[QGIS Commit] r12688 - in trunk/qgis/src: app/composer
core/composer ui
svn_qgis at osgeo.org
Thu Jan 7 08:29:24 EST 2010
Author: mhugent
Date: 2010-01-07 08:29:23 -0500 (Thu, 07 Jan 2010)
New Revision: 12688
trunk/qgis/src/app/composer/qgscomposertablewidget.cpp
trunk/qgis/src/app/composer/qgscomposertablewidget.h
trunk/qgis/src/core/composer/qgscomposertable.cpp
trunk/qgis/src/core/composer/qgscomposertable.h
trunk/qgis/src/ui/qgscomposertablewidgetbase.ui
More options for composer table
Modified: trunk/qgis/src/app/composer/qgscomposertablewidget.cpp
--- trunk/qgis/src/app/composer/qgscomposertablewidget.cpp 2010-01-07 12:03:33 UTC (rev 12687)
+++ trunk/qgis/src/app/composer/qgscomposertablewidget.cpp 2010-01-07 13:29:23 UTC (rev 12688)
@@ -21,6 +21,7 @@
#include "qgscomposermap.h"
#include "qgsmaplayerregistry.h"
#include "qgsvectorlayer.h"
+#include <QColorDialog>
#include <QFontDialog>
QgsComposerTableWidget::QgsComposerTableWidget( QgsComposerTable* table ): QWidget( 0 ), mComposerTable( table )
@@ -167,6 +168,50 @@
+void QgsComposerTableWidget::on_mGridStrokeWidthSpinBox_valueChanged( double d )
+ if ( !mComposerTable )
+ return;
+ mComposerTable->setGridStrokeWidth( d );
+ mComposerTable->update();
+void QgsComposerTableWidget::on_mGridColorButton_clicked()
+ return;
+ QColor newColor = QColorDialog::getColor( mComposerTable->gridColor(), 0, tr( "Select grid color" ) );
+ if ( !newColor.isValid() )
+ return;
+ mGridColorButton->setColor( newColor );
+ mComposerTable->setGridColor( newColor );
+void QgsComposerTableWidget::on_mShowGridCheckBox_stateChanged( int state )
+ return;
+ bool showGrid = false;
+ if ( state == Qt::Checked )
+ showGrid = true;
+ mComposerTable->setShowGrid( showGrid );
void QgsComposerTableWidget::updateGuiElements()
@@ -199,6 +244,16 @@
mMaximumColumnsSpinBox->setValue( mComposerTable->maximumNumberOfFeatures() );
mMarginSpinBox->setValue( mComposerTable->lineTextDistance() );
+ mGridStrokeWidthSpinBox->setValue( mComposerTable->gridStrokeWidth() );
+ mGridColorButton->setColor( mComposerTable->gridColor() );
+ if ( mComposerTable->showGrid() )
+ mShowGridCheckBox->setCheckState( Qt::Checked );
+ else
+ mShowGridCheckBox->setCheckState( Qt::Unchecked );
blockAllSignals( false );
@@ -208,6 +263,9 @@
mComposerMapComboBox->blockSignals( b );
mMaximumColumnsSpinBox->blockSignals( b );
mMarginSpinBox->blockSignals( b );
+ mGridColorButton->blockSignals( b );
+ mGridStrokeWidthSpinBox->blockSignals( b );
+ mShowGridCheckBox->blockSignals( b );
Modified: trunk/qgis/src/app/composer/qgscomposertablewidget.h
--- trunk/qgis/src/app/composer/qgscomposertablewidget.h 2010-01-07 12:03:33 UTC (rev 12687)
+++ trunk/qgis/src/app/composer/qgscomposertablewidget.h 2010-01-07 13:29:23 UTC (rev 12688)
@@ -42,8 +42,11 @@
void on_mComposerMapComboBox_currentIndexChanged( int index );
void on_mMaximumColumnsSpinBox_valueChanged( int i );
void on_mMarginSpinBox_valueChanged( double d );
+ void on_mGridStrokeWidthSpinBox_valueChanged( double d );
+ void on_mGridColorButton_clicked();
void on_mHeaderFontPushButton_clicked();
void on_mContentFontPushButton_clicked();
+ void on_mShowGridCheckBox_stateChanged( int state );
