[QGIS Commit] r13974 - in docs/trunk/english_us/user_guide: . print_composer_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 28 07:01:11 EDT 2010
Author: dassau
Date: 2010-07-28 11:01:11 +0000 (Wed, 28 Jul 2010)
New Revision: 13974
Added:
   docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_attribute1.png
   docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_attribute2.png
   docs/trunk/english_us/user_guide/features_at_a_glance.tex
   docs/trunk/english_us/user_guide/grass_integration.tex
   docs/trunk/english_us/user_guide/print_composer.tex
   docs/trunk/english_us/user_guide/working_with_vector.tex
started some manual updates
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex	2010-07-27 20:20:13 UTC (rev 13973)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex	2010-07-28 11:01:11 UTC (rev 13974)
@@ -1024,8 +1024,8 @@
 \item Define default snapping tolerance in map units or pixel
 \item Define search radius for vertex edits in map units or pixel
 \item \checkbox{Show markers only for selected features}
-\item Define vertex marker style (Cross, semi transparent circle or none) and
-size
+\item Define vertex marker style (cross (default), semi transparent circle or
+none) and size
 \item \checkbox{Suppress attributes pop-up windows after each created feature}
 \end{itemize}
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex	2010-07-27 20:20:13 UTC (rev 13973)
+++ docs/trunk/english_us/user_guide/grass_integration.tex	2010-07-28 11:01:11 UTC (rev 13974)
@@ -562,6 +562,13 @@
 to use further module parameters and flags, you need to start the GRASS Shell
 and run the module in the command line.
+A new feature in QGIS \CURRENT is the support for a
+\button{show advanced options >>} button below the simplified module dialog
+in the \tab{Options} tab. At the moment it is only added to the module v.in.ascii
+as an example use, but will probably be part of more / all modules in the
+GRASS toolbox in future versions of QGIS. This allows to use the complete GRASS
+module options without the need to switch to the GRASS Shell.
 \minisec{Output}
 The \tab{Output} tab provides information about the output status of the
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex	2010-07-27 20:20:13 UTC (rev 13973)
+++ docs/trunk/english_us/user_guide/print_composer.tex	2010-07-28 11:01:11 UTC (rev 13974)
@@ -30,28 +30,24 @@
  & Export to an image format &
  \includegraphics[width=0.7cm]{mActionSaveAsPDF} & Export as PDF \\
  \hline \includegraphics[width=0.7cm]{mActionSaveAsSVG} & Export print
- composition to SVG & & \\
- \hline \includegraphics[width=0.7cm]{mActionFilePrint} & Print or
- export as Postscript &
- \includegraphics[width=0.7cm]{mActionZoomFullExtent} & Zoom to
- full extend \\
- \hline \includegraphics[width=0.7cm]{mActionZoomIn} & Zoom in &
- \includegraphics[width=0.7cm]{mActionZoomOut} & Zoom out \\
- \hline \includegraphics[width=0.7cm]{mActionDraw} & Refresh
- view &
- \includegraphics[width=0.7cm]{mActionAddMap} & Add
- new map from QGIS map canvas \\
- \hline \includegraphics[width=0.7cm]{mActionSaveMapAsImage} & Add Image to
- print composition &
- \includegraphics[width=0.7cm]{mActionLabel} & Add label to print composition \\
- \hline \includegraphics[width=0.7cm]{mActionAddLegend} & Add new legend to
- \includegraphics[width=0.7cm]{mActionScaleBar} & Add new scalebar to print
- composition\\
- \hline \includegraphics[width=0.7cm]{mActionAddBasicShape} & Add basic shape to
- \includegraphics[width=0.7cm]{mActionAddArrow} & Add arrow to print
- composition\\
+ composition to SVG & \includegraphics[width=0.7cm]{mActionFilePrint}
+ & Print or export as Postscript \\
+ \hline \includegraphics[width=0.7cm]{mActionZoomFullExtent} & Zoom to
+ full extend & \includegraphics[width=0.7cm]{mActionZoomIn} & Zoom in \\
+ \hline \includegraphics[width=0.7cm]{mActionZoomOut} & Zoom out &
+ \includegraphics[width=0.7cm]{mActionDraw} & Refresh view \\
+ \hline \includegraphics[width=0.7cm]{mActionAddMap} & Add new map from
+ QGIS map canvas & \includegraphics[width=0.7cm]{mActionSaveMapAsImage}
+ & Add Image to print composition \\
+ \hline \includegraphics[width=0.7cm]{mActionLabel} & Add label to print
+ composition & \includegraphics[width=0.7cm]{mActionAddLegend} & Add new
+ legend to print composition \\
+ \hline \includegraphics[width=0.7cm]{mActionScaleBar} & Add new scalebar
+ to print composition & \includegraphics[width=0.7cm]{mActionAddBasicShape}
+ & Add basic shape to print composition \\
+ \hline \includegraphics[width=0.7cm]{mActionAddArrow} & Add arrow to print
+ composition & \includegraphics[width=0.7cm]{mActionOpenTable} & Add attribute
+ table to print composition \\
  \hline \includegraphics[width=0.7cm]{mActionSelectPan} & Select/Move item in
  print composition &
  \includegraphics[width=0.7cm]{mActionMoveItemContent} & Move content within
@@ -477,6 +473,42 @@
 computer.
 \end{itemize}
+\section{Add attribute table values}
+It is possible to add parts of an attribute table of a vector layer to the
+print composer canvas.
+\begin{figure}[ht]
+\centering
+\subfloat[table dialog]{\label{subfig:tabledialog1}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_attribute1}}
+\hspace{1cm}
+\subfloat[general options dialog]{\label{subfig:tabledialog2}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_attribute2}}
+\caption{Print composer attribute table item tab - Table and General options dialog \nixcaption}\label{fig:attrcomp}
+\end{figure}
+\minisec{Table dialog}
+The \textbf{Table} dialog of the attribute table item tab provides following
+functionalities (see Figure \ref{fig:attrcomp}a)):
+\begin{itemize}[label=--]
+\item The \textbf{Table} dialog allows to draw an ellipse, rectangle, or
+\end{itemize}
+\minisec{General options dialog}
+The \textbf{General options} dialog of the attribute table item tab
+provides following functionalities (see Figure \ref{fig:attrcomp}b)):
+\item Here you can define color and outline width for the element frame, set
+a background color and opacity for the map canvas. The \button{Position}
+button opens the \dialog{Set items position} dialog and allows to set the map
+canvas position using reference points or coordinates. Furthermore you can
+select or unselect to display the element frame with the \checkbox{Show
+frame} checkbox.
+\end{itemize}
 \section{Raise, lower and align elements}
 Raise or lower functionalities for elements are inside the
Added: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_attribute1.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_attribute1.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_attribute2.png
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_attribute2.png
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-07-27 20:20:13 UTC (rev 13973)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-07-28 11:01:11 UTC (rev 13974)
@@ -1419,7 +1419,8 @@
 tool also works with 'on the fly' projection turned on and supports
 the topological editing feature. This tool is, unlike other tools in Quantum GIS,
 persistent, so when some operation is done, selection stays active for this
-feature and tool.
+feature and tool. If the node tool couldn't find any features, a warning will be
+displayed.
 Important is to set the property \mainmenuopt{Settings} >
 \dropmenuopttwo{mActionOptions}{Options} >
More information about the QGIS-commit mailing list
