[QGIS Commit] r12833 - trunk/qgis/src/core
svn_qgis at osgeo.org
Mon Jan 25 17:00:09 EST 2010
Author: jef
Date: 2010-01-25 17:00:08 -0500 (Mon, 25 Jan 2010)
New Revision: 12833
trunk/qgis/src/core/qgsvectorlayer.cpp
workaround for #1759
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2010-01-24 16:26:35 UTC (rev 12832)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2010-01-25 22:00:08 UTC (rev 12833)
@@ -439,15 +439,6 @@
pa[i].setY( y[i] );
-#ifdef QGISDEBUGVERBOSE
- // this is only used for verbose debug output
- for ( int i = 0; i < pa.size(); ++i )
- QgsDebugMsgLevel( "pa" + QString::number( pa.point( i ).x() ), 2 );
- QgsDebugMsgLevel( "pa" + QString::number( pa.point( i ).y() ), 2 );
-#endif
// The default pen gives bevelled joins between segements of the
// polyline, which is good enough for the moment.
//preserve a copy of the pen before we start fiddling with it
@@ -581,52 +572,6 @@
// Only try to draw polygons if there is something to draw
if ( total_points > 0 )
- // Store size here and use it in the loop to avoid penalty of
- // multiple calls to size()
- int numRings = rings.size();
- for ( register int i = 0; i < numRings; ++i )
- // Store the pointer in a variable with a short name so as to make
- // the following code easier to type and read.
- ringTypePtr r = rings[i];
- // only do this once to avoid penalty of additional calls
- unsigned ringSize = r->first.size();
- // Transfer points to the array of QPointF
- QPolygonF pa( ringSize );
- for ( register unsigned int j = 0; j != ringSize; ++j )
- pa[j].setX( r->first[j] );
- pa[j].setY( r->second[j] );
- path.addPolygon( pa );
- // Tidy up the pointed to pairs of vectors as we finish with them
- delete rings[i];
-#if 0
- // A bit of code to aid in working out what values of
- // QgsClipper::minX, etc cause the X11 zoom bug.
- int largestX = -std::numeric_limits<int>::max();
- int smallestX = std::numeric_limits<int>::max();
- int largestY = -std::numeric_limits<int>::max();
- int smallestY = std::numeric_limits<int>::max();
- largestX = std::max( largestX, pa.point( i ).x() );
- smallestX = std::min( smallestX, pa.point( i ).x() );
- largestY = std::max( largestY, pa.point( i ).y() );
- smallestY = std::min( smallestY, pa.point( i ).y() );
- QgsDebugMsg( QString( "Largest X coordinate was %1" ).arg( largestX ) );
- QgsDebugMsg( QString( "Smallest X coordinate was %1" ).arg( smallestX ) );
- QgsDebugMsg( QString( "Largest Y coordinate was %1" ).arg( largestY ) );
- QgsDebugMsg( QString( "Smallest Y coordinate was %1" ).arg( smallestY ) );
-#endif
//preserve a copy of the brush and pen before we start fiddling with it
QBrush brush = p->brush(); //to be kept as original
QPen pen = p->pen(); // to be kept original
@@ -658,20 +603,92 @@
p->setBrush( myTransparentBrush );
p->setPen( myTransparentPen );
- // draw the polygon
- p->drawPath( path );
+ if ( numRings == 1 )
+ ringTypePtr r = rings[0];
+ unsigned ringSize = r->first.size();
+ QPolygonF pa( ringSize );
+ for ( register unsigned int j = 0; j != ringSize; ++j )
+ pa[j].setX( r->first[j] );
+ pa[j].setY( r->second[j] );
+ p->drawPolygon( pa );
- // draw vertex markers if in editing mode, but only to the main canvas
- if ( mEditable && renderContext.drawEditingInformation() )
+ // draw vertex markers if in editing mode, but only to the main canvas
+ if ( mEditable && renderContext.drawEditingInformation() )
+ drawVertexMarker( r->first[j], r->second[j], *p, mCurrentVertexMarkerType, mCurrentVertexMarkerSize );
+ delete rings[0];
+ else
- for ( int i = 0; i < path.elementCount(); ++i )
+ // Store size here and use it in the loop to avoid penalty of
+ // multiple calls to size()
+ int numRings = rings.size();
+ for ( register int i = 0; i < numRings; ++i )
- const QPainterPath::Element & e = path.elementAt( i );
- drawVertexMarker( e.x, e.y, *p, mCurrentVertexMarkerType, mCurrentVertexMarkerSize );
+ // Store the pointer in a variable with a short name so as to make
+ // the following code easier to type and read.
+ ringTypePtr r = rings[i];
+ // only do this once to avoid penalty of additional calls
+ // Transfer points to the array of QPointF
+ path.addPolygon( pa );
+ // Tidy up the pointed to pairs of vectors as we finish with them
+ delete rings[i];
+#if 0
+ // A bit of code to aid in working out what values of
+ // QgsClipper::minX, etc cause the X11 zoom bug.
+ int largestX = -std::numeric_limits<int>::max();
+ int smallestX = std::numeric_limits<int>::max();
+ int largestY = -std::numeric_limits<int>::max();
+ int smallestY = std::numeric_limits<int>::max();
+ for ( int i = 0; i < pa.size(); ++i )
+ largestX = std::max( largestX, pa.point( i ).x() );
+ smallestX = std::min( smallestX, pa.point( i ).x() );
+ largestY = std::max( largestY, pa.point( i ).y() );
+ smallestY = std::min( smallestY, pa.point( i ).y() );
+ QgsDebugMsg( QString( "Largest X coordinate was %1" ).arg( largestX ) );
+ QgsDebugMsg( QString( "Smallest X coordinate was %1" ).arg( smallestX ) );
+ QgsDebugMsg( QString( "Largest Y coordinate was %1" ).arg( largestY ) );
+ QgsDebugMsg( QString( "Smallest Y coordinate was %1" ).arg( smallestY ) );
+#endif
+ // draw the polygon
+ p->drawPath( path );
+ for ( int i = 0; i < path.elementCount(); ++i )
+ const QPainterPath::Element & e = path.elementAt( i );
+ drawVertexMarker( e.x, e.y, *p, mCurrentVertexMarkerType, mCurrentVertexMarkerSize );
