[QGIS Commit] r12834 - in trunk/qgis: python/core src/app src/app/legend src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jan 26 10:43:54 EST 2010
Author: wonder
Date: 2010-01-26 10:43:54 -0500 (Tue, 26 Jan 2010)
New Revision: 12834
Added:
   trunk/qgis/python/core/qgspluginlayer.sip
   trunk/qgis/python/core/qgspluginlayerregistry.sip
   trunk/qgis/src/core/qgspluginlayer.cpp
   trunk/qgis/src/core/qgspluginlayer.h
   trunk/qgis/src/core/qgspluginlayerregistry.cpp
   trunk/qgis/src/core/qgspluginlayerregistry.h
   trunk/qgis/python/core/core.sip
   trunk/qgis/python/core/qgsmaplayer.sip
   trunk/qgis/src/app/legend/qgslegendlayer.cpp
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/core/CMakeLists.txt
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/core/qgsmaplayer.h
   trunk/qgis/src/core/qgsproject.cpp
[FEATURE] Support for custom plugin layers. Applied patch from #2392 contributed by Mathias Walker. Thanks!
Some parts modified to make plugin layers easier to use and more robust.
Modified: trunk/qgis/python/core/core.sip
--- trunk/qgis/python/core/core.sip	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/python/core/core.sip	2010-01-26 15:43:54 UTC (rev 12834)
@@ -43,6 +43,8 @@
 %Include qgsmarkercatalogue.sip
 %Include qgsmessageoutput.sip
 %Include qgsoverlayobject.sip
+%Include qgspluginlayer.sip
+%Include qgspluginlayerregistry.sip
 %Include qgspoint.sip
 %Include qgsproject.sip
 %Include qgsprovidermetadata.sip
Modified: trunk/qgis/python/core/qgsmaplayer.sip
--- trunk/qgis/python/core/qgsmaplayer.sip	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/python/core/qgsmaplayer.sip	2010-01-26 15:43:54 UTC (rev 12834)
@@ -22,6 +22,10 @@
       sipClass = sipClass_QgsRasterLayer;
+    else if (layer->type() == QgsMapLayer::PluginLayer)
+      sipClass = sipClass_QgsPluginLayer;
   else
@@ -35,7 +39,8 @@
     enum LayerType
         VectorLayer,
-        RasterLayer
+        RasterLayer,
+        PluginLayer
     /** Constructor
@@ -109,7 +114,7 @@
     /** True if the layer can be edited */
-    virtual bool isEditable() const = 0;
+    virtual bool isEditable() const;
     /** sets state from Dom document
        @param layer_node is Dom node corresponding to ``maplayer'' tag
@@ -323,6 +328,9 @@
 protected:
+    /** set whether layer is valid or not - should be used in constructor */
+    void setValid( bool valid );
     /** called by readXML(), used by children to read state specific to them from
         project files.
Added: trunk/qgis/python/core/qgspluginlayer.sip
--- trunk/qgis/python/core/qgspluginlayer.sip	                        (rev 0)
+++ trunk/qgis/python/core/qgspluginlayer.sip	2010-01-26 15:43:54 UTC (rev 12834)
@@ -0,0 +1,14 @@
+class QgsPluginLayer : QgsMapLayer
+%TypeHeaderCode
+#include "qgspluginlayer.h"
+%End
+  public:
+    QgsPluginLayer(QString layerType, QString layerName = QString());
+    /** return plugin layer type (the same as used in QgsPluginLayerRegistry) */
+    QString pluginLayerType();
Added: trunk/qgis/python/core/qgspluginlayerregistry.sip
--- trunk/qgis/python/core/qgspluginlayerregistry.sip	                        (rev 0)
+++ trunk/qgis/python/core/qgspluginlayerregistry.sip	2010-01-26 15:43:54 UTC (rev 12834)
@@ -0,0 +1,52 @@
+class QgsPluginLayerType
+%TypeHeaderCode
+#include "qgspluginlayerregistry.h"
+%End
+  public:
+    QgsPluginLayerType(QString name);
+    virtual ~QgsPluginLayerType();
+    QString name();
+    /** return new layer of this type. Return NULL on error */
+    virtual QgsPluginLayer* createLayer() /Factory/;
+    /** show plugin layer properties dialog. Return FALSE if the dialog cannot be shown. */
+    virtual bool showLayerProperties(QgsPluginLayer* layer);
