[QGIS Commit] r12776 - in trunk/qgis: . doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Jan 16 06:43:46 EST 2010
Author: wonder
Date: 2010-01-16 06:43:46 -0500 (Sat, 16 Jan 2010)
New Revision: 12776
   trunk/qgis/INSTALL
   trunk/qgis/doc/INSTALL.t2t
Installation guide: updated QGIS deps (minimal sip version set to 4.8, geos to 3.0, added qwt)
Regenerated INSTALL file.
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL	2010-01-16 11:08:04 UTC (rev 12775)
+++ trunk/qgis/INSTALL	2010-01-16 11:43:46 UTC (rev 12776)
@@ -25,21 +25,22 @@
     3.10. Compilation and installation
     3.11. Run qgis.exe from the directory where it's installed (CMAKE_INSTALL_PREFIX)
     3.12. Create the installation package: (optional)
-  4. Building on Mac OSX using frameworks and cmake (QGIS > 0.8)
-    4.1. Install XCODE
+  4. Building on Mac OSX using frameworks and cmake or Xcode
+    4.1. Install Xcode
     4.2. Install Qt4 from .dmg
     4.3. Install development frameworks for QGIS dependencies
       4.3.1. Additional Dependencies : General compatibility note
-      4.3.2. Additional Dependencies : GSL
-      4.3.3. Additional Dependencies : Expat
+      4.3.2. Additional Dependencies : Expat
+      4.3.3. Additional Dependencies : Python
       4.3.4. Additional Dependencies : SIP
       4.3.5. Additional Dependencies : PyQt
-      4.3.6. Additional Dependencies : Bison
-    4.4. Install CMAKE for OSX
+      4.3.6. Additional Dependencies : Qwt/PyQwt
+      4.3.7. Additional Dependencies : Bison
+    4.4. Install CMake for OSX
     4.5. Install subversion for OSX
     4.6. Check out QGIS from SVN
     4.7. Configure the build
-      4.7.1. Configure the Cmake build
+      4.7.1. Configure the CMake build
       4.7.2. Configure the Xcode build
     4.8. Building
       4.8.1. Building with Cmake
@@ -140,7 +141,7 @@
 You can download this document as part of the Quantum GIS 'User and
 Installation Guide' in HTML and PDF format via http://www.qgis.org. A current
 version is also available at the wiki, see:
-http://wiki.qgis.org/qgiswiki/BuildingFromSource
+http://www.qgis.org/wiki/Installation_Guide
 Translations of this document can also be downloaded at the documentation area
 of the Quantum GIS project at http://www.qgis.org. More information is
@@ -173,33 +174,32 @@
 for building from source. The configure script in this directory simply checks
 for the existence of cmake and provides some clues to build QGIS.
-For complete information, see the wiki at:
-   http://wiki.qgis.org/qgiswiki/Building_with_CMake
   2.1. An overview of the dependencies required for building
 '''Required build deps:'''
- * CMake >= 2.4.3
- * Flex, Bison
+* CMake >= 2.4.3
+* Flex, Bison
 '''Required runtime deps:'''
- * Qt >= 4.3.0
- * Proj >= ? (known to work with 4.4.x)
- * GEOS >= 2.2 (3.0 is supported, maybe 2.1.x works too)
- * Sqlite3 >= ? (probably 3.0.0)
- * GDAL/OGR >= 1.4.x
+* Qt >= 4.3.0
+* Proj >= 4.4.x
+* GEOS >= 3.0
+* Sqlite3 >= 3.0.0
+* GDAL/OGR >= 1.4.x
 '''Optional dependencies:'''
- * for GRASS plugin - GRASS >= 6.0.0
- * for georeferencer - GSL >= ? (works with 1.8)
- * for postgis support and SPIT plugin - PostgreSQL >= 8.0.x
- * for gps plugin - expat >= ? (1.95 is OK)
- * for mapserver export and PyQGIS - Python >= 2.3 (2.5+ preferred)
- * for PyQGIS - SIP >= 4.5, PyQt >= must match Qt version
+* for GRASS plugin - GRASS >= 6.0.0
+* for georeferencer - GSL >= 1.8
+* for postgis support and SPIT plugin - PostgreSQL >= 8.0.x
+* for gps plugin - expat >= 1.95
+* for mapserver export and PyQGIS - Python >= 2.3 (2.5+ preferred)
+* for PyQGIS - SIP >= 4.8, PyQt >= must match Qt version
+* for GPS tracking - Qwt >= 5.0
 '''Recommended runtime deps:'''
- * for gps plugin - gpsbabel
+* for gps plugin - gpsbabel
   3. Building under windows using msys
@@ -236,7 +236,7 @@
 Download qt4.3 opensource precompiled edition exe and install (including the
 download and install of mingw) from here:
-http://www.trolltech.com/developer/downloads/qt/windows
+http://qt.nokia.com/downloads
 When the installer will ask for MinGW, you don't need to download and install
 it, just point the installer to c:\msys\mingw
@@ -460,14 +460,14 @@
 on qgis.nsi and choose the option 'Compile NSIS Script'.
