01-04 14:43:23 UTC (rev 12670)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.h	2010-01-05 13:32:37 UTC (rev 12671)
@@ -235,8 +235,10 @@
  *  \brief Widget with GRASS standard options.
-class QgsGrassModuleStandardOptions: public QgsGrassModuleOptions, QWidget
+class QgsGrassModuleStandardOptions: QWidget, public QgsGrassModuleOptions
+  Q_OBJECT
   public:
     //! Constructor
     QgsGrassModuleStandardOptions(
@@ -266,6 +268,10 @@
     bool inputRegion( struct Cell_head *window, bool all );
     QStringList flagNames() { return mFlagNames; }
+  public slots:
+    // ! Show/hide advanced options
+    void switchAdvanced();
   private:
     //! Name of module executable
     QString mXName;
@@ -281,6 +287,12 @@
     //! Use of region defined in qgm
     bool mUsesRegion;
+    // ! Advanced options switch button
+    QPushButton mAdvancedPushButton;
+    // ! Advanced options frame
+    QFrame mAdvancedFrame;
 /****************** QgsGrassModuleGroupBoxItem ************************/
More information about the QGIS-commit mailing list
