[QGIS Commit] r12777 - in trunk/qgis/src: core/symbology-ng
gui/symbology-ng ui/symbollayer
svn_qgis at osgeo.org
Sat Jan 16 07:55:18 EST 2010
Author: mhugent
Date: 2010-01-16 07:55:17 -0500 (Sat, 16 Jan 2010)
New Revision: 12777
Added:
trunk/qgis/src/ui/symbollayer/widget_svgfill.ui
trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp
trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2registry.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp
[FEATURE]: SVG fill symbol layer for polygon textures
Modified: trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp 2010-01-16 12:55:17 UTC (rev 12777)
@@ -64,22 +64,7 @@
p->setBrush( mBrush );
p->setPen( mPen );
- if ( rings == NULL )
- // simple polygon without holes
- p->drawPolygon( points );
- else
- // polygon with holes must be drawn using painter path
- QPainterPath path;
- path.addPolygon( points );
- QList<QPolygonF>::iterator it;
- for ( it = rings->begin(); it != rings->end(); ++it )
- path.addPolygon( *it );
- p->drawPath( path );
+ _renderPolygon( p, points, rings );
QgsStringMap QgsSimpleFillSymbolLayerV2::properties() const
@@ -97,3 +82,212 @@
return new QgsSimpleFillSymbolLayerV2( mColor, mBrushStyle, mBorderColor, mBorderStyle, mBorderWidth );
+//QgsSVGFillSymbolLayer
+#include <QFile>
+#include <QSvgRenderer>
+QgsSVGFillSymbolLayer::QgsSVGFillSymbolLayer( const QString& svgFilePath, double width ): mPatternWidth( width ), mOutline( 0 )
+ setSvgFilePath( svgFilePath );
+ mOutlineWidth = 0.3;
+ setSubSymbol( new QgsLineSymbolV2() );
+QgsSVGFillSymbolLayer::QgsSVGFillSymbolLayer( const QByteArray& svgData, double width ): mSvgData( svgData ), mPatternWidth( width ), mOutline( 0 )
+ storeViewBox();
+QgsSVGFillSymbolLayer::~QgsSVGFillSymbolLayer()
+ delete mOutline;
+void QgsSVGFillSymbolLayer::setSvgFilePath( const QString& svgPath )
+ QFile svgFile( svgPath );
+ if ( svgFile.open( QFile::ReadOnly ) )
+ mSvgData = svgFile.readAll();
+ storeViewBox();
+ mSvgFilePath = svgPath;
+QgsSymbolLayerV2* QgsSVGFillSymbolLayer::create( const QgsStringMap& properties )
+ QByteArray data;
+ double width = 20;
+ QString svgFilePath;
+ if ( properties.contains( "width" ) )
+ width = properties["width"].toDouble();
+ if ( properties.contains( "svgFile" ) )
+ svgFilePath = properties["svgFile"];
+ if ( !svgFilePath.isEmpty() )
+ return new QgsSVGFillSymbolLayer( svgFilePath, width );
+ else
+ if ( properties.contains( "data" ) )
+ data = QByteArray::fromHex( properties["data"].toLocal8Bit() );
+ return new QgsSVGFillSymbolLayer( data, width );
+QString QgsSVGFillSymbolLayer::layerType() const
+ return "SVGFill";
+void QgsSVGFillSymbolLayer::startRender( QgsSymbolV2RenderContext& context )
+ if ( mSvgViewBox.isNull() )
+ return;
+ //create QImage with appropriate dimensions
+ int pixelWidth = context.outputPixelSize( mPatternWidth );//mPatternWidth.value( context, QgsOutputUnit::Pixel );
+ int pixelHeight = pixelWidth / mSvgViewBox.width() * mSvgViewBox.height();
+ QImage textureImage( pixelWidth, pixelHeight, QImage::Format_ARGB32_Premultiplied );
+ textureImage.fill( QColor( 255, 255, 255, 0 ).rgba() );
+ //rasterise byte array to image
+ QPainter p( &textureImage );
+ QSvgRenderer r( mSvgData );
