[QGIS Commit] r12687 - trunk/qgis/src/providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jan 7 07:03:33 EST 2010
Author: rblazek
Date: 2010-01-07 07:03:33 -0500 (Thu, 07 Jan 2010)
New Revision: 12687
   trunk/qgis/src/providers/grass/qgsgrass.cpp
temporal fix for 1900
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp	2010-01-07 11:01:44 UTC (rev 12686)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp	2010-01-07 12:03:33 UTC (rev 12687)
@@ -90,6 +90,10 @@
   // Init GRASS libraries (required)
   G_no_gisinit();  // Doesn't check write permissions for mapset compare to G_gisinit("libgrass++");
+  // I think that mask should not be used in QGIS as it can only confuse people,
+  // anyway, I don't think anybody is using MASK
+  G_suppress_masking();
   // Set program name
   G_set_program_name( "QGIS" );
@@ -594,9 +598,15 @@
     // Reinitialize GRASS
     G__setenv(( char * ) "GISRC", ( char * ) "" );
-    G__setenv(( char * ) "GISDBASE", ( char * ) "" );
-    G__setenv(( char * ) "LOCATION_NAME", ( char * ) "" );
-    G__setenv(( char * ) "MAPSET", ( char * ) "" );
+    // Temporarily commented because of
+    //   http://trac.osgeo.org/qgis/ticket/1900
+    //   http://trac.osgeo.org/gdal/ticket/3313
+    // it can be uncommented once GDAL with patch gets depoyed (probably GDAL 1.8)
+    //G__setenv(( char * ) "GISDBASE", ( char * ) "" );
+    //G__setenv(( char * ) "LOCATION_NAME", ( char * ) "" );
+    //G__setenv(( char * ) "MAPSET", ( char * ) "" );
     defaultGisdbase = "";
     defaultLocation = "";
     defaultMapset = "";
More information about the QGIS-commit mailing list