#endif // QGSCOMPOSERTABLEWIDGET_H
Modified: trunk/qgis/src/core/composer/qgscomposertable.cpp
--- trunk/qgis/src/core/composer/qgscomposertable.cpp 2010-01-07 12:03:33 UTC (rev 12687)
+++ trunk/qgis/src/core/composer/qgscomposertable.cpp 2010-01-07 13:29:23 UTC (rev 12688)
@@ -22,9 +22,10 @@
#include <QPainter>
-QgsComposerTable::QgsComposerTable( QgsComposition* composition ): QgsComposerItem( composition ), mVectorLayer( 0 ), mComposerMap( 0 ), mMaximumNumberOfFeatures( 5 )
+QgsComposerTable::QgsComposerTable( QgsComposition* composition ): QgsComposerItem( composition ), mVectorLayer( 0 ), mComposerMap( 0 ), \
+ mMaximumNumberOfFeatures( 5 ), mLineTextDistance( 1.0 ), mShowGrid( true ), mGridStrokeWidth( 0.5 ), mGridColor( QColor( 0, 0, 0 ) )
- mLineTextDistance = 1;
QgsComposerTable::~QgsComposerTable()
@@ -70,21 +71,24 @@
//adapt item fram to max width / height
adaptItemFrame( maxColumnWidthMap, attributeList );
+ drawBackground( painter );
//now draw the text
- double currentX = 0;
+ double currentX = mGridStrokeWidth;
double currentY;
QgsFieldMap vectorFields = mVectorLayer->pendingFields();
QgsFieldMap::const_iterator fieldIt = vectorFields.constBegin();
for ( ; fieldIt != vectorFields.constEnd(); ++fieldIt )
- currentY = 0;
+ currentY = mGridStrokeWidth;
currentY += mLineTextDistance;
currentY += fontAscentMillimeters( mHeaderFont );
currentX += mLineTextDistance;
drawText( painter, currentX, currentY, fieldIt.value().name(), mHeaderFont );
+ currentY += mGridStrokeWidth;
//draw the attribute values
QList<QgsAttributeMap>::const_iterator attIt = attributeList.begin();
@@ -99,18 +103,25 @@
drawText( painter, currentX, currentY, attMapIt.value().toString(), mContentFont );
+ currentX += maxColumnWidthMap[fieldIt.key()];
- currentX += maxColumnWidthMap[fieldIt.key()];
+ currentX += mGridStrokeWidth;
//and the borders
- painter->setPen( mGridPen );
- drawHorizontalGridLines( painter, attributeList.size() );
- drawVerticalGridLines( painter, maxColumnWidthMap );
+ if ( mShowGrid )
+ QPen gridPen;
+ gridPen.setWidthF( mGridStrokeWidth );
+ gridPen.setColor( mGridColor );
+ painter->setPen( gridPen );
+ drawHorizontalGridLines( painter, attributeList.size() );
+ drawVerticalGridLines( painter, maxColumnWidthMap );
//draw frame and selection boxes if necessary
drawFrame( painter );
@@ -127,6 +138,12 @@
composerTableElem.setAttribute( "lineTextDist", mLineTextDistance );
composerTableElem.setAttribute( "headerFont", mHeaderFont.toString() );
composerTableElem.setAttribute( "contentFont", mContentFont.toString() );
+ composerTableElem.setAttribute( "gridStrokeWidth", mGridStrokeWidth );
+ composerTableElem.setAttribute( "gridColorRed", mGridColor.red() );
+ composerTableElem.setAttribute( "gridColorGreen", mGridColor.green() );
+ composerTableElem.setAttribute( "gridColorBlue", mGridColor.blue() );
+ composerTableElem.setAttribute( "showGrid", mShowGrid );
if ( mComposerMap )
composerTableElem.setAttribute( "composerMap", mComposerMap->id() );
@@ -154,7 +171,15 @@
mHeaderFont.fromString( itemElem.attribute( "headerFont", "" ) );
mContentFont.fromString( itemElem.attribute( "contentFont", "" ) );