 In this approach I will try to avoid as much as possible building dependencies
 from source and rather use frameworks wherever possible.
-Included are a few notes for building on Mac OS X 10.5 (Leopard) and 10.6
-(Snow Leopard).
+The base system here is Mac OS X 10.4 (Tiger) and below. Included are a few notes
+for building on Mac OS X 10.5 (Leopard) and 10.6 (Snow Leopard).
 Snow Leopard note: A cmake/qt/sip bug currently exists where a 32-bit
 cmake build fails to provide python bindings. This means that python plugin support
@@ -475,14 +475,16 @@
 build method to if you require python support.
-I recommend to get the latest xcode dmg from the Apple XDC Web site. Install
-XCODE after the ~1gb download is complete.
+I recommend to get the latest Xcode dmg from the Apple XDC Web site
+(http:/developer.apple.com). The Mac system install disks come with a copy of
+Xcode, but it's likely out of date.
+Install Xcode after the ~1gb download is complete.
 /!\ Note: It may be that you need to create some symlinks after installing
-the XCODE SDK (in particular if you are using XCODE 2.5 on tiger):
+Xcode (in particular if you are using Xcode 2.5 on Tiger):
   cd /Developer/SDKs/MacOSX10.4u.sdk/usr/
@@ -494,59 +496,45 @@
-You need a minimum of Qt-4.3.0. I suggest getting the latest (at time of writing).
+You need a minimum of Qt-4.3.0. I suggest getting the latest.
 Snow Leopard note: If you are building on Snow Leopard, you will need to
 decide between 32-bit support in the older, Qt Carbon branch, or 64-bit
 support in the Qt Cocoa branch. Appropriate installers are available for both
-as of Qt-4.6.0, but the beta version of Qt-4.6.0 has proven to introduce numerous
-bugs in Qgis. Unfortunately, the 32-bit branch of Qt currently does not build with
-python bindings (see notes below). You can achieve support for python in Qgis with
-the Xcode build method noted below.
+as of Qt-4.5.2.  Qt 4.6+ is recommended for Cocoa.
-  ftp://ftp.trolltech.com/qt/source/
+  http://qt.nokia.com/downloads
-Mac versions are named as:
-  qt-mac-opensource-x.y.z.dmg
-x, y, z being the major, minor and revision version.
-If you want debug frameworks, Qt also provide a dmg with these.  These are in
+If you want debug frameworks, Qt also provides a dmg with these.  These are in
 addition to the non-debug frameworks.
 Once downloaded open the dmg and run the installer. Note you need admin
 privileges to install.
-After installing you need to make two small changes:
+Qt 4.4+ note: Starting in Qt 4.4 (?) libQtCLucene was added, and in 4.5
+libQtUiTools was added, both in /usr/lib.  When using a system SDK (which will
+happen in the Xcode build), these libraries will not be found.  To fix this problem,
+add symlinks to /usr/local:
-First edit /Library/Frameworks/QtCore.framework/Headers/qconfig.h and
-change
-/!\ Note: this isn't needed since version 4.2.3
+  sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
+  sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
-QT_EDITION_Unknown to QT_EDITION_OPENSOURCE
-Second change the default mkspec symlink so that it points to macx-g++:
+These should then be found automatically on Leopard and above.  Earlier systems
+may need some help by adding '-L/usr/local/lib' to CMAKE_SHARED_LINKER_FLAGS,
+CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake build, or
+adding '/usr/local/lib' to LIBRARY_SEARCH_PATHS in the Xcode build.