+class QgsPluginLayerRegistry
+%TypeHeaderCode
+%End
+  public:
+    /** means of accessing canonical single instance  */
+    static QgsPluginLayerRegistry* instance();
+    ~QgsPluginLayerRegistry();
+    /** add plugin layer type (take ownership) and return TRUE on success */
+    bool addPluginLayerType(QgsPluginLayerType* pluginLayerType /Transfer/);
+    /** remove plugin layer type and return TRUE on success */
+    bool removePluginLayerType(QString typeName);
+    /** return plugin layer type metadata or NULL if doesn't exist */
+    QgsPluginLayerType* pluginLayerType(QString typeName);
+    /** return new layer if corresponding plugin has been found, else return NULL */
+    // to be resolved
+    //QgsPluginLayer* createLayer(QString typeName);
+  private:
+    /** private since instance() creates it */
+    QgsPluginLayerRegistry();
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp	2010-01-26 15:43:54 UTC (rev 12834)
@@ -165,7 +165,7 @@
     else
       vectorLayerSymbology( vlayer, widthScale ); // get and change symbology
-  else // RASTER
+  else if ( theMapLayer->type() == QgsMapLayer::RasterLayer ) // RASTER
     QgsRasterLayer* rlayer = qobject_cast<QgsRasterLayer *>( theMapLayer );
     rasterLayerSymbology( rlayer ); // get and change symbology
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-01-26 15:43:54 UTC (rev 12834)
@@ -118,6 +118,8 @@
 #include "qgsoptions.h"
 #include "qgspastetransformations.h"
 #include "qgspluginitem.h"
 #include "qgspluginmanager.h"
 #include "qgspluginmetadata.h"
 #include "qgspluginregistry.h"
@@ -6108,7 +6110,7 @@
     rlp->exec();
     delete rlp; // delete since dialog cannot be reused without updating code
-  else // VECTOR
+  else if ( ml->type() == QgsMapLayer::VectorLayer ) // VECTOR
     QgsVectorLayer* vlayer = qobject_cast<QgsVectorLayer *>( ml );
@@ -6125,4 +6127,20 @@
     vlp->exec();
     delete vlp; // delete since dialog cannot be reused without updating code
+  else if ( ml->type() == QgsMapLayer::PluginLayer )
+    QgsPluginLayer* pl = qobject_cast<QgsPluginLayer *>( ml );
+    if ( !pl )
+      return;
+    QgsPluginLayerType* plt = QgsPluginLayerRegistry::instance()->pluginLayerType( pl->pluginLayerType() );
+    if ( !plt )
+      return;
+    if ( !plt->showLayerProperties( pl ) )
+      QMessageBox::information( this, tr( "Warning" ), tr( "This layer doesn't have a properties dialog." ) );
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/src/core/CMakeLists.txt	2010-01-26 15:43:54 UTC (rev 12834)
@@ -60,6 +60,8 @@
   qgsoverlayobject.cpp
   qgspalgeometry.cpp
   qgspalobjectpositionmanager.cpp
+  qgspluginlayer.cpp
+  qgspluginlayerregistry.cpp
   qgspoint.cpp
   qgsproject.cpp
   qgsprojectfiletransform.cpp
@@ -221,6 +223,7 @@
   qgsmaplayerregistry.h
   qgsmaprenderer.h
   qgsmessageoutput.h
+  qgspluginlayer.h
   qgsproject.h
   qgsrunprocess.h
   qgsvectorlayer.h
@@ -388,6 +391,8 @@
   qgsmessageoutput.h
   qgsoverlayobjectpositionmanager.h
   qgspalobjectpositionmanager.h
+  qgspluginlayer.h
+  qgspluginlayerregistry.h
   qgspoint.h
   qgsproject.h
   qgsprojectfiletransform.h
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2010-01-26 15:43:54 UTC (rev 12834)
@@ -850,3 +850,12 @@
   mpCacheImage = thepImage;
+bool QgsMapLayer::isEditable() const
+  return false;
+void QgsMapLayer::setValid( bool valid )
+  mValid = valid;
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/src/core/qgsmaplayer.h	2010-01-26 15:43:54 UTC (rev 12834)
@@ -48,7 +48,8 @@
     enum LayerType
       VectorLayer,
-      RasterLayer
+      RasterLayer,
+      PluginLayer
     /** Constructor
@@ -126,7 +127,7 @@
@@ -343,6 +344,9 @@
   protected:
         project files.