mLineTextDistance = itemElem.attribute( "lineTextDist", "1.0" ).toDouble();
+ mGridStrokeWidth = itemElem.attribute( "gridStrokeWidth", "0.5" ).toDouble();
+ mShowGrid = itemElem.attribute( "showGrid", "1" ).toInt();
+ //grid color
+ int gridRed = itemElem.attribute( "gridColorRed", "0" ).toInt();
+ int gridGreen = itemElem.attribute( "gridColorGreen", "0" ).toInt();
+ int gridBlue = itemElem.attribute( "gridColorBlue", "0" ).toInt();
+ mGridColor = QColor( gridRed, gridGreen, gridBlue );
//composer map
int composerMapId = itemElem.attribute( "composerMap", "-1" ).toInt();
if ( composerMapId == -1 )
@@ -263,7 +288,8 @@
void QgsComposerTable::adaptItemFrame( const QMap<int, double>& maxWidthMap, const QList<QgsAttributeMap>& attributeList )
//calculate height
- double totalHeight = fontAscentMillimeters( mHeaderFont ) + attributeList.size() * fontAscentMillimeters( mContentFont ) + ( attributeList.size() + 1 ) * mLineTextDistance * 2;
+ double totalHeight = fontAscentMillimeters( mHeaderFont ) + attributeList.size() * fontAscentMillimeters( mContentFont ) \
+ + ( attributeList.size() + 1 ) * mLineTextDistance * 2 + ( attributeList.size() + 2 ) * mGridStrokeWidth;
//adapt frame to total width
double totalWidth = 0;
@@ -273,6 +299,7 @@
totalWidth += maxColWidthIt.value();
totalWidth += ( 2 * maxWidthMap.size() * mLineTextDistance );
+ totalWidth += ( maxWidthMap.size() + 1 ) * mGridStrokeWidth;
QTransform t = transform();
setSceneRect( QRectF( t.dx(), t.dy(), totalWidth, totalHeight ) );
@@ -280,27 +307,33 @@
void QgsComposerTable::drawHorizontalGridLines( QPainter* p, int nAttributes )
//horizontal lines
- double currentY = 0;
- p->drawLine( QPointF( 0, currentY ), QPointF( rect().width(), currentY ) );
+ double halfGridStrokeWidth = mGridStrokeWidth / 2.0;
+ double currentY = halfGridStrokeWidth;
+ p->drawLine( QPointF( halfGridStrokeWidth, currentY ), QPointF( rect().width() - halfGridStrokeWidth, currentY ) );
currentY += ( fontAscentMillimeters( mHeaderFont ) + 2 * mLineTextDistance );
for ( int i = 0; i < nAttributes; ++i )
currentY += ( fontAscentMillimeters( mContentFont ) + 2 * mLineTextDistance );
void QgsComposerTable::drawVerticalGridLines( QPainter* p, const QMap<int, double>& maxWidthMap )
//vertical lines
- p->drawLine( QPointF( currentX, 0 ), QPointF( currentX, rect().height() ) );
+ double currentX = halfGridStrokeWidth;
+ p->drawLine( QPointF( currentX, halfGridStrokeWidth ), QPointF( currentX, rect().height() - halfGridStrokeWidth ) );
QMap<int, double>::const_iterator maxColWidthIt = maxWidthMap.constBegin();
for ( ; maxColWidthIt != maxWidthMap.constEnd(); ++maxColWidthIt )
currentX += ( maxColWidthIt.value() + 2 * mLineTextDistance );
Modified: trunk/qgis/src/core/composer/qgscomposertable.h
--- trunk/qgis/src/core/composer/qgscomposertable.h 2010-01-07 12:03:33 UTC (rev 12687)
+++ trunk/qgis/src/core/composer/qgscomposertable.h 2010-01-07 13:29:23 UTC (rev 12688)
@@ -55,6 +55,15 @@
void setContentFont( const QFont& f ) { mContentFont = f; }
QFont contentFont() const { return mContentFont; }
+ void setShowGrid( bool show ) { mShowGrid = show;}
+ bool showGrid() const { return mShowGrid; }