-  cd /usr/local/Qt4.3/mkspecs/
-  sudo rm default
-  sudo ln -sf macx-g++ default
-/!\ Note: this doesn't seem to be needed since version 4.4.
-Download William Kyngesburye's excellent all in one framework that includes
-proj, gdal, sqlite3, etc.
+Download William Kyngesburye's excellent GDAL Complete package that includes
+PROJ, GEOS, GDAL, SQLite3, and image libraries, as frameworks.  There is also
+a GSL framework.
   http://www.kyngchaos.com/wiki/software:frameworks
@@ -554,8 +542,10 @@
 Once downloaded, open and install the frameworks.
-William provides an additional installer package for Postgresql/PostGIS. It's
-available here:
+William provides an additional installer package for Postgresql (for PostGIS support).
+Qgis just needs the libpq client library, so unless you want to setup the full
+Postgres + PostGIS server, all you need is the client-only package.
+It's available here:
   http://www.kyngchaos.com/wiki/software:postgres
@@ -567,6 +557,7 @@
   http://www.kyngchaos.com/wiki/software:grass
@@ -575,83 +566,64 @@
 If you are wanting to build Qgis as a 64-bit application, you will need to
 provide the appropriate build commands to produce 64-bit support in dependencies.
 Likewise, for 32-bit support on Snow Leopard, you will need to override the
-default system architecture, which is 64-bit according to instructions for
+default system architecture, which is 64-bit, according to instructions for
 individual dependency packages.
-Retrieve the current version of the Gnu Scientific Library from:
+Snow Leopard note: Snow Leopard includes a usable expat, so this step is
+not necessary on Snow Leopard.
+Get the expat sources:
-  ftp://ftp.gnu.org/gnu/gsl/
+  http://sourceforge.net/project/showfiles.php?group_id=10127
-Then extract it and build it to a prefix of /usr/local.  Double-click the source
-tarball to unpack it, then cd to the source folder and:
+Double-click the source tarball to unpack, then, in Terminal.app, cd to the source folder and:
   ./configure
-  make
-  sudo make install
+  make
+  sudo make install
-Snow Leopard note: For explicit 32-bit support in gsl, substitute the standard
-configure line with:
+Leopard note: To compile for 64bit, substitute the standard configure line with:
-  ./configure --build=i386
+  ./configure CFLAGS="-Os -arch x86_64"
-And for 64-bit gsl:
-  ./configure --build=x86_64
+Leopard and Snow Leopard note: Leopard and Snow Leopard include a usable
+Python 2.5 and 2.6, respectively. So there is no need to install Python on
+Leopard and Snow Leopard. You can still install Python from python.org if preferred.
+Make sure you install at least the latest Python 2.5 from
+  http://www.python.org/download/
-Snow Leopard note: Snow Leopard includes a usable expat, so this step is
-not necessary.
-Get the expat sources:
+Python 3 is a major change, and may have compatibility issues, so try it at your own risk.
-  http://sourceforge.net/project/showfiles.php?group_id=10127
-Double-click the source tarball to unpack, then cd to the source folder and:
-  ./configure
-  make
-  sudo make install
-Leopard and Snow Leopard note: Leopard and Snow Leopard include a usable Python
-2.5 or 2.6, respectively.  You can install Python from python.org if preferred.
-Make sure you have the latest Python 2.5 from
-  http://www.python.org/download/mac/
 Retrieve the python bindings toolkit SIP from
   http://www.riverbankcomputing.com/software/sip/download
-Double-click the source tarball to unpack it, then cd to the source folder
-and (this installs by default into the Python framework):
+Double-click the source tarball to unpack it, then, in Terminal.app, cd to the source folder
+and (this installs by default into the Python framework, and is appropriate only for python.org Python installs):
   python configure.py
@@ -666,44 +638,41 @@
 basic configure above:
-  python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin -e /usr/local/include -v /usr/local/share/sip
+  python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin \
+  -e /usr/local/include -v /usr/local/share/sip
 Snow Leopard notes
-If building on Snow Leopard, you need to use one of the following configure lines
-based on your installed version of Qt. If you are using 32-bit Qt (Qt Carbon):
+Similar to Leopard, you should install outside the system Python path.