Added: trunk/qgis/src/core/qgspluginlayer.cpp
--- trunk/qgis/src/core/qgspluginlayer.cpp	                        (rev 0)
+++ trunk/qgis/src/core/qgspluginlayer.cpp	2010-01-26 15:43:54 UTC (rev 12834)
@@ -0,0 +1,11 @@
+QgsPluginLayer::QgsPluginLayer( QString layerType, QString layerName )
+    : QgsMapLayer( PluginLayer, layerName ), mPluginLayerType( layerType )
+QString QgsPluginLayer::pluginLayerType()
+  return mPluginLayerType;
Added: trunk/qgis/src/core/qgspluginlayer.h
--- trunk/qgis/src/core/qgspluginlayer.h	                        (rev 0)
+++ trunk/qgis/src/core/qgspluginlayer.h	2010-01-26 15:43:54 UTC (rev 12834)
@@ -0,0 +1,28 @@
+#ifndef QGSPLUGINLAYER_H
+#define QGSPLUGINLAYER_H
+#include "qgsmaplayer.h"
+/** \ingroup core
+  Base class for plugin layers. These can be implemented by plugins
+  and registered in QgsPluginLayerRegistry.
+  In order to be readable from project files, they should set these attributes in layer DOM node:
+   "type" = "plugin"
+   "name" = "your_layer_type"
+class CORE_EXPORT QgsPluginLayer : public QgsMapLayer
+    Q_OBJECT
+  public:
+    QgsPluginLayer( QString layerType, QString layerName = QString() );
+  protected:
+    QString mPluginLayerType;
+#endif // QGSPLUGINLAYER_H
Added: trunk/qgis/src/core/qgspluginlayerregistry.cpp
--- trunk/qgis/src/core/qgspluginlayerregistry.cpp	                        (rev 0)
+++ trunk/qgis/src/core/qgspluginlayerregistry.cpp	2010-01-26 15:43:54 UTC (rev 12834)
@@ -0,0 +1,128 @@
+                    qgspluginlayerregistry.cpp - class for
+                    registering plugin layer creators
+    begin                : Mon Nov 30 2009
+    copyright            : (C) 2009 by Mathias Walker, Sourcepole
+    email                : mwa at sourcepole.ch
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/* $Id$ */
+#include "qgslogger.h"
+#include "qgsmaplayerregistry.h"
+QgsPluginLayerType::QgsPluginLayerType(QString name)
+  : mName(name)
+QgsPluginLayerType::~QgsPluginLayerType()
+QString QgsPluginLayerType::name()
+  return mName;
+QgsPluginLayer* QgsPluginLayerType::createLayer()
+  return NULL;
+bool QgsPluginLayerType::showLayerProperties(QgsPluginLayer* layer)
+  return false;
+/** Static calls to enforce singleton behaviour */
+QgsPluginLayerRegistry* QgsPluginLayerRegistry::_instance = NULL;
+QgsPluginLayerRegistry* QgsPluginLayerRegistry::instance()
+  if ( _instance == NULL )
+    _instance = new QgsPluginLayerRegistry();
+  return _instance;
+QgsPluginLayerRegistry::QgsPluginLayerRegistry()
+QgsPluginLayerRegistry::~QgsPluginLayerRegistry()
+  if ( !mPluginLayerTypes.isEmpty() )
+    QgsDebugMsg("QgsPluginLayerRegistry::~QgsPluginLayerRegistry(): creator list not empty");
+    foreach (QString typeName, mPluginLayerTypes.keys())
+      removePluginLayerType(typeName);
+bool QgsPluginLayerRegistry::addPluginLayerType(QgsPluginLayerType* type)
+  if (type == NULL)
+    return false;
+  if (mPluginLayerTypes.contains(type->name()))
+    return false;
+  mPluginLayerTypes[type->name()] = type;