+ if ( !r.isValid() )
+ return;
+ r.render( &p );
+ QTransform brushTransform;
+ brushTransform.scale( 1.0 / context.renderContext().rasterScaleFactor(), 1.0 / context.renderContext().rasterScaleFactor() );
+ mBrush.setTextureImage( textureImage );
+ mBrush.setTransform( brushTransform );
+ if ( mOutline )
+ mOutline->startRender( context.renderContext() );
+void QgsSVGFillSymbolLayer::stopRender( QgsSymbolV2RenderContext& context )
+ if ( mOutline )
+ mOutline->stopRender( context.renderContext() );
+void QgsSVGFillSymbolLayer::renderPolygon( const QPolygonF& points, QList<QPolygonF>* rings, QgsSymbolV2RenderContext& context )
+ QPainter* p = context.renderContext().painter();
+ if ( !p )
+ return;
+ p->setBrush( mBrush );
+ p->setPen( QPen( Qt::NoPen ) );
+ if ( mOutline )
+ mOutline->renderPolyline( points, context.renderContext() );
+ if ( rings )
+ QList<QPolygonF>::const_iterator ringIt = rings->constBegin();
+ for ( ; ringIt != rings->constEnd(); ++ringIt )
+ mOutline->renderPolyline( *ringIt, context.renderContext() );
+QgsStringMap QgsSVGFillSymbolLayer::properties() const
+ QgsStringMap map;
+ if ( !mSvgFilePath.isEmpty() )
+ map.insert( "svgFile", mSvgFilePath );
+ else
+ map.insert( "data", QString( mSvgData.toHex() ) );
+ map.insert( "width", QString::number( mPatternWidth ) );
+ return map;
+QgsSymbolLayerV2* QgsSVGFillSymbolLayer::clone() const
+ QgsSymbolLayerV2* clonedLayer = 0;
+ clonedLayer = new QgsSVGFillSymbolLayer( mSvgFilePath, mPatternWidth );
+ else
+ clonedLayer = new QgsSVGFillSymbolLayer( mSvgData, mPatternWidth );
+ if ( mOutline )
+ clonedLayer->setSubSymbol( mOutline->clone() );
+ return clonedLayer;
+void QgsSVGFillSymbolLayer::storeViewBox()
+ if ( !mSvgData.isEmpty() )
+ if ( r.isValid() )
+ mSvgViewBox = r.viewBoxF();
+ return;
+ mSvgViewBox = QRectF();
+ return;
+bool QgsSVGFillSymbolLayer::setSubSymbol( QgsSymbolV2* symbol )
+ if ( !symbol || symbol->type() != QgsSymbolV2::Line )
+ delete symbol;
+ return false;
+ QgsLineSymbolV2* lineSymbol = dynamic_cast<QgsLineSymbolV2*>( symbol );
+ if ( lineSymbol )
+ delete mOutline;
+ mOutline = lineSymbol;
+ return true;
+ delete symbol;
+ return false;
Modified: trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h 2010-01-16 12:55:17 UTC (rev 12777)
@@ -61,4 +61,58 @@
QPen mPen;
+/**A class for svg fill patterns. The class automatically scales the pattern to
+ the appropriate pixel dimensions of the output device*/
+class CORE_EXPORT QgsSVGFillSymbolLayer: public QgsFillSymbolLayerV2
+ public:
+ QgsSVGFillSymbolLayer( const QString& svgFilePath = "", double width = 20 );
+ QgsSVGFillSymbolLayer( const QByteArray& svgData, double width = 20 );
+ ~QgsSVGFillSymbolLayer();
+ static QgsSymbolLayerV2* create( const QgsStringMap& properties = QgsStringMap() );
+ // implemented from base classes
+ QString layerType() const;
+ void startRender( QgsSymbolV2RenderContext& context );
+ void stopRender( QgsSymbolV2RenderContext& context );
+ void renderPolygon( const QPolygonF& points, QList<QPolygonF>* rings, QgsSymbolV2RenderContext& context );
+ QgsStringMap properties() const;
+ QgsSymbolLayerV2* clone() const;
+ //gettersn and setters