+Also, you need to specify the architecture you want (requires at least SIP 4.9),
+and make sure to run the versioned python binary (this one responds to the
+'arch' command, 'python' does not). If you are using 32-bit Qt (Qt Carbon):
-  python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin -e /usr/local/include -v /usr/local/share/sip --arch i386
+  python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin \
+  -e /usr/local/include -v /usr/local/share/sip --arch=i386
 For 64-bit Qt (Qt Cocoa), use this configure line:
-  python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin -e /usr/local/include -v /usr/local/share/sip --arch x86_64
+  -e /usr/local/include -v /usr/local/share/sip --arch=x86_64
-If you encounter problems compiling PyQt using the instructions
-below you can also try adding python from your frameworks dir
-explicitly to your path e.g.
-  export PATH=/Library/Frameworks/Python.framework/Versions/Current/bin:$PATH
 Retrieve the python bindings toolkit for Qt from
   http://www.riverbankcomputing.com/software/pyqt/download
   export QTDIR=/Developer/Applications/Qt
@@ -715,7 +684,9 @@
 Leopard notes
-If building on Leopard, using Leopard's bundled Python, PyQt wants to install in the system path -- this is not a good idea.  Use this configure command instead of the basic configure above:
+If building on Leopard, using Leopard's bundled Python, PyQt wants to install
+in the system path -- this is not a good idea.  Use this configure command
+instead of the basic configure above:
@@ -727,23 +698,82 @@
 Snow Leopard notes
-If building on Snow Leopard, you need to use one of the following configure lines based on your installed version of Qt. If you are using 32-bit Qt (Qt Carbon):
+Also, you need to specify the architecture you want (requires at least PyQt 4.6),
+'arch' command, which is important for pyuic4, 'python' does not).
+If you are using 32-bit Qt (Qt Carbon):
-  python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch i386
+  python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch i386
-  python configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch x86_64
+  python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch x86_64
+The GPS tracking feature uses Qwt.  Some popular 3rd-party plugins use PyQwt.
+You can take care of both with the PyQwt source from:
+  http://pyqwt.sourceforge.net/
+Double-click the tarball to unpack it.
+Now, first edit qwtconfig.pri in the qwt-5.2 subdir and change some settings so
+you don't get a bloated debug static library (too bad they are configurable from
+qmake).  Scroll down to the 'release/debug mode' block.  Edit the last 'CONFIG +='
+line, within an 'else' block, and change 'debug' to 'release'.  Also uncomment
+(remove # prefix) the line 'CONFIG += QwtDll'.
+Save and close.
+Now, cd into the qwt-5.2 subdir in a Terminal.  Type these commands to build and install:
+  qmake -spec macx-g++
+  make
+  sudo make install
+The Qwt shared library is now installed in /usr/local/qwt-5.x.x[-svn] (x.x is the
+minor.point version, and it may be an SVN version).  Remember this for QGIS and PyQwt configuration.
+Now for PyQwt.  Still in the Terminal:
+  python configure.py --extra-include-dirs=/usr/local/qwt-5.2.1-svn/include \
+  --extra-lib-dirs=/usr/local/qwt-5.2.1-svn/lib --extra-libs=qwt
+  make
+  sudo make install
+Make sure to use the qwt install path from the Qwt build above.
+Snow Leopard note
+If using Qt Carbon, you need to specify which architectures to build, otherwise
+it will default to a combination that does not work (ie x86_64 for a Carbon Qt).
+This is not needed for Qt Cocoa. Configure as follows:
+  python configure.py --extra-cflags="-arch i386" --extra-cxxflags="-arch i386" \
+  --extra-lflags="-arch i386" --extra-include-dirs=/usr/local/qwt-5.2.1-svn/include \
-Leopard and Snow Leopard note: Leopard and Snow Leopard includes Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
+Leopard and Snow Leopard note: Leopard and Snow Leopard include Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
 The version of bison available by default on Mac OS X 10.4 and older is too old so you need to
 get a more recent one on your system. Download at least version 2.3 from:
@@ -762,7 +792,7 @@
 Get the latest source release from here:
@@ -786,9 +816,10 @@
-Leopard and Snow Leopard note: Leopard and Snow Leopard include SVN, so this step can be skipped on these Operating Systems.