+  return true;
+bool QgsPluginLayerRegistry::removePluginLayerType(QString typeName)
+  if (!mPluginLayerTypes.contains(typeName))
+    return false;
+  // remove all remaining layers of this type - to avoid invalid behaviour
+  QList<QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers().values();
+  foreach (QgsMapLayer* layer, layers)
+    if (layer->type() == QgsMapLayer::PluginLayer)
+      QgsPluginLayer* pl = qobject_cast<QgsPluginLayer*>(layer);
+      if (pl->pluginLayerType() == typeName)
+        QgsMapLayerRegistry::instance()->removeMapLayer(layer->getLayerID());
+  delete mPluginLayerTypes.take(typeName);
+  return true;
+QgsPluginLayerType* QgsPluginLayerRegistry::pluginLayerType(QString typeName)
+  return mPluginLayerTypes.value(typeName, NULL);
+QgsPluginLayer* QgsPluginLayerRegistry::createLayer(QString typeName)
+  QgsPluginLayerType* type = pluginLayerType(typeName);
+  if (!type)
+    QgsDebugMsg("Unknown plugin layer type: "+typeName);
+    return NULL;
+  return type->createLayer();
Added: trunk/qgis/src/core/qgspluginlayerregistry.h
--- trunk/qgis/src/core/qgspluginlayerregistry.h	                        (rev 0)
+++ trunk/qgis/src/core/qgspluginlayerregistry.h	2010-01-26 15:43:54 UTC (rev 12834)
@@ -0,0 +1,89 @@
+/* $Id$ */
+#ifndef QGSPLUGINLAYERREGSITRY_H
+#define QGSPLUGINLAYERREGSITRY_H
+#include <QMap>
+#include <QDomNode>
+class QgsPluginLayer;
+/** \ingroup core
+    class for creating plugin specific layers
+class CORE_EXPORT QgsPluginLayerType
+  public:
+    QString name();
+    virtual QgsPluginLayer* createLayer();
+protected:
+    QString mName;
+/** \ingroup core
+    a registry of plugin layers types
+class CORE_EXPORT QgsPluginLayerRegistry
+  public:
+    bool addPluginLayerType(QgsPluginLayerType* pluginLayerType);
+    QgsPluginLayer* createLayer(QString typeName);
+  private:
+    typedef QMap<QString, QgsPluginLayerType*> PluginLayerTypes;
+    /** pointer to canonical Singleton object */
+    static QgsPluginLayerRegistry* _instance;
+    PluginLayerTypes mPluginLayerTypes;
+#endif // QGSPLUGINLAYERREGSITRY_H
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp	2010-01-25 22:00:08 UTC (rev 12833)
+++ trunk/qgis/src/core/qgsproject.cpp	2010-01-26 15:43:54 UTC (rev 12834)
@@ -30,6 +30,8 @@
 #include "qgsprojectfiletransform.h"
 #include "qgsprojectversion.h"
 #include <QApplication>
 #include <QFileInfo>
@@ -695,6 +697,11 @@
       mapLayer = new QgsRasterLayer;
+    else if ( type == "plugin" )
+      QString typeName = element.attribute( "name" );
+      mapLayer = QgsPluginLayerRegistry::instance()->createLayer( typeName );
     Q_CHECK_PTR( mapLayer );
@@ -873,7 +880,7 @@
   QString type = layerNode.toElement().attribute( "type" );
-  QgsMapLayer *mapLayer;
+  QgsMapLayer *mapLayer = NULL;
   if ( type == "vector" )
@@ -883,6 +890,11 @@
+    QString typeName = layerNode.toElement().attribute( "name" );
   else
     QgsDebugMsg( "bad layer type" );
More information about the QGIS-commit mailing list