+ void setSvgFilePath( const QString& svgPath );
+ QString svgFilePath() const { return mSvgFilePath; }
+ void setPatternWidth( double width ) { mPatternWidth = width;}
+ double patternWidth() const { return mPatternWidth; }
+ QgsSymbolV2* subSymbol() { return mOutline; }
+ bool setSubSymbol( QgsSymbolV2* symbol );
+ protected:
+ /**Width of the pattern (in QgsSymbolV2 output units)*/
+ double mPatternWidth;
+ /**SVG data*/
+ QByteArray mSvgData;
+ /**Path to the svg file (or empty if constructed directly from data)*/
+ QString mSvgFilePath;
+ /**SVG view box (to keep the aspect ratio */
+ QRectF mSvgViewBox;
+ /**Brush that receives rendered pixel image in startRender() method*/
+ QBrush mBrush;
+ /**Outline width*/
+ double mOutlineWidth;
+ /**Custom outline*/
+ QgsLineSymbolV2* mOutline;
+ private:
+ /**Helper function that gets the view box from the byte array*/
+ void storeViewBox();
#endif
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp 2010-01-16 12:55:17 UTC (rev 12777)
@@ -4,6 +4,7 @@
#include "qgsrendercontext.h"
#include <QSize>
+#include <QPainter>
#include <QPointF>
#include <QPolygonF>
@@ -50,3 +51,30 @@
renderPolygon( poly, NULL, context );
stopRender( context );
+void QgsFillSymbolLayerV2::_renderPolygon( QPainter* p, const QPolygonF& points, const QList<QPolygonF>* rings )
+ if ( !p )
+ return;
+ if ( rings == NULL )
+ // simple polygon without holes
+ p->drawPolygon( points );
+ else
+ // polygon with holes must be drawn using painter path
+ QPainterPath path;
+ path.addPolygon( points );
+ QList<QPolygonF>::const_iterator it = rings->constBegin();
+ for ( ; it != rings->constEnd(); ++it )
+ path.addPolygon( *it );
+ p->drawPath( path );
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h 2010-01-16 12:55:17 UTC (rev 12777)
@@ -114,6 +114,8 @@
protected:
QgsFillSymbolLayerV2( bool locked = false );
+ /**Default method to render polygon*/
+ void _renderPolygon( QPainter* p, const QPolygonF& points, const QList<QPolygonF>* rings );
class QgsSymbolLayerV2Widget;
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2registry.cpp
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2registry.cpp 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2registry.cpp 2010-01-16 12:55:17 UTC (rev 12777)
@@ -24,11 +24,13 @@
addSymbolLayerType( new QgsSymbolLayerV2Metadata( "SimpleFill", QgsSymbolV2::Fill,
QgsSimpleFillSymbolLayerV2::create ) );
+ addSymbolLayerType( new QgsSymbolLayerV2Metadata( "SVGFill", QgsSymbolV2::Fill, QgsSVGFillSymbolLayer::create ) );
QgsSymbolLayerV2Registry::~QgsSymbolLayerV2Registry()
- foreach (QString name, mMetadata.keys())
+ foreach( QString name, mMetadata.keys() )
delete mMetadata[name];
@@ -91,7 +93,7 @@
QMap<QString, QgsSymbolLayerV2AbstractMetadata*>::ConstIterator it = mMetadata.begin();
for ( ; it != mMetadata.end(); ++it )
- if ( (*it)->type() == type )
+ if (( *it )->type() == type )
lst.append( it.key() );
return lst;
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2010-01-16 12:55:17 UTC (rev 12777)
@@ -498,3 +498,116 @@
btnChangeColor->setColor( mLayer->color() );
emit changed();
+#include <QFileDialog>
+QgsSVGFillSymbolLayerWidget::QgsSVGFillSymbolLayerWidget( QWidget* parent ): QgsSymbolLayerV2Widget( parent )