+Leopard and Snow Leopard note: Leopard and Snow Leopard (Xcode 3+)
+include SVN, so this step can be skipped on Leopard and Snow Leopard.
-The http://sourceforge.net/projects/macsvn/ (MacSVN) project has a downloadable
+The [http://sourceforge.net/projects/macsvn/MacSVN] project has a downloadable
 build of svn. If you are a GUI inclined person you may want to grab their gui
 client too. Get the command line client here:
@@ -832,7 +863,7 @@
 Now we are going to check out the sources for QGIS. First we will create a
-directory for working in:
+directory for working in (or some folder of your choice):
   mkdir -p ~/dev/cpp cd ~/dev/cpp
@@ -872,51 +903,38 @@
-There are 2 different methods to build QGIS: the traditional Cmake method,
+There are 2 different methods to build QGIS: the traditional CMake method,
 and the new Xcode project (starting with QGIS 1.1). The Xcode project has
-additional bundling steps, though some optional Qgis features must be explicitly
-stated in a user configuration file. The Cmake build handles optional features,
+additional bundling steps, though some optional QGIS features must be explicitly
+stated in a user configuration file. The CMake build handles optional features,
 and some bundling steps are available with scripts in the mac directory.
 CMake supports out of source build so we will create a 'build' dir for the
-build process. By convention I build my software into a dir called 'apps' in
-my home directory. If you have the correct permissions you may want to build
+build process. OS X uses ${HOME}/Applications as a standard user app folder (it gives it the system app folder icon).
+If you have the correct permissions you may want to build
 straight into your /Applications folder. The instructions below assume you are
-building into a pre-existing ${HOME}/apps directory ...
+building into a pre-existing ${HOME}/Applications directory ...
   cd qgis
   mkdir build
   cd build
-  cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ -D CMAKE_BUILD_TYPE=Release ..
+  cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release ..
-Leopard note: To find the custom install of SIP on Leopard, add ""-
-D SIP_BINARY_PATH=/usr/local/bin/sip"" to the cmake command above,
-before the .. at the end, ie:
-  cmake -D CMAKE_INSTALL_PREFIX=$HOME/apps/ \
-      -D CMAKE_BUILD_TYPE=Release \
-      -D SIP_BINARY_PATH=/usr/local/bin/sip \
 To use the application build of GRASS on OSX, you can optionally use the
 following cmake invocation (minimum GRASS 6.3 required, substitute the GRASS
 version as required):
-  cmake -D CMAKE_INSTALL_PREFIX=${HOME}/apps/ \
-        -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/
-        include \
-        -D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
+  cmake -D CMAKE_INSTALL_PREFIX=~/Applications -D CMAKE_BUILD_TYPE=Release \
+  -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/include \
+  -D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
 Or, to use a Unix-style build of GRASS, use the following cmake invocation
@@ -924,41 +942,52 @@
 path and version as required):
-    -D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
-    -D GRASS_PREFIX=/user/local/grass-6.4.0 \
+  -D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
+  -D GRASS_PREFIX=/user/local/grass-6.4.0 \
-Snow Leopard note: To handle the appropriate version of Qt (32-bit or 64-bit), you will need to invoke cmake based on which version of Qt you installed.
+Leopard note: To find the custom install of SIP on Leopard, add
+'-D SIP_BINARY_PATH=/usr/local/bin/sip' to the cmake commands above,
+before the '..' at the end, ie:
-For 32-bit Qt (Carbon) with GRASS-6.4:
+  -D SIP_BINARY_PATH=/usr/local/bin/sip \
-      -D CMAKE_C_FLAGS=-m32 \
-      -D CMAKE_CXX_FLAGS=-m32
-      -D CMAKE_OSX_ARCHITECTURES=i386
-      -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/include\
+Snow Leopard note: To handle the appropriate version of Qt (32-bit or 64-bit), you will need to invoke cmake based on which version of Qt you installed.  Also, SIP/PyQt detection will fail for 32bit because Python runs 64bit.