+ void setGridStrokeWidth( double w ) { mGridStrokeWidth = w; }
+ double gridStrokeWidth() const { return mGridStrokeWidth; }
+ void setGridColor( const QColor& c ) { mGridColor = c; }
+ QColor gridColor() const { return mGridColor; }
private:
/**Associated vector layer*/
QgsVectorLayer* mVectorLayer;
@@ -64,10 +73,14 @@
int mMaximumNumberOfFeatures;
/**Distance between table lines and text*/
double mLineTextDistance;
- QPen mGridPen;
QFont mHeaderFont;
QFont mContentFont;
+ bool mShowGrid;
+ double mGridStrokeWidth;
+ QColor mGridColor;
/**Retrieves feature attributes*/
bool getFeatureAttributes( QList<QgsAttributeMap>& attributes );
/**Calculate the maximum width values of the vector attributes*/
Modified: trunk/qgis/src/ui/qgscomposertablewidgetbase.ui
--- trunk/qgis/src/ui/qgscomposertablewidgetbase.ui 2010-01-07 12:03:33 UTC (rev 12687)
+++ trunk/qgis/src/ui/qgscomposertablewidgetbase.ui 2010-01-07 13:29:23 UTC (rev 12688)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>287</width>
- <height>238</height>
+ <width>239</width>
+ <height>281</height>
</rect>
</property>
<property name="windowTitle">
@@ -24,8 +24,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>269</width>
- <height>194</height>
+ <width>221</width>
+ <height>237</height>
</rect>
</property>
<attribute name="label">
@@ -74,7 +74,7 @@
</item>
</layout>
</item>
- <item row="3" column="0">
+ <item row="3" column="0" colspan="2">
<layout class="QHBoxLayout" name="horizontalLayout">
<item>
<widget class="QLabel" name="mMarginLabel">
@@ -88,14 +88,55 @@
</item>
</layout>
</item>
- <item row="4" column="0">
+ <item row="4" column="0" colspan="2">
+ <widget class="QCheckBox" name="mShowGridCheckBox">
+ <property name="text">
+ <string>Show grid</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="0" colspan="2">
+ <layout class="QHBoxLayout" name="horizontalLayout_5">
+ <item>
+ <widget class="QLabel" name="mGridStrokeWidthLabel">
+ <string>Grid stroke width</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="mGridStrokeWidthSpinBox"/>
+ </item>
+ </layout>
+ </item>
+ <item row="6" column="0">
+ <widget class="QLabel" name="mGridColorLabel">
+ <string>Grid color</string>
+ </property>
+ </widget>
+ </item>
+ <item row="6" column="1">
+ <widget class="QgsColorButton" name="mGridColorButton">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item row="7" column="0">
<widget class="QPushButton" name="mHeaderFontPushButton">
<string>Header Font...</string>
</property>
</widget>
</item>
- <item row="4" column="1">
+ <item row="7" column="1">
<widget class="QPushButton" name="mContentFontPushButton">
<string>Content Font...</string>
@@ -103,18 +144,18 @@
</widget>
</item>
</layout>
- <zorder>mHeaderFontPushButton</zorder>
- <zorder>mContentFontPushButton</zorder>
- <zorder></zorder>
- <zorder></zorder>
- <zorder></zorder>
- <zorder></zorder>
- <zorder></zorder>
</widget>
</widget>
</item>
</layout>
</widget>
+ <customwidgets>
+ <customwidget>
+ <class>QgsColorButton</class>
+ <extends>QToolButton</extends>
+ <header>qgscolorbutton.h</header>
+ </customwidget>
+ </customwidgets>
<resources/>
<connections/>
</ui>