+ mLayer = 0;
+ setupUi( this );
+ insertIcons();
+void QgsSVGFillSymbolLayerWidget::setSymbolLayer( QgsSymbolLayerV2* layer )
+ if ( !layer )
+ return;
+ if ( layer->layerType() != "SVGFill" )
+ return;
+ mLayer = dynamic_cast<QgsSVGFillSymbolLayer*>( layer );
+ if ( mLayer )
+ double width = mLayer->patternWidth();
+ mTextureWidthSpinBox->setValue( width );
+ mSVGLineEdit->setText( mLayer->svgFilePath() );
+QgsSymbolLayerV2* QgsSVGFillSymbolLayerWidget::symbolLayer()
+ return mLayer;
+void QgsSVGFillSymbolLayerWidget::on_mBrowseToolButton_clicked()
+ QString filePath = QFileDialog::getOpenFileName( 0, tr( "Select svg texture file" ) );
+ if ( !filePath.isNull() )
+ mSVGLineEdit->setText( filePath );
+ emit changed();
+void QgsSVGFillSymbolLayerWidget::on_mTextureWidthSpinBox_valueChanged( double d )
+ if ( mLayer )
+ mLayer->setPatternWidth( d );
+ emit changed();
+void QgsSVGFillSymbolLayerWidget::on_mSVGLineEdit_textChanged( const QString & text )
+ if ( !mLayer )
+ return;
+ QFileInfo fi( text );
+ if ( !fi.exists() )
+ return;
+ mLayer->setSvgFilePath( text );
+ emit changed();
+void QgsSVGFillSymbolLayerWidget::on_mSvgListWidget_itemActivated( QListWidgetItem* item )
+ mSVGLineEdit->setText( item->data( Qt::UserRole ).toString() );
+void QgsSVGFillSymbolLayerWidget::insertIcons()
+ mSvgListWidget->clear();
+ QStringList svgFiles = QgsSvgMarkerSymbolLayerV2::listSvgFiles();
+ QSvgRenderer renderer;
+ QPainter painter;
+ QStringList::const_iterator it = svgFiles.constBegin();
+ for ( ; it != svgFiles.constEnd(); ++it )
+ renderer.load( *it );
+ QPixmap pixmap( renderer.defaultSize() );
+ pixmap.fill();
+ painter.begin( &pixmap );
+ renderer.render( &painter );
+ painter.end();
+ QListWidgetItem* item = new QListWidgetItem( mSvgListWidget );
+ item->setData( Qt::UserRole, *it );
+ item->setIcon( QIcon( pixmap ) );
+ item->setToolTip( *it );
+void QgsSVGFillSymbolLayerWidget::on_mChangeOutlinePushButton_clicked()
+ QgsSymbolV2PropertiesDialog dlg( mLayer->subSymbol(), this );
+ if ( dlg.exec() == 0 )
+ return;
+ emit changed();
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h 2010-01-16 12:55:17 UTC (rev 12777)
@@ -206,5 +206,38 @@
QgsLineDecorationSymbolLayerV2* mLayer;
+#include "ui_widget_svgfill.h"
+class QgsSVGFillSymbolLayer;
+class GUI_EXPORT QgsSVGFillSymbolLayerWidget : public QgsSymbolLayerV2Widget, private Ui::WidgetSVGFill
+ Q_OBJECT
+ public:
+ QgsSVGFillSymbolLayerWidget( QWidget* parent = NULL );
+ static QgsSymbolLayerV2Widget* create() { return new QgsSVGFillSymbolLayerWidget(); }
+ // from base class
+ virtual void setSymbolLayer( QgsSymbolLayerV2* layer );
+ virtual QgsSymbolLayerV2* symbolLayer();
+ protected:
+ QgsSVGFillSymbolLayer* mLayer;
+ //sets new output unit. Is called on combo box or spin box change
+ void setOutputUnit();
+ void insertIcons();
+ private slots:
+ void on_mBrowseToolButton_clicked();
+ void on_mTextureWidthSpinBox_valueChanged( double d );
+ void on_mSVGLineEdit_textChanged( const QString & text );
+ void on_mSvgListWidget_itemActivated( QListWidgetItem* item );
+ void on_mChangeOutlinePushButton_clicked();
#endif