+For 32-bit Qt (Carbon) with GRASS-6.4, create a 32bit python script and add arch flags to the configuration:
+  sudo cat >/usr/local/bin/python32 <<EOF
+  #!/bin/sh
+  exec arch -i386 /usr/bin/python2.6 \${1+"\$@"}
+  EOF
+  sudo chmod +x /usr/local/bin/python32
+  -D CMAKE_CXX_FLAGS="-arch i386" -D CMAKE_OSX_ARCHITECTURES=i386 \
+  -D PYTHON_EXECUTABLE=/usr/local/bin/python32 \
 For 64-bit Qt (Cocoa) with GRASS-6.4:
-      -D CMAKE_C_FLAGS=-m64 \
-      -D CMAKE_CXX_FLAGS=-m64
-      -D CMAKE_OSX_ARCHITECTURES=x86_64
+  -D CMAKE_CXX_FLAGS="-arch x86_64" -D CMAKE_OSX_ARCHITECTURES=x86_64 \
@@ -967,10 +996,10 @@
 In the mac/xcode folder in the source, duplicate the 'qgis_user-template.xcconfig'
 file and name it 'qgis_user.xcconfig'. A default build will use the KyngChaos
-frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 and extra dependencies
+frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 (for Tiger)
+or the system Python (for Leopard and Snow Leopard) and extra dependencies
 as described above, and compile for the current OSX architecture and version, so no
-extra configuration is necessary. If building on Leopard or newer, you may want to
-use the system Python, which requires editing qgis_user.xcconfig.
+extra configuration is necessary.
 See the mac/xcode/readme.rtf for details, if you need to customize the build.
 The default build will also bundle the Qt frameworks, Postgres library, and
@@ -1017,19 +1046,12 @@
   xcodebuild
-Snow Leopard note: You can also build Qgis using the new llvm compilers supplied
-with Xcode 3.2.x. To do this, you first need to export the proper compiler settings:
+The Qgis application will be found in the 'build/$SDKSYS/Release' folder
+in the xcode folder, where $SDKSYS is the system you configured for in your
+qgis_user.xcconfig. Copy this to whereever you like.
-  export CC=/Developer/usr/bin/llvm-gcc
-  export CXX=/Developer/usr/bin/llvm-g++
-  xcodebuild
-The Qgis application will be found in the 'build/$SYSTEM/Release' folder in the xcode folder.
-Copy this to whereever you like.
   5. Building on GNU/Linux
@@ -2173,7 +2195,7 @@
 Create a 'Build' directory in the top level QGIS directory. This will be where all the build output will be generated.
-Run Start-->All Programs-->CMake-->CMake.
+Run Start>All Programs>CMake-->CMake.
 In the 'Where is the source code:' box, browse to the top level QGIS directory.
@@ -2516,7 +2538,7 @@
 Download Qt 4.x.x source for windows from
-  http:\\www.trolltech.com
 Unpack the source to
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t	2010-01-16 11:08:04 UTC (rev 12775)
+++ trunk/qgis/doc/INSTALL.t2t	2010-01-16 11:43:46 UTC (rev 12776)
@@ -24,8 +24,8 @@
 % To generate the text version of this document:
 % txt2tags -t txt -o INSTALL INSTALL.t2t
-% To generate the moinmoin version of this document:
-% txt2tags -t moin -o INSTALL.moin INSTALL.t2t
+% To generate the mediawiki version of this document:
+% txt2tags -t wiki --no-enum-title -o INSTALL.wiki INSTALL.t2t
 % To generate the html version of this document:
 % txt2tags -t html -o INSTALL.html INSTALL.t2t
 % To generate the LaTeX version of this document:
@@ -54,7 +54,7 @@
@@ -89,31 +89,30 @@
 == An overview of the dependencies required for building ==
- * CMake >= 2.4.3
- * Flex, Bison
+* CMake >= 2.4.3
+* Flex, Bison
- * Qt >= 4.3.0
+* Qt >= 4.3.0
+* Proj >= 4.4.x
+* GEOS >= 3.0
+* Sqlite3 >= 3.0.0
More information about the QGIS-commit mailing list