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp 2010-01-16 11:43:46 UTC (rev 12776)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbolv2propertiesdialog.cpp 2010-01-16 12:55:17 UTC (rev 12777)
@@ -74,26 +74,26 @@
QgsSymbolLayerV2Registry* reg = QgsSymbolLayerV2Registry::instance();
- QgsSymbolLayerV2AbstractMetadata* abstractMetadata = reg->symbolLayerMetadata(name);
- if (abstractMetadata == NULL)
+ QgsSymbolLayerV2AbstractMetadata* abstractMetadata = reg->symbolLayerMetadata( name );
+ if ( abstractMetadata == NULL )
- QgsDebugMsg("Failed to find symbol layer's entry in registry: "+name);
+ QgsDebugMsg( "Failed to find symbol layer's entry in registry: " + name );
return false;
- QgsSymbolLayerV2Metadata* metadata = dynamic_cast<QgsSymbolLayerV2Metadata*>(abstractMetadata);
- if (metadata == NULL)
+ QgsSymbolLayerV2Metadata* metadata = dynamic_cast<QgsSymbolLayerV2Metadata*>( abstractMetadata );
+ if ( metadata == NULL )
- QgsDebugMsg("Failed to cast symbol layer's metadata: "+name);
+ QgsDebugMsg( "Failed to cast symbol layer's metadata: " + name );
return false;
- metadata->setWidgetFunction(f);
+ metadata->setWidgetFunction( f );
return true;
static void _initWidgetFunctions()
static bool initialized = false;
- if (initialized)
+ if ( initialized )
return;
_initWidgetFunction( "SimpleLine", QgsSimpleLineSymbolLayerV2Widget::create );
@@ -104,6 +104,7 @@
_initWidgetFunction( "SvgMarker", QgsSvgMarkerSymbolLayerV2Widget::create );
_initWidgetFunction( "SimpleFill", QgsSimpleFillSymbolLayerV2Widget::create );
+ _initWidgetFunction( "SVGFill", QgsSVGFillSymbolLayerWidget::create );
initialized = true;
Added: trunk/qgis/src/ui/symbollayer/widget_svgfill.ui
--- trunk/qgis/src/ui/symbollayer/widget_svgfill.ui (rev 0)
+++ trunk/qgis/src/ui/symbollayer/widget_svgfill.ui 2010-01-16 12:55:17 UTC (rev 12777)
@@ -0,0 +1,81 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>WidgetSVGFill</class>
+ <widget class="QWidget" name="WidgetSVGFill">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>211</width>
+ <height>199</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>Form</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_2">
+ <item>
+ <widget class="QLabel" name="mTextureWidthLabel">
+ <property name="text">
+ <string>Texture width:</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="mTextureWidthSpinBox">
+ <property name="maximum">
+ <double>99999999.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="1" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_4">
+ <item>
+ <widget class="QLabel" name="mOutlineLabel">
+ <string>Outline:</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QPushButton" name="mChangeOutlinePushButton">
+ <string>Change</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="2" column="0">
+ <widget class="QListWidget" name="mSvgListWidget">
+ <property name="flow">
+ <enum>QListView::LeftToRight</enum>
+ </property>
+ <property name="viewMode">
+ <enum>QListView::IconMode</enum>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout">
+ <item>
+ <widget class="QLineEdit" name="mSVGLineEdit"/>
+ </item>
+ <item>
+ <widget class="QToolButton" name="mBrowseToolButton">
+ <string>...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections/>
+</ui>
